[U-Boot] [PATCH] rockchip: add a dummy byte for the sdram-channel property
Add an extra byte so that this data is not byteswapped.
Signed-off-by: Ziyuan Xu jk.kernel@gmail.com ---
arch/arm/dts/rk3288-evb.dts | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts index caf24ee..3e1ee58 100644 --- a/arch/arm/dts/rk3288-evb.dts +++ b/arch/arm/dts/rk3288-evb.dts @@ -25,7 +25,8 @@ 0x8 0x1f4>; rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 0x0 0xc3 0x6 0x2>; - rockchip,sdram-channel = /bits/ 8 <0x2 0xa 0x3 0x2 0x2 0x0 0xe 0xe>; + /* Add a dummy value to cause of-platdata think this is bytes */ + rockchip,sdram-channel = /bits/ 8 <0x2 0xa 0x3 0x2 0x2 0x0 0xe 0xe 0xff>; rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; };
Ziyuan Xu
