[U-Boot] [PATCH 0/3] Prepare for net: phy: prevent uclass_eth device "node" field overwriting
Prepare for [1] so that it doesn't break the build for a bunch of boards. There are a number of reasons this series broke the build but none of them depend on changes in the series, so fix up those situations ahead of applying that series.
[1] https://patchwork.ozlabs.org/cover/940104/
Joe Hershberger (3): arm: Prevent redefinition error in fsl-layerscape phy: Break include cycle net: phy: Clean up includes of common.h
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- drivers/net/phy/atheros.c | 1 + drivers/net/phy/broadcom.c | 1 - drivers/net/phy/davicom.c | 1 + drivers/net/phy/generic_10g.c | 2 - drivers/net/phy/lxt.c | 1 + drivers/net/phy/marvell.c | 1 - drivers/net/phy/micrel_ksz8xxx.c | 1 - drivers/net/phy/micrel_ksz90x1.c | 2 - drivers/net/phy/natsemi.c | 1 + drivers/net/phy/phy.c | 2 - drivers/net/phy/realtek.c | 1 - drivers/net/phy/smsc.c | 1 + drivers/net/phy/teranetics.c | 1 - drivers/net/phy/vitesse.c | 1 + include/exports.h | 3 +- include/phy.h | 55 +--------------------------- include/phy_interface.h | 65 +++++++++++++++++++++++++++++++++ 18 files changed, 74 insertions(+), 68 deletions(-) create mode 100644 include/phy_interface.h
The include/phy.h will start including dm.h, which pulls in linux/compat.h after the attempted redefinition in arch/arm/include/asm/armv8/mmu.h, so move this include to allow redefinition.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 40c2c3a..052e070 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -9,6 +9,7 @@ #include <asm/io.h> #include <linux/errno.h> #include <asm/system.h> +#include <fm_eth.h> #include <asm/armv8/mmu.h> #include <asm/io.h> #include <asm/arch/fsl_serdes.h> @@ -18,7 +19,6 @@ #include <fsl_immap.h> #include <asm/arch/mp.h> #include <efi_loader.h> -#include <fm_eth.h> #include <fsl-mc/fsl_mc.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h>
Hi Joe,
https://patchwork.ozlabs.org/patch/949356/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Because some phy wants to export some functions [1], export.h was including the whole phy subsystem which pulls in lots of stuff that causes some ordering and redefinition issues. Split out the only part that is actually needed in export.h and include it there and in phy.h.
[1] commit 95279315076c ("board/ls2085rdb: Export functions for standalone AQ FW load apps")
include/exports.h | 3 +-- include/phy.h | 55 +---------------------------------------- include/phy_interface.h | 65 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 67 insertions(+), 56 deletions(-) create mode 100644 include/phy_interface.h
diff --git a/include/exports.h b/include/exports.h index ebe81d9..a4b862f 100644 --- a/include/exports.h +++ b/include/exports.h @@ -3,8 +3,7 @@
#ifndef __ASSEMBLY__ #ifdef CONFIG_PHY_AQUANTIA -#include <miiphy.h> -#include <phy.h> +#include <phy_interface.h> #endif
struct spi_slave; diff --git a/include/phy.h b/include/phy.h index 7c3fc5c..09645a8 100644 --- a/include/phy.h +++ b/include/phy.h @@ -13,6 +13,7 @@ #include <linux/mii.h> #include <linux/ethtool.h> #include <linux/mdio.h> +#include <phy_interface.h>
#define PHY_FIXED_ID 0xa5a55a5a
@@ -48,60 +49,6 @@ #endif
-typedef enum { - PHY_INTERFACE_MODE_MII, - PHY_INTERFACE_MODE_GMII, - PHY_INTERFACE_MODE_SGMII, - PHY_INTERFACE_MODE_SGMII_2500, - PHY_INTERFACE_MODE_QSGMII, - PHY_INTERFACE_MODE_TBI, - PHY_INTERFACE_MODE_RMII, - PHY_INTERFACE_MODE_RGMII, - PHY_INTERFACE_MODE_RGMII_ID, - PHY_INTERFACE_MODE_RGMII_RXID, - PHY_INTERFACE_MODE_RGMII_TXID, - PHY_INTERFACE_MODE_RTBI, - PHY_INTERFACE_MODE_XGMII, - PHY_INTERFACE_MODE_XAUI, - PHY_INTERFACE_MODE_RXAUI, - PHY_INTERFACE_MODE_SFI, - PHY_INTERFACE_MODE_INTERNAL, - PHY_INTERFACE_MODE_NONE, /* Must be last */ - - PHY_INTERFACE_MODE_COUNT, -} phy_interface_t; - -static const char *phy_interface_strings[] = { - [PHY_INTERFACE_MODE_MII] = "mii", - [PHY_INTERFACE_MODE_GMII] = "gmii", - [PHY_INTERFACE_MODE_SGMII] = "sgmii", - [PHY_INTERFACE_MODE_SGMII_2500] = "sgmii-2500", - [PHY_INTERFACE_MODE_QSGMII] = "qsgmii", - [PHY_INTERFACE_MODE_TBI] = "tbi", - [PHY_INTERFACE_MODE_RMII] = "rmii", - [PHY_INTERFACE_MODE_RGMII] = "rgmii", - [PHY_INTERFACE_MODE_RGMII_ID] = "rgmii-id", - [PHY_INTERFACE_MODE_RGMII_RXID] = "rgmii-rxid", - [PHY_INTERFACE_MODE_RGMII_TXID] = "rgmii-txid", - [PHY_INTERFACE_MODE_RTBI] = "rtbi", - [PHY_INTERFACE_MODE_XGMII] = "xgmii", - [PHY_INTERFACE_MODE_XAUI] = "xaui", - [PHY_INTERFACE_MODE_RXAUI] = "rxaui", - [PHY_INTERFACE_MODE_SFI] = "sfi", - [PHY_INTERFACE_MODE_INTERNAL] = "internal", - [PHY_INTERFACE_MODE_NONE] = "", -}; - -static inline const char *phy_string_for_interface(phy_interface_t i) -{ - /* Default to unknown */ - if (i > PHY_INTERFACE_MODE_NONE) - i = PHY_INTERFACE_MODE_NONE; - - return phy_interface_strings[i]; -} - - struct phy_device;
#define MDIO_NAME_LEN 32 diff --git a/include/phy_interface.h b/include/phy_interface.h new file mode 100644 index 0000000..0760d65 --- /dev/null +++ b/include/phy_interface.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Andy Fleming afleming@gmail.com + * + * This file pretty much stolen from Linux's mii.h/ethtool.h/phy.h + */ + +#ifndef _PHY_INTERFACE_H +#define _PHY_INTERFACE_H + +typedef enum { + PHY_INTERFACE_MODE_MII, + PHY_INTERFACE_MODE_GMII, + PHY_INTERFACE_MODE_SGMII, + PHY_INTERFACE_MODE_SGMII_2500, + PHY_INTERFACE_MODE_QSGMII, + PHY_INTERFACE_MODE_TBI, + PHY_INTERFACE_MODE_RMII, + PHY_INTERFACE_MODE_RGMII, + PHY_INTERFACE_MODE_RGMII_ID, + PHY_INTERFACE_MODE_RGMII_RXID, + PHY_INTERFACE_MODE_RGMII_TXID, + PHY_INTERFACE_MODE_RTBI, + PHY_INTERFACE_MODE_XGMII, + PHY_INTERFACE_MODE_XAUI, + PHY_INTERFACE_MODE_RXAUI, + PHY_INTERFACE_MODE_SFI, + PHY_INTERFACE_MODE_INTERNAL, + PHY_INTERFACE_MODE_NONE, /* Must be last */ + + PHY_INTERFACE_MODE_COUNT, +} phy_interface_t; + +static const char * const phy_interface_strings[] = { + [PHY_INTERFACE_MODE_MII] = "mii", + [PHY_INTERFACE_MODE_GMII] = "gmii", + [PHY_INTERFACE_MODE_SGMII] = "sgmii", + [PHY_INTERFACE_MODE_SGMII_2500] = "sgmii-2500", + [PHY_INTERFACE_MODE_QSGMII] = "qsgmii", + [PHY_INTERFACE_MODE_TBI] = "tbi", + [PHY_INTERFACE_MODE_RMII] = "rmii", + [PHY_INTERFACE_MODE_RGMII] = "rgmii", + [PHY_INTERFACE_MODE_RGMII_ID] = "rgmii-id", + [PHY_INTERFACE_MODE_RGMII_RXID] = "rgmii-rxid", + [PHY_INTERFACE_MODE_RGMII_TXID] = "rgmii-txid", + [PHY_INTERFACE_MODE_RTBI] = "rtbi", + [PHY_INTERFACE_MODE_XGMII] = "xgmii", + [PHY_INTERFACE_MODE_XAUI] = "xaui", + [PHY_INTERFACE_MODE_RXAUI] = "rxaui", + [PHY_INTERFACE_MODE_SFI] = "sfi", + [PHY_INTERFACE_MODE_INTERNAL] = "internal", + [PHY_INTERFACE_MODE_NONE] = "", +}; + +static inline const char *phy_string_for_interface(phy_interface_t i) +{ + /* Default to unknown */ + if (i > PHY_INTERFACE_MODE_NONE) + i = PHY_INTERFACE_MODE_NONE; + + return phy_interface_strings[i]; +} + +#endif /* _PHY_INTERFACE_H */
Hi Joe,
https://patchwork.ozlabs.org/patch/949355/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
We want to be able to include some other system headers in phy.h but that requires us to have included common.h in the top-level first.
Also, common.h includes config.h as the first thing it does, so don't include it directly.
Seried-cc: ti Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
drivers/net/phy/atheros.c | 1 + drivers/net/phy/broadcom.c | 1 - drivers/net/phy/davicom.c | 1 + drivers/net/phy/generic_10g.c | 2 -- drivers/net/phy/lxt.c | 1 + drivers/net/phy/marvell.c | 1 - drivers/net/phy/micrel_ksz8xxx.c | 1 - drivers/net/phy/micrel_ksz90x1.c | 2 -- drivers/net/phy/natsemi.c | 1 + drivers/net/phy/phy.c | 2 -- drivers/net/phy/realtek.c | 1 - drivers/net/phy/smsc.c | 1 + drivers/net/phy/teranetics.c | 1 - drivers/net/phy/vitesse.c | 1 + 14 files changed, 6 insertions(+), 11 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 79f68af..3783d15 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -5,6 +5,7 @@ * Copyright 2011, 2013 Freescale Semiconductor, Inc. * author Andy Fleming */ +#include <common.h> #include <phy.h>
#define AR803x_PHY_DEBUG_ADDR_REG 0x1d diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c index 202e3dd..3399fd2 100644 --- a/drivers/net/phy/broadcom.c +++ b/drivers/net/phy/broadcom.c @@ -5,7 +5,6 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ -#include <config.h> #include <common.h> #include <phy.h>
diff --git a/drivers/net/phy/davicom.c b/drivers/net/phy/davicom.c index 27c7788..4666497 100644 --- a/drivers/net/phy/davicom.c +++ b/drivers/net/phy/davicom.c @@ -5,6 +5,7 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ +#include <common.h> #include <phy.h>
#define MIIM_DM9161_SCR 0x10 diff --git a/drivers/net/phy/generic_10g.c b/drivers/net/phy/generic_10g.c index 1024d7d..b4384e1 100644 --- a/drivers/net/phy/generic_10g.c +++ b/drivers/net/phy/generic_10g.c @@ -7,8 +7,6 @@ * * Based loosely off of Linux's PHY Lib */ - -#include <config.h> #include <common.h> #include <miiphy.h> #include <phy.h> diff --git a/drivers/net/phy/lxt.c b/drivers/net/phy/lxt.c index 5942664..2618deb 100644 --- a/drivers/net/phy/lxt.c +++ b/drivers/net/phy/lxt.c @@ -5,6 +5,7 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ +#include <common.h> #include <phy.h>
/* LXT971 Status 2 registers */ diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index 436ff57..efbbd31 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -5,7 +5,6 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ -#include <config.h> #include <common.h> #include <errno.h> #include <phy.h> diff --git a/drivers/net/phy/micrel_ksz8xxx.c b/drivers/net/phy/micrel_ksz8xxx.c index c70c036..3411150 100644 --- a/drivers/net/phy/micrel_ksz8xxx.c +++ b/drivers/net/phy/micrel_ksz8xxx.c @@ -6,7 +6,6 @@ * author Andy Fleming * (C) 2012 NetModule AG, David Andrey, added KSZ9031 */ -#include <config.h> #include <common.h> #include <dm.h> #include <errno.h> diff --git a/drivers/net/phy/micrel_ksz90x1.c b/drivers/net/phy/micrel_ksz90x1.c index 5462532..3951535 100644 --- a/drivers/net/phy/micrel_ksz90x1.c +++ b/drivers/net/phy/micrel_ksz90x1.c @@ -8,8 +8,6 @@ * (C) Copyright 2017 Adaptrum, Inc. * Written by Alexandru Gagniuc alex.g@adaptrum.com for Adaptrum, Inc. */ - -#include <config.h> #include <common.h> #include <dm.h> #include <errno.h> diff --git a/drivers/net/phy/natsemi.c b/drivers/net/phy/natsemi.c index 05c7e7c..efde457 100644 --- a/drivers/net/phy/natsemi.c +++ b/drivers/net/phy/natsemi.c @@ -5,6 +5,7 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ +#include <common.h> #include <phy.h>
/* NatSemi DP83630 */ diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 4e610bf..a88c13a 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -7,8 +7,6 @@ * * Based loosely off of Linux's PHY Lib */ - -#include <config.h> #include <common.h> #include <console.h> #include <dm.h> diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index b0867af..b3e6578 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -6,7 +6,6 @@ * author Andy Fleming * Copyright 2016 Karsten Merker merker@debian.org */ -#include <config.h> #include <common.h> #include <linux/bitops.h> #include <phy.h> diff --git a/drivers/net/phy/smsc.c b/drivers/net/phy/smsc.c index 2f92957..7740a25 100644 --- a/drivers/net/phy/smsc.c +++ b/drivers/net/phy/smsc.c @@ -9,6 +9,7 @@ * Some code copied from linux kernel * Copyright (c) 2006 Herbert Valerio Riedel hvr@gnu.org */ +#include <common.h> #include <miiphy.h>
/* This code does not check the partner abilities. */ diff --git a/drivers/net/phy/teranetics.c b/drivers/net/phy/teranetics.c index d674e8f..49d6a1a 100644 --- a/drivers/net/phy/teranetics.c +++ b/drivers/net/phy/teranetics.c @@ -5,7 +5,6 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming */ -#include <config.h> #include <common.h> #include <phy.h>
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c index 9df4a3f..eca26c9 100644 --- a/drivers/net/phy/vitesse.c +++ b/drivers/net/phy/vitesse.c @@ -6,6 +6,7 @@ * Original Author: Andy Fleming * Add vsc8662 phy support - Priyanka Jain */ +#include <common.h> #include <miiphy.h>
/* Cicada Auxiliary Control/Status Register */
Hi Joe,
https://patchwork.ozlabs.org/patch/949357/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
