[U-Boot] [PATCH] net/eth: add newline to "failed MAC address" warning
This prevents u-boot to display during bootime: Out: serial Err: serial Net: UEC3Warning: failed to set MAC address
Now corrected and it will display: Out: serial Err: serial Net: UEC3 Warning: failed to set MAC address
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- net/eth.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/net/eth.c b/net/eth.c index 02baa37..1c0c780 100644 --- a/net/eth.c +++ b/net/eth.c @@ -302,7 +302,7 @@ int eth_initialize(bd_t *bis) puts("\nWarning: eth device name has a space!\n");
if (eth_write_hwaddr(dev, "eth", eth_number)) - puts("Warning: failed to set MAC address\n"); + puts("\nWarning: failed to set MAC address\n");
eth_number++; dev = dev->next;
Signed-off-by: Holger Brunckholger.brunck@keymile.com
Acked-by: Philip Balister philip@opensdr.com
But, when i submitted the same patch, I was told this is not the right way to solve the problem. I would still like to see this patch go in until someone has time to rewrite the problem section of code.
Philip
puts("\nWarning: failed to set MAC address\n"); eth_number++; dev = dev->next;
i don't think it is the right way long term, but short term, i think it's correct wrt the surrounding code. -mike
Yes I agree. It never meant to be more than a bootlog improvement. The root cause should be fixed in the long term.
Regards Holger
Dear Holger Brunck,
In message 1316782071-8988-1-git-send-email-holger.brunck@keymile.com you wrote:
Applied, thanks.
Holger Brunck
Mike Frysinger
Philip Balister
