Hello Tom,
please pull from u-boot-i2c next
The following changes since commit f4f845b859266790b97421f0740efce36bc9b8d2:
Merge patch series "Universal Payload initial series" (2024-08-09 16:03:21 -0600)
https://source.denx.de/u-boot/custodians/u-boot-i2c.git tags/i2c-dm-updates-for-v2024-10-next
for you to fetch changes up to 710b9c89f2c2f19436f6c21d092af1a2b24a26a6:
i2c: Remove CFG_SYS_I2C_DIRECT_BUS (2024-08-13 06:23:15 +0200)
---------------------------------------------------------------- i2c DM updates for v2024.10 next
- Add series from Simon, which removes old content in i2c.h so that we can move towards having just the dm API.
It does not remove any boards, but instead removes functionality.
---------------------------------------------------------------- Simon Glass (18): i2c: Remove board_i2c_init() i2c: Remove IC2_xxx enum i2c: Remove CFG_I2C_MULTI_BUS mips: malta: Drop CMD_DATE armv8: ls2085a: Drop CMD_DATE mx28 / mx51: Drop CMD_DATE MPC837XERDB: ethernut5: work_92105: Drop CMD_DATE rtc: Drop CFG_SYS_RTC_BUS_NUM date: Drop the legacy I2C code fsl: mxc: Drop legacy I2c i2c: Drop reference to SYS_I2C_INIT_BOARD octeon: Drop OCTEON_I2C_FDT dead code i2c: Remove I2C_SET_BUS() i2c: Remove I2C_GET_BUS() i2c: Drop CFG_SYS_MAX_I2C_BUS i2c: Drop i2c_get_bus_num_fdt() and i2c_reset_port_fdt() i2c: Remove CFG_SYS_I2C_MAX_HOPS i2c: Remove CFG_SYS_I2C_DIRECT_BUS
README | 27 +-------------------------- arch/mips/mach-octeon/octeon_fdt.c | 7 ------- cmd/date.c | 32 -------------------------------- cmd/i2c.c | 23 ----------------------- configs/MPC837XERDB_defconfig | 1 - configs/ethernut5_defconfig | 1 - configs/ls2080aqds_nand_defconfig | 1 - configs/ls2080aqds_qspi_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 1 - configs/malta64_defconfig | 1 - configs/malta64el_defconfig | 1 - configs/malta_defconfig | 1 - configs/maltael_defconfig | 1 - configs/mx28evk_defconfig | 1 - configs/mx51evk_defconfig | 1 - configs/work_92105_defconfig | 1 - doc/I2C_Edge_Conditions | 10 ++++------ drivers/ddr/fsl/main.c | 3 +-- drivers/i2c/i2c_core.c | 141 --------------------------------------------------------------------------------------------------------------------------------------------- drivers/i2c/mxc_i2c.c | 1 + drivers/i2c/soft_i2c.c | 11 ----------- drivers/power/power_i2c.c | 5 ----- drivers/usb/host/ohci-lpc32xx.c | 4 ---- include/configs/ethernut5.h | 3 --- include/configs/ls1028aqds.h | 1 - include/configs/ls1028ardb.h | 2 -- include/configs/ls1046afrwy.h | 1 - include/configs/lx2160aqds.h | 3 --- include/configs/lx2160ardb.h | 3 --- include/configs/lx2162aqds.h | 3 --- include/configs/m53menlo.h | 2 -- include/configs/sniper.h | 14 -------------- include/configs/tqma6.h | 3 --- include/configs/tqma6_wru4.h | 1 - include/i2c.h | 107 ----------------------------------------------------------------------------------------------------------- 35 files changed, 7 insertions(+), 412 deletions(-)
Azure build: https://dev.azure.com/hs0298/hs/_build/results?buildId=122&view=results
Thanks!
bye, Heiko
On Tue, Aug 13, 2024 at 12:44:29PM +0200, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
