[U-Boot] Help with driver for a ethernet switch
Hello all,
Could anyone help me with this? Which change should I do on http://git.denx.de/u-boot/drivers/net/ks8695eth.c to make it work with the ks8995m ? Have anyone done this before?
thanks,
Raphael
Hi Raphael,
Raphael Amorim wrote:
Hello all,
thanks,
Raphael
First, read the data sheets for both chips to find out how similar/different they are. If similar, modify or copy the ks8695 driver. If they're significantly different, you might find a better match for a template.
No matter what, you need to understand your hardware.
Please note that the KS8695 driver will be changing soon because the API that it uses is deprecated. There are plenty of examples of drivers that use the preferred methods.
regards, Ben
Ben Warren
Raphael Amorim
