[U-Boot] [PATCH v2 1/3] arm: exynos: arndale: Remove unused CONFIG_POWER and CONFIG_POWER_I2C
The CONFIG_POWER and CONFIG_POWER_I2C were introduced in include/configs/exynos5-common.h in commit 19bd3aaa5991 ("exynos5: fix build break by adding CONFIG_POWER") and then it propagated up to include/configs/arndale.h. However before that commit, there was no build break at all on Arndale and SMDK5250 boards. It seems the commit fixed nothing and just added unused defines.
In fact, the Arndale board is not configuring its PMIC (S5M8767) which uses I2C bus.
Signed-off-by: Krzysztof Kozlowski krzk@kernel.org Reviewed-by: Simon Glass sjg@chromium.org
Not tested on Arndale board. Testing is welcomed.
Changes since v1: 1. Add Simon's tag. 2. Reorder patches - first remove CONFIG_POWER_I2C, then CONFIG_DM_I2C_COMPAT. --- include/configs/arndale.h | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/include/configs/arndale.h b/include/configs/arndale.h index dd321c4748d0..841f3616482b 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -29,10 +29,6 @@
#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK
-/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C - #define CONFIG_PREBOOT
#define CONFIG_S5P_PA_SYSRAM 0x02020000 @@ -41,8 +37,4 @@ /* The PERIPHBASE in the CBAR register is wrong on the Arndale, so override it */ #define CONFIG_ARM_GIC_BASE_ADDRESS 0x10480000
-/* Power */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C - #endif /* __CONFIG_H */
The CONFIG_DM_I2C_COMPAT was introduced in include/configs/exynos5-common.h in commit 189d80166b31 ("exynos5: enable dm i2c") and then it propagated up to configs/arndale_defconfig. However since beginning the Arndale board (Exynos5250) was not using I2C.
In fact, the Arndale board is not configuring its PMIC (S5M8767) which uses I2C bus. This setting can be thus safely removed to fix build warning:
This board uses CONFIG_DM_I2C_COMPAT. Please remove (possibly in a subsequent patch in your series) before sending patches to the mailing list.
Changes since v1: 1. Add Simon's tag. 2. Reorder patches - first remove CONFIG_POWER_I2C, then CONFIG_DM_I2C_COMPAT. --- configs/arndale_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 9727d28c1241..e90d670f6813 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_SOUND=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_ENV_IS_IN_MMC=y -CONFIG_DM_I2C_COMPAT=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y
Changes since v1:
- Add Simon's tag.
- Reorder patches - first remove CONFIG_POWER_I2C, then CONFIG_DM_I2C_COMPAT.
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Arndale board has an Asix AX88760 USB 2.0 Hub and Fast Ethernet combo. The appropriate driver for it is USB_ETHER_ASIX.
The mistake probably came from misinterpretation of commit e9954b867ce0 ("usb: eth: add ASIX AX88179 DRIVER") which was tested on RECS5250 COM module. This module indeed has Exynos5250 and some similarities with Arndale 5250 board but the USB/Ethernet chip used there is apparently different.
Fixes: f58ad98a621c ("usb: net: migrate USB Ethernet adapters to Kconfig") Signed-off-by: Krzysztof Kozlowski krzk@kernel.org Reviewed-by: Lukasz Majewski lukma@denx.de
Not tested.
Changes since v1: 1. Add Lukasz's tag. --- configs/arndale_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index e90d670f6813..37ad6accc396 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -42,4 +42,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_ASIX=y
Not tested.
Changes since v1:
- Add Lukasz's tag.
Changes since v1:
- Add Simon's tag.
Krzysztof Kozlowski
Minkyu Kang
