Re: [U-Boot] [PATCH 09/12] ARM: kirkwood: Add device-tree for nsa310s
(adding back list and cc, my bad replied from a mobile device)
On Wed, May 16, 2018 at 8:10 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
On 16.05.2018 09:58, Chris Packham wrote:
Hi Stefan,
On Wed, 16 May 2018, 12:09 AM Stefan Roese, <sr@denx.de mailto:sr@denx.de> wrote:
Hi Chris, On 10.05.2018 02:51, Chris Packham wrote: > On Thu, May 10, 2018 at 6:27 AM bodhi bodhi <mibodhi@gmail.com <mailto:mibodhi@gmail.com>> wrote: > >> Hi Chris, > >> What we have in Linux mainline is Zyxel NSA310 (Marvell 88f6281). The > Zyxel NSA310S (Marvell 88f6702) is actually a different box, which has not > been mainlined yet. > >> By the way, there are 3 variations of the Zyxel NSA310 box. This box has > some combination of: red USB Led, lm85 sensor, adt7476 sensor that make > them slighly different. The mainlined NSA310 DTS is for the one
with
> adt7476 sensor. > > > Ah OK. I did see 2 boards in the kernel, this was one of the "educated > guesses" which turns out not to to be a good guess. For now I'll just drop > this conversion from the series. Yes, that makes sense. Please do so. We can always get the correct version back into mainline, once we have Kirkwood "enabled" in a modern way. What is your plan with this Kirkwood revival? Do you plan to send updates to enable DM for those boards and perhaps some drivers as well? How should I proceed with this DT patch-set?
I was about to ask you.
I was thinking about sending a v2 omitting nas310s, but if that's the only change you could just omit it at your end.
So for a start its good that I apply these patches, omitting the nas310s one?
Yes thanks. Aside from the commend from Bodhi I haven't seen any other feedback. Not sure if you wanted to wait a bit longer.
Then I've got another set lined up for the boards using spi flash which lays the groundwork for Jagan's spi changes. I may as well switch over the i2c configs since the driver already supports DM. I'll probably send those later this week.
If i get really enthusiastic i might give converting the mvgbe driver to DM a try but the hardware I have for testing is complicated.
Sounds like a plan. Thanks for working on this.
No problem I'm keen to see Kirkwood hang around.
Chris Packham
