[U-Boot-Users] [PATCH 4/8] Add PPC4xx-HCU4 and HCU5 boards: HCU5 config
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- include/configs/hcu5.h | 392 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 392 insertions(+), 0 deletions(-) create mode 100644 include/configs/hcu5.h
diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h new file mode 100644 index 0000000..87f6948 --- /dev/null +++ b/include/configs/hcu5.h @@ -0,0 +1,392 @@ +/* + * (C) Copyright 2007 Netstal Maschinen AG + * Niklaus Giger (Niklaus.Giger@netstal.com) + * + * (C) Copyright 2006-2007 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2006 + * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * hcu5.h - configuration for HCU5 board (derived from sequoia.h) + ***********************************************************************/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +#define CONFIG_HCU5 1 /* Board is HCU5 */ +#define CONFIG_440EPX 1 /* Specific PPC440EPx */ +#define CONFIG_440 1 /* ... PPC440 family */ +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_SYS_CLK_FREQ 33333333 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_ADD_RAM_INFO 1 /* Print additional info */ + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */ + +#define CFG_BOOT_BASE_ADDR 0xfff00000 +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ +#define CFG_FLASH_BASE 0xfff80000 /* start of FLASH */ +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ +#define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ +#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 +#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 +#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000 + +/* Don't change either of these */ +#define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ + +#define CFG_USB2D0_BASE 0xe0000100 +#define CFG_USB_DEVICE 0xe0000000 +#define CFG_USB_HOST 0xe0000400 + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer + *----------------------------------------------------------------------*/ +/* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ +#define CFG_INIT_RAM_OCM 1 /* OCM as init ram */ +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ + +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +#undef CFG_EXT_SERIAL_CLOCK /* external serial clock */ +#define CONFIG_BAUDRATE 9600 +#undef CONFIG_SERIAL_MULTI /* needed to be able to define + CONFIG_SERIAL_SOFTWARE_FIFO, but + CONFIG_SERIAL_SOFTWARE_FIFO (16) does not work */ +/* Size (bytes) of interrupt driven serial port buffer. + * Set to 0 to use polling instead of interrupts. + * Setting to 0 will also disable RTS/CTS handshaking. + */ +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#undef CONFIG_UART1_CONSOLE + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ + +#undef CFG_ENV_IS_IN_NVRAM +#undef CFG_ENV_IS_IN_FLASH +#define CFG_ENV_IS_IN_EEPROM +#undef CFG_ENV_IS_NOWHERE + +#ifdef CFG_ENV_IS_IN_EEPROM +/* Put the environment after the SDRAM and bootstrap configuration */ +#define PROM_SIZE 2048 +#define CFG_BOOSTRAP_OPTION_OFFSET 512 +#define CFG_ENV_OFFSET (CFG_BOOSTRAP_OPTION_OFFSET + 0x10) +#define CFG_ENV_SIZE (PROM_SIZE-CFG_ENV_OFFSET) +#endif + +#ifdef CFG_ENV_IS_IN_FLASH +/* Put the environment in Flash */ +#define CFG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ +#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +#endif + +/*----------------------------------------------------------------------- + * DDR SDRAM + *----------------------------------------------------------------------*/ +#define CFG_MBYTES_SDRAM (128) /* 128 MB or 256 MB */ +#define CFG_DDR_CACHED_ADDR 0x40000000 /* setup 2nd TLB cached here */ +#undef CONFIG_DDR_DATA_EYE /* Do not use DDR2 optimization */ +#define CONFIG_DDR_ECC 1 /* enable ECC */ + +/*----------------------------------------------------------------------- + * I2C stuff for a ATMEL AT24C16 (2kB holding ENV, we are using the + * the second internal I2C controller of the PPC440EPx + *----------------------------------------------------------------------*/ +#define CFG_SPD_BUS_NUM 1 + +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F + +/* This is the 7bit address of the device, not including P. */ +#define CFG_I2C_EEPROM_ADDR 0x50 +#define CFG_I2C_EEPROM_ADDR_LEN 1 + +/* The EEPROM can do 16byte ( 1 << 4 ) page writes. */ +#define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 +#define CFG_EEPROM_PAGE_WRITE_BITS 4 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#undef CFG_I2C_MULTI_EEPROMS + + +#define CONFIG_PREBOOT "echo;" \ + "echo Type "run nfs" to mount Linux root filesystem over NFS;"\ + "echo" + +#undef CONFIG_BOOTARGS + +/* Setup some board specific values for the default environment variables */ +#define CONFIG_HOSTNAME hcu5 +#define CONFIG_IPADDR 172.25.1.42 +#define CONFIG_ETHADDR 00:60:13:00:00:00 /* Netstal Machines AG MAC */ +#define CONFIG_OVERWRITE_ETHADDR_ONCE +#define CONFIG_SERVERIP 172.25.1.3 + +#define CFG_TFTP_LOADADDR 0x01000000 /* @16 MB */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "loadaddr=0x01000000\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "nfs=tftp 200000 ${bootfile};run nfsargs addip addtty;" \ + "bootm\0" \ + "bootfile=hcu5/uImage\0" \ + "rootpath=/home/hcu/eldk/ppc_4xxFP\0" \ + "load=tftp 100000 hcu5/u-boot.bin\0" \ + "update=protect off FFFa0000 FFFFFFFF;era FFFa0000 FFFFFFFF;" \ + "cp.b 100000 FFFa0000 60000\0" \ + "upd=run load;run update\0" \ + "vx=tftp ${loadaddr} hcu5/hcu5_vx_rom;" \ + "setenv bootargs emac(0,0)hcu5_vx_rom e=${ipaddr} " \ + " h=${serverip} u=dpu pw=netstal8752 tn=hcu5 f=0x3008;" \ + "bootvx ${loadaddr}\0" \ + "" +#define CONFIG_BOOTCOMMAND "run vx" + +#if 0 +#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ +#else +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ +#endif + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#define CONFIG_M88E1111_PHY 1 +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR 0 /* PHY address, See schematics */ + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ + +#define CONFIG_HAS_ETH0 +#define CFG_RX_ETH_BUFFER 32 /* Number of ethernet rx buffers & descriptors */ + +#define CONFIG_NET_MULTI 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_PHY1_ADDR 1 + +/* USB */ +#define CONFIG_USB_OHCI +#define CONFIG_USB_STORAGE + +/* Comment this out to enable USB 1.1 device */ +#define USB_2_0_DEVICE + +#define CMD_USB CFG_CMD_USB + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +// CFG_CMD_FLASH | + +#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ + CFG_CMD_ASKENV | \ + CFG_CMD_BSP | \ + CFG_CMD_DHCP | \ + CFG_CMD_DIAG | \ + CFG_CMD_EEPROM | \ + CFG_CMD_ELF | \ + CFG_CMD_FAT | \ + CFG_CMD_I2C | \ + CFG_CMD_IMMAP | \ + CFG_CMD_IRQ | \ + CFG_CMD_MII | \ + CFG_CMD_NET | \ + CFG_CMD_NFS | \ + CFG_CMD_PCI | \ + CFG_CMD_PING | \ + CFG_CMD_REGINFO | \ + CFG_CMD_SDRAM | \ + CMD_USB) + +#define CONFIG_SUPPORT_VFAT + +/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#include <cmd_confdefs.h> + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x0400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#undef CONFIG_PCI_PNP /* do (not) pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE*/ + +/* Board-specific PCI */ +#define CFG_PCI_PRE_INIT /* enable board pci_pre_init() */ +#define CFG_PCI_TARGET_INIT +#define CFG_PCI_MASTER_INIT + +#define CFG_PCI_SUBSYS_VENDORID 0x10e8 /* AMCC */ +#define CFG_PCI_SUBSYS_ID 0xcafe /* Whatever */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ +#define CFG_FLASH CFG_FLASH_BASE +#define CFG_CS_1 0xC8000000 /* CAN */ +#define CFG_CS_2 0xCC000000 /* CPLD and IMC-Bus Standard */ +#define CFG_CPLD CFG_CS_2 +#define CFG_CS_3 0xCD000000 /* CPLD and IMC-Bus Fast */ + +/*----------------------------------------------------------------------- + * FLASH organization + * Memory Bank 0 (BOOT-FLASH) initialization + */ +#define CFG_BOOTFLASH_CS 0 /* Boot Flash chip connected to CSx */ +#define CFG_EBC_PB0AP 0x02005400 +#define CFG_EBC_PB0CR 0xFFF18000 /* (CFG_FLASH | 0xda000) */ +#define FLASH_BASE0_PRELIM CFG_FLASH_BASE /* FLASH bank #0 */ +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 32 /* max number of sectors on one chip */ + + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +/* Memory Bank 1 CAN-Chips initialization */ +#define CFG_EBC_PB1AP 0x02054500 +#define CFG_EBC_PB1CR 0xC8018000 + +/* Memory Bank 2 CPLD/IMC-Bus standard initialization */ +#define CFG_EBC_PB2AP 0x01840300 +#define CFG_EBC_PB2CR 0xCC0BA000 + +/* Memory Bank 3 IMC-Bus fast mode initialization */ +#define CFG_EBC_PB3AP 0x01800300 +#define CFG_EBC_PB3CR 0xCE0BA000 + +/* Memory Bank 4 (not used) initialization */ +#undef CFG_EBC_PB4AP +#undef CFG_EBC_PB4CR + +/* Memory Bank 5 (not used) initialization */ +#undef CFG_EBC_PB5AP +#undef CFG_EBC_PB5CR + +#define HCU_CPLD_VERSION_REGISTER ( CFG_CPLD + 0x0F00000 ) +#define HCU_HW_VERSION_REGISTER ( CFG_CPLD + 0x1400000 ) + +/*----------------------------------------------------------------------- + * Cache Configuration + *----------------------------------------------------------------------*/ +#define CFG_DCACHE_SIZE (32<<10) /* For AMCC 440 CPUs */ +#define CFG_CACHELINE_SIZE 32 /* ... */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#define CFG_HUSH_PARSER /* use "hush" command parser */ +#ifdef CFG_HUSH_PARSER + #define CFG_PROMPT_HUSH_PS2 "> " +#endif + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif +#endif /* __CONFIG_H */ +
Niklaus Giger
