[U-Boot] [RFC 1/1] m68k: mfc5227x: do not rely on uninitialized stack values
The behavior get_clocks depends on the unitialized value of bootmode.
By setting it to zero we get a defined behavior and can get rid of superfluos coding.
The problem was indicated by cppcheck.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- I have no hardware to test this. Please, check thorougly before merging. --- --- arch/m68k/cpu/mcf5227x/speed.c | 10 ++-------- 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/arch/m68k/cpu/mcf5227x/speed.c b/arch/m68k/cpu/mcf5227x/speed.c index 44de4a6701..978cc7adc6 100644 --- a/arch/m68k/cpu/mcf5227x/speed.c +++ b/arch/m68k/cpu/mcf5227x/speed.c @@ -73,14 +73,8 @@ int get_clocks(void)
ccm_t *ccm = (ccm_t *)MMAP_CCM; pll_t *pll = (pll_t *)MMAP_PLL; - int vco, temp, pcrvalue, pfdr; - u8 bootmode; - - pcrvalue = in_be32(&pll->pcr) & 0xFF0F0FFF; - pfdr = pcrvalue >> 24; - - if (pfdr == 0x1E) - bootmode = 0; /* Normal Mode */ + int vco, temp, pcrvalue; + u8 bootmode = 0; /* Normal Mode */;
#ifdef CONFIG_CF_SBF bootmode = 3; /* Serial Mode */
Hi Heinrich,
thanks for the patch
- u8 bootmode;
- if (pfdr == 0x1E)
sure uninitialized vars are an issue.This change works and make things simpler.
But looking the code i have a doubt now: this code seems attempting to detect "runtime" the boot mode, getting clocks from pll registers already set i.e. form SBF header. So there can be a case where jumpers (or pull up/down resistors) are set to SBF (11) and "bootmode" variable will be set to 3 only if CONFIG_CF_SBF is set, otherwise it will be 0 and not 3.
Of course, if we try to boot by SBF and CONFIG_CF_SBF is not set, u-boot will not boot in anyway, since spi init will be totally missing.
But in case a different "fully runtime" proposal could be:
diff --git a/arch/m68k/cpu/mcf5227x/speed.c b/arch/m68k/cpu/mcf5227x/speed.c index 44de4a6701..e21c1d574b 100644 --- a/arch/m68k/cpu/mcf5227x/speed.c +++ b/arch/m68k/cpu/mcf5227x/speed.c @@ -74,7 +74,7 @@ int get_clocks(void) ccm_t *ccm = (ccm_t *)MMAP_CCM; pll_t *pll = (pll_t *)MMAP_PLL; int vco, temp, pcrvalue, pfdr; - u8 bootmode; + u8 bootmode = 3;
pcrvalue = in_be32(&pll->pcr) & 0xFF0F0FFF; pfdr = pcrvalue >> 24; @@ -82,10 +82,6 @@ int get_clocks(void) if (pfdr == 0x1E) bootmode = 0; /* Normal Mode */
-#ifdef CONFIG_CF_SBF - bootmode = 3; /* Serial Mode */ -#endif - if (bootmode == 0) { /* Normal mode */ vco = ((in_be32(&pll->pcr) & 0xFF000000) >> 24) * CONFIG_SYS_INPUT_CLKSRC;
What do you think ?
Regards, Angelo Dureghello
Angelo Dureghello
