Re: [RFC PATCH v4 1/2] arch: riscv: cpu: Add callback to init each core
Hi Green,
From: Green Wan [mailto:green.wan@sifive.com] Sent: Monday, April 12, 2021 10:33 AM To: Sean Anderson Cc: Rick Chen; Rick Jian-Zhi Chen(陳建志); Bin Meng; U-Boot Mailing List; Paul Walmsley; Pragnesh Patel; Simon Glass; Atish Patra; Leo Yu-Chi Liang(梁育齊); Brad Kim Subject: Re: [RFC PATCH v4 1/2] arch: riscv: cpu: Add callback to init each core
Hi Bin and Sean,
While we keep the consistency of cache control discussion going, later today I'd like to send the v5 patch which is not directly relevant to cache control.
I will prefer not to mix cache control issue into this patch. Like I said, this callback is a init for all harts before lottery.
Thanks, Rick
Regards, Green
On Sun, Apr 11, 2021 at 11:43 PM Sean Anderson seanga2@gmail.com wrote:
On 4/9/21 12:05 PM, Green Wan wrote:
Hi folks,
Correct me if I'm wrong, like Rick mentioned, i/dcache enable/disable() is only called on the main hart. Right now the dummy i/dcache enable/disable are empty and shared among all riscv CPU. The ax25 is the only one that has its own implementation for now.
Right, so why are caches are disabled on all harts before booting Linux on ax25? Is there a requirement for this on ax25 which that other platforms (which have always-on caches like k210, or which have non-disableable caches like fuX40) do not have?
--Sean
FU540/FU740 also leverages the dummy i/dcache enable/disable() functions (only main hart calls them). L2 cache on FU540/FU740 is enabled as SRAM purpose. And according to the HW design behavior, once L2 is enabled, it can't be disabled unless doing a reset.[1] The Linux L2$ driver will handle that according to the configuration of L2 registers.
[1] https://static.dev.sifive.com/FU540-C000-v1.0.pdf
Thanks,
On Fri, Apr 9, 2021 at 9:18 PM Sean Anderson seanga2@gmail.com wrote:
On 4/9/21 4:16 AM, Rick Chen wrote:
Hi Sean ,Bin
From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Tuesday, April 06, 2021 5:16 PM To: Sean Anderson Cc: Green Wan; Rick Jian-Zhi Chen(陳建志); Paul Walmsley; Pragnesh Patel; Bin Meng; Simon Glass; Atish Patra; Leo Yu-Chi Liang(梁育齊); Brad Kim; U-Boot Mailing List Subject: Re: [RFC PATCH v4 1/2] arch: riscv: cpu: Add callback to init each core
On Sat, Apr 3, 2021 at 6:53 AM Sean Anderson seanga2@gmail.com wrote: > > On 3/30/21 1:26 AM, Green Wan wrote: >> Add a callback riscv_hart_early_init() to ./arch/riscv/cpu/start.S to >> allow different riscv hart perform setup code for each hart as early >> as possible. Since all the harts enter the callback, they must be able >> to run the same setup. >> >> Signed-off-by: Green Wan green.wan@sifive.com >> --- >> arch/riscv/cpu/cpu.c | 15 +++++++++++++++ >> arch/riscv/cpu/start.S | 14 ++++++++++++++ >> 2 files changed, 29 insertions(+) >> >> diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c >> index 85592f5bee..1652e51137 100644 >> --- a/arch/riscv/cpu/cpu.c >> +++ b/arch/riscv/cpu/cpu.c >> @@ -140,3 +140,18 @@ int arch_early_init_r(void) >> { >> return riscv_cpu_probe(); >> } >> + >> +/** >> + * riscv_hart_early_init() - A dummy function called by >> + * ./arch/riscv/cpu/start.S to allow to disable/enable features of each core. >> + * For example, turn on or off the functional block of CPU harts. >> + * >> + * In a multi-core system, this function must not access shared resources. >> + * >> + * Any access to such resources would probably be better done with >> + * available_harts_lock held. However, I doubt that any such access will be >> + * necessary. >> + */ >> +__weak void riscv_hart_early_init(void) >> +{ >> +} >> diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S >> index 8589509e01..ab73008f23 100644 >> --- a/arch/riscv/cpu/start.S >> +++ b/arch/riscv/cpu/start.S >> @@ -117,6 +117,20 @@ call_board_init_f_0: >> mv sp, a0 >> #endif >> >> +#if CONFIG_IS_ENABLED(RISCV_MMODE) >> + /* >> + * Jump to riscv_hart_early_init() to perform init for each core. Not >> + * expect to access gd since gd is not initialized. All operations in the >> + * function should affect core itself only. In multi-core system, any access >> + * to common resource or registers outside core should be avoided or need a >> + * protection for multicore. >> + * >> + * A dummy implementation is provided in ./arch/riscv/cpu/cpu.c. >> + */ >> +call_riscv_hart_early_init: >> + jal riscv_hart_early_init >> +#endif >> + > > I wonder if we could move the calls to icache_enable and dcache_enable > into this function. Though this would have the consequence of enabling > caches on all harts for CPUs which previously only enabled them for the > boot hart. I think ax25 is the only CPU which currently does this. Bin, > would this be an issue?
No, they are functions shall be called in different stage about lottery. riscv_hart_early_init() is called before lottery for all harts. It shall not move icache_enable() and dcache_enable() into riscv_hart_early_init(), they are belong to the stage after lottery only for main hart.
Good catch. I believe AX25 cache support is currently somehow broken?
No, AX25 cache support is currently work well.
I think Rick has to comment on this as he added this via commit:
commit 52923c6db7f00e0197ec894c8c1bb8a7681974bb Author: Rick Chen rick@andestech.com Date: Wed Nov 7 09:34:06 2018 +0800
riscv: cache: Implement i/dcache [status, enable, disable] AndeStar RISC-V(V5) provide mcache_ctl register which can configure I/D cache as enabled or disabled. This CSR will be encapsulated by CONFIG_RISCV_NDS. If you want to configure cache on AndeStar V5 AE350 platform. YOu can enable [*] AndeStar V5 ISA support by make menuconfig. This approach also provide the expansion when the vender specific features are going to join in. Signed-off-by: Rick Chen <rick@andestech.com> Cc: Greentime Hu <greentime@andestech.com>
The original commit has i/d cache enabled on all harts. But it was later moved to boot hart due to SMP support.
Not all harts will enable i/d cache during startup currently, only main hart will enable i/d cache here. So only main hart will disable i/d cache in cleanup_before_linux().
Ok, so we have ax25 where cache is disabled on all harts before Linux, and fu740 where cache will be enabled on all harts. Is there any guidance from Linux on what should be happening here?
--Sean
Thanks, Rick
However on the cleanup side, it looks only the boot hart calls i/d cache disable?
See arch/riscv/cpu/ax25/cpu.c:: cleanup_before_linux()
Regards, Bin
On Tue, Apr 13, 2021 at 10:39 AM Rick Chen rickchen36@gmail.com wrote:
Hi Green,
Hi Bin and Sean,
Thanks, Rick
Agree with you.
- Green
Regards, Green
Hi folks,
--Sean
Thanks,
Hi Sean ,Bin
> From: Bin Meng [mailto:bmeng.cn@gmail.com] > Sent: Tuesday, April 06, 2021 5:16 PM > To: Sean Anderson > Cc: Green Wan; Rick Jian-Zhi Chen(陳建志); Paul Walmsley; Pragnesh Patel; Bin Meng; Simon Glass; Atish Patra; Leo Yu-Chi Liang(梁育齊); Brad Kim; U-Boot Mailing List > Subject: Re: [RFC PATCH v4 1/2] arch: riscv: cpu: Add callback to init each core > > On Sat, Apr 3, 2021 at 6:53 AM Sean Anderson seanga2@gmail.com wrote: >> >> On 3/30/21 1:26 AM, Green Wan wrote: >>> Add a callback riscv_hart_early_init() to ./arch/riscv/cpu/start.S to >>> allow different riscv hart perform setup code for each hart as early >>> as possible. Since all the harts enter the callback, they must be able >>> to run the same setup. >>> >>> Signed-off-by: Green Wan green.wan@sifive.com >>> --- >>> arch/riscv/cpu/cpu.c | 15 +++++++++++++++ >>> arch/riscv/cpu/start.S | 14 ++++++++++++++ >>> 2 files changed, 29 insertions(+) >>> >>> diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c >>> index 85592f5bee..1652e51137 100644 >>> --- a/arch/riscv/cpu/cpu.c >>> +++ b/arch/riscv/cpu/cpu.c >>> @@ -140,3 +140,18 @@ int arch_early_init_r(void) >>> { >>> return riscv_cpu_probe(); >>> } >>> + >>> +/** >>> + * riscv_hart_early_init() - A dummy function called by >>> + * ./arch/riscv/cpu/start.S to allow to disable/enable features of each core. >>> + * For example, turn on or off the functional block of CPU harts. >>> + * >>> + * In a multi-core system, this function must not access shared resources. >>> + * >>> + * Any access to such resources would probably be better done with >>> + * available_harts_lock held. However, I doubt that any such access will be >>> + * necessary. >>> + */ >>> +__weak void riscv_hart_early_init(void) >>> +{ >>> +} >>> diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S >>> index 8589509e01..ab73008f23 100644 >>> --- a/arch/riscv/cpu/start.S >>> +++ b/arch/riscv/cpu/start.S >>> @@ -117,6 +117,20 @@ call_board_init_f_0: >>> mv sp, a0 >>> #endif >>> >>> +#if CONFIG_IS_ENABLED(RISCV_MMODE) >>> + /* >>> + * Jump to riscv_hart_early_init() to perform init for each core. Not >>> + * expect to access gd since gd is not initialized. All operations in the >>> + * function should affect core itself only. In multi-core system, any access >>> + * to common resource or registers outside core should be avoided or need a >>> + * protection for multicore. >>> + * >>> + * A dummy implementation is provided in ./arch/riscv/cpu/cpu.c. >>> + */ >>> +call_riscv_hart_early_init: >>> + jal riscv_hart_early_init >>> +#endif >>> + >> >> I wonder if we could move the calls to icache_enable and dcache_enable >> into this function. Though this would have the consequence of enabling >> caches on all harts for CPUs which previously only enabled them for the >> boot hart. I think ax25 is the only CPU which currently does this. Bin, >> would this be an issue?
> > I think Rick has to comment on this as he added this via commit: > > commit 52923c6db7f00e0197ec894c8c1bb8a7681974bb > Author: Rick Chen rick@andestech.com > Date: Wed Nov 7 09:34:06 2018 +0800 > > riscv: cache: Implement i/dcache [status, enable, disable] > > AndeStar RISC-V(V5) provide mcache_ctl register which > can configure I/D cache as enabled or disabled. > > This CSR will be encapsulated by CONFIG_RISCV_NDS. > If you want to configure cache on AndeStar V5 > AE350 platform. YOu can enable [*] AndeStar V5 ISA support > by make menuconfig. > > This approach also provide the expansion when the > vender specific features are going to join in. > > Signed-off-by: Rick Chen rick@andestech.com > Cc: Greentime Hu greentime@andestech.com > > The original commit has i/d cache enabled on all harts. But it was > later moved to boot hart due to SMP support.
--Sean
Thanks, Rick
> > However on the cleanup side, it looks only the boot hart calls i/d > cache disable?
> > See arch/riscv/cpu/ax25/cpu.c:: cleanup_before_linux() > > Regards, > Bin
On 4/12/21 10:39 PM, Rick Chen wrote:
Hi Green,
Hi Bin and Sean,
Yes, but enabling caches is a very similar thing (this proposal even uses it to turn on caches, among other things). At the moment we have two calls to enable caches at almost the same time as what Green proposes. These calls only translate into work done on one platform. I think having one call (or perhaps two) for this purpose would help reduce codepaths across different platforms going forward.
--Sean
Thanks, Rick
Regards, Green
Hi folks,
--Sean
Thanks,
Hi Sean ,Bin
--Sean
Thanks, Rick
Hi Sean
Hi Green,
Hi Bin and Sean,
Maybe we can add two callbacks (early_lottery_init and late_lottery_init) before and after lottery individually for all scenarios.
Thanks, Rick
--Sean
Thanks, Rick
Regards, Green
Hi folks,
--Sean
Thanks,
On 4/9/21 4:16 AM, Rick Chen wrote: > Hi Sean ,Bin > >> From: Bin Meng [mailto:bmeng.cn@gmail.com] >> Sent: Tuesday, April 06, 2021 5:16 PM >> To: Sean Anderson >> Cc: Green Wan; Rick Jian-Zhi Chen(陳建志); Paul Walmsley; Pragnesh Patel; Bin Meng; Simon Glass; Atish Patra; Leo Yu-Chi Liang(梁育齊); Brad Kim; U-Boot Mailing List >> Subject: Re: [RFC PATCH v4 1/2] arch: riscv: cpu: Add callback to init each core >> >> On Sat, Apr 3, 2021 at 6:53 AM Sean Anderson seanga2@gmail.com wrote: >>> >>> On 3/30/21 1:26 AM, Green Wan wrote: >>>> Add a callback riscv_hart_early_init() to ./arch/riscv/cpu/start.S to >>>> allow different riscv hart perform setup code for each hart as early >>>> as possible. Since all the harts enter the callback, they must be able >>>> to run the same setup. >>>> >>>> Signed-off-by: Green Wan green.wan@sifive.com >>>> --- >>>> arch/riscv/cpu/cpu.c | 15 +++++++++++++++ >>>> arch/riscv/cpu/start.S | 14 ++++++++++++++ >>>> 2 files changed, 29 insertions(+) >>>> >>>> diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c >>>> index 85592f5bee..1652e51137 100644 >>>> --- a/arch/riscv/cpu/cpu.c >>>> +++ b/arch/riscv/cpu/cpu.c >>>> @@ -140,3 +140,18 @@ int arch_early_init_r(void) >>>> { >>>> return riscv_cpu_probe(); >>>> } >>>> + >>>> +/** >>>> + * riscv_hart_early_init() - A dummy function called by >>>> + * ./arch/riscv/cpu/start.S to allow to disable/enable features of each core. >>>> + * For example, turn on or off the functional block of CPU harts. >>>> + * >>>> + * In a multi-core system, this function must not access shared resources. >>>> + * >>>> + * Any access to such resources would probably be better done with >>>> + * available_harts_lock held. However, I doubt that any such access will be >>>> + * necessary. >>>> + */ >>>> +__weak void riscv_hart_early_init(void) >>>> +{ >>>> +} >>>> diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S >>>> index 8589509e01..ab73008f23 100644 >>>> --- a/arch/riscv/cpu/start.S >>>> +++ b/arch/riscv/cpu/start.S >>>> @@ -117,6 +117,20 @@ call_board_init_f_0: >>>> mv sp, a0 >>>> #endif >>>> >>>> +#if CONFIG_IS_ENABLED(RISCV_MMODE) >>>> + /* >>>> + * Jump to riscv_hart_early_init() to perform init for each core. Not >>>> + * expect to access gd since gd is not initialized. All operations in the >>>> + * function should affect core itself only. In multi-core system, any access >>>> + * to common resource or registers outside core should be avoided or need a >>>> + * protection for multicore. >>>> + * >>>> + * A dummy implementation is provided in ./arch/riscv/cpu/cpu.c. >>>> + */ >>>> +call_riscv_hart_early_init: >>>> + jal riscv_hart_early_init >>>> +#endif >>>> + >>> >>> I wonder if we could move the calls to icache_enable and dcache_enable >>> into this function. Though this would have the consequence of enabling >>> caches on all harts for CPUs which previously only enabled them for the >>> boot hart. I think ax25 is the only CPU which currently does this. Bin, >>> would this be an issue? > > No, they are functions shall be called in different stage about lottery. > riscv_hart_early_init() is called before lottery for all harts. > It shall not move icache_enable() and dcache_enable() into > riscv_hart_early_init(), they are belong to the stage after lottery > only for main hart. > >> >> Good catch. I believe AX25 cache support is currently somehow broken? > > No, AX25 cache support is currently work well. > >> >> I think Rick has to comment on this as he added this via commit: >> >> commit 52923c6db7f00e0197ec894c8c1bb8a7681974bb >> Author: Rick Chen rick@andestech.com >> Date: Wed Nov 7 09:34:06 2018 +0800 >> >> riscv: cache: Implement i/dcache [status, enable, disable] >> >> AndeStar RISC-V(V5) provide mcache_ctl register which >> can configure I/D cache as enabled or disabled. >> >> This CSR will be encapsulated by CONFIG_RISCV_NDS. >> If you want to configure cache on AndeStar V5 >> AE350 platform. YOu can enable [*] AndeStar V5 ISA support >> by make menuconfig. >> >> This approach also provide the expansion when the >> vender specific features are going to join in. >> >> Signed-off-by: Rick Chen rick@andestech.com >> Cc: Greentime Hu greentime@andestech.com >> >> The original commit has i/d cache enabled on all harts. But it was >> later moved to boot hart due to SMP support. > > Not all harts will enable i/d cache during startup currently, only > main hart will enable i/d cache here. > So only main hart will disable i/d cache in cleanup_before_linux().
--Sean
> Thanks, > Rick > >> >> However on the cleanup side, it looks only the boot hart calls i/d >> cache disable? > >> >> See arch/riscv/cpu/ax25/cpu.c:: cleanup_before_linux() >> >> Regards, >> Bin
On 4/13/21 12:12 AM, Rick Chen wrote:
Hi Sean
Hi Green,
Hi Bin and Sean,
Yes, that is a possibility. But do we actually need that flexibility? This comes back around to my original question: why does ax25 disable cache on all harts before jumping to Linux?
And of course, does this actually need to be done before the lottery?
--Sean
Hi Sean
Hi Green,
Hi Bin and Sean,
I sort of agree with Sean to merge some callbacks and keep most boot flow clean. And I feel early/late_lottery_init not a generic/meaningful name for a bootloader. But I doubt we should restrict all harts that must be cache enabled/disabled. Won't it conflict with some H/W behavior or decrease flexibilities?
Not sure the question is for me. Since some callbacks are only called by main hart after picking up the lottery, any init must be done within each hart itself, we have to do them before the lottery unless HW provides a common way to set up all harts. Of course, we can use IPI. But IPI is not a straightforward way.
- Geen
--Sean
Hi Sean,
Hi Sean
Hi Green,
Hi Bin and Sean,
clarify your above expressions: only disable main hart (not all harts) before jumping to Linux.
Why you think it is a question to disable cache before jumping to Linux. You can find many same cache flow in cleanup_before_linux of /arch/arm Are they all the questions ?
Thanks, Rick
--Sean
On 4/13/21 9:05 PM, Rick Chen wrote:
Hi Sean,
Hi Sean
Hi Green,
Hi Bin and Sean,
Well, for example K210 cannot disable cache (or rather, cache is a property of memory address), so cache is always enabled. And this series from Green suggests that the FU740 also cannot disable cache once enabled, and he would like to enable it on all harts very early in boot. So does it matter whether cache is enabled or disabled?
Alternatively, why is cache only enabled on the main hart on ax25? Would it be OK to enable it on all harts (and then later disable it on all harts)?
--Sean
Thanks, Rick
--Sean
Green Wan
Rick Chen
Sean Anderson
