[U-Boot] [PATCH v3] Add support for Wandboard Quad
Add support for the Quad version of Wandboard; fix compile warning resulting from having 2G of memory.
Signed-off-by: Tapani Utriainen tapani@technexion.com Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- board/wandboard/README | 5 +++++ board/wandboard/wandboard.c | 2 +- boards.cfg | 1 + include/configs/wandboard.h | 2 ++ 4 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/wandboard/README b/board/wandboard/README index ce83bbe..498db2f 100644 --- a/board/wandboard/README +++ b/board/wandboard/README @@ -22,6 +22,11 @@ To build U-Boot for the Wandboard Solo version: $ make wandboard_solo_config $ make
+To build U-Boot for the Wandboard Quad version: + +$ make wandboard_quad_config +$ make + Flashing U-boot into the SD card --------------------------------
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 5666cbf..43c02ac 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -48,7 +48,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = CONFIG_DDR_MB * SZ_1M; + gd->ram_size = (phys_size_t)CONFIG_DDR_MB * 1024 * 1024;
return 0; } diff --git a/boards.cfg b/boards.cfg index fff4f45..2635942 100644 --- a/boards.cfg +++ b/boards.cfg @@ -272,6 +272,7 @@ nitrogen6q2g arm armv7 nitrogen6x boundar nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 wandboard_dl arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 +wandboard_quad arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 wandboard_solo arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 5593f1c..b2995d8 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -103,6 +103,8 @@
#if defined(CONFIG_MX6DL) #define CONFIG_DEFAULT_FDT_FILE "imx6dl-wandboard.dtb" +#elif defined(CONFIG_MX6Q) +#define CONFIG_DEFAULT_FDT_FILE "imx6q-wandboard.dtb" #elif defined(CONFIG_MX6S) #define CONFIG_DEFAULT_FDT_FILE "imx6s-wandboard.dtb" #endif
Hi Tapani,
gd->ram_size = (phys_size_t)CONFIG_DDR_MB * 1024 * 1024; return 0;
Patch does not apply cleanly because your mailer or your editor replaced original <tab> with whitespaces. I change back again, but please take care of this issue for the next time.
Apart of that:
Acked-by: Stefano Babic sbabic@denx.de
This patch was pending for a while, I will push it still for the release.
Best regards, Stefano Babic
Tapani, the easiest way of sending the patches is using git send-email command. This avoid this problems with the e-mail client.
Apart of that:
Thanks Stefano.
-- Otavio Salvador O.S. Systems http://www.ossystems.com.br http://projetos.ossystems.com.br Mobile: +55 (53) 9981-7854 Mobile: +1 (347) 903-9750
Otavio Salvador
Stefano Babic
Tapani
