[PATCH 0/2] power: remove non-DM max8997/8 files
Remove non-DM files about max8997 and max8998. There are already max8997/8 pmic driver to support driver-model. But i didn't remove them because there was one place to use them.
Now, it's time to remove non-DM max8997/8 files after converting to DM in samsung/common/misc.c
Jaehoon Chung (2): board: samsung: covert to driver model about power_key_pressed power: pmic: remove pmic_max8997/8 files
board/samsung/common/misc.c | 27 ++++---- drivers/power/pmic/Makefile | 2 - drivers/power/pmic/pmic_max8997.c | 107 ------------------------------ drivers/power/pmic/pmic_max8998.c | 32 --------- 4 files changed, 14 insertions(+), 154 deletions(-) delete mode 100644 drivers/power/pmic/pmic_max8997.c delete mode 100644 drivers/power/pmic/pmic_max8998.c
Convert to driver model about power_key_pressed.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- board/samsung/common/misc.c | 27 ++++++++++++++------------- 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 837463ba78f8..c8b9ad71e49e 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -116,32 +116,33 @@ void set_board_info(void) #ifdef CONFIG_LCD_MENU static int power_key_pressed(u32 reg) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ - struct pmic *pmic; + struct udevice *dev; + int ret; u32 status; u32 mask;
- pmic = pmic_get(KEY_PWR_PMIC_NAME); - if (!pmic) { - printf("%s: Not found\n", KEY_PWR_PMIC_NAME); + if (IS_ENABLED(CONFIG_TARGET_TRATS)) + ret = pmic_get("max8997-pmic", &dev); + else if (IS_ENABLED(CONFIG_TARGET_TRATS2)) + ret = pmic_get("max77686-pmic", &dev); + else if (IS_ENABLED(CONFIG_TARGET_S5PC210_UNIVERSAL)) + ret = pmic_get("max8998-pmic", &dev); + else return 0; - }
- if (pmic_probe(pmic)) - return 0; + if (ret) + return ret;
if (reg == KEY_PWR_STATUS_REG) mask = KEY_PWR_STATUS_MASK; else mask = KEY_PWR_INTERRUPT_MASK;
- if (pmic_reg_read(pmic, reg, &status)) - return 0; + status = pmic_reg_read(dev, reg); + if (status < 0) + return status;
return !!(status & mask); -#else - return 0; -#endif }
static int key_pressed(int key)
Remove pmic_max8997/8 files about no-DM. There are already existed max8997/8 as driver-model.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/power/pmic/Makefile | 2 - drivers/power/pmic/pmic_max8997.c | 107 ------------------------------ drivers/power/pmic/pmic_max8998.c | 32 --------- 3 files changed, 141 deletions(-) delete mode 100644 drivers/power/pmic/pmic_max8997.c delete mode 100644 drivers/power/pmic/pmic_max8998.c
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 8395009e08f7..89099fde5738 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -30,8 +30,6 @@ obj-$(CONFIG_$(SPL_)PMIC_LP87565) += lp87565.o obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o -obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o -obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o obj-$(CONFIG_POWER_PCA9450) += pmic_pca9450.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o diff --git a/drivers/power/pmic/pmic_max8997.c b/drivers/power/pmic/pmic_max8997.c deleted file mode 100644 index 1d834ff71304..000000000000 --- a/drivers/power/pmic/pmic_max8997.c +++ /dev/null @@ -1,107 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012 Samsung Electronics - * Lukasz Majewski l.majewski@samsung.com - */ - -#include <common.h> -#include <log.h> -#include <power/pmic.h> -#include <power/max8997_pmic.h> -#include <i2c.h> -#include <errno.h> - -unsigned char max8997_reg_ldo(int uV) -{ - unsigned char ret; - if (uV <= 800000) - return 0; - if (uV >= 3950000) - return MAX8997_LDO_MAX_VAL; - ret = (uV - 800000) / 50000; - if (ret > MAX8997_LDO_MAX_VAL) { - printf("MAX8997 LDO SETTING ERROR (%duV) -> %u\n", uV, ret); - ret = MAX8997_LDO_MAX_VAL; - } - - return ret; -} - -static int pmic_charger_state(struct pmic *p, int state, int current) -{ - unsigned char fc; - u32 val = 0; - - if (pmic_probe(p)) - return -ENODEV; - - if (state == PMIC_CHARGER_DISABLE) { - puts("Disable the charger.\n"); - pmic_reg_read(p, MAX8997_REG_MBCCTRL2, &val); - val &= ~(MBCHOSTEN | VCHGR_FC); - pmic_reg_write(p, MAX8997_REG_MBCCTRL2, val); - - return -ENOTSUPP; - } - - if (current < CHARGER_MIN_CURRENT || current > CHARGER_MAX_CURRENT) { - printf("%s: Wrong charge current: %d [mA]\n", - __func__, current); - return -EINVAL; - } - - fc = (current - CHARGER_MIN_CURRENT) / CHARGER_CURRENT_RESOLUTION; - fc = fc & 0xf; /* up to 950 mA */ - - printf("Enable the charger @ %d [mA]\n", fc * CHARGER_CURRENT_RESOLUTION - + CHARGER_MIN_CURRENT); - - val = fc | MBCICHFCSET; - pmic_reg_write(p, MAX8997_REG_MBCCTRL4, val); - - pmic_reg_read(p, MAX8997_REG_MBCCTRL2, &val); - val = MBCHOSTEN | VCHGR_FC; /* enable charger & fast charge */ - pmic_reg_write(p, MAX8997_REG_MBCCTRL2, val); - - return 0; -} - -static int pmic_charger_bat_present(struct pmic *p) -{ - u32 val; - - if (pmic_probe(p)) - return -ENODEV; - - pmic_reg_read(p, MAX8997_REG_STATUS4, &val); - - return !(val & DETBAT); -} - -static struct power_chrg power_chrg_pmic_ops = { - .chrg_bat_present = pmic_charger_bat_present, - .chrg_state = pmic_charger_state, -}; - -int pmic_init(unsigned char bus) -{ - static const char name[] = "MAX8997_PMIC"; - struct pmic *p = pmic_alloc(); - - if (!p) { - printf("%s: POWER allocation error!\n", __func__); - return -ENOMEM; - } - - debug("Board PMIC init\n"); - - p->name = name; - p->interface = PMIC_I2C; - p->number_of_regs = PMIC_NUM_OF_REGS; - p->hw.i2c.addr = MAX8997_I2C_ADDR; - p->hw.i2c.tx_num = 1; - p->bus = bus; - - p->chrg = &power_chrg_pmic_ops; - return 0; -} diff --git a/drivers/power/pmic/pmic_max8998.c b/drivers/power/pmic/pmic_max8998.c deleted file mode 100644 index f058238c9217..000000000000 --- a/drivers/power/pmic/pmic_max8998.c +++ /dev/null @@ -1,32 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2011 Samsung Electronics - * Lukasz Majewski l.majewski@samsung.com - */ - -#include <common.h> -#include <power/pmic.h> -#include <power/max8998_pmic.h> -#include <errno.h> - -int pmic_init(unsigned char bus) -{ - static const char name[] = "MAX8998_PMIC"; - struct pmic *p = pmic_alloc(); - - if (!p) { - printf("%s: POWER allocation error!\n", __func__); - return -ENOMEM; - } - - puts("Board PMIC init\n"); - - p->name = name; - p->interface = PMIC_I2C; - p->number_of_regs = PMIC_NUM_OF_REGS; - p->hw.i2c.addr = MAX8998_I2C_ADDR; - p->hw.i2c.tx_num = 1; - p->bus = bus; - - return 0; -}
Jaehoon Chung
