[U-Boot] [PATCH 00/12] Enable returning back to BootROM from spear SPL
Spear machines currently have only the possibility to boot from NOR while an interesting alternative exist: booting from USB. For this, the BootROM will enumerate an USB device and wait for a RAM driver (likely, the SPL). It will load the driver in SRAM and jump to it. Once the initialization done, the SPL must return back into the BootROM so that another enumeration occurs allowing the user to upload the full Bootloader (eg. U-Boot). The BootROM will finally load the file in RAM and jump into it.
Most of the patches are cleanups and preparation work to ease the reading of the main assembly file.
The last patch is a fallback on USB Boot if the NOR is empty or corrupted. Of course if USB boot has not been enabled, nothing will happen.
Tested on a custom board featuring a SPEAr600.
Hope this change will find users!
Thanks, Miquèl
Miquel Raynal (12): spl: Fix typo in kernel doc arm: spear: Drop useless board_init_r call arm: spear: Call the SPL 'SPL', not 'Xloader' arm: spear: Drop false comment arm: spear: Fix the main comment in start.S arm: spear: Purely cosmetic changes in start.S arm: spear: Use PUSH/POP mnemonics when relevant arm: spear: Reference the link register with LR instead of R14 arm: spear: Simplify start.S organization arm: spear: Support returning to BootROM arm: spear: Do not link the _main branch arm: spear: Return to BootROM if failing to boot from the main device
arch/arm/cpu/arm926ejs/spear/spl.c | 47 +++++++++++++++++++++-- arch/arm/cpu/arm926ejs/spear/start.S | 56 +++++++++++----------------- common/spl/spl.c | 2 +- 3 files changed, 66 insertions(+), 39 deletions(-)
Fix a tiny typo in boot_from_devices() kernel doc.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- common/spl/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 88d4b8a9bf..745da7d431 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -532,7 +532,7 @@ static int spl_load_image(struct spl_image_info *spl_image, }
/** - * boot_from_devices() - Try loading an booting U-Boot from a list of devices + * boot_from_devices() - Try loading a booting U-Boot from a list of devices * * @spl_image: Place to put the image details if successful * @spl_boot_list: List of boot devices to try
Thanks, Stefan
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de
It is clearly stated that board_init_f should *not* call board_init_r. Indeed, board_init_f should return. The code will continue through arch/arm/lib/crt0.S which will do more setup before calling board_init_r.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/spl.c b/arch/arm/cpu/arm926ejs/spear/spl.c index d2bddb589a..b004cccafd 100644 --- a/arch/arm/cpu/arm926ejs/spear/spl.c +++ b/arch/arm/cpu/arm926ejs/spear/spl.c @@ -251,6 +251,4 @@ void board_init_f(ulong dummy) puts("Configure DDR\n"); mpmc_init(); spear_late_init(); - - board_init_r(NULL, 0); }
Thanks, Stefan
Rename Xloader as SPL in comments.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 1cab4ca6fb..e69deb7926 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -33,14 +33,14 @@
reset: /* - * Xloader has to return back to BootROM in a few cases. + * SPL has to return back to BootROM in a few cases. * eg. Ethernet boot, UART boot, USB boot * Saving registers for returning back */ stmdb sp!, {r0-r12,r14} bl cpu_init_crit /* - * Clearing bss area is not done in Xloader. + * Clearing bss area is not done in SPL. * BSS area lies in the DDR location which is not yet initialized * bss is assumed to be uninitialized. */
Thanks, Stefan
SPL BSS lies in SRAM and is actually initialized to 0 by the SPL in arch/arm/lib/crt0.S:_main(), which is called by cpu_init_crit.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index e69deb7926..4395985549 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -39,11 +39,6 @@ reset: */ stmdb sp!, {r0-r12,r14} bl cpu_init_crit -/* - * Clearing bss area is not done in SPL. - * BSS area lies in the DDR location which is not yet initialized - * bss is assumed to be uninitialized. - */ ldmia sp!, {r0-r12,pc}
Thanks, Stefan
This comment describes the board state at the moment where we enter the SPL. The description is entirely wrong; re-write it to fit the reality.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 4395985549..c3bb58c55b 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -21,10 +21,9 @@ * * Startup Code (reset vector) * - * Below are the critical initializations already taken place in BootROM. - * So, these are not taken care in Xloader - * 1. Relocation to RAM - * 2. Initializing stacks + * The BootROM already initialized its own stack in the [0-0xb00] reserved + * range of the SRAM. The SPL (in _main) will update the stack pointer to + * its own SRAM area (right before the gd section). * ************************************************************************* */
Thanks, Stefan
Before cleaning a bit further the spear/start.S file, apply a few cosmetic changes: capital letters, comment indentation and small rewriting.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index c3bb58c55b..566cf668b7 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -31,11 +31,10 @@ .globl reset
reset: -/* - * SPL has to return back to BootROM in a few cases. - * eg. Ethernet boot, UART boot, USB boot - * Saving registers for returning back - */ + /* + * SPL has to return back to BootROM in a few cases (eg. Ethernet boot, + * UART boot, USB boot): save registers in BootROM's stack. + */ stmdb sp!, {r0-r12,r14} bl cpu_init_crit ldmia sp!, {r0-r12,pc} @@ -52,14 +51,14 @@ reset: */ cpu_init_crit: /* - * flush v4 I/D caches + * Flush v4 I/D caches */ mov r0, #0 - mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ - mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ + mcr p15, 0, r0, c7, c7, 0 /* Flush v3/v4 cache */ + mcr p15, 0, r0, c8, c7, 0 /* Flush v4 TLB */
/* - * enable instruction cache + * Enable instruction cache */ mrc p15, 0, r0, c1, c0, 0 orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */
Thanks, Stefan
Quoting ARM "RealView Compilation Tools Assembler Guide v4.0":
PUSH and POP are synonyms for STMDB and LDM (or LDMIA), with the base register sp (r13), and the adjusted address written back to the base register. PUSH and POP are the preferred mnemonic in these cases.
Let's follow this recommandation to ease the reading and substitute LDMIA/STMDB operations with PUSH/POP mnemonics.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 566cf668b7..25895f01ac 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -35,9 +35,9 @@ reset: * SPL has to return back to BootROM in a few cases (eg. Ethernet boot, * UART boot, USB boot): save registers in BootROM's stack. */ - stmdb sp!, {r0-r12,r14} + push {r0-r12,r14} bl cpu_init_crit - ldmia sp!, {r0-r12,pc} + pop {r0-r12,pc}
/* ************************************************************************* @@ -67,6 +67,6 @@ cpu_init_crit: /* * Go setup Memory and board specific bits prior to relocation. */ - stmdb sp!, {lr} + push {lr} bl _main /* _main will call board_init_f */ - ldmia sp!, {pc} + pop {pc}
Thanks, Stefan
The link register is stored in R14. ARM assembly code allows to use the 'lr' name to reference it instead of 'r14' which is not very meaningful. Do the substitution to ease the reading.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 25895f01ac..2bc9d5990e 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -35,7 +35,7 @@ reset: * SPL has to return back to BootROM in a few cases (eg. Ethernet boot, * UART boot, USB boot): save registers in BootROM's stack. */ - push {r0-r12,r14} + push {r0-r12,lr} bl cpu_init_crit pop {r0-r12,pc}
Thanks, Stefan
There is no reason to do the few spear-related initialization, in a different procedure than 'reset'. Spare one branching and get a linear code flow by removing this indirection.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 17 ++--------------- 1 file changed, 2 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 2bc9d5990e..5fb2bd12ec 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -36,20 +36,7 @@ reset: * UART boot, USB boot): save registers in BootROM's stack. */ push {r0-r12,lr} - bl cpu_init_crit - pop {r0-r12,pc}
-/* - ************************************************************************* - * - * CPU_init_critical registers - * - * setup important registers - * setup memory timing - * - ************************************************************************* - */ -cpu_init_crit: /* * Flush v4 I/D caches */ @@ -67,6 +54,6 @@ cpu_init_crit: /* * Go setup Memory and board specific bits prior to relocation. */ - push {lr} bl _main /* _main will call board_init_f */ - pop {pc} + + pop {r0-r12,pc}
Thanks, Stefan
Implement the weak board_return_to_bootrom() function so that when enabling the spl_bootrom.c driver, one can make use of usbboot on spear platforms. All necessary information to return to the BootROM are stored in the BootROM's stack. The SPL stack pointer is reset so we save the BootROM's stack pointer into the SPL .data section.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/spl.c | 35 ++++++++++++++++++++++++++-- arch/arm/cpu/arm926ejs/spear/start.S | 7 +++++- 2 files changed, 39 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/spl.c b/arch/arm/cpu/arm926ejs/spear/spl.c index b004cccafd..b2cacf2d3e 100644 --- a/arch/arm/cpu/arm926ejs/spear/spl.c +++ b/arch/arm/cpu/arm926ejs/spear/spl.c @@ -16,6 +16,12 @@ #include <asm/arch/spr_syscntl.h> #include <linux/mtd/st_smi.h>
+/* Reserve some space to store the BootROM's stack pointer during SPL operation. + * The BSS cannot be used for this purpose because it will be zeroed after + * having stored the pointer, so force the location to the data section. + */ +u32 bootrom_stash_sp __attribute__((section(".data"))); + static void ddr_clock_init(void) { struct misc_regs *misc_p = (struct misc_regs *)CONFIG_SPEAR_MISCBASE; @@ -223,8 +229,9 @@ u32 spl_boot_device(void) { u32 mode = 0;
- /* Currently only SNOR is supported as the only */ - if (snor_boot_selected()) { + if (usb_boot_selected()) { + mode = BOOT_DEVICE_BOOTROM; + } else if (snor_boot_selected()) { /* SNOR-SMI initialization */ snor_init();
@@ -252,3 +259,27 @@ void board_init_f(ulong dummy) mpmc_init(); spear_late_init(); } + +/* + * In a few cases (Ethernet, UART or USB boot, we might want to go back into the + * BootROM code right after having initialized a few components like the DRAM). + * The following function is called from SPL common code (board_init_r). + */ +void board_return_to_bootrom(void) +{ + /* + * Retrieve the BootROM's stack pointer and jump back to the start of + * the SPL, where we can easily branch back into the BootROM. Don't do + * it right here because SPL might be compiled in Thumb mode while the + * BootROM expects ARM mode. + */ + asm volatile ("ldr r0, =bootrom_stash_sp;" + "ldr r0, [r0];" + "mov sp, r0;" +#if defined(CONFIG_SPL_SYS_THUMB_BUILD) + "blx back_to_bootrom;" +#else + "bl back_to_bootrom;" +#endif + ); +} diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 5fb2bd12ec..2cf854eb74 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -29,13 +29,17 @@ */
.globl reset + .globl back_to_bootrom
reset: /* * SPL has to return back to BootROM in a few cases (eg. Ethernet boot, - * UART boot, USB boot): save registers in BootROM's stack. + * UART boot, USB boot): save registers in BootROM's stack and then the + * BootROM's stack pointer in the SPL's data section. */ push {r0-r12,lr} + ldr r0, =bootrom_stash_sp + str sp, [r0]
/* * Flush v4 I/D caches @@ -56,4 +60,5 @@ reset: */ bl _main /* _main will call board_init_f */
+back_to_bootrom: pop {r0-r12,pc}
Thanks, Stefan
The _main call is not supposed to return at all: don't link the branch.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/start.S | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 2cf854eb74..9ac96291b7 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -57,8 +57,9 @@ reset:
/* * Go setup Memory and board specific bits prior to relocation. + * This call is not supposed to return. */ - bl _main /* _main will call board_init_f */ + b _main /* _main will call board_init_f */
Thanks, Stefan
Overload the weak function board_boot_order() so that besides choosing the main boot device, we can fallback on USB boot by returning in the BootROM, eg. if the NOR flash is empty while it was the primary boot medium.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- arch/arm/cpu/arm926ejs/spear/spl.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/spear/spl.c b/arch/arm/cpu/arm926ejs/spear/spl.c index b2cacf2d3e..fc332fb626 100644 --- a/arch/arm/cpu/arm926ejs/spear/spl.c +++ b/arch/arm/cpu/arm926ejs/spear/spl.c @@ -241,6 +241,18 @@ u32 spl_boot_device(void) return mode; }
+void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = spl_boot_device(); + + /* + * If the main boot device (eg. NOR) is empty, try to jump back into the + * BootROM for USB boot process. + */ + if (USB_BOOT_SUPPORTED) + spl_boot_list[1] = BOOT_DEVICE_BOOTROM; +} + void board_init_f(ulong dummy) { struct misc_regs *misc_p = (struct misc_regs *)CONFIG_SPEAR_MISCBASE;
Thanks, Stefan
Many thanks for working on this and improving the neglected SPEAr U-Boot port. It's quite some time since I worked on this platform and I still do have a x600 board hidden somewhere. Frankly, if there is no real need I will not dig this board up to update and test a new U-Boot version on it (sorry).
Thanks, Stefan
Hi Stefan,
Stefan Roese sr@denx.de wrote on Tue, 7 May 2019 14:50:02 +0200:
Absolutely no problem, thanks for reviewing!
Miquèl
Miquel Raynal
Stefan Roese
