[U-Boot] [PATCH 2/9 V3] add c structures for SoC access
* add's c structures for SoC access to pheriperials head files * add's missing pheriperials head files (new SoC)
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- include/asm-arm/arch-at91/at91_matrix.h | 125 +++++++++++++++++++++++++++ include/asm-arm/arch-at91/at91_pdc.h | 41 +++++++++ include/asm-arm/arch-at91/at91_pio.h | 104 ++++++++++++++++++++++ include/asm-arm/arch-at91/at91_pit.h | 15 +++ include/asm-arm/arch-at91/at91_pmc.h | 100 +++++++++++++++++++++ include/asm-arm/arch-at91/at91_rstc.h | 30 ++++++- include/asm-arm/arch-at91/at91_spi.h | 21 +++++ include/asm-arm/arch-at91/at91_wdt.h | 29 ++++++ include/asm-arm/arch-at91/at91cap9.h | 9 ++ include/asm-arm/arch-at91/at91sam9260.h | 17 ++++ include/asm-arm/arch-at91/at91sam9261.h | 14 +++- include/asm-arm/arch-at91/at91sam9263.h | 22 +++++ include/asm-arm/arch-at91/at91sam9_sdramc.h | 13 +++ include/asm-arm/arch-at91/at91sam9_smc.h | 63 ++++++++++++++ include/asm-arm/arch-at91/at91sam9g45.h | 15 +++ include/asm-arm/arch-at91/at91sam9rl.h | 14 +++- include/asm-arm/arch-at91/gpio.h | 3 + include/asm-arm/arch-at91/io.h | 3 + 18 files changed, 635 insertions(+), 3 deletions(-) create mode 100644 include/asm-arm/arch-at91/at91_matrix.h create mode 100644 include/asm-arm/arch-at91/at91_pdc.h
diff --git a/include/asm-arm/arch-at91/at91_matrix.h b/include/asm-arm/arch-at91/at91_matrix.h new file mode 100644 index 0000000..eeaae9d --- /dev/null +++ b/include/asm-arm/arch-at91/at91_matrix.h @@ -0,0 +1,125 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_MATRIX_H +#define AT91_MATRIX_H + +#ifdef __ASSEMBLY__ + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x11C) +#elif defined(CONFIG_AT91SAM9261) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x30) +#elif defined(CONFIG_AT91SAM9263) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x120) +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x128) +#else +#error AT91_ASM_MATRIX_CSA0 is not definied for current CPU +#endif + +#define AT91_ASM_MATRIX_MCFG AT91_MATRIX_BASE + +#else +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_MATRIX_MASTERS 6 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9261) +#define AT91_MATRIX_MASTERS 1 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9263) +#define AT91_MATRIX_MASTERS 9 +#define AT91_MATRIX_SLAVES 7 +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_MATRIX_MASTERS 11 +#define AT91_MATRIX_SLAVES 8 +#else +#error CPU not supported. Please update at91_matrix.h +#endif + +typedef struct at91_prority { + u32 a; + u32 b; +} at91_prority_t; + + +typedef struct at91_matrix { + u32 mcfg[AT91_MATRIX_MASTERS]; +#if defined(CONFIG_AT91SAM9261) + u32 scfg[AT91_MATRIX_SLAVES]; + u32 res61_1[3]; + u32 tcr; + u32 res61_2[2]; + u32 csa; + u32 pucr; + u32 res61_3[114]; +#else +#if (AT91_MATRIX_MASTERS < 16) + u32 reserve1[16 - AT91_MATRIX_MASTERS]; +#endif + u32 scfg[AT91_MATRIX_SLAVES]; +#if (AT91_MATRIX_SLAVES < 16) + u32 reserve2[16 - AT91_MATRIX_SLAVES]; +#endif + at91_prority_t pr[AT91_MATRIX_SLAVES]; +#if (AT91_MATRIX_SLAVES < 16) + u32 reserve3[32 - (2 * AT91_MATRIX_SLAVES)]; +#endif + u32 mrcr; /* 0x100 Master Remap Control */ + u32 reserve4[3]; +#if defined(CONFIG_AT91SAM9G45) + u32 ccr[52] /* 0x110 - 0x1E0 Chip Configuration */ + u32 womr; /* 0x1E4 Write Protect Mode */ + u32 wpsr; /* 0x1E8 Write Protect Status */ + u32 resg45_1[10]; +#elif defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) + u32 res60_1[3]; + u32 csa; + u32 res60_2[56]; +#elif defined(CONFIG_AT91SAM9263) + u32 res63_1; + u32 tcmr; + u32 res63_2[2]; + u32 csa[2]; + u32 res63_3[54]; +#else + u32 reserve5[60]; +#endif +#endif +} at91_matrix_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_MATRIX_CSA_DBPUC 0x00000100 +#define AT91_MATRIX_CSA_VDDIOMSEL_1_8V 0x00000000 +#define AT91_MATRIX_CSA_VDDIOMSEL_3_3V 0x00010000 + +#define AT91_MATRIX_CSA_EBI_CS1A 0x00000002 +#define AT91_MATRIX_CSA_EBI_CS3A 0x00000008 +#define AT91_MATRIX_CSA_EBI_CS4A 0x00000010 +#define AT91_MATRIX_CSA_EBI_CS5A 0x00000020 + +#define AT91_MATRIX_CSA_EBI1_CS2A 0x00000008 + +#endif diff --git a/include/asm-arm/arch-at91/at91_pdc.h b/include/asm-arm/arch-at91/at91_pdc.h new file mode 100644 index 0000000..dd12587 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_pdc.h @@ -0,0 +1,41 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_PDC_H +#define AT91_PDC_H + +typedef struct at91_pdc { + u32 rpr; /* 0x100 Receive Pointer Register */ + u32 rcr; /* 0x104 Receive Counter Register */ + u32 tpr; /* 0x108 Transmit Pointer Register */ + u32 tcr; /* 0x10C Transmit Counter Register */ + u32 pnpr; /* 0x110 Receive Next Pointer Register */ + u32 pncr; /* 0x114 Receive Next Counter Register */ + u32 tnpr; /* 0x118 Transmit Next Pointer Register */ + u32 tncr; /* 0x11C Transmit Next Counter Register */ + u32 ptcr; /* 0x120 Transfer Control Register */ + u32 ptsr; /* 0x124 Transfer Status Register */ +} at91_pdc_t; + +#endif diff --git a/include/asm-arm/arch-at91/at91_pio.h b/include/asm-arm/arch-at91/at91_pio.h index f6ce1f9..52724e5 100644 --- a/include/asm-arm/arch-at91/at91_pio.h +++ b/include/asm-arm/arch-at91/at91_pio.h @@ -16,6 +16,109 @@ #ifndef AT91_PIO_H #define AT91_PIO_H
+#ifdef __ASSEMBLY__ + +#define AT91_ASM_PIO_RANGE 0x200 +#define AT91_ASM_PIOC_PDR \ + (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x04) +#define AT91_ASM_PIOC_PUDR \ + (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x60) + +#define AT91_ASM_PIOD_PDR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x04) +#define AT91_ASM_PIOD_PUDR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x60) +#define AT91_ASM_PIOD_ASR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x70) + +#else + +typedef struct at91_port { + u32 per; /* 0x00 PIO Enable Register */ + u32 pdr; /* 0x04 PIO Disable Register */ + u32 psr; /* 0x08 PIO Status Register */ + u32 reserved0; + u32 oer; /* 0x10 Output Enable Register */ + u32 odr; /* 0x14 Output Disable Registerr */ + u32 osr; /* 0x18 Output Status Register */ + u32 reserved1; + u32 ifer; /* 0x20 Input Filter Enable Register */ + u32 ifdr; /* 0x24 Input Filter Disable Register */ + u32 ifsr; /* 0x28 Input Filter Status Register */ + u32 reserved2; + u32 sodr; /* 0x30 Set Output Data Register */ + u32 codr; /* 0x34 Clear Output Data Register */ + u32 odsr; /* 0x38 Output Data Status Register */ + u32 pdsr; /* 0x3C Pin Data Status Register */ + u32 ier; /* 0x40 Interrupt Enable Register */ + u32 idr; /* 0x44 Interrupt Disable Register */ + u32 imr; /* 0x48 Interrupt Mask Register */ + u32 isr; /* 0x4C Interrupt Status Register */ + u32 mder; /* 0x50 Multi-driver Enable Register */ + u32 mddr; /* 0x54 Multi-driver Disable Register */ + u32 mdsr; /* 0x58 Multi-driver Status Register */ + u32 reserved3; + u32 pudr; /* 0x60 Pull-up Disable Register */ + u32 puer; /* 0x64 Pull-up Enable Register */ + u32 pusr; /* 0x68 Pad Pull-up Status Register */ + u32 reserved4; + u32 asr; /* 0x70 Select A Register */ + u32 bsr; /* 0x74 Select B Register */ + u32 absr; /* 0x78 AB Select Status Register */ + u32 reserved5[9]; /* */ + u32 ower; /* 0xA0 Output Write Enable Register */ + u32 owdr; /* 0xA4 Output Write Disable Register */ + u32 owsr; /* OxA8 utput Write Status Register */ + u32 reserved6[85]; +} at91_port_t; + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) +#define AT91_PIO_PORTS 3 +#elif defined(CONFIG_AT91SAM9263) +#define AT91_PIO_PORTS 5 +#else +#define AT91_PIO_PORTS 4 +#endif + +typedef union at91_pio { + struct { + at91_port_t pioa; + at91_port_t piob; + at91_port_t pioc; + #if (AT91_PIO_PORTS > 3) + at91_port_t piod; + #endif + #if (AT91_PIO_PORTS > 4) + at91_port_t pioe; + #endif + } ; + at91_port_t port[AT91_PIO_PORTS]; +} at91_pio_t; + +#ifdef CONFIG_AT91_GPIO +int at91_set_gpio_periph(u32 pin, int use_pullup); +int at91_set_a_periph(u32 pin, int use_pullup); +int at91_set_b_periph(u32 pin, int use_pullup); +int at91_set_gpio_input(u32 pin, int use_pullup); +int at91_set_gpio_output(u32 pin, int value); +int at91_set_deglitch(u32 pin, int is_on); +int at91_set_multi_drive(u32 pin, int is_on); +int at91_set_gpio_value(u32 pin, int value); +int at91_get_gpio_value(u32 pin); +#endif + +#endif + +#define AT91_PIN_TO_MASK(x) (1<<x) +#define AT91_PORTPIN(PORT, PIN) ((0x0##PORT - 9) * 32 + ((PIN) & 0x1F)) +#define AT91_PIO_PORTA 0x0 +#define AT91_PIO_PORTB 0x1 +#define AT91_PIO_PORTC 0x2 +#define AT91_PIO_PORTD 0x3 +#define AT91_PIO_PORTE 0x4 + +#ifdef CONFIG_AT91_LEGACY + #define PIO_PER 0x00 /* Enable Register */ #define PIO_PDR 0x04 /* Disable Register */ #define PIO_PSR 0x08 /* Status Register */ @@ -45,5 +148,6 @@ #define PIO_OWER 0xa0 /* Output Write Enable Register */ #define PIO_OWDR 0xa4 /* Output Write Disable Register */ #define PIO_OWSR 0xa8 /* Output Write Status Register */ +#endif
#endif diff --git a/include/asm-arm/arch-at91/at91_pit.h b/include/asm-arm/arch-at91/at91_pit.h index 94dd242..5615a02 100644 --- a/include/asm-arm/arch-at91/at91_pit.h +++ b/include/asm-arm/arch-at91/at91_pit.h @@ -16,6 +16,20 @@ #ifndef AT91_PIT_H #define AT91_PIT_H
+typedef struct at91_pit { + u32 mr; /* 0x00 Mode Register */ + u32 sr; /* 0x04 Status Register */ + u32 pivr; /* 0x08 Periodic Interval Value Register */ + u32 piir; /* 0x0C Periodic Interval Image Register */ +} at91_pit_t; + +#define AT91_PIT_MR_IEN 0x02000000 +#define AT91_PIT_MR_EN 0x01000000 +#define AT91_PIT_MR_PIV_MASK (x & 0x000fffff) +#define AT91_PIT_MR_PIV(x) (x & AT91_PIT_MR_PIV_MASK) + +#ifdef CONFIG_AT91_LEGACY + #define AT91_PIT_MR (AT91_PIT + 0x00) /* Mode Register */ #define AT91_PIT_PITIEN (1 << 25) /* Timer Interrupt Enable */ #define AT91_PIT_PITEN (1 << 24) /* Timer Enabled */ @@ -29,4 +43,5 @@ #define AT91_PIT_PICNT (0xfff << 20) /* Interval Counter */ #define AT91_PIT_CPIV (0xfffff) /* Inverval Value */
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91_pmc.h b/include/asm-arm/arch-at91/at91_pmc.h index 9fe94c7..9a0e1d2 100644 --- a/include/asm-arm/arch-at91/at91_pmc.h +++ b/include/asm-arm/arch-at91/at91_pmc.h @@ -16,6 +16,105 @@ #ifndef AT91_PMC_H #define AT91_PMC_H
+#ifdef __ASSEMBLY__ + +#define AT91_ASM_PMC_MOR (AT91_PMC_BASE + 0x20) +#define AT91_ASM_PMC_PLLAR (AT91_PMC_BASE + 0x28) +#define AT91_ASM_PMC_PLLBR (AT91_PMC_BASE + 0x2c) +#define AT91_ASM_PMC_MCKR (AT91_PMC_BASE + 0x30) +#define AT91_ASM_PMC_SR (AT91_PMC_BASE + 0x68) + +#else + +#include <asm/types.h> + +typedef struct at91_pmc { + u32 scer; /* 0x00 System Clock Enable Register */ + u32 scdr; /* 0x04 System Clock Disable Register */ + u32 scsr; /* 0x08 System Clock Status Register */ + u32 reserved0; + u32 pcer; /* 0x10 Peripheral Clock Enable Register */ + u32 pcdr; /* 0x14 Peripheral Clock Disable Register */ + u32 pcsr; /* 0x18 Peripheral Clock Status Register */ + u32 reserved1; + u32 mor; /* 0x20 Main Oscilator Register */ + u32 mcfr; /* 0x24 Main Clock Frequency Register */ + u32 pllar; /* 0x28 PLL A Register */ + u32 pllbr; /* 0x2C PLL B Register */ + u32 mckr; /* 0x30 Master Clock Register */ + u32 reserved2[3]; + u32 pck[4]; /* 0x40 Programmable Clock Register 0 - 3 */ + u32 reserved3[4]; + u32 ier; /* 0x60 Interrupt Enable Register */ + u32 idr; /* 0x64 Interrupt Disable Register */ + u32 sr; /* 0x68 Status Register */ + u32 imr; /* 0x6C Interrupt Mask Register */ + u32 reserved4[4]; +#ifdef CONFIG_AT91SAM9 + u32 pllicpr; /* 0x80 Change Pump Current Register */ +#else + u32 reserved5; +#endif + u32 reserved6[21]; +#ifdef CONFIG_AT91CAP9 + u32 wpmr; /* 0xE4 Write Protect Mode Register */ + u32 wpsr; /* 0xE8 Write Protect Status Register */ +#else + u32 reserved7[2]; +#endif + u32 reserved8[5]; +} at91_pmc_t; + +#endif /* end assembly */ + +#define AT91_PMC_MOR_MOSCEN 0x01 +#define AT91_PMC_MOR_OSCBYPASS 0x02 +#define AT91_PMC_MOR_OSCOUNT(x) ((x & 0xff) << 8) + +#define AT91_PMC_PLLxR_DIV(x) (x & 0xFF) +#define AT91_PMC_PLLxR_PLLCOUNT(x) ((x & 0x3F) << 8) +#define AT91_PMC_PLLxR_OUT(x) ((x & 0x03) << 14) +#define AT91_PMC_PLLxR_MUL(x) ((x & 0x7FF) << 16) +#define AT91_PMC_PLLAR_29 0x20000000 +#define AT91_PMC_PLLBR_USBDIV_1 0x00000000 +#define AT91_PMC_PLLBR_USBDIV_2 0x10000000 +#define AT91_PMC_PLLBR_USBDIV_4 0x20000000 + +#define AT91_PMC_MCKR_CSS_SLOW 0x00000000 +#define AT91_PMC_MCKR_CSS_MAIN 0x00000001 +#define AT91_PMC_MCKR_CSS_PLLA 0x00000002 +#define AT91_PMC_MCKR_CSS_PLLB 0x00000003 +#define AT91_PMC_MCKR_CSS_MASK 0x00000003 + +#define AT91_PMC_MCKR_PRES_1 0x00000000 +#define AT91_PMC_MCKR_PRES_2 0x00000004 +#define AT91_PMC_MCKR_PRES_4 0x00000008 +#define AT91_PMC_MCKR_PRES_8 0x0000000C +#define AT91_PMC_MCKR_PRES_16 0x00000010 +#define AT91_PMC_MCKR_PRES_32 0x00000014 +#define AT91_PMC_MCKR_PRES_64 0x00000018 +#define AT91_PMC_MCKR_PRES_MASK 0x0000001C + +#define AT91_PMC_MCKR_MDIV_1 0x00000000 +#define AT91_PMC_MCKR_MDIV_2 0x00000100 +#define AT91_PMC_MCKR_MDIV_4 0x00000200 +#define AT91_PMC_MCKR_MDIV_MASK 0x00000300 + +#define AT91_PMC_MCKR_PLLADIV_1 0x00001000 +#define AT91_PMC_MCKR_PLLADIV_2 0x00002000 + +#define AT91_PMC_IxR_MOSCS 0x00000001 +#define AT91_PMC_IxR_LOCKA 0x00000002 +#define AT91_PMC_IxR_LOCKB 0x00000004 +#define AT91_PMC_IxR_MCKRDY 0x00000008 +#define AT91_PMC_IxR_LOCKU 0x00000040 +#define AT91_PMC_IxR_PCKRDY0 0x00000100 +#define AT91_PMC_IxR_PCKRDY1 0x00000200 +#define AT91_PMC_IxR_PCKRDY2 0x00000400 +#define AT91_PMC_IxR_PCKRDY3 0x00000800 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_PMC_SCER (AT91_PMC + 0x00) /* System Clock Enable Register */ #define AT91_PMC_SCDR (AT91_PMC + 0x04) /* System Clock Disable Register */
@@ -117,4 +216,5 @@
#define AT91_PMC_VER (AT91_PMC + 0xfc) /* PMC Module Version [AT91CAP9 only] */
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91_rstc.h b/include/asm-arm/arch-at91/at91_rstc.h index e49caef..86f4ffb 100644 --- a/include/asm-arm/arch-at91/at91_rstc.h +++ b/include/asm-arm/arch-at91/at91_rstc.h @@ -16,11 +16,37 @@ #ifndef AT91_RSTC_H #define AT91_RSTC_H
+#ifdef __ASSEMBLY__ +#define AT91_ASM_RSTC_MR (AT91_RSTC_BASE + 0x08) +#else + +typedef struct at91_rstc { + u32 cr; /* Reset Controller Control Register */ + u32 sr; /* Reset Controller Status Register */ + u32 mr; /* Reset Controller Mode Register */ +} at91_rstc_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_RSTC_KEY 0xA5000000 + +#define AT91_RSTC_CR_PROCRST 0x00000001 +#define AT91_RSTC_CR_PERRST 0x00000004 +#define AT91_RSTC_CR_EXTRST 0x00000008 + +#define AT91_RSTC_MR_URSTEN 0x00000001 +#define AT91_RSTC_MR_URSTIEN 0x00000010 +#define AT91_RSTC_MR_ERSTL(x) ((x & 0xf) << 8) +#define AT91_RSTC_MR_ERSTL_MASK 0x0000FF00 + +#define AT91_RSTC_SR_NRSTL 0x00010000 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_RSTC_CR (AT91_RSTC + 0x00) /* Reset Controller Control Register */ #define AT91_RSTC_PROCRST (1 << 0) /* Processor Reset */ #define AT91_RSTC_PERRST (1 << 2) /* Peripheral Reset */ #define AT91_RSTC_EXTRST (1 << 3) /* External Reset */ -#define AT91_RSTC_KEY (0xa5 << 24) /* KEY Password */
#define AT91_RSTC_SR (AT91_RSTC + 0x04) /* Reset Controller Status Register */ #define AT91_RSTC_URSTS (1 << 0) /* User Reset Status */ @@ -38,4 +64,6 @@ #define AT91_RSTC_URSTIEN (1 << 4) /* User Reset Interrupt Enable */ #define AT91_RSTC_ERSTL (0xf << 8) /* External Reset Length */
+#endif /* CONFIG_AT91_LEGACY */ + #endif diff --git a/include/asm-arm/arch-at91/at91_spi.h b/include/asm-arm/arch-at91/at91_spi.h index 30643c6..c520e89 100644 --- a/include/asm-arm/arch-at91/at91_spi.h +++ b/include/asm-arm/arch-at91/at91_spi.h @@ -16,6 +16,25 @@ #ifndef AT91_SPI_H #define AT91_SPI_H
+#include <asm/arch/at91_pdc.h> + +typedef struct at91_spi { + u32 cr; /* 0x00 Control Register */ + u32 mr; /* 0x04 Mode Register */ + u32 rdr; /* 0x08 Receive Data Register */ + u32 tdr; /* 0x0C Transmit Data Register */ + u32 sr; /* 0x10 Status Register */ + u32 ier; /* 0x14 Interrupt Enable Register */ + u32 idr; /* 0x18 Interrupt Disable Register */ + u32 imr; /* 0x1C Interrupt Mask Register */ + u32 reserve1[4]; + u32 csr[4]; /* 0x30 Chip Select Register 0-3 */ + u32 reserve2[48]; + at91_pdc_t pdc; +} at91_spi_t; + +#ifdef CONFIG_AT91_LEGACY + #define AT91_SPI_CR 0x00 /* Control Register */ #define AT91_SPI_SPIEN (1 << 0) /* SPI Enable */ #define AT91_SPI_SPIDIS (1 << 1) /* SPI Disable */ @@ -102,4 +121,6 @@
#define AT91_SPI_PTSR 0x0124 /* PDC Transfer Status Register */
+#endif /* CONFIG_AT91_LEGACY */ + #endif diff --git a/include/asm-arm/arch-at91/at91_wdt.h b/include/asm-arm/arch-at91/at91_wdt.h index 7e18537..cf08daf 100644 --- a/include/asm-arm/arch-at91/at91_wdt.h +++ b/include/asm-arm/arch-at91/at91_wdt.h @@ -17,6 +17,34 @@ #ifndef AT91_WDT_H #define AT91_WDT_H
+#ifdef __ASSEMBLY__ + +#define AT91_ASM_WDT_MR (AT91_WDT_BASE + 0x04) + +#else + +typedef struct at91_wdt { + u32 cr; + u32 mr; + u32 sr; +} at91_wdt_t; + +#endif + +#define AT91_WDT_CR_WDRSTT 1 +#define AT91_WDT_CR_KEY 0xa5000000 /* KEY Password */ + +#define AT91_WDT_MR_WDV(x) (x & 0xfff) +#define AT91_WDT_MR_WDFIEN 0x00001000 +#define AT91_WDT_MR_WDRSTEN 0x00002000 +#define AT91_WDT_MR_WDRPROC 0x00004000 +#define AT91_WDT_MR_WDDIS 0x00008000 +#define AT91_WDT_MR_WDD(x) ((x & 0xfff) << 16) +#define AT91_WDT_MR_WDDBGHLT 0x10000000 +#define AT91_WDT_MR_WDIDLEHLT 0x20000000 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_WDT_CR (AT91_WDT + 0x00) /* Watchdog Control Register */ #define AT91_WDT_WDRSTT (1 << 0) /* Restart */ #define AT91_WDT_KEY (0xa5 << 24) /* KEY Password */ @@ -35,4 +63,5 @@ #define AT91_WDT_WDUNF (1 << 0) /* Watchdog Underflow */ #define AT91_WDT_WDERR (1 << 1) /* Watchdog Error */
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91cap9.h b/include/asm-arm/arch-at91/at91cap9.h index b128ac5..c825710 100644 --- a/include/asm-arm/arch-at91/at91cap9.h +++ b/include/asm-arm/arch-at91/at91cap9.h @@ -53,6 +53,14 @@ #define AT91CAP9_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ #define AT91CAP9_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */
+#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 + +#define AT91_PIT_BASE 0xfffffd30 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -119,6 +127,7 @@ #define AT91CAP9_SCKCR_OSCSEL_RC (0 << 3) #define AT91CAP9_SCKCR_OSCSEL_32 (1 << 3)
+#endif /* CONFIG_AT91_LEGACY */ /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9260.h b/include/asm-arm/arch-at91/at91sam9260.h index 73975f4..fd38fab 100644 --- a/include/asm-arm/arch-at91/at91sam9260.h +++ b/include/asm-arm/arch-at91/at91sam9260.h @@ -49,6 +49,21 @@ #define AT91SAM9260_ID_IRQ1 30 /* Advanced Interrupt Controller (IRQ1) */ #define AT91SAM9260_ID_IRQ2 31 /* Advanced Interrupt Controller (IRQ2) */
+#define AT91_EMAC_BASE 0xfffc4000 + +#define AT91_SDRAMC_BASE 0xffffea00 +#define AT91_SMC_BASE 0xffffec00 +#define AT91_MATRIX_BASE 0xffffee00 + +#define AT91_PIO_BASE 0xfffff400 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 + +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -105,6 +120,8 @@ #define AT91_USART4 AT91SAM9260_BASE_US4 #define AT91_USART5 AT91SAM9260_BASE_US5
+#endif /* CONFIG_AT91_LEGACY */ + /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9261.h b/include/asm-arm/arch-at91/at91sam9261.h index b303e07..2fe9d17 100644 --- a/include/asm-arm/arch-at91/at91sam9261.h +++ b/include/asm-arm/arch-at91/at91sam9261.h @@ -43,6 +43,18 @@ #define AT91SAM9261_ID_IRQ1 30 /* Advanced Interrupt Controller (IRQ1) */ #define AT91SAM9261_ID_IRQ2 31 /* Advanced Interrupt Controller (IRQ2) */
/* * User Peripheral physical base addresses. @@ -64,7 +76,6 @@ #define AT91SAM9261_BASE_SPI1 0xfffcc000 #define AT91_BASE_SYS 0xffffea00
- /* * System Peripherals (offset from AT91_BASE_SYS) */ @@ -88,6 +99,7 @@ #define AT91_USART1 AT91SAM9261_BASE_US1 #define AT91_USART2 AT91SAM9261_BASE_US2
/* * Internal Memory. diff --git a/include/asm-arm/arch-at91/at91sam9263.h b/include/asm-arm/arch-at91/at91sam9263.h index 966a683..e52c297 100644 --- a/include/asm-arm/arch-at91/at91sam9263.h +++ b/include/asm-arm/arch-at91/at91sam9263.h @@ -47,6 +47,26 @@ #define AT91SAM9263_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ #define AT91SAM9263_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */
+#define AT91_EMAC_BASE 0xfffbc000 + +#define AT91_ECC0_BASE 0xffffe000 +#define AT91_SDRAMC0_BASE 0xffffe200 +#define AT91_SMC0_BASE 0xffffe400 +#define AT91_ECC1_BASE 0xffffe600 +#define AT91_SDRAMC1_BASE 0xffffe800 +#define AT91_SMC1_BASE 0xffffea00 +#define AT91_MATRIX_BASE 0xffffec00 +#define AT91_CCFG_BASE 0xffffed10 +#define AT91_DBGU_BASE 0xffffee00 +#define AT91_AIC_BASE 0xfffff000 +#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 + +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY
/* * User Peripheral physical base addresses. @@ -108,6 +128,8 @@ #define AT91_SMC AT91_SMC0 #define AT91_SDRAMC AT91_SDRAMC0
+#endif /* CONFIG_AT91_LEGACY */ + /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9_sdramc.h b/include/asm-arm/arch-at91/at91sam9_sdramc.h index 5af2b54..c3da3a6 100644 --- a/include/asm-arm/arch-at91/at91sam9_sdramc.h +++ b/include/asm-arm/arch-at91/at91sam9_sdramc.h @@ -17,6 +17,19 @@ #ifndef AT91SAM9_SDRAMC_H #define AT91SAM9_SDRAMC_H
+#ifdef __ASSEMBLY__ + +#ifndef AT91_SDRAMC_BASE +#define AT91_SDRAMC_BASE AT91_SDRAMC0_BASE +#endif + +#define AT91_ASM_SDRAMC_MR AT91_SDRAMC_BASE +#define AT91_ASM_SDRAMC_TR (AT91_SDRAMC_BASE + 0x04) +#define AT91_ASM_SDRAMC_CR (AT91_SDRAMC_BASE + 0x08) +#define AT91_ASM_SDRAMC_MDR (AT91_SDRAMC_BASE + 0x24) + +#endif + /* SDRAM Controller (SDRAMC) registers */ #define AT91_SDRAMC_MR (AT91_SDRAMC + 0x00) /* SDRAM Controller Mode Register */ #define AT91_SDRAMC_MODE (0xf << 0) /* Command Mode */ diff --git a/include/asm-arm/arch-at91/at91sam9_smc.h b/include/asm-arm/arch-at91/at91sam9_smc.h index d64511b..8173c4e 100644 --- a/include/asm-arm/arch-at91/at91sam9_smc.h +++ b/include/asm-arm/arch-at91/at91sam9_smc.h @@ -16,6 +16,68 @@ #ifndef AT91SAM9_SMC_H #define AT91SAM9_SMC_H
+#ifdef __ASSEMBLY__ + +#ifndef AT91_SMC_BASE +#define AT91_SMC_BASE AT91_SMC0_BASE +#endif + +#define AT91_ASM_SMC_SETUP0 AT91_SMC_BASE +#define AT91_ASM_SMC_PULSE0 (AT91_SMC_BASE + 0x04) +#define AT91_ASM_SMC_CYCLE0 (AT91_SMC_BASE + 0x08) +#define AT91_ASM_SMC_MODE0 (AT91_SMC_BASE + 0x0C) + +#else + +typedef struct at91_cs { + u32 setup; /* 0x00 SMC Setup Register */ + u32 pulse; /* 0x04 SMC Pulse Register */ + u32 cycle; /* 0x08 SMC Cycle Register */ + u32 mode; /* 0x0C SMC Mode Register */ +} at91_cs_t; + +typedef struct at91_smc { + at91_cs_t cs[8]; +} at91_smc_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_SMC_SETUP_NWE(x) (x & 0x3f) +#define AT91_SMC_SETUP_NCS_WR(x) ((x & 0x3f) << 8) +#define AT91_SMC_SETUP_NRD(x) ((x & 0x3f) << 16) +#define AT91_SMC_SETUP_NCS_RD(x) ((x & 0x3f) << 24) + +#define AT91_SMC_PULSE_NWE(x) (x & 0x7f) +#define AT91_SMC_PULSE_NCS_WR(x) ((x & 0x7f) << 8) +#define AT91_SMC_PULSE_NRD(x) ((x & 0x7f) << 16) +#define AT91_SMC_PULSE_NCS_RD(x) ((x & 0x7f) << 24) + +#define AT91_SMC_CYCLE_NWE(x) (x & 0x1ff) +#define AT91_SMC_CYCLE_NRD(x) ((x & 0x1ff) << 16) + +#define AT91_SMC_MODE_RM_NCS 0x00000000 +#define AT91_SMC_MODE_RM_NRD 0x00000001 +#define AT91_SMC_MODE_WM_NCS 0x00000000 +#define AT91_SMC_MODE_WM_NWE 0x00000002 + +#define AT91_SMC_MODE_EXNW_DISABLE 0x00000000 +#define AT91_SMC_MODE_EXNW_FROZEN 0x00000020 +#define AT91_SMC_MODE_EXNW_READY 0x00000030 + +#define AT91_SMC_MODE_BAT 0x00000100 +#define AT91_SMC_MODE_DBW_8 0x00000000 +#define AT91_SMC_MODE_DBW_16 0x00001000 +#define AT91_SMC_MODE_DBW_32 0x00002000 +#define AT91_SMC_MODE_TDF_CYCLE(x) ((x & 0xf) << 16) +#define AT91_SMC_MODE_TDF 0x00100000 +#define AT91_SMC_MODE_PMEN 0x01000000 +#define AT91_SMC_MODE_PS_4 0x00000000 +#define AT91_SMC_MODE_PS_8 0x10000000 +#define AT91_SMC_MODE_PS_16 0x20000000 +#define AT91_SMC_MODE_PS_32 0x30000000 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_SMC_SETUP(n) (AT91_SMC + 0x00 + ((n)*0x10)) /* Setup Register for CS n */ #define AT91_SMC_NWESETUP (0x3f << 0) /* NWE Setup Length */ #define AT91_SMC_NWESETUP_(x) ((x) << 0) @@ -74,3 +136,4 @@ #endif
#endif +#endif diff --git a/include/asm-arm/arch-at91/at91sam9g45.h b/include/asm-arm/arch-at91/at91sam9g45.h index 0feed9c..78c0b16 100644 --- a/include/asm-arm/arch-at91/at91sam9g45.h +++ b/include/asm-arm/arch-at91/at91sam9g45.h @@ -51,6 +51,19 @@ #define AT91SAM9G45_ID_VDEC 30 /* Video Decoder */ #define AT91SAM9G45_ID_IRQ0 31 /* Advanced Interrupt Controller */
+#define AT91_EMAC_BASE 0xfffbc000 +#define AT91_SMC_BASE 0xffffe800 +#define AT91_MATRIX_BASE 0xffffea00 + +#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 + +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -114,6 +127,8 @@ #define AT91_USART2 AT91SAM9G45_BASE_US2 #define AT91_USART3 AT91SAM9G45_BASE_US3
+#endif + /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9rl.h b/include/asm-arm/arch-at91/at91sam9rl.h index 4dd8037..af0e434 100644 --- a/include/asm-arm/arch-at91/at91sam9rl.h +++ b/include/asm-arm/arch-at91/at91sam9rl.h @@ -44,6 +44,18 @@ #define AT91SAM9RL_ID_AC97C 24 /* AC97 Controller */ #define AT91SAM9RL_ID_IRQ0 31 /* Advanced Interrupt Controller (IRQ0) */
/* * User Peripheral physical base addresses. @@ -68,7 +80,6 @@ #define AT91SAM9RL_BASE_AC97C 0xfffd8000 #define AT91_BASE_SYS 0xffffc000
- /* * System Peripherals (offset from AT91_BASE_SYS) */ @@ -99,6 +110,7 @@ #define AT91_USART2 AT91SAM9RL_BASE_US2 #define AT91_USART3 AT91SAM9RL_BASE_US3
/* * Internal Memory. diff --git a/include/asm-arm/arch-at91/gpio.h b/include/asm-arm/arch-at91/gpio.h index e2d375b..bc53171 100644 --- a/include/asm-arm/arch-at91/gpio.h +++ b/include/asm-arm/arch-at91/gpio.h @@ -18,6 +18,8 @@ #include <asm/arch/at91_pio.h> #include <asm/arch/hardware.h>
+#ifdef CONFIG_AT91_LEGACY + #define PIN_BASE 32
#define MAX_GPIO_BANKS 5 @@ -365,3 +367,4 @@ static inline int at91_get_gpio_value(unsigned pin) }
#endif +#endif diff --git a/include/asm-arm/arch-at91/io.h b/include/asm-arm/arch-at91/io.h index f09b2df..38d185e 100644 --- a/include/asm-arm/arch-at91/io.h +++ b/include/asm-arm/arch-at91/io.h @@ -23,6 +23,8 @@
#include <asm/io.h>
+#ifdef CONFIG_AT91_LEGACY + static inline unsigned int at91_sys_read(unsigned int reg_offset) { void *addr = (void *)AT91_BASE_SYS; @@ -36,5 +38,6 @@ static inline void at91_sys_write(unsigned int reg_offset, unsigned long value)
__raw_writel(value, addr + reg_offset); } +#endif
#endif
Jens Scharsig wrote:
- add's c structures for SoC access to pheriperials head files
- add's missing pheriperials head files (new SoC)
I was expecting this patch to convert existing #define's to c struct's I was not expecting it to add new features. The features should be broken out into their own patch. Specifically at91_matrix
These are significant enough changes that you should append a copyright to them.
This looks like a new feature that needs its own patch
- Memory Setup stuff - taken from blob memsetup.S
This is also used in at91_pdc.h Multiple files in the next patches use it as well. Please review the above reference to memsetup.S
- Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de)
- project.
- MA 02111-1307 USA
- u32 a;
- u32 b;
+} at91_prority_t;
- u32 mcfg[AT91_MATRIX_MASTERS];
- u32 scfg[AT91_MATRIX_SLAVES];
- u32 res61_1[3];
- u32 tcr;
- u32 res61_2[2];
- u32 csa;
- u32 pucr;
- u32 res61_3[114];
- u32 reserve1[16 - AT91_MATRIX_MASTERS];
This #if () construct is awkward. From above it does ot look like either the AT91_MATRIX_MASTER or AT91_MATRIX_SLAVE is ever >= 16. These should be reduced
The board specific element names are also awkward. Please try to reduce this.
Maybe have seperate headers per board? This is the way the kernel does it.
- u32 reserve2[16 - AT91_MATRIX_SLAVES];
- at91_prority_t pr[AT91_MATRIX_SLAVES];
- u32 reserve3[32 - (2 * AT91_MATRIX_SLAVES)];
- u32 mrcr; /* 0x100 Master Remap Control */
- u32 reserve4[3];
- u32 ccr[52] /* 0x110 - 0x1E0 Chip Configuration */
- u32 womr; /* 0x1E4 Write Protect Mode */
- u32 wpsr; /* 0x1E8 Write Protect Status */
- u32 resg45_1[10];
- u32 res60_1[3];
- u32 csa;
- u32 res60_2[56];
- u32 res63_1;
- u32 tcmr;
- u32 res63_2[2];
- u32 csa[2];
- u32 res63_3[54];
+#else
- u32 reserve5[60];
memsetup.S
- project.
- MA 02111-1307 USA
- u32 rpr; /* 0x100 Receive Pointer Register */
- u32 rcr; /* 0x104 Receive Counter Register */
- u32 tpr; /* 0x108 Transmit Pointer Register */
- u32 tcr; /* 0x10C Transmit Counter Register */
- u32 pnpr; /* 0x110 Receive Next Pointer Register */
- u32 pncr; /* 0x114 Receive Next Counter Register */
- u32 tnpr; /* 0x118 Transmit Next Pointer Register */
- u32 tncr; /* 0x11C Transmit Next Counter Register */
- u32 ptcr; /* 0x120 Transfer Control Register */
- u32 ptsr; /* 0x124 Transfer Status Register */
+} at91_pdc_t;
This is only used by at91_spi.h's c structure. It seems like these elements should just be appended to the at91_spi_t Please move them.
- (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x04)
- (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x60)
- (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x04)
- (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x60)
- (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x70)
+#else
- u32 per; /* 0x00 PIO Enable Register */
- u32 pdr; /* 0x04 PIO Disable Register */
- u32 psr; /* 0x08 PIO Status Register */
- u32 reserved0;
- u32 oer; /* 0x10 Output Enable Register */
- u32 odr; /* 0x14 Output Disable Registerr */
- u32 osr; /* 0x18 Output Status Register */
- u32 reserved1;
- u32 ifer; /* 0x20 Input Filter Enable Register */
- u32 ifdr; /* 0x24 Input Filter Disable Register */
- u32 ifsr; /* 0x28 Input Filter Status Register */
- u32 reserved2;
- u32 sodr; /* 0x30 Set Output Data Register */
- u32 codr; /* 0x34 Clear Output Data Register */
- u32 odsr; /* 0x38 Output Data Status Register */
- u32 pdsr; /* 0x3C Pin Data Status Register */
- u32 ier; /* 0x40 Interrupt Enable Register */
- u32 idr; /* 0x44 Interrupt Disable Register */
- u32 imr; /* 0x48 Interrupt Mask Register */
- u32 isr; /* 0x4C Interrupt Status Register */
- u32 mder; /* 0x50 Multi-driver Enable Register */
- u32 mddr; /* 0x54 Multi-driver Disable Register */
- u32 mdsr; /* 0x58 Multi-driver Status Register */
- u32 reserved3;
- u32 pudr; /* 0x60 Pull-up Disable Register */
- u32 puer; /* 0x64 Pull-up Enable Register */
- u32 pusr; /* 0x68 Pad Pull-up Status Register */
- u32 reserved4;
- u32 asr; /* 0x70 Select A Register */
- u32 bsr; /* 0x74 Select B Register */
- u32 absr; /* 0x78 AB Select Status Register */
- u32 reserved5[9]; /* */
- u32 ower; /* 0xA0 Output Write Enable Register */
- u32 owdr; /* 0xA4 Output Write Disable Register */
- u32 owsr; /* OxA8 utput Write Status Register */
- u32 reserved6[85];
+} at91_port_t;
It would be better if the '4' case was an explicit list of boards like 3 & 5 and the #else case was #error "Error unsupported AT91_PIO_PORTS" or something like this.
- struct {
at91_port_t pioa;
at91_port_t piob;
at91_port_t pioc;
- #if (AT91_PIO_PORTS > 3)
at91_port_t piod;
- #endif
- #if (AT91_PIO_PORTS > 4)
at91_port_t pioe;
- #endif
- at91_port_t port[AT91_PIO_PORTS];
+} at91_pio_t;
this could be moved to gpio patch.
Is this necessary? You are packing arguments that you are passing to the gpio functions. It would be better if there were seperate port, pin parameters than combining and then uncombining. Please change this.
- u32 mr; /* 0x00 Mode Register */
- u32 sr; /* 0x04 Status Register */
- u32 pivr; /* 0x08 Periodic Interval Value Register */
- u32 piir; /* 0x0C Periodic Interval Image Register */
+} at91_pit_t;
These are already defined in the legacy case Pull the legacy ones into the common part of the file
Where are these used ? Remove if unused.
These could always be defined and the #else turned into #ifndef __ASSEMBLY__
+#else
- u32 scer; /* 0x00 System Clock Enable Register */
- u32 scdr; /* 0x04 System Clock Disable Register */
- u32 scsr; /* 0x08 System Clock Status Register */
- u32 reserved0;
- u32 pcer; /* 0x10 Peripheral Clock Enable Register */
- u32 pcdr; /* 0x14 Peripheral Clock Disable Register */
- u32 pcsr; /* 0x18 Peripheral Clock Status Register */
- u32 reserved1;
- u32 mor; /* 0x20 Main Oscilator Register */
- u32 mcfr; /* 0x24 Main Clock Frequency Register */
- u32 pllar; /* 0x28 PLL A Register */
- u32 pllbr; /* 0x2C PLL B Register */
ws above 2 lines have extra space after 'u32 '
- u32 mckr; /* 0x30 Master Clock Register */
- u32 reserved2[3];
- u32 pck[4]; /* 0x40 Programmable Clock Register 0 - 3 */
- u32 reserved3[4];
- u32 ier; /* 0x60 Interrupt Enable Register */
- u32 idr; /* 0x64 Interrupt Disable Register */
- u32 sr; /* 0x68 Status Register */
- u32 imr; /* 0x6C Interrupt Mask Register */
- u32 reserved4[4];
- u32 pllicpr; /* 0x80 Change Pump Current Register */
+#else
- u32 reserved5;
board specific elements is awkward. Please combine these element names Similar below.
- u32 reserved6[21];
- u32 wpmr; /* 0xE4 Write Protect Mode Register */
- u32 wpsr; /* 0xE8 Write Protect Status Register */
+#else
- u32 reserved7[2];
- u32 reserved8[5];
+} at91_pmc_t;
Change mixed case in macro to all upper. Also make sure macros are not already defined in legacy
@@ -117,4 +216,5 @@
Similar as above this define should be common and the #else -> #ifndef __ASSEMBLY__
- u32 cr; /* Reset Controller Control Register */
- u32 sr; /* Reset Controller Status Register */
- u32 mr; /* Reset Controller Mode Register */
+} at91_rstc_t;
- u32 cr; /* 0x00 Control Register */
- u32 mr; /* 0x04 Mode Register */
- u32 rdr; /* 0x08 Receive Data Register */
- u32 tdr; /* 0x0C Transmit Data Register */
- u32 sr; /* 0x10 Status Register */
- u32 ier; /* 0x14 Interrupt Enable Register */
- u32 idr; /* 0x18 Interrupt Disable Register */
- u32 imr; /* 0x1C Interrupt Mask Register */
- u32 reserve1[4];
- u32 csr[4]; /* 0x30 Chip Select Register 0-3 */
- u32 reserve2[48];
- at91_pdc_t pdc;
see above note wrt pdc
+} at91_spi_t;
+#else
- u32 cr;
- u32 mr;
- u32 sr;
+} at91_wdt_t;
Remove extra space Other similar extra space below
- User Peripheral physical base addresses.
- Internal Memory.
- Internal Memory.
- System Peripherals (offset from AT91_BASE_SYS)
- Internal Memory.
- Internal Memory.
ws extra space after 'AT91_SMC_BASE '
Tom
.... This looks like a new feature that needs its own patch
The at91_matrix holds c stuctures for all derivates together, so i put the code in the new file.
I will be fix this copy and paste problems
OK, we can remove the #if. AT91_MATRIX_MASTER and AT91_MATRIX_SLAVE can only have an invalid value, if defines above are wrong.
You're right, but we have many files with the same function. What file names will have the file name, when several soc are supported (e.g SAM9260 and 9G20 use the same matrix hw)?
To get better readable Code, we can do following:
#if defined(CONFIG_AT91SAM...1) || defined(CONFIG_AT91SAM...1) typedef struct at91_matrix { ... } at91_matrix_t; #elseif defined(CONFIG_AT91SAM...1) typedef struct at91_matrix { ... } at91_matrix_t; #else #error #error CPU not supported. Please update at91_matrix.h #endif
and we can also remove the AT91_MATRIX_MASTER and AT91_MATRIX_SLAVE defines
+} at91_pdc_t;
PDC is the peripherial DMA controller. Currently only SPI use in SPI Thats right, but some other peripherials (currently not needed in u-boot) needs it to (eg. AC91 controller, SCC ...).
Will be add
Is this necessary?
I think, yes.
Serveral drivers (e.g nand and I2C) uses this packed pins for arguments.
OK
Curently, nowhere
Remove if unused.
It's defined only to complete mr register flags.
OK
+#else
- u32 reserved5;
+#else
- u32 reserved7[2];
Do you think we should define registers, even if they are only used by a particular cpu type?
OK
regards Jens
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- include/asm-arm/arch-at91/at91_matrix.h | 116 +++++++++++++++++++++++++++ include/asm-arm/arch-at91/at91_pdc.h | 39 +++++++++ include/asm-arm/arch-at91/at91_pio.h | 97 ++++++++++++++++++++++ include/asm-arm/arch-at91/at91_pit.h | 15 ++++ include/asm-arm/arch-at91/at91_pmc.h | 91 +++++++++++++++++++++ include/asm-arm/arch-at91/at91_rstc.h | 30 +++++++- include/asm-arm/arch-at91/at91_spi.h | 21 +++++ include/asm-arm/arch-at91/at91_wdt.h | 29 +++++++ include/asm-arm/arch-at91/at91cap9.h | 8 ++ include/asm-arm/arch-at91/at91sam9260.h | 14 +++ include/asm-arm/arch-at91/at91sam9261.h | 12 +++- include/asm-arm/arch-at91/at91sam9263.h | 20 +++++ include/asm-arm/arch-at91/at91sam9_sdramc.h | 13 +++ include/asm-arm/arch-at91/at91sam9_smc.h | 63 +++++++++++++++ include/asm-arm/arch-at91/at91sam9g45.h | 13 +++ include/asm-arm/arch-at91/at91sam9rl.h | 12 +++- include/asm-arm/arch-at91/gpio.h | 3 + include/asm-arm/arch-at91/io.h | 3 + 18 files changed, 596 insertions(+), 3 deletions(-) create mode 100644 include/asm-arm/arch-at91/at91_matrix.h create mode 100644 include/asm-arm/arch-at91/at91_pdc.h
diff --git a/include/asm-arm/arch-at91/at91_matrix.h b/include/asm-arm/arch-at91/at91_matrix.h new file mode 100644 index 0000000..9b3c110 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_matrix.h @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_MATRIX_H +#define AT91_MATRIX_H + +#ifdef __ASSEMBLY__ + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x11C) +#elif defined(CONFIG_AT91SAM9261) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x30) +#elif defined(CONFIG_AT91SAM9263) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x120) +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x128) +#else +#error AT91_ASM_MATRIX_CSA0 is not definied for current CPU +#endif + +#define AT91_ASM_MATRIX_MCFG AT91_MATRIX_BASE + +#else +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_MATRIX_MASTERS 6 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9261) +#define AT91_MATRIX_MASTERS 1 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9263) +#define AT91_MATRIX_MASTERS 9 +#define AT91_MATRIX_SLAVES 7 +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_MATRIX_MASTERS 11 +#define AT91_MATRIX_SLAVES 8 +#else +#error CPU not supported. Please update at91_matrix.h +#endif + +typedef struct at91_priority { + u32 a; + u32 b; +} at91_priority_t; + +typedef struct at91_matrix { + u32 mcfg[AT91_MATRIX_MASTERS]; +#if defined(CONFIG_AT91SAM9261) + u32 scfg[AT91_MATRIX_SLAVES]; + u32 res61_1[3]; + u32 tcr; + u32 res61_2[2]; + u32 csa; + u32 pucr; + u32 res61_3[114]; +#else + u32 reserve1[16 - AT91_MATRIX_MASTERS]; + u32 scfg[AT91_MATRIX_SLAVES]; + u32 reserve2[16 - AT91_MATRIX_SLAVES]; + at91_priority_t pr[AT91_MATRIX_SLAVES]; + u32 reserve3[32 - (2 * AT91_MATRIX_SLAVES)]; + u32 mrcr; /* 0x100 Master Remap Control */ + u32 reserve4[3]; +#if defined(CONFIG_AT91SAM9G45) + u32 ccr[52] /* 0x110 - 0x1E0 Chip Configuration */ + u32 womr; /* 0x1E4 Write Protect Mode */ + u32 wpsr; /* 0x1E8 Write Protect Status */ + u32 resg45_1[10]; +#elif defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) + u32 res60_1[3]; + u32 csa; + u32 res60_2[56]; +#elif defined(CONFIG_AT91SAM9263) + u32 res63_1; + u32 tcmr; + u32 res63_2[2]; + u32 csa[2]; + u32 res63_3[54]; +#else + u32 reserve5[60]; +#endif +#endif +} at91_matrix_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_MATRIX_CSA_DBPUC 0x00000100 +#define AT91_MATRIX_CSA_VDDIOMSEL_1_8V 0x00000000 +#define AT91_MATRIX_CSA_VDDIOMSEL_3_3V 0x00010000 + +#define AT91_MATRIX_CSA_EBI_CS1A 0x00000002 +#define AT91_MATRIX_CSA_EBI_CS3A 0x00000008 +#define AT91_MATRIX_CSA_EBI_CS4A 0x00000010 +#define AT91_MATRIX_CSA_EBI_CS5A 0x00000020 + +#define AT91_MATRIX_CSA_EBI1_CS2A 0x00000008 + +#endif diff --git a/include/asm-arm/arch-at91/at91_pdc.h b/include/asm-arm/arch-at91/at91_pdc.h new file mode 100644 index 0000000..42f87ca --- /dev/null +++ b/include/asm-arm/arch-at91/at91_pdc.h @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_PDC_H +#define AT91_PDC_H + +typedef struct at91_pdc { + u32 rpr; /* 0x100 Receive Pointer Register */ + u32 rcr; /* 0x104 Receive Counter Register */ + u32 tpr; /* 0x108 Transmit Pointer Register */ + u32 tcr; /* 0x10C Transmit Counter Register */ + u32 pnpr; /* 0x110 Receive Next Pointer Register */ + u32 pncr; /* 0x114 Receive Next Counter Register */ + u32 tnpr; /* 0x118 Transmit Next Pointer Register */ + u32 tncr; /* 0x11C Transmit Next Counter Register */ + u32 ptcr; /* 0x120 Transfer Control Register */ + u32 ptsr; /* 0x124 Transfer Status Register */ +} at91_pdc_t; + +#endif diff --git a/include/asm-arm/arch-at91/at91_pio.h b/include/asm-arm/arch-at91/at91_pio.h index f6ce1f9..92c3717 100644 --- a/include/asm-arm/arch-at91/at91_pio.h +++ b/include/asm-arm/arch-at91/at91_pio.h @@ -3,6 +3,7 @@ * * Copyright (C) 2005 Ivan Kokshaysky * Copyright (C) SAN People + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) * * Parallel I/O Controller (PIO) - System peripherals registers. * Based on AT91RM9200 datasheet revision E. @@ -16,6 +17,101 @@ #ifndef AT91_PIO_H #define AT91_PIO_H
+ +#define AT91_ASM_PIO_RANGE 0x200 +#define AT91_ASM_PIOC_PDR \ + (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x04) +#define AT91_ASM_PIOC_PUDR \ + (AT91_PIO_BASE + AT91_PIO_PORTC*AT91_ASM_PIO_RANGE + 0x60) + +#define AT91_ASM_PIOD_PDR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x04) +#define AT91_ASM_PIOD_PUDR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x60) +#define AT91_ASM_PIOD_ASR \ + (AT91_PIO_BASE + AT91_PIO_PORTD*AT91_ASM_PIO_RANGE + 0x70) + +#ifndef __ASSEMBLY__ + +typedef struct at91_port { + u32 per; /* 0x00 PIO Enable Register */ + u32 pdr; /* 0x04 PIO Disable Register */ + u32 psr; /* 0x08 PIO Status Register */ + u32 reserved0; + u32 oer; /* 0x10 Output Enable Register */ + u32 odr; /* 0x14 Output Disable Registerr */ + u32 osr; /* 0x18 Output Status Register */ + u32 reserved1; + u32 ifer; /* 0x20 Input Filter Enable Register */ + u32 ifdr; /* 0x24 Input Filter Disable Register */ + u32 ifsr; /* 0x28 Input Filter Status Register */ + u32 reserved2; + u32 sodr; /* 0x30 Set Output Data Register */ + u32 codr; /* 0x34 Clear Output Data Register */ + u32 odsr; /* 0x38 Output Data Status Register */ + u32 pdsr; /* 0x3C Pin Data Status Register */ + u32 ier; /* 0x40 Interrupt Enable Register */ + u32 idr; /* 0x44 Interrupt Disable Register */ + u32 imr; /* 0x48 Interrupt Mask Register */ + u32 isr; /* 0x4C Interrupt Status Register */ + u32 mder; /* 0x50 Multi-driver Enable Register */ + u32 mddr; /* 0x54 Multi-driver Disable Register */ + u32 mdsr; /* 0x58 Multi-driver Status Register */ + u32 reserved3; + u32 pudr; /* 0x60 Pull-up Disable Register */ + u32 puer; /* 0x64 Pull-up Enable Register */ + u32 pusr; /* 0x68 Pad Pull-up Status Register */ + u32 reserved4; + u32 asr; /* 0x70 Select A Register */ + u32 bsr; /* 0x74 Select B Register */ + u32 absr; /* 0x78 AB Select Status Register */ + u32 reserved5[9]; /* */ + u32 ower; /* 0xA0 Output Write Enable Register */ + u32 owdr; /* 0xA4 Output Write Disable Register */ + u32 owsr; /* OxA8 utput Write Status Register */ + u32 reserved6[85]; +} at91_port_t; + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) || \ + defined(CONFIG_AT91SAM9G10) || defined(CONFIG_AT91SAM9G20) +#define AT91_PIO_PORTS 3 +#elif defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G45) || \ + defined(CONFIG_AT91SAM9M10G45) +#define AT91_PIO_PORTS 5 +#elif defined(CONFIG_AT91RM9200) || defined(CONFIG_AT91CAP9) || \ + defined(CONFIG_AT91SAM9RL) +#define AT91_PIO_PORTS 4 +#else +#error "Unsupported cpu. Please update at91_pio.h" +#endif + +typedef union at91_pio { + struct { + at91_port_t pioa; + at91_port_t piob; + at91_port_t pioc; + #if (AT91_PIO_PORTS > 3) + at91_port_t piod; + #endif + #if (AT91_PIO_PORTS > 4) + at91_port_t pioe; + #endif + } ; + at91_port_t port[AT91_PIO_PORTS]; +} at91_pio_t; + +#endif + +#define AT91_PIN_TO_MASK(x) (1<<x) +#define AT91_PORTPIN(PORT, PIN) ((0x0##PORT - 9) * 32 + ((PIN) & 0x1F)) +#define AT91_PIO_PORTA 0x0 +#define AT91_PIO_PORTB 0x1 +#define AT91_PIO_PORTC 0x2 +#define AT91_PIO_PORTD 0x3 +#define AT91_PIO_PORTE 0x4 + +#ifdef CONFIG_AT91_LEGACY + #define PIO_PER 0x00 /* Enable Register */ #define PIO_PDR 0x04 /* Disable Register */ #define PIO_PSR 0x08 /* Status Register */ @@ -45,5 +141,6 @@ #define PIO_OWER 0xa0 /* Output Write Enable Register */ #define PIO_OWDR 0xa4 /* Output Write Disable Register */ #define PIO_OWSR 0xa8 /* Output Write Status Register */ +#endif
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91_pmc.h b/include/asm-arm/arch-at91/at91_pmc.h index 9fe94c7..369b5d7 100644 --- a/include/asm-arm/arch-at91/at91_pmc.h +++ b/include/asm-arm/arch-at91/at91_pmc.h @@ -3,6 +3,7 @@ * * Copyright (C) 2005 Ivan Kokshaysky * Copyright (C) SAN People + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) * * Power Management Controller (PMC) - System peripherals registers. * Based on AT91RM9200 datasheet revision E. @@ -16,6 +17,95 @@ #ifndef AT91_PMC_H #define AT91_PMC_H
+#define AT91_ASM_PMC_MOR (AT91_PMC_BASE + 0x20) +#define AT91_ASM_PMC_PLLAR (AT91_PMC_BASE + 0x28) +#define AT91_ASM_PMC_PLLBR (AT91_PMC_BASE + 0x2c) +#define AT91_ASM_PMC_MCKR (AT91_PMC_BASE + 0x30) +#define AT91_ASM_PMC_SR (AT91_PMC_BASE + 0x68) + +#ifndef __ASSEMBLY__ + +#include <asm/types.h> + +typedef struct at91_pmc { + u32 scer; /* 0x00 System Clock Enable Register */ + u32 scdr; /* 0x04 System Clock Disable Register */ + u32 scsr; /* 0x08 System Clock Status Register */ + u32 reserved0; + u32 pcer; /* 0x10 Peripheral Clock Enable Register */ + u32 pcdr; /* 0x14 Peripheral Clock Disable Register */ + u32 pcsr; /* 0x18 Peripheral Clock Status Register */ + u32 reserved1; + u32 mor; /* 0x20 Main Oscilator Register */ + u32 mcfr; /* 0x24 Main Clock Frequency Register */ + u32 pllar; /* 0x28 PLL A Register */ + u32 pllbr; /* 0x2C PLL B Register */ + u32 mckr; /* 0x30 Master Clock Register */ + u32 reserved2[3]; + u32 pck[4]; /* 0x40 Programmable Clock Register 0 - 3 */ + u32 reserved3[4]; + u32 ier; /* 0x60 Interrupt Enable Register */ + u32 idr; /* 0x64 Interrupt Disable Register */ + u32 sr; /* 0x68 Status Register */ + u32 imr; /* 0x6C Interrupt Mask Register */ + u32 reserved4[4]; + u32 pllicpr; /* 0x80 Change Pump Current Register (SAM9) */ + u32 reserved5[21]; + u32 wpmr; /* 0xE4 Write Protect Mode Register (CAP0) */ + u32 wpsr; /* 0xE8 Write Protect Status Register (CAP0) */ + u32 reserved8[5]; +} at91_pmc_t; + +#endif /* end not assembly */ + +#define AT91_PMC_MOR_MOSCEN 0x01 +#define AT91_PMC_MOR_OSCBYPASS 0x02 +#define AT91_PMC_MOR_OSCOUNT(x) ((x & 0xff) << 8) + +#define AT91_PMC_PLLXR_DIV(x) (x & 0xFF) +#define AT91_PMC_PLLXR_PLLCOUNT(x) ((x & 0x3F) << 8) +#define AT91_PMC_PLLXR_OUT(x) ((x & 0x03) << 14) +#define AT91_PMC_PLLXR_MUL(x) ((x & 0x7FF) << 16) +#define AT91_PMC_PLLAR_29 0x20000000 +#define AT91_PMC_PLLBR_USBDIV_1 0x00000000 +#define AT91_PMC_PLLBR_USBDIV_2 0x10000000 +#define AT91_PMC_PLLBR_USBDIV_4 0x20000000 + +#define AT91_PMC_MCKR_CSS_SLOW 0x00000000 +#define AT91_PMC_MCKR_CSS_MAIN 0x00000001 +#define AT91_PMC_MCKR_CSS_PLLA 0x00000002 +#define AT91_PMC_MCKR_CSS_PLLB 0x00000003 +#define AT91_PMC_MCKR_CSS_MASK 0x00000003 + +#define AT91_PMC_MCKR_PRES_1 0x00000000 +#define AT91_PMC_MCKR_PRES_2 0x00000004 +#define AT91_PMC_MCKR_PRES_4 0x00000008 +#define AT91_PMC_MCKR_PRES_8 0x0000000C +#define AT91_PMC_MCKR_PRES_16 0x00000010 +#define AT91_PMC_MCKR_PRES_32 0x00000014 +#define AT91_PMC_MCKR_PRES_64 0x00000018 +#define AT91_PMC_MCKR_PRES_MASK 0x0000001C + +#define AT91_PMC_MCKR_MDIV_1 0x00000000 +#define AT91_PMC_MCKR_MDIV_2 0x00000100 +#define AT91_PMC_MCKR_MDIV_4 0x00000200 +#define AT91_PMC_MCKR_MDIV_MASK 0x00000300 + +#define AT91_PMC_MCKR_PLLADIV_1 0x00001000 +#define AT91_PMC_MCKR_PLLADIV_2 0x00002000 + +#define AT91_PMC_IXR_MOSCS 0x00000001 +#define AT91_PMC_IXR_LOCKA 0x00000002 +#define AT91_PMC_IXR_LOCKB 0x00000004 +#define AT91_PMC_IXR_MCKRDY 0x00000008 +#define AT91_PMC_IXR_LOCKU 0x00000040 +#define AT91_PMC_IXR_PCKRDY0 0x00000100 +#define AT91_PMC_IXR_PCKRDY1 0x00000200 +#define AT91_PMC_IXR_PCKRDY2 0x00000400 +#define AT91_PMC_IXR_PCKRDY3 0x00000800 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_PMC_SCER (AT91_PMC + 0x00) /* System Clock Enable Register */ #define AT91_PMC_SCDR (AT91_PMC + 0x04) /* System Clock Disable Register */
@@ -117,4 +207,5 @@
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91_rstc.h b/include/asm-arm/arch-at91/at91_rstc.h index e49caef..9ff2c5b 100644 --- a/include/asm-arm/arch-at91/at91_rstc.h +++ b/include/asm-arm/arch-at91/at91_rstc.h @@ -16,11 +16,37 @@ #ifndef AT91_RSTC_H #define AT91_RSTC_H
+#define AT91_ASM_RSTC_MR (AT91_RSTC_BASE + 0x08) + +#ifndef __ASSEMBLY__ + +typedef struct at91_rstc { + u32 cr; /* Reset Controller Control Register */ + u32 sr; /* Reset Controller Status Register */ + u32 mr; /* Reset Controller Mode Register */ +} at91_rstc_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_RSTC_KEY 0xA5000000 + +#define AT91_RSTC_CR_PROCRST 0x00000001 +#define AT91_RSTC_CR_PERRST 0x00000004 +#define AT91_RSTC_CR_EXTRST 0x00000008 + +#define AT91_RSTC_MR_URSTEN 0x00000001 +#define AT91_RSTC_MR_URSTIEN 0x00000010 +#define AT91_RSTC_MR_ERSTL(x) ((x & 0xf) << 8) +#define AT91_RSTC_MR_ERSTL_MASK 0x0000FF00 + +#define AT91_RSTC_SR_NRSTL 0x00010000 + +#ifdef CONFIG_AT91_LEGACY + #define AT91_RSTC_CR (AT91_RSTC + 0x00) /* Reset Controller Control Register */ #define AT91_RSTC_PROCRST (1 << 0) /* Processor Reset */ #define AT91_RSTC_PERRST (1 << 2) /* Peripheral Reset */ #define AT91_RSTC_EXTRST (1 << 3) /* External Reset */ -#define AT91_RSTC_KEY (0xa5 << 24) /* KEY Password */
+#endif /* CONFIG_AT91_LEGACY */ #endif diff --git a/include/asm-arm/arch-at91/at91cap9.h b/include/asm-arm/arch-at91/at91cap9.h index b128ac5..658124b 100644 --- a/include/asm-arm/arch-at91/at91cap9.h +++ b/include/asm-arm/arch-at91/at91cap9.h @@ -53,6 +53,13 @@ #define AT91CAP9_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ #define AT91CAP9_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */
+#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 +#define AT91_PIT_BASE 0xfffffd30 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -119,6 +126,7 @@ #define AT91CAP9_SCKCR_OSCSEL_RC (0 << 3) #define AT91CAP9_SCKCR_OSCSEL_32 (1 << 3)
+#endif /* CONFIG_AT91_LEGACY */ /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9260.h b/include/asm-arm/arch-at91/at91sam9260.h index 73975f4..7ca6078 100644 --- a/include/asm-arm/arch-at91/at91sam9260.h +++ b/include/asm-arm/arch-at91/at91sam9260.h @@ -49,6 +49,18 @@ #define AT91SAM9260_ID_IRQ1 30 /* Advanced Interrupt Controller (IRQ1) */ #define AT91SAM9260_ID_IRQ2 31 /* Advanced Interrupt Controller (IRQ2) */
+#define AT91_EMAC_BASE 0xfffc4000 +#define AT91_SDRAMC_BASE 0xffffea00 +#define AT91_SMC_BASE 0xffffec00 +#define AT91_MATRIX_BASE 0xffffee00 +#define AT91_PIO_BASE 0xfffff400 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -105,6 +117,8 @@ #define AT91_USART4 AT91SAM9260_BASE_US4 #define AT91_USART5 AT91SAM9260_BASE_US5
+#endif /* CONFIG_AT91_LEGACY */ + /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9261.h b/include/asm-arm/arch-at91/at91sam9261.h index b303e07..1d8cab6 100644 --- a/include/asm-arm/arch-at91/at91sam9261.h +++ b/include/asm-arm/arch-at91/at91sam9261.h @@ -43,6 +43,16 @@ #define AT91SAM9261_ID_IRQ1 30 /* Advanced Interrupt Controller (IRQ1) */ #define AT91SAM9261_ID_IRQ2 31 /* Advanced Interrupt Controller (IRQ2) */
/* * User Peripheral physical base addresses. @@ -64,7 +74,6 @@ #define AT91SAM9261_BASE_SPI1 0xfffcc000 #define AT91_BASE_SYS 0xffffea00
- /* * System Peripherals (offset from AT91_BASE_SYS) */ @@ -88,6 +97,7 @@ #define AT91_USART1 AT91SAM9261_BASE_US1 #define AT91_USART2 AT91SAM9261_BASE_US2
/* * Internal Memory. diff --git a/include/asm-arm/arch-at91/at91sam9263.h b/include/asm-arm/arch-at91/at91sam9263.h index 966a683..b26b7b4 100644 --- a/include/asm-arm/arch-at91/at91sam9263.h +++ b/include/asm-arm/arch-at91/at91sam9263.h @@ -47,6 +47,24 @@ #define AT91SAM9263_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ #define AT91SAM9263_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */
+#define AT91_EMAC_BASE 0xfffbc000 +#define AT91_ECC0_BASE 0xffffe000 +#define AT91_SDRAMC0_BASE 0xffffe200 +#define AT91_SMC0_BASE 0xffffe400 +#define AT91_ECC1_BASE 0xffffe600 +#define AT91_SDRAMC1_BASE 0xffffe800 +#define AT91_SMC1_BASE 0xffffea00 +#define AT91_MATRIX_BASE 0xffffec00 +#define AT91_CCFG_BASE 0xffffed10 +#define AT91_DBGU_BASE 0xffffee00 +#define AT91_AIC_BASE 0xfffff000 +#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY
/* * User Peripheral physical base addresses. @@ -108,6 +126,8 @@ #define AT91_SMC AT91_SMC0 #define AT91_SDRAMC AT91_SDRAMC0
+#ifdef __ASSEMBLY__ + +#ifndef AT91_SDRAMC_BASE +#define AT91_SDRAMC_BASE AT91_SDRAMC0_BASE +#endif + +#define AT91_ASM_SDRAMC_MR AT91_SDRAMC_BASE +#define AT91_ASM_SDRAMC_TR (AT91_SDRAMC_BASE + 0x04) +#define AT91_ASM_SDRAMC_CR (AT91_SDRAMC_BASE + 0x08) +#define AT91_ASM_SDRAMC_MDR (AT91_SDRAMC_BASE + 0x24) + +#endif + /* SDRAM Controller (SDRAMC) registers */ #define AT91_SDRAMC_MR (AT91_SDRAMC + 0x00) /* SDRAM Controller Mode Register */ #define AT91_SDRAMC_MODE (0xf << 0) /* Command Mode */ diff --git a/include/asm-arm/arch-at91/at91sam9_smc.h b/include/asm-arm/arch-at91/at91sam9_smc.h index d64511b..d180c8a 100644 --- a/include/asm-arm/arch-at91/at91sam9_smc.h +++ b/include/asm-arm/arch-at91/at91sam9_smc.h @@ -16,6 +16,68 @@ #ifndef AT91SAM9_SMC_H #define AT91SAM9_SMC_H
#endif +#endif diff --git a/include/asm-arm/arch-at91/at91sam9g45.h b/include/asm-arm/arch-at91/at91sam9g45.h index 0feed9c..99c03f7 100644 --- a/include/asm-arm/arch-at91/at91sam9g45.h +++ b/include/asm-arm/arch-at91/at91sam9g45.h @@ -51,6 +51,17 @@ #define AT91SAM9G45_ID_VDEC 30 /* Video Decoder */ #define AT91SAM9G45_ID_IRQ0 31 /* Advanced Interrupt Controller */
+#define AT91_EMAC_BASE 0xfffbc000 +#define AT91_SMC_BASE 0xffffe800 +#define AT91_MATRIX_BASE 0xffffea00 +#define AT91_PIO_BASE 0xfffff200 +#define AT91_PMC_BASE 0xfffffc00 +#define AT91_RSTC_BASE 0xfffffd00 +#define AT91_PIT_BASE 0xfffffd30 +#define AT91_WDT_BASE 0xfffffd40 + +#ifdef CONFIG_AT91_LEGACY + /* * User Peripheral physical base addresses. */ @@ -114,6 +125,8 @@ #define AT91_USART2 AT91SAM9G45_BASE_US2 #define AT91_USART3 AT91SAM9G45_BASE_US3
+#endif + /* * Internal Memory. */ diff --git a/include/asm-arm/arch-at91/at91sam9rl.h b/include/asm-arm/arch-at91/at91sam9rl.h index 4dd8037..12054f6 100644 --- a/include/asm-arm/arch-at91/at91sam9rl.h +++ b/include/asm-arm/arch-at91/at91sam9rl.h @@ -44,6 +44,16 @@ #define AT91SAM9RL_ID_AC97C 24 /* AC97 Controller */ #define AT91SAM9RL_ID_IRQ0 31 /* Advanced Interrupt Controller (IRQ0) */
/* * User Peripheral physical base addresses. @@ -68,7 +78,6 @@ #define AT91SAM9RL_BASE_AC97C 0xfffd8000 #define AT91_BASE_SYS 0xffffc000
- /* * System Peripherals (offset from AT91_BASE_SYS) */ @@ -99,6 +108,7 @@ #define AT91_USART2 AT91SAM9RL_BASE_US2 #define AT91_USART3 AT91SAM9RL_BASE_US3
#include <asm/io.h>
#endif
Jens Scharsig
Tom
