Hi Wolfgang, Gabe,
I have two x86 tidy-up patch series that I intend to apply in the next 2-3 weeks to a 'next' branch on the x86 repo. Being 'next', these patches are intended for the current merge window which closes on December 12
Please be aware that the latest series (checkpatch cleanup) is designed to be applied first, but it was actually created _after_ the 'Various x86 cleanups' series and hence, there is a wee little bit of incompatibility between the two (and silly me should have called the latest one v0 as well...). The conflicts aren't so bad - I already have them resolved but the second series is not checkpatch clean yet. Before I apply this series to 'next' I will be posting a unified patch set in the next week or so - It will be a 12 part series which will line up 1-to-1 so I'll be setting the in-reply-to to thread from the current patches. In the meantime, please:
1) Have a look at the two independent series and let me know if there is any glaring issues I need to address 2) Let me know if you need more than two weeks 3) Be prepared to rebase any current x86 patches against 'next' in three weeks time (unless otherwise informed)
Gabe, going by this schedule, there will be a good two weeks between the x86 cleanup hitting 'next' and the merge window closing - I think this should be plenty of time to get the rebased coreboot patches onto the mailing list before the merge window closes, and ideally into x86/next for a speedy pull into mainline before the end of the year :)
Regards,
Graeme
Dear Graeme Russ,
You confuse me.
Currently the merge window is closed. The next release is scheduled for December 12. ONly then, the _next_ merge window will open.
This being mostly cleanup, and we still being relatively early in the stabilization phase, I would also accept this stuff now.
- Have a look at the two independent series and let me know if there is
I will, time permitting.
- Let me know if you need more than two weeks
- Be prepared to rebase any current x86 patches against 'next' in three
Which merge window are you talking about?
Hi Wolfgang,
On 07/11/11 06:09, Wolfgang Denk wrote:
Dear Graeme Russ,
You confuse me.
Oops, what you're saying is what I meant - next merge window
OK - There is only one patch that adds new 'features' - The 'Add multiboot header' but that's just some canned static data, no code
Thanks
Sorry for the confusion - I intend to get Gabe's patches into x86/next as soon as the next merge window opens on December 12
Regards,
Graeme
Dear Graeme Russ,
So let's add the stuff now.
Hi Wolfgang,
On Mon, Nov 7, 2011 at 6:50 AM, Wolfgang Denk wd@denx.de wrote:
Dear Graeme Russ,
OK, I'll expedite posting a merged patchset
Regards,
Graeme
Graeme Russ
