[U-Boot] [U-boot] [Patch 0/5] keystone2: add network support for K2E SoC and EVM
These patches add network support for Keystne2 Edison SoC boards.
Based on "[U-boot] [Patch 0/5] keystone_net: use MDIO bus and eth PHY frameworks" https://www.mail-archive.com/u-boot@lists.denx.de/msg148974.html
Hao Zhang (1): board: k2e_evm: add network support
Ivan Khoronzhuk (4): ARM: keystone2: keysonte_nav: add support for K2E SoC net: keystone_serdes: add keystone K2E SoC support net: keystone_net: add Keystone2 K2E SoC support net: keystone_net: increase PHY auto negotiate time
arch/arm/include/asm/arch-keystone/hardware-k2e.h | 20 +++++++ board/ti/ks2_evm/board_k2e.c | 68 ++++++++++++++++++++++- drivers/net/keystone_net.c | 47 ++++++++++++++-- include/configs/k2e_evm.h | 10 ++++ include/configs/ks2_evm.h | 1 + 5 files changed, 140 insertions(+), 6 deletions(-)
Keystone2 Edison SoC uses the same keystone navigator, but uses different NETCP PktDMA definitions. This patch adds required definitions.
Acked-by: Vitaly Andrianov vitalya@ti.com Acked-by: Murali Karicheri m-karicheri2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/include/asm/arch-keystone/hardware-k2e.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2e.h b/arch/arm/include/asm/arch-keystone/hardware-k2e.h index 62172a4..f09aa93 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2e.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2e.h @@ -41,4 +41,17 @@ /* Number of DSP cores */ #define KS2_NUM_DSPS 1
+/* NETCP pktdma */ +#define KS2_NETCP_PDMA_CTRL_BASE 0x24186000 +#define KS2_NETCP_PDMA_TX_BASE 0x24187000 +#define KS2_NETCP_PDMA_TX_CH_NUM 21 +#define KS2_NETCP_PDMA_RX_BASE 0x24188000 +#define KS2_NETCP_PDMA_RX_CH_NUM 91 +#define KS2_NETCP_PDMA_SCHED_BASE 0x24186100 +#define KS2_NETCP_PDMA_RX_FLOW_BASE 0x24189000 +#define KS2_NETCP_PDMA_RX_FLOW_NUM 96 +#define KS2_NETCP_PDMA_RX_FREE_QUEUE 4001 +#define KS2_NETCP_PDMA_RX_RCV_QUEUE 4002 +#define KS2_NETCP_PDMA_TX_SND_QUEUE 896 + #endif
Keystone2 Edison SoC uses the same keystone SerDes driver. This patch adds support for K2E SoCs.
Acked-by: Vitaly Andrianov vitalya@ti.com Acked-by: Murali Karicheri m-karicheri2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/include/asm/arch-keystone/hardware-k2e.h | 4 ++++ drivers/net/keystone_net.c | 6 ++++++ include/configs/k2e_evm.h | 3 +++ include/configs/ks2_evm.h | 1 + 4 files changed, 14 insertions(+)
diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2e.h b/arch/arm/include/asm/arch-keystone/hardware-k2e.h index f09aa93..4eac5f8 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2e.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2e.h @@ -38,6 +38,10 @@ #define KS2_CIC2_DDR3_ECC_IRQ_NUM -1 /* not defined in K2E */ #define KS2_CIC2_DDR3_ECC_CHAN_NUM -1 /* not defined in K2E */
+/* SGMII SerDes */ +#define KS2_SGMII_SERDES2_BASE 0x02324000 +#define KS2_LANES_PER_SGMII_SERDES 4 + /* Number of DSP cores */ #define KS2_NUM_DSPS 1
diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 8348a91..6897dd9 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -546,6 +546,12 @@ static void keystone2_net_serdes_setup(void) &ks2_serdes_sgmii_156p25mhz, CONFIG_KSNET_SERDES_LANES_PER_SGMII);
+#ifdef CONFIG_SOC_K2E + ks2_serdes_init(CONFIG_KSNET_SERDES_SGMII2_BASE, + &ks2_serdes_sgmii_156p25mhz, + CONFIG_KSNET_SERDES_LANES_PER_SGMII); +#endif + /* wait till setup */ udelay(5000); } diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 3502d10..fd45d61 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -34,4 +34,7 @@ /* NAND Configuration */ #define CONFIG_SYS_NAND_PAGE_2K
+/* SerDes */ +#define CONFIG_TI_KEYSTONE_SERDES + #endif /* __CONFIG_K2E_EVM_H */ diff --git a/include/configs/ks2_evm.h b/include/configs/ks2_evm.h index dcce7c3..a92ab04 100644 --- a/include/configs/ks2_evm.h +++ b/include/configs/ks2_evm.h @@ -140,6 +140,7 @@ #define CONFIG_KSNET_MAC_ID_BASE KS2_MAC_ID_BASE_ADDR #define CONFIG_KSNET_NETCP_BASE KS2_NETCP_BASE #define CONFIG_KSNET_SERDES_SGMII_BASE KS2_SGMII_SERDES_BASE +#define CONFIG_KSNET_SERDES_SGMII2_BASE KS2_SGMII_SERDES2_BASE #define CONFIG_KSNET_SERDES_LANES_PER_SGMII KS2_LANES_PER_SGMII_SERDES
/* AEMIF */
The Keystone2 Edison SoC uses the same keystone net driver. This patch adds opportunity to use it by K2E SoCs.
Acked-by: Vitaly Andrianov vitalya@ti.com Acked-by: Murali Karicheri m-karicheri2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/include/asm/arch-keystone/hardware-k2e.h | 3 +++ drivers/net/keystone_net.c | 5 +++++ 2 files changed, 8 insertions(+)
diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2e.h b/arch/arm/include/asm/arch-keystone/hardware-k2e.h index 4eac5f8..ab0d5f9 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2e.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2e.h @@ -58,4 +58,7 @@ #define KS2_NETCP_PDMA_RX_RCV_QUEUE 4002 #define KS2_NETCP_PDMA_TX_SND_QUEUE 896
+/* NETCP */ +#define KS2_NETCP_BASE 0x24000000 + #endif diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 6897dd9..889b273 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -289,6 +289,11 @@ int mac_sl_config(u_int16_t port, struct mac_sl_cfg *cfg) writel(cfg->max_rx_len, DEVICE_EMACSL_BASE(port) + CPGMACSL_REG_MAXLEN); writel(cfg->ctl, DEVICE_EMACSL_BASE(port) + CPGMACSL_REG_CTL);
+#ifdef CONFIG_K2E_EVM + /* Map RX packet flow priority to 0 */ + writel(0, DEVICE_EMACSL_BASE(port) + CPGMACSL_REG_RX_PRI_MAP); +#endif + return ret; }
The new Marvel PHY (88E1514) used on K2L/K2E EVM requires longer time to auto negotiate with SoC's SGMII port.
It can take about 3 sec to up the PHY after reset, so add code to expose sgmii auto negotiation waiting process.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- drivers/net/keystone_net.c | 36 +++++++++++++++++++++++++++++++----- 1 file changed, 31 insertions(+), 5 deletions(-)
diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 889b273..ddd2701 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -11,6 +11,7 @@
#include <net.h> #include <phy.h> +#include <errno.h> #include <miiphy.h> #include <malloc.h> #include <asm/ti-common/keystone_nav.h> @@ -30,6 +31,7 @@ static unsigned int sys_has_mdio = 1; #define RX_BUFF_NUMS 24 #define RX_BUFF_LEN 1520 #define MAX_SIZE_STREAM_BUFFER RX_BUFF_LEN +#define SGMII_ANEG_TIMEOUT 4000
static u8 rx_buffs[RX_BUFF_NUMS * RX_BUFF_LEN] __aligned(16);
@@ -169,7 +171,7 @@ int keystone_sgmii_link_status(int port) (status & SGMII_REG_STATUS_LINK); }
-int keystone_sgmii_config(int port, int interface) +int keystone_sgmii_config(struct phy_device *phy_dev, int port, int interface) { unsigned int i, status, mask; unsigned int mr_adv_ability, control; @@ -230,11 +232,35 @@ int keystone_sgmii_config(int port, int interface) if (control & SGMII_REG_CONTROL_AUTONEG) mask |= SGMII_REG_STATUS_AUTONEG;
- for (i = 0; i < 1000; i++) { + status = __raw_readl(SGMII_STATUS_REG(port)); + if ((status & mask) == mask) + return 0; + + printf("\n%s Waiting for SGMII auto negotiation to complete", + phy_dev->dev->name); + while ((status & mask) != mask) { + /* + * Timeout reached ? + */ + if (i > SGMII_ANEG_TIMEOUT) { + puts(" TIMEOUT !\n"); + phy_dev->link = 0; + return 0; + } + + if (ctrlc()) { + puts("user interrupt!\n"); + phy_dev->link = 0; + return -EINTR; + } + + if ((i++ % 500) == 0) + printf("."); + + udelay(1000); /* 1 ms */ status = __raw_readl(SGMII_STATUS_REG(port)); - if ((status & mask) == mask) - break; } + puts(" done\n");
return 0; } @@ -374,7 +400,7 @@ static int keystone2_eth_open(struct eth_device *dev, bd_t *bis)
keystone2_net_serdes_setup();
- keystone_sgmii_config(eth_priv->slave_port - 1, + keystone_sgmii_config(phy_dev, eth_priv->slave_port - 1, eth_priv->sgmii_link_type);
udelay(10000);
This patch adds network support code and enables keystone_net driver usage for k2e_evm evaluation board.
Acked-by: Vitaly Andrianov vitalya@ti.com Acked-by: Murali Karicheri m-karicheri2@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- board/ti/ks2_evm/board_k2e.c | 68 +++++++++++++++++++++++++++++++++++++++++++- include/configs/k2e_evm.h | 7 +++++ 2 files changed, 74 insertions(+), 1 deletion(-)
diff --git a/board/ti/ks2_evm/board_k2e.c b/board/ti/ks2_evm/board_k2e.c index 5472a43..b14a00e 100644 --- a/board/ti/ks2_evm/board_k2e.c +++ b/board/ti/ks2_evm/board_k2e.c @@ -10,6 +10,7 @@ #include <common.h> #include <asm/arch/ddr3.h> #include <asm/arch/hardware.h> +#include <asm/ti-common/keystone_net.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -35,10 +36,75 @@ static struct pll_init_data core_pll_config[] = { CORE_PLL_1500, };
- static struct pll_init_data pa_pll_config = PASS_PLL_1000;
+#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET +struct eth_priv_t eth_priv_cfg[] = { + { + .int_name = "K2E_EMAC0", + .rx_flow = 0, + .phy_addr = 0, + .slave_port = 1, + .sgmii_link_type = SGMII_LINK_MAC_PHY, + }, + { + .int_name = "K2E_EMAC1", + .rx_flow = 8, + .phy_addr = 1, + .slave_port = 2, + .sgmii_link_type = SGMII_LINK_MAC_PHY, + }, + { + .int_name = "K2E_EMAC2", + .rx_flow = 16, + .phy_addr = 2, + .slave_port = 3, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, + { + .int_name = "K2E_EMAC3", + .rx_flow = 24, + .phy_addr = 3, + .slave_port = 4, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, + { + .int_name = "K2E_EMAC4", + .rx_flow = 32, + .phy_addr = 4, + .slave_port = 5, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, + { + .int_name = "K2E_EMAC5", + .rx_flow = 40, + .phy_addr = 5, + .slave_port = 6, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, + { + .int_name = "K2E_EMAC6", + .rx_flow = 48, + .phy_addr = 6, + .slave_port = 7, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, + { + .int_name = "K2E_EMAC7", + .rx_flow = 56, + .phy_addr = 7, + .slave_port = 8, + .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, + }, +}; + +int get_num_eth_ports(void) +{ + return sizeof(eth_priv_cfg) / sizeof(struct eth_priv_t); +} +#endif + #if defined(CONFIG_BOARD_EARLY_INIT_F) int board_early_init_f(void) { diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index fd45d61..dfb1835 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -34,6 +34,13 @@ /* NAND Configuration */ #define CONFIG_SYS_NAND_PAGE_2K
+/* Network */ +#define CONFIG_DRIVER_TI_KEYSTONE_NET +#define CONFIG_TI_KSNAV +#define CONFIG_KSNAV_PKTDMA_NETCP +#define CONFIG_KSNET_NETCP_V1_5 +#define CONFIG_KSNET_CPSW_NUM_PORTS 9 + /* SerDes */ #define CONFIG_TI_KEYSTONE_SERDES
Ivan Khoronzhuk
