[PATCH 1/1] docs: Fix the docs build with Sphinx 6.0
Sphinx 6.0 removed the execfile_() function, which we use as part of the configuration process. They *did* warn us... Just open-code the functionality as is done in Sphinx itself.
Tested (using SPHINX_CONF, since this code is only executed with an alternative config file) on various Sphinx versions from 2.5 through 6.0.
Reported-by: Martin Liška mliska@suse.cz Cc: stable@vger.kernel.org Signed-off-by: Jonathan Corbet corbet@lwn.net
Rebased for U-Boot Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/sphinx/load_config.py | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/doc/sphinx/load_config.py b/doc/sphinx/load_config.py index eeb394b39e..8b416bfd75 100644 --- a/doc/sphinx/load_config.py +++ b/doc/sphinx/load_config.py @@ -3,7 +3,7 @@
import os import sys -from sphinx.util.pycompat import execfile_ +from sphinx.util.osutil import fs_encoding
# ------------------------------------------------------------------------------ def loadConfig(namespace): @@ -48,7 +48,9 @@ def loadConfig(namespace): sys.stdout.write("load additional sphinx-config: %s\n" % config_file) config = namespace.copy() config['__file__'] = config_file - execfile_(config_file, config) + with open(config_file, 'rb') as f: + code = compile(f.read(), fs_encoding, 'exec') + exec(code, config) del config['__file__'] namespace.update(config) else:
