[U-Boot] [PATCH v3] powerpc, 8xx: Add support for MCR3000 board from CSSI
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors.
This patch adds support for the first board.
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr --- v3: Takes into account comments received from Heiko and Wolfgang
Applies after the v2 serie 'powerpc, 8xx: Modernise the 8xx'
.travis.yml | 2 + arch/powerpc/cpu/mpc8xx/Kconfig | 5 + board/cssi/MAINTAINERS | 6 + board/cssi/MCR3000/Kconfig | 15 ++ board/cssi/MCR3000/MCR3000.c | 320 ++++++++++++++++++++++++++++++++++++++++ board/cssi/MCR3000/Makefile | 10 ++ board/cssi/MCR3000/nand.c | 65 ++++++++ board/cssi/MCR3000/u-boot.lds | 91 ++++++++++++ configs/MCR3000_defconfig | 88 +++++++++++ drivers/net/mpc8xx_fec.c | 20 +++ include/configs/MCR3000.h | 162 ++++++++++++++++++++ 11 files changed, 784 insertions(+) create mode 100644 board/cssi/MAINTAINERS create mode 100644 board/cssi/MCR3000/Kconfig create mode 100644 board/cssi/MCR3000/MCR3000.c create mode 100644 board/cssi/MCR3000/Makefile create mode 100644 board/cssi/MCR3000/nand.c create mode 100644 board/cssi/MCR3000/u-boot.lds create mode 100644 configs/MCR3000_defconfig create mode 100644 include/configs/MCR3000.h
diff --git a/.travis.yml b/.travis.yml index 6f14ec2396..226c8313b1 100644 --- a/.travis.yml +++ b/.travis.yml @@ -210,6 +210,8 @@ matrix: - env: - BUILDMAN="mpc86xx" - env: + - BUILDMAN="mpc8xx" + - env: - BUILDMAN="siemens" - env: - BUILDMAN="tegra" diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 9e1ad33c28..5a7db335ed 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -8,6 +8,9 @@ choice prompt "Target select" optional
+config TARGET_MCR3000 + bool "Support MCR3000 board from CSSI" + endchoice
choice @@ -167,4 +170,6 @@ config SYS_OR7_PRELIM config SYS_IMMR hex "Value for IMMR"
+source "board/cssi/MCR3000/Kconfig" + endmenu diff --git a/board/cssi/MAINTAINERS b/board/cssi/MAINTAINERS new file mode 100644 index 0000000000..cbf1406a54 --- /dev/null +++ b/board/cssi/MAINTAINERS @@ -0,0 +1,6 @@ +BOARDS from CS Systemes d'Information +M: Christophe Leroy christophe.leroy@c-s.fr +S: Maintained +F: board/cssi/ +F: include/configs/MCR3000.h +F: configs/MCR3000_defconfig diff --git a/board/cssi/MCR3000/Kconfig b/board/cssi/MCR3000/Kconfig new file mode 100644 index 0000000000..ecfd90fd4c --- /dev/null +++ b/board/cssi/MCR3000/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MCR3000 + +config SYS_BOARD + default "MCR3000" + +config SYS_VENDOR + default "cssi" + +config SYS_CONFIG_NAME + default "MCR3000" + +config SYS_TEXT_BASE + default 0x04000000 + +endif diff --git a/board/cssi/MCR3000/MCR3000.c b/board/cssi/MCR3000/MCR3000.c new file mode 100644 index 0000000000..88dc6d7a36 --- /dev/null +++ b/board/cssi/MCR3000/MCR3000.c @@ -0,0 +1,320 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Florent Trinh Thai florent.trinh-thai@c-s.fr + * Christophe Leroy christophe.leroy@c-s.fr + * + * Board specific routines for the MCR3000 board + * + * - initialisation + * - memory controller + * - serial io initialisation + * - ethernet io initialisation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <hwconfig.h> +#include <mpc8xx.h> +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#endif +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + + +/* ------------------------------------------------------------------------- + * constant + */ +static const uint cs1_dram_table_66[] = { + /* DRAM - single read. (offset 0 in upm RAM) */ + 0x0F3DFC04, 0x0FEFBC04, 0x00BE7804, 0x0FFDF400, + 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - burst read. (offset 8 in upm RAM) */ + 0x0F3DFC04, 0x0FEFBC04, 0x00BF7C04, 0x00FFFC00, + 0x00FFFC00, 0x00FEF800, 0x0FFDF400, 0x1FFFFC05, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - single write. (offset 18 in upm RAM) */ + 0x0F3DFC04, 0x0FEFB800, 0x00BF7404, 0x0FFEF804, + 0x0FFDF404, 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - burst write. (offset 20 in upm RAM) */ + 0x0F3DFC04, 0x0FEFB800, 0x00BF7400, 0x00FFFC00, + 0x00FFFC00, 0x00FFFC04, 0x0FFEF804, 0x0FFDF404, + 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* refresh (offset 30 in upm RAM) */ + 0x0FFDF404, 0x0FFEBC04, 0x0FFD7C84, 0x0FFFFC04, + 0x0FFFFC04, 0x0FFFFC04, 0x1FFFFC85, 0xFFFFFFFF, + + /* init */ + 0x0FEEB874, 0x0FBD7474, 0x1FFFFC45, 0xFFFFFFFF, + + /* exception. (offset 3c in upm RAM) */ + 0xFFFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, +}; + +/* ------------------------------------------------------------------------- + * Device Tree Support + */ +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +static int fdt_set_node_and_value(void *blob, char *nodename, char *regname, + void *var, int size) +{ + int ret = 0; + int nodeoffset = 0; + + nodeoffset = fdt_path_offset(blob, nodename); + if (nodeoffset >= 0) { + ret = fdt_setprop(blob, nodeoffset, regname, var, size); + if (ret < 0) + printf("fdt_setprop(): cannot set %s/%s property; err: %s\n", + nodename, regname, fdt_strerror(ret)); + } else { + printf("ft_blob_update(): cannot find %s node err:%s\n", + nodename, fdt_strerror(nodeoffset)); + } + return ret; +} + +/* + * update "brg" property in the blob + */ +static void ft_blob_update(void *blob, bd_t *bd) +{ + uchar enetaddr[6]; + __be32 brg_data = cpu_to_be32(bd->bi_busfreq); + + /* BRG */ + fdt_set_node_and_value(blob, "/soc/cpm", "brg-frequency", &brg_data, + sizeof(brg_data)); + + /* MAC addr */ + if (eth_getenv_enetaddr("ethaddr", enetaddr)) + fdt_set_node_and_value(blob, "ethernet0", "local-mac-address", + enetaddr, sizeof(u8) * 6); + + /* Bus Frequency for CPM */ + fdt_set_node_and_value(blob, "/soc", "bus-frequency", &bd->bi_busfreq, + sizeof(u32)); +} + +static void ft_e1_setup(void *blob) +{ + ulong data_rate = 2; + ulong channel_phase = 0; + char *sync = "receive"; + + /* Set data rate */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", "data-rate", + &data_rate, sizeof(u32)); + + /* Set channel phase to 0 */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", "channel-phase", + &channel_phase, sizeof(u32)); + + /* rising edge sync pulse transmit */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", + "rising-edge-sync-pulse", sync, + sizeof(u8) * strlen(sync)); +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + ft_blob_update(blob, bd); + ft_e1_setup(blob); +} +#endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ + +/* ------------------------------------------------------------------------- + * Check Board Identity: + */ +int checkboard(void) +{ + serial_puts("BOARD: MCR3000 CSSI\n"); + + return 0; +} + + +/* ------------------------------------------------------------------------- + * Initialize SDRAM + */ +int dram_init(void) +{ + immap_t __iomem *immap = (immap_t __iomem *)CONFIG_SYS_IMMR; + memctl8xx_t __iomem *memctl = &immap->im_memctl; + + printf("UPMA init for SDRAM (CAS latency 2), "); + printf("init address 0x%08x, size ", (int)dram_init); + /* Configure UPMA for cs1 */ + upmconfig(UPMA, (uint *)cs1_dram_table_66, + sizeof(cs1_dram_table_66) / sizeof(uint)); + udelay(10); + out_be16(&memctl->memc_mptpr, 0x0200); + out_be32(&memctl->memc_mamr, 0x14904000); + udelay(10); + out_be32(&memctl->memc_or1, CONFIG_SYS_OR1_PRELIM); + out_be32(&memctl->memc_br1, CONFIG_SYS_BR1_PRELIM); + udelay(10); + out_be32(&memctl->memc_mcr, 0x80002830); + out_be32(&memctl->memc_mar, 0x00000088); + out_be32(&memctl->memc_mcr, 0x80002038); + udelay(200); + + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + SDRAM_MAX_SIZE); + + return 0; +} + +/* ------------------------------------------------------------------------- + * Miscelaneous init + */ + +#define ADDR_CPLD_R_ETAT ((unsigned short *)(ADDR_CPLD + 0x6)) +#define R_ID_CPLD_MASK 0xFF00 + +#define ADDR_FLASH_ENV_AREA ((unsigned short *)(ADDR_FLASH + 0x40000)) + +struct environment { + uint32_t crc; + uint8_t data[]; +}; + + +#define LEN_STR 80 + +int misc_init_r(void) +{ + immap_t __iomem *immr = (immap_t __iomem *)CONFIG_SYS_IMMR; + iop8xx_t __iomem *iop = &immr->im_ioport; + char str[LEN_STR]; + char s_ethaddr[LEN_STR]; + char s_id_cpld[LEN_STR]; + char s_num_serie[LEN_STR]; + char s_password[LEN_STR]; + unsigned short version_cpld; + struct environment *env; + uint32_t crc; + char *s; + int i, j; + + /* -------------------------------------------- + * GPIO or per. Function + * PCPAR[13] = 0 [0x0004] -> GPIO: (BTN_ACQ_AL) + * -------------------------------------------- */ + clrsetbits_be16(&iop->iop_pcpar, 0, 0x4); + + /* ---------------------------------------------- + * In/Out or per. Function 0/1 + * PCDIR[13] = 1 [0x0004] -> GPIO: IN (CS_POT1_5V) + * ---------------------------------------------- */ + clrsetbits_be16(&iop->iop_pcdir, 0, 0x4); + + /* if BTN_ACQ_IN is pressed then bootdelay is changed to 60 second */ + if ((in_be16(&iop->iop_pcdat) & 0x0004) == 0) + setenv("bootdelay", "60"); + + /* verifying environment variable area */ + env = (struct environment *)CONFIG_ENV_ADDR; + crc = crc32(0, env->data, (CONFIG_ENV_SIZE - sizeof(uint32_t))); + if (crc != env->crc) { + /* It can be an update request */ + for (i = 0; i < 8; i++) { + str[i] = *(((uint8_t *)CONFIG_ENV_ADDR) + i); + str[(i+1)] = 0; + } + if (strcmp(str, "ETHADDR=") == 0) { + /* getting saved value */ + i = 0; + for (j = 0; j < 4; j++) { + while (*(((uint8_t *)CONFIG_ENV_ADDR) + i) != + '=') + i++; + switch (j) { + case 0: + s = s_ethaddr; + break; + case 1: + s = s_num_serie; + break; + case 2: + s = s_id_cpld; + break; + case 3: + s = s_password; + break; + } + do { + i++; + *s = *(((uint8_t *)CONFIG_ENV_ADDR) + i); + s++; + } while (*(((uint8_t *)CONFIG_ENV_ADDR) + i) + != 0x00); + } + + /* creating or updating environment variable */ + if (s_ethaddr[0] != 0x00) + setenv("ethaddr", s_ethaddr); + if (s_num_serie[0] != 0x00) + setenv("num_serie", s_num_serie); + if (s_id_cpld[0] != 0x00) + setenv("id_cpld", s_id_cpld); + if (s_password[0] != 0x00) + setenv("password", s_password); + saveenv(); + } + } + + /* we do not modify environment variable area if CRC is false */ + crc = crc32(0, env->data, (CONFIG_ENV_SIZE - sizeof(uint32_t))); + if (crc == env->crc) { + /* getting version value in CPLD register */ + for (i = 0; i < LEN_STR; i++) + str[i] = 0; + version_cpld = *ADDR_CPLD_R_ETAT & R_ID_CPLD_MASK; + if (((version_cpld >> 12) & 0x000f) < 0x000a) + str[0] = ((version_cpld >> 12) & 0x000f) + 0x30; + else + str[0] = (((version_cpld >> 12) & 0x000f) - 0x000a) + + 0x41; + if (((version_cpld >> 8) & 0x000f) < 0x000a) + str[1] = ((version_cpld >> 8) & 0x000f) + 0x30; + else + str[1] = (((version_cpld >> 8) & 0x000f) - 0x000a) + + 0x41; + str[2] = 0x30; + str[3] = 0x30; + + /* updating "id_cpld" variable if not corresponding */ + s = getenv("id_cpld"); + if ((s == NULL) || (strcmp(s, str) != 0)) { + setenv("id_cpld", str); + saveenv(); + } + } + + return 0; +} + +int board_early_init_f(void) +{ + immap_t __iomem *immr = (immap_t __iomem *)CONFIG_SYS_IMMR; + + /* + * Erase FPGA(s) for reboot + */ + clrbits_be32(&immr->im_cpm.cp_pbdat, 0x00020000); /* PROGFPGA down */ + setbits_be32(&immr->im_cpm.cp_pbdir, 0x00020000); /* PROGFPGA output */ + udelay(1); /* Wait more than 300ns */ + setbits_be32(&immr->im_cpm.cp_pbdat, 0x00020000); /* PROGFPGA up */ + + return 0; +} diff --git a/board/cssi/MCR3000/Makefile b/board/cssi/MCR3000/Makefile new file mode 100644 index 0000000000..401d5aa4c1 --- /dev/null +++ b/board/cssi/MCR3000/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2010-2017 CS Systemes d'Information +# Christophe Leroy christophe.leroy@c-s.fr +# +# SPDX-License-Identifier: GPL-2.0+ +# +# + +obj-y += MCR3000.o +obj-$(CONFIG_CMD_NAND) += nand.o diff --git a/board/cssi/MCR3000/nand.c b/board/cssi/MCR3000/nand.c new file mode 100644 index 0000000000..8e5b0d0618 --- /dev/null +++ b/board/cssi/MCR3000/nand.c @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Florent Trinh Thai florent.trinh-thai@c-s.fr + * Christophe Leroy christophe.leroy@c-s.fr + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <nand.h> +#include <asm/io.h> + +#define BIT_CLE ((unsigned short)0x0800) +#define BIT_ALE ((unsigned short)0x0400) +#define BIT_NCE ((unsigned short)0x1000) + +static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd, unsigned int ctrl) +{ + struct nand_chip *this = mtdinfo->priv; + immap_t __iomem *immr = (immap_t __iomem *)CONFIG_SYS_IMMR; + unsigned short pddat = 0; + + /* The hardware control change */ + if (ctrl & NAND_CTRL_CHANGE) { + pddat = in_be16(&immr->im_ioport.iop_pddat); + + /* Clearing ALE and CLE */ + pddat &= ~(BIT_CLE | BIT_ALE); + + /* Driving NCE pin */ + if (ctrl & NAND_NCE) + pddat &= ~BIT_NCE; + else + pddat |= BIT_NCE; + + /* Driving CLE and ALE pin */ + if (ctrl & NAND_CLE) + pddat |= BIT_CLE; + if (ctrl & NAND_ALE) + pddat |= BIT_ALE; + + out_be16(&immr->im_ioport.iop_pddat, pddat); + } + + /* Writing the command */ + if (cmd != NAND_CMD_NONE) + out_8(this->IO_ADDR_W, cmd); +} + +int board_nand_init(struct nand_chip *nand) +{ + immap_t __iomem *immr = (immap_t __iomem *)CONFIG_SYS_IMMR; + + /* Set GPIO Port */ + setbits_be16(&immr->im_ioport.iop_pddir, 0x1c00); + clrbits_be16(&immr->im_ioport.iop_pdpar, 0x1c00); + clrsetbits_be16(&immr->im_ioport.iop_pddat, 0x0c00, 0x1000); + + nand->chip_delay = 60; + nand->ecc.mode = NAND_ECC_SOFT; + nand->cmd_ctrl = nand_hwcontrol; + + return 0; +} diff --git a/board/cssi/MCR3000/u-boot.lds b/board/cssi/MCR3000/u-boot.lds new file mode 100644 index 0000000000..cd042ca0ce --- /dev/null +++ b/board/cssi/MCR3000/u-boot.lds @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Christophe Leroy christophe.leroy@c-s.fr + * + * (C) Copyright 2001-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * Modified by Yuli Barcohen yuli@arabellasw.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_ARCH(powerpc) +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .text : + { + arch/powerpc/cpu/mpc8xx/start.o (.text) + arch/powerpc/cpu/mpc8xx/start.o (.text*) + arch/powerpc/cpu/mpc8xx/traps.o (.text*) + arch/powerpc/cpu/mpc8xx/built-in.o (.text*) + arch/powerpc/lib/built-in.o (.text*) + board/cssi/MCR3000/built-in.o (.text*) + disk/built-in.o (.text*) + drivers/net/built-in.o (.text*) + + *(.text) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + + /* Read-write section, merged into data segment: */ + . = (. + 0x0FFF) & 0xFFFFF000; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(4096); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(4096); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.bss*) + *(.sbss*) + *(COMMON) + . = ALIGN(4); + } + __bss_end = . ; + PROVIDE (end = .); +} +ENTRY(_start) diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig new file mode 100644 index 0000000000..562face283 --- /dev/null +++ b/configs/MCR3000_defconfig @@ -0,0 +1,88 @@ +CONFIG_PPC=y +CONFIG_8xx=y +CONFIG_TARGET_MCR3000=y +CONFIG_BOOTDELAY=5 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_NET=y +CONFIG_CMD_DHCP=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +# CONFIG_MMC is not set +CONFIG_MTD_NOR_FLASH=y +# CONFIG_PCI is not set +CONFIG_OF_LIBFDT=y +CONFIG_SYS_PROMPT="S3K> " +CONFIG_NETDEVICES=y +CONFIG_MPC8XX_FEC=y + +CONFIG_CMD_SAVEENV=y +CONFIG_CMD_FLASH=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_NAND=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_MD5SUM is not set +# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SETGETDCR is not set +# CONFIG_CMD_SHA1 is not set +# CONFIG_CMD_SOURCE is not set +CONFIG_CMD_IMMAP=y + +CONFIG_SYS_IMMR=0xFF000000 + +CONFIG_SYS_OR0_PRELIM=0xFFC00926 +CONFIG_SYS_BR0_PRELIM=0x04000801 +CONFIG_SYS_BR1_PRELIM_BOOL=y +CONFIG_SYS_BR1_PRELIM=0x00000081 +CONFIG_SYS_OR1_PRELIM=0xFE000E00 +CONFIG_SYS_BR2_PRELIM_BOOL=y +CONFIG_SYS_BR2_PRELIM=0x08000801 +CONFIG_SYS_OR2_PRELIM=0xFFFF8F2A +CONFIG_SYS_BR3_PRELIM_BOOL=y +CONFIG_SYS_BR3_PRELIM=0x0C000401 +CONFIG_SYS_OR3_PRELIM=0xFFFF8142 +CONFIG_SYS_BR4_PRELIM_BOOL=y +CONFIG_SYS_BR4_PRELIM=0x10000801 +CONFIG_SYS_OR4_PRELIM=0xFFFF8D08 +CONFIG_SYS_BR5_PRELIM_BOOL=y +CONFIG_SYS_BR5_PRELIM=0x14000801 +CONFIG_SYS_OR5_PRELIM=0xFFFF8916 +CONFIG_SYS_BR6_PRELIM_BOOL=y +CONFIG_SYS_BR6_PRELIM=0x18000801 +CONFIG_SYS_OR6_PRELIM=0xFFFF0908 +CONFIG_SYS_BR7_PRELIM_BOOL=y +CONFIG_SYS_BR7_PRELIM=0x1C000001 +CONFIG_SYS_OR7_PRELIM=0xFFFF810A + +CONFIG_8xx_GCLK_FREQ=132000000 + +CONFIG_SYS_SYPCR=0xFFFFFF8F +CONFIG_SYS_SIUMCR=0x00600400 +CONFIG_SYS_TBSCR=0x00C3 +CONFIG_SYS_PISCR=0x0000 +CONFIG_SYS_PLPRCR_BOOL=y +CONFIG_SYS_PLPRCR=0x00460004 +CONFIG_SYS_SCCR_MASK=0x60000000 +CONFIG_SYS_SCCR=0x00C20000 +CONFIG_SYS_DER=0x2002000F + +CONFIG_AUTOBOOT=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="\nEnter password - autoboot in %d sec...\n" +CONFIG_AUTOBOOT_DELAY_STR="root" + +CONFIG_OF_BOARD_SETUP=y + +CONFIG_LZMA=y +CONFIG_SHA256=y + diff --git a/drivers/net/mpc8xx_fec.c b/drivers/net/mpc8xx_fec.c index b070d6696a..e525d3b593 100644 --- a/drivers/net/mpc8xx_fec.c +++ b/drivers/net/mpc8xx_fec.c @@ -413,6 +413,26 @@ static void fec_pin_init(int fecidx) */ out_be16(&immr->im_ioport.iop_pdpar, 0x1fff); out_be16(&immr->im_ioport.iop_pddir, 0x1fff); + +#if defined(CONFIG_TARGET_MCR3000) + out_be16(&immr->im_ioport.iop_papar, 0xBBFF); + out_be16(&immr->im_ioport.iop_padir, 0x04F0); + out_be16(&immr->im_ioport.iop_paodr, 0x0000); + + out_be32(&immr->im_cpm.cp_pbpar, 0x000133FF); + out_be32(&immr->im_cpm.cp_pbdir, 0x0003BF0F); + out_be16(&immr->im_cpm.cp_pbodr, 0x0000); + + out_be16(&immr->im_ioport.iop_pcpar, 0x0400); + out_be16(&immr->im_ioport.iop_pcdir, 0x0080); + out_be16(&immr->im_ioport.iop_pcso , 0x0D53); + out_be16(&immr->im_ioport.iop_pcint, 0x0000); + + out_be16(&immr->im_ioport.iop_pdpar, 0x03FE); + out_be16(&immr->im_ioport.iop_pddir, 0x1C09); + + setbits_be32(&immr->im_ioport.utmode, 0x80); +#endif #endif
#endif /* CONFIG_ETHER_ON_FEC1 */ diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h new file mode 100644 index 0000000000..019ce894e4 --- /dev/null +++ b/include/configs/MCR3000.h @@ -0,0 +1,162 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Christophe Leroy christophe.leroy@c-s.fr + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "sdram_type=SDRAM\0" \ + "flash_type=AM29LV160DB\0" \ + "loadaddr=0x400000\0" \ + "filename=uImage.lzma\0" \ + "nfsroot=/opt/ofs\0" \ + "dhcp_ip=ip=:::::eth0:dhcp\0" \ + "console_args=console=ttyCPM0,115200N8\0" \ + "flashboot=setenv bootargs " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "mcr3k:eth0:off;" \ + "${ofl_args}; " \ + "bootm 0x04060000 - 0x04050000\0" \ + "tftpboot=setenv bootargs " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "mcr3k:eth0:off " \ + "${ofl_args}; " \ + "tftp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "bootm ${loadaddr} - 0xf00000\0" \ + "netboot=dhcp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "setenv bootargs " \ + "root=/dev/nfs rw " \ + "${console_args} " \ + "${dhcp_ip};" \ + "bootm ${loadaddr} - 0xf00000\0" \ + "nfsboot=setenv bootargs " \ + "root=/dev/nfs rw nfsroot=${serverip}:${nfsroot} " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "mcr3k:eth0:off;" \ + "bootm 0x04060000 - 0x04050000\0" \ + "dhcpboot=dhcp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "setenv bootargs " \ + "${console_args} " \ + "${dhcp_ip} " \ + "${ofl_args}; " \ + "bootm ${loadaddr} - 0xf00000\0" + +#define CONFIG_BOOTDELAY 5 + +#define CONFIG_IPADDR 192.168.0.3 +#define CONFIG_SERVERIP 192.168.0.1 +#define CONFIG_NETMASK 255.0.0.0 + +#define CONFIG_BOOTCOMMAND "run flashboot" +#define CONFIG_BOOTARGS "ubi.mtd=4 root=ubi0:rootfs rw " \ + "rootfstype=ubifs rootflags=sync " \ + "console=ttyCPM0,115200N8 " \ + "ip=${ipaddr}:::${netmask}:mcr3k:eth0:off" + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#undef CONFIG_LOADS_BAUD_CHANGE /* don't allow baudrate change */ + +#define CONFIG_WATCHDOG 1 /* watchdog enabled */ + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_CMDLINE_EDITING 1 +#ifdef CONFIG_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "S3K> " +#endif + +#define CONFIG_SYS_MEMTEST_START 0x00002000 +#define CONFIG_SYS_MEMTEST_END 0x00800000 + +#define CONFIG_SYS_LOAD_ADDR 0x200000 + +#define CONFIG_SYS_HZ 1000 + +/* Physical memory map of the MCR3000 board */ +#define ADDR_FLASH (CONFIG_SYS_BR0_PRELIM & 0xFFFF0000) +#define ADDR_CPLD ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000800) + +/* Definitions for initial stack pointer and data area (in DPRAM) */ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR +#define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 +#define CONFIG_SYS_GBL_DATA_SIZE 64 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* RAM configuration (note that CONFIG_SYS_SDRAM_BASE must be zero) */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define SDRAM_MAX_SIZE (32 * 1024 * 1024) + +/* FLASH organization */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 35 +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) +#define CONFIG_SYS_MONITOR_LEN (256 << 10) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MALLOC_LEN (4096 << 10) + +/* Environment Configuration */ + +/* environment is in FLASH */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) +#define CONFIG_ENV_OVERWRITE 1 + +/* Cache Configuration */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +/* Ethernet configuration part */ +#define CONFIG_SYS_DISCOVER_PHY 1 +#ifdef CONFIG_MPC8XX_FEC +#define CONFIG_MII_INIT 1 +#endif + +/* NAND configuration part */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#define CONFIG_SYS_NAND_BASE 0x0C000000 + +/* Internal Definitions */ + +/* Boot Flags*/ +#define BOOTFLAG_COLD 0x01 +#define BOOTFLAG_WARM 0x02 + +/* Misc Settings */ +#define CONFIG_CMD_REGINFO + +#endif /* __CONFIG_H */
Dear Christophe,
Thanks.
- Device Tree Support
Incorrect multiline comment style... Please fix globally.
This is apparently ancient code. No other board does it this way any more. It seems do_fixup_by_path_*() is preferred now.
Is this not a redundant setting? Can you not use CONFIG_ENV_ADDR instead?
- uint32_t crc;
- uint8_t data[];
This is a (incomplete) redefine of struct environment_s. Why cannot you use that?
- /* verifying environment variable area */
- env = (struct environment *)CONFIG_ENV_ADDR;
- crc = crc32(0, env->data, (CONFIG_ENV_SIZE - sizeof(uint32_t)));
- if (crc != env->crc) {
str[(i+1)] = 0;
i = 0;
i++;
switch (j) {
case 0:
s = s_ethaddr;
break;
case 1:
s = s_num_serie;
break;
case 2:
s = s_id_cpld;
break;
case 3:
s = s_password;
break;
do {
i++;
s++;
!= 0x00);
saveenv();
This code is pretty scary...
- /* we do not modify environment variable area if CRC is false */
- if (crc == env->crc) {
str[i] = 0;
else
0x41;
else
0x41;
str[2] = 0x30;
str[3] = 0x30;
saveenv();
And again comment (we do not modify environment variable area) and code (call to saveenv()) do not agree.
This code is giving me the creeps...
Reviewed-by: Wolfgang Denk wd@denx.de
Dear Wolfgang,
Le 06/07/2017 à 17:23, Wolfgang Denk a écrit :
Dear Christophe,
Thanks.
Oops, I only fixed the ones in the .h Done everywhere now.
Ok
Yes you are right, fixed it.
- uint32_t crc;
- uint8_t data[];
str[(i+1)] = 0;
i = 0;
i++;
switch (j) {
case 0:
s = s_ethaddr;
break;
case 1:
s = s_num_serie;
break;
case 2:
s = s_id_cpld;
break;
case 3:
s = s_password;
break;
do {
i++;
s++;
!= 0x00);
saveenv();
Ok, I remove it for the time being, this code is not necessary for starting the board. Will fix that later in a more correct way.
str[i] = 0;
else
0x41;
else
0x41;
str[2] = 0x30;
str[3] = 0x30;
saveenv();
Ok, removed (see above).
Best regards Christophe
Hello Christophe,
Am 06.07.2017 um 16:45 schrieb Christophe Leroy:
no more comments beside Wolfgangs.
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Christophe LEROY
Christophe Leroy
Heiko Schocher
