Re: [U-Boot-Users] [DNX#2006081142000081] [PATCH 07/07]: mpc7448hpc2 board flash support
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006081142000081] was created:
<snip>
This patch comes from Yuli's posted patch on 8/8/2006 about "CFI Driver Little-Endian write Issue". If that patch applied, please discard this one.
Signed-off-by: Yuli Barcohen yuli@arabellasw.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
drivers/cfi_flash.c | 32 ++++++++++++++++++++++++++------ 1 files changed, 26 insertions(+), 6 deletions(-)
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index fd0a186..33a5822 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -2,9 +2,12 @@
- (C) Copyright 2002-2004
- Brad Kemp, Seranoa Networks, Brad.Kemp@seranoa.com
- Copyright (C) 2003 Arabella Software Ltd.
- Copyright (C) 2003, 2006 Arabella Software Ltd.
- Yuli Barcohen yuli@arabellasw.com
- Modified to work with AMD flashes
- Added support for byte lanes swap
- Added support for 32-bit chips consisting of two 16-bit devices
- (for example, S70GL256M00)
- Copyright (C) 2004
- Ed Okerson
@@ -45,10 +48,13 @@ /* #define DEBUG */
#include <common.h>
+#ifdef CFG_FLASH_CFI_DRIVER
+#include <watchdog.h> #include <asm/processor.h> #include <asm/byteorder.h> #include <environment.h> -#ifdef CFG_FLASH_CFI_DRIVER
- This file implements a Common Flash Interface (CFI) driver for
U-Boot. @@ -71,6 +77,10 @@ #ifdef CFG_FLASH_CFI_DRIVER
- Verify erase and program timeouts.
+#if defined(__LITTLE_ENDIAN) && !defined(CFG_FLASH_CFI_SWAP) +#define CFG_FLASH_CFI_SWAP +#endif
#ifndef CFG_FLASH_BANKS_LIST #define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } #endif @@ -268,7 +278,7 @@ inline uchar flash_read_uchar (flash_inf uchar *cp;
cp = flash_make_addr (info, 0, offset); -#if defined(__LITTLE_ENDIAN) +#if defined(CFG_FLASH_CFI_SWAP) return (cp[0]); #else return (cp[info->portwidth - 1]); @@ -295,7 +305,7 @@ #ifdef DEBUG debug ("addr[%x] = 0x%x\n", x, addr[x]); } #endif -#if defined(__LITTLE_ENDIAN) +#if defined(CFG_FLASH_CFI_SWAP) retval = ((addr[(info->portwidth)] << 8) | addr[0]); #else retval = ((addr[(2 * info->portwidth) - 1] << 8) | @@ -327,7 +337,7 @@ #ifdef DEBUG debug ("addr[%x] = 0x%x\n", x, addr[x]); } #endif -#if defined(__LITTLE_ENDIAN) +#if defined(CFG_FLASH_CFI_SWAP) retval = (addr[0] << 16) | (addr[(info->portwidth)] << 24) | (addr[(2 * info->portwidth)]) | (addr[(3 * info->portwidth)] << 8); #else @@ -892,12 +902,22 @@ static void flash_make_cmd (flash_info_t int i; uchar *cp = (uchar *) cmdbuf;
-#if defined(__LITTLE_ENDIAN) +#if defined(CFG_FLASH_CFI_SWAP) for (i = info->portwidth; i > 0; i--) #else for (i = 1; i <= info->portwidth; i++) #endif *cp++ = (i & (info->chipwidth - 1)) ? '\0' : cmd; +#ifdef CFG_FLASH_CFI_2x16
- if ((info->portwidth == FLASH_CFI_32BIT) && (info->chipwidth ==
FLASH_CFI_BY16))
</snip>
Your U-Boot support team
DENX Support System
