[U-Boot-Users] [PATCH: u-boot-fdt 3/3] For fdt_find_node_by_path(), handle the root path properly.
Also removes the special case root path detection in cmd_fdt.c since it is no longer necessary.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- common/cmd_fdt.c | 35 ++++++++++++----------------------- libfdt/fdt_ro.c | 4 ++++ 2 files changed, 16 insertions(+), 23 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 5a2c3fd..aa65297 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -52,25 +52,6 @@ static int fdt_parse_prop(char *pathp, char *prop, char *newval, char *data, int *len); static int fdt_print(char *pathp, char *prop, int depth);
-static int findnodeoffset(const char *pathp) -{ - int nodeoffset; - - if (strcmp(pathp, "/") == 0) { - nodeoffset = 0; - } else { - nodeoffset = fdt_find_node_by_path (fdt, pathp); - if (nodeoffset < 0) { - /* - * Not found or something else bad happened. - */ - printf ("findnodeoffset() libfdt: %s\n", - fdt_strerror(nodeoffset)); - } - } - return nodeoffset; -} - /* * Flattened Device Tree command, see the help for parameter definitions. */ @@ -187,11 +168,13 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) pathp = argv[2]; nodep = argv[3];
- nodeoffset = findnodeoffset(pathp); + nodeoffset = fdt_find_node_by_path (fdt, pathp); if (nodeoffset < 0) { /* * Not found or something else bad happened. */ + printf ("libfdt fdt_find_node_by_path() returned %s\n", + fdt_strerror(nodeoffset)); return 1; } err = fdt_add_subnode(fdt, nodeoffset, nodep); @@ -225,11 +208,13 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) prop = argv[3]; newval = argv[4];
- nodeoffset = findnodeoffset(pathp); + nodeoffset = fdt_find_node_by_path (fdt, pathp); if (nodeoffset < 0) { /* * Not found or something else bad happened. */ + printf ("libfdt fdt_find_node_by_path() returned %s\n", + fdt_strerror(nodeoffset)); return 1; } ret = fdt_parse_prop(pathp, prop, newval, data, &len); @@ -283,11 +268,13 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) * Get the path. The root node is an oddball, the offset * is zero and has no name. */ - nodeoffset = findnodeoffset(argv[2]); + nodeoffset = fdt_find_node_by_path (fdt, argv[2]); if (nodeoffset < 0) { /* * Not found or something else bad happened. */ + printf ("libfdt fdt_find_node_by_path() returned %s\n", + fdt_strerror(nodeoffset)); return 1; } /* @@ -584,11 +571,13 @@ static int fdt_print(char *pathp, char *prop, int depth) int len; /* length of the property */ int level = 0; /* keep track of nesting level */
- nodeoffset = findnodeoffset(pathp); + nodeoffset = fdt_find_node_by_path (fdt, pathp); if (nodeoffset < 0) { /* * Not found or something else bad happened. */ + printf ("libfdt fdt_find_node_by_path() returned %s\n", + fdt_strerror(nodeoffset)); return 1; } /* diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index 923c389..ffd9209 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -283,6 +283,10 @@ int fdt_find_node_by_path(const void *fdt, const char *path) if (*path != '/') return -FDT_ERR_BADPATH;
+ /* Handle the root path: root offset is 0 */ + if (strcmp(path, "/") == 0) + return 0; + while (*p) { const char *q;
Jerry Van Baren
