[U-Boot] [PATCH 1/9 v2] MPC85xx: Add QE clk support for mpc85xx platforms
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com Acked-by: Timur Tabi Timur@freescale.com --- v2 change: Fix the indention issue pointed by Scott, and add Acked-by.
cpu/mpc85xx/cpu.c | 4 ++++ cpu/mpc85xx/speed.c | 13 +++++++++++++ include/asm-ppc/immap_85xx.h | 2 ++ include/e500.h | 1 + 4 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index ef976a4..b812d88 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -184,6 +184,10 @@ int checkcpu (void) printf("CPM: %s MHz\n", strmhz(buf1, sysinfo.freqSystemBus)); #endif
+#ifdef CONFIG_QE + printf(" QE:%-4s MHz\n", strmhz(buf1, sysinfo.freqQE)); +#endif + puts("L1: D-cache 32 kB enabled\n I-cache 32 kB enabled\n");
return 0; diff --git a/cpu/mpc85xx/speed.c b/cpu/mpc85xx/speed.c index b0f47e0..16dbe76 100644 --- a/cpu/mpc85xx/speed.c +++ b/cpu/mpc85xx/speed.c @@ -40,6 +40,9 @@ void get_sys_info (sys_info_t * sysInfo) uint plat_ratio,e500_ratio,half_freqSystemBus; uint lcrr_div; int i; +#ifdef CONFIG_QE + u32 qe_ratio; +#endif
plat_ratio = (gur->porpllsr) & 0x0000003e; plat_ratio >>= 1; @@ -65,6 +68,12 @@ void get_sys_info (sys_info_t * sysInfo) } #endif
+#ifdef CONFIG_QE + qe_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_QE_RATIO) + >> MPC85xx_PORPLLSR_QE_RATIO_SHIFT; + sysInfo->freqQE = qe_ratio * CONFIG_SYS_CLK_FREQ; +#endif + #if defined(CONFIG_SYS_LBC_LCRR) /* We will program LCRR to this value later */ lcrr_div = CONFIG_SYS_LBC_LCRR & LCRR_CLKDIV; @@ -112,6 +121,10 @@ int get_clocks (void) gd->mem_clk = sys_info.freqDDRBus; gd->lbc_clk = sys_info.freqLocalBus;
+#ifdef CONFIG_QE + gd->qe_clk = sys_info.freqQE; + gd->brg_clk = gd->qe_clk / 2; +#endif /* * The base clock for I2C depends on the actual SOC. Unfortunately, * there is no pattern that can be used to determine the frequency, so diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 0810b8e..a4d25cd 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1581,6 +1581,8 @@ typedef struct ccsr_gur { #define MPC85xx_PORPLLSR_DDR_RATIO 0x00003e00 #define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT 9 #endif +#define MPC85xx_PORPLLSR_QE_RATIO 0x3e000000 +#define MPC85xx_PORPLLSR_QE_RATIO_SHIFT 25 uint porbmsr; /* 0xe0004 - POR boot mode status register */ #define MPC85xx_PORBMSR_HA 0x00070000 uint porimpscr; /* 0xe0008 - POR I/O impedance status and control register */ diff --git a/include/e500.h b/include/e500.h index 4c5eeb7..84b580d 100644 --- a/include/e500.h +++ b/include/e500.h @@ -18,6 +18,7 @@ typedef struct unsigned long freqSystemBus; unsigned long freqDDRBus; unsigned long freqLocalBus; + unsigned long freqQE; } MPC85xx_SYS_INFO;
#endif /* _ASMLANGUAGE */
Haiying Wang
