[U-Boot] [PATCH 1/3] spi: fsl_qspi: fix an error of using GENMASK
This commit fixes the change of bad490a24212c068c5b718b9189f47ea4075d078.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- drivers/spi/fsl_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index ed39114..d8d37cd 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -24,7 +24,7 @@ DECLARE_GLOBAL_DATA_PTR; #define TX_BUFFER_SIZE 0x40 #endif
-#define OFFSET_BITS_MASK GENMASK(24, 0) +#define OFFSET_BITS_MASK GENMASK(23, 0)
#define FLASH_STATUS_WEL 0x02
This patch fixes the following compile warning: drivers/spi/fsl_qspi.c: In function 'fsl_qspi_probe': drivers/spi/fsl_qspi.c:937:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct fsl_qspi_regs *)plat->reg_base; ^ Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index d8d37cd..755cc27 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -931,7 +931,7 @@ static int fsl_qspi_probe(struct udevice *bus)
dm_spi_bus->max_hz = plat->speed_hz;
- priv->regs = (struct fsl_qspi_regs *)plat->reg_base; + priv->regs = (struct fsl_qspi_regs *)(unsigned long)plat->reg_base; priv->flags = plat->flags;
priv->speed_hz = plat->speed_hz;
In current driver everytime we memcpy 4 bytes to the dest memory regardless of the remaining length. This patch add checking the remaining length before memcpy. If the length is shorter than 4 bytes, memcpy the actual length of data to the dest memory.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- drivers/spi/fsl_qspi.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 755cc27..b41b226 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -499,7 +499,10 @@ static void qspi_op_rdid(struct fsl_qspi_priv *priv, u32 *rxbuf, u32 len) if (rbsr_reg & QSPI_RBSR_RDBFL_MASK) { data = qspi_read32(priv->flags, ®s->rbdr[i]); data = qspi_endian_xchg(data); - memcpy(rxbuf, &data, 4); + if (size < 4) + memcpy(rxbuf, &data, size); + else + memcpy(rxbuf, &data, 4); rxbuf++; size -= 4; i++;
Oh, so sorry for the mess... The network seems to get problems..:(
Regards, Qianyu
-----Original Message----- From: Gong Qianyu [mailto:Qianyu.Gong@freescale.com] Sent: Monday, December 14, 2015 6:37 PM To: u-boot@lists.denx.de Cc: Hu Mingkai-B21284; Sun York-R58495; Yuan Yao-B46683; jteki@openedev.com; Gong Qianyu-B52263 Subject: [PATCH 3/3] spi: fsl_quadspi: Fix qspi_op_rdid memcpy issue
if (size < 4)
else
-- 2.1.0.27.g96db324
Applied to u-boot-spi/master
Gong Q.Y.
Gong Qianyu
Jagan Teki
