[U-Boot-Users] [PATCH] Update SystemACE driver for 16bit access
This patch removes some problems when the Xilinx SystemACE driver is used with 16bit access on an big endian platform (like the AMCC Katmai).
Signed-off-by: Stefan Roese sr@denx.de
--- commit d93e2212f962668b3dce091ff5edc33f2347fe37 tree 19b9b366ae1bdb33437370fa5dd009068c2039ec parent 874bb7b88fe9b4648e1288a387af2e31014a72f3 author Stefan Roese sr@denx.de Tue, 20 Feb 2007 13:17:42 +0100 committer Stefan Roese sr@denx.de Tue, 20 Feb 2007 13:17:42 +0100
drivers/systemace.c | 14 +++++++++++--- 1 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/drivers/systemace.c b/drivers/systemace.c index 9502623..3bd2ea9 100644 --- a/drivers/systemace.c +++ b/drivers/systemace.c @@ -66,8 +66,8 @@ writeb(val>>8, CFG_SYSTEMACE_BASE+off+1);} #endif #else -#define ace_readw(off) (readw(CFG_SYSTEMACE_BASE+off)) -#define ace_writew(val, off) (writew(val, CFG_SYSTEMACE_BASE+off)) +#define ace_readw(off) (in16(CFG_SYSTEMACE_BASE+off)) +#define ace_writew(val, off) (out16(CFG_SYSTEMACE_BASE+off,val)) #endif
/* */ @@ -119,6 +119,14 @@ block_dev_desc_t *systemace_get_dev(int dev) systemace_dev.removable = 1; systemace_dev.block_read = systemace_read;
+#if (CFG_SYSTEMACE_WIDTH == 16) + /* + * By default the SystemACE comes up in 8-bit mode. + * Ensure that 16-bit mode gets enabled. + */ + ace_writew(0x0001, 0); +#endif + init_part(&systemace_dev);
} @@ -197,7 +205,7 @@ static unsigned long systemace_read(int dev, unsigned long start, #endif /* Write LBA block address */ ace_writew((start >> 0) & 0xffff, 0x10); - ace_writew((start >> 16) & 0x00ff, 0x12); + ace_writew((start >> 16) & 0x0fff, 0x12);
/* NOTE: in the Write Sector count below, a count of 0 causes a transfer of 256, so &0xff gives the right
I've got a similar patch in my tree; How about something like this instead:
ace_writew(CFG_SYSTEMACE_WIDTH == 8 ? 0 : 0x0001, 0);
That way it handles both conditions; 8 when it should be 16, and 16 when it should be 8
init_part(&systemace_dev); }
Good catch!
Cheers, g.
Even better. Will update my version.
Best regards, Stefan
===================================================================== DENX Software Engineering GmbH, HRB 165235 Munich, CEO: Wolfgang Denk Office: Kirchenstr. 5, D-82194 Groebenzell, Germany =====================================================================
Grant Likely
Stefan Roese
