[PATCH v3 0/4] Deduplicate dhelectronics board files
This series unifies common MAC address code for imx6, imx8 and stm32 based boards by DH. It is thought of as a starting point for more deduplication in the future.
Changes in v3: - Entire series reviewed by Marek
Changes in v2: - Tested-by Marek - convert to livetree (rebase on commit 5a605b7c86152) - Fix spelling
Philip Oberfichtner (4): board: dhelectronics: Implement common MAC address functions ARM: imx6: DH: Use common MAC address functions ARM: imx8: DH: Use common MAC address functions ARM: stm32: DH: Use common MAC address functions
board/dhelectronics/common/Makefile | 10 ++ board/dhelectronics/common/dh_common.c | 65 ++++++++++ board/dhelectronics/common/dh_common.h | 28 ++++ board/dhelectronics/common/dh_imx.c | 24 ++++ board/dhelectronics/common/dh_imx.h | 12 ++ board/dhelectronics/dh_imx6/dh_imx6.c | 47 ++----- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 121 +++++++----------- board/dhelectronics/dh_stm32mp1/board.c | 102 +++++++-------- 8 files changed, 246 insertions(+), 163 deletions(-) create mode 100644 board/dhelectronics/common/Makefile create mode 100644 board/dhelectronics/common/dh_common.c create mode 100644 board/dhelectronics/common/dh_common.h create mode 100644 board/dhelectronics/common/dh_imx.c create mode 100644 board/dhelectronics/common/dh_imx.h
This is a starting point for unifying duplicate code in the DH board files. The functions for setting up MAC addresses are very similar for the i.MX6, i.MX8 and stm32mp1 based boards.
All pre-existing implementations follow the same logic:
(1) Check if ethaddr is already set in the environment (2) If not, try to get it from a board specific location (e.g. fuse) (3) If not, try to get it from eeprom
After this commit, (1) and (3) are implemented as common functions, ready to be used by board specific files.
Furthermore there is an implementation of (2) for imx based boards.
Signed-off-by: Philip Oberfichtner pro@denx.de Reviewed-by: Marek Vasut marex@denx.de ---
Changes in v3: - Reviewed by Marek
Changes in v2: - convert to livetree (rebase on commit 5a605b7c86152)
board/dhelectronics/common/Makefile | 10 ++++ board/dhelectronics/common/dh_common.c | 65 ++++++++++++++++++++++++++ board/dhelectronics/common/dh_common.h | 28 +++++++++++ board/dhelectronics/common/dh_imx.c | 24 ++++++++++ board/dhelectronics/common/dh_imx.h | 12 +++++ 5 files changed, 139 insertions(+) create mode 100644 board/dhelectronics/common/Makefile create mode 100644 board/dhelectronics/common/dh_common.c create mode 100644 board/dhelectronics/common/dh_common.h create mode 100644 board/dhelectronics/common/dh_imx.c create mode 100644 board/dhelectronics/common/dh_imx.h
diff --git a/board/dhelectronics/common/Makefile b/board/dhelectronics/common/Makefile new file mode 100644 index 0000000000..a472ea8d51 --- /dev/null +++ b/board/dhelectronics/common/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de +# + +obj-y += dh_common.o + +ifneq (,$(CONFIG_ARCH_MX6)$(CONFIG_ARCH_IMX8M)) +obj-y += dh_imx.o +endif diff --git a/board/dhelectronics/common/dh_common.c b/board/dhelectronics/common/dh_common.c new file mode 100644 index 0000000000..67e3d59b1f --- /dev/null +++ b/board/dhelectronics/common/dh_common.c @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + * Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +#include <common.h> +#include <dm.h> +#include <i2c_eeprom.h> +#include <net.h> + +#include "dh_common.h" + +bool dh_mac_is_in_env(const char *env) +{ + unsigned char enetaddr[6]; + + return eth_env_get_enetaddr(env, enetaddr); +} + +int dh_get_mac_from_eeprom(unsigned char *enetaddr, const char *alias) +{ + struct udevice *dev; + int ret; + ofnode node; + + node = ofnode_path(alias); + if (!ofnode_valid(node)) { + printf("%s: ofnode for %s not found!", __func__, alias); + return -ENOENT; + } + + ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, node, &dev); + if (ret) { + printf("%s: Cannot find EEPROM! ret = %d\n", __func__, ret); + return ret; + } + + ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6); + if (ret) { + printf("%s: Error reading EEPROM! ret = %d\n", __func__, ret); + return ret; + } + + if (!is_valid_ethaddr(enetaddr)) { + printf("%s: Address read from EEPROM is invalid!\n", __func__); + return -EINVAL; + } + + return 0; +} + +__weak int dh_setup_mac_address(void) +{ + unsigned char enetaddr[6]; + + if (dh_mac_is_in_env("ethaddr")) + return 0; + + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) + return eth_env_set_enetaddr("ethaddr", enetaddr); + + printf("%s: Unable to set mac address!\n", __func__); + return -ENXIO; +} diff --git a/board/dhelectronics/common/dh_common.h b/board/dhelectronics/common/dh_common.h new file mode 100644 index 0000000000..2b24637d96 --- /dev/null +++ b/board/dhelectronics/common/dh_common.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +/* + * dh_mac_is_in_env - Check if MAC address is already set + * + * @env: name of environment variable + * Return: true if MAC is set, false otherwise + */ +bool dh_mac_is_in_env(const char *env); + +/* + * dh_get_mac_from_eeprom - Get MAC address from eeprom and write it to enetaddr + * + * @enetaddr: buffer where address is to be stored + * @alias: alias for EEPROM device tree node + * Return: 0 if OK, other value on error + */ +int dh_get_mac_from_eeprom(unsigned char *enetaddr, const char *alias); + +/* + * dh_setup_mac_address - Try to get MAC address from various locations and write it to env + * + * Return: 0 if OK, other value on error + */ +int dh_setup_mac_address(void); diff --git a/board/dhelectronics/common/dh_imx.c b/board/dhelectronics/common/dh_imx.c new file mode 100644 index 0000000000..7f451bad59 --- /dev/null +++ b/board/dhelectronics/common/dh_imx.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + * Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <common.h> +#include <net.h> +#include "dh_imx.h" + +int dh_imx_get_mac_from_fuse(unsigned char *enetaddr) +{ + /* + * If IIM fuses contain valid MAC address, use it. + * The IIM MAC address fuses are NOT programmed by default. + */ + imx_get_mac_from_fuse(0, enetaddr); + if (!is_valid_ethaddr(enetaddr)) + return -EINVAL; + + return 0; +} diff --git a/board/dhelectronics/common/dh_imx.h b/board/dhelectronics/common/dh_imx.h new file mode 100644 index 0000000000..284f8637fb --- /dev/null +++ b/board/dhelectronics/common/dh_imx.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +/* + * dh_imx_get_mac_from_fuse - Get MAC address from fuse and write it to env + * + * @enetaddr: buffer where address is to be stored + * Return: 0 if OK, other value on error + */ +int dh_imx_get_mac_from_fuse(unsigned char *enetaddr);
To reduce code duplication, let the imx6 based DH boards use the common code for setting up their MAC addresses.
Signed-off-by: Philip Oberfichtner pro@denx.de Tested-by: Marek Vasut marex@denx.de Reviewed-by: Marek Vasut marex@denx.de ---
board/dhelectronics/dh_imx6/dh_imx6.c | 47 ++++++++------------------- 1 file changed, 14 insertions(+), 33 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index e8aba83e1a..07fc9b1fe6 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -36,6 +36,9 @@ #include <linux/delay.h> #include <usb/ehci-ci.h>
+#include "../common/dh_common.h" +#include "../common/dh_imx.h" + DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) @@ -82,46 +85,24 @@ int board_usb_phy_mode(int port) } #endif
-static int setup_dhcom_mac_from_fuse(void) +int dh_setup_mac_address(void) { - struct udevice *dev; - ofnode eeprom; unsigned char enetaddr[6]; - int ret;
- ret = eth_env_get_enetaddr("ethaddr", enetaddr); - if (ret) /* ethaddr is already set */ + if (dh_mac_is_in_env("ethaddr")) return 0;
- imx_get_mac_from_fuse(0, enetaddr); - - if (is_valid_ethaddr(enetaddr)) { - eth_env_set_enetaddr("ethaddr", enetaddr); - return 0; - } - - eeprom = ofnode_get_aliases_node("eeprom0"); - if (!ofnode_valid(eeprom)) { - printf("Can't find eeprom0 alias!\n"); - return -ENODEV; - } + if (!dh_imx_get_mac_from_fuse(enetaddr)) + goto out;
- ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, eeprom, &dev); - if (ret) { - printf("Cannot find EEPROM!\n"); - return ret; - } + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) + goto out;
- ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6); - if (ret) { - printf("Error reading configuration EEPROM!\n"); - return ret; - } + printf("%s: Unable to get MAC address!\n", __func__); + return -ENXIO;
- if (is_valid_ethaddr(enetaddr)) - eth_env_set_enetaddr("ethaddr", enetaddr); - - return 0; +out: + return eth_env_set_enetaddr("ethaddr", enetaddr); }
int board_early_init_f(void) @@ -188,7 +169,7 @@ int board_late_init(void) u32 hw_code; char buf[16];
- setup_dhcom_mac_from_fuse(); + dh_setup_mac_address();
hw_code = board_get_hwcode();
To reduce code duplication, let the imx8 based DH boards use the common code for setting up their MAC addresses.
.../dh_imx8mp/imx8mp_dhcom_pdk2.c | 121 +++++++----------- 1 file changed, 48 insertions(+), 73 deletions(-)
diff --git a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c index 8676c44d0d..6f06daf86f 100644 --- a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c +++ b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c @@ -16,6 +16,8 @@ #include <miiphy.h>
#include "lpddr4_timing.h" +#include "../common/dh_common.h" +#include "../common/dh_imx.h"
@@ -75,95 +77,68 @@ static void setup_fec(void) set_clk_enet(ENET_125MHZ); }
-static int setup_mac_address_from_eeprom(char *alias, char *env, bool odd) +static int dh_imx8_setup_ethaddr(void) { unsigned char enetaddr[6]; - struct udevice *dev; - int ret, offset; - - offset = fdt_path_offset(gd->fdt_blob, alias); - if (offset < 0) { - printf("%s: No eeprom0 path offset\n", __func__); - return offset; - } - - ret = uclass_get_device_by_of_offset(UCLASS_I2C_EEPROM, offset, &dev); - if (ret) { - printf("Cannot find EEPROM!\n"); - return ret; - } - - ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6); - if (ret) { - printf("Error reading configuration EEPROM!\n"); - return ret; - } + + if (dh_mac_is_in_env("ethaddr")) + return 0; + + if (!dh_imx_get_mac_from_fuse(enetaddr)) + goto out; + + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) + goto out; + + return -ENXIO; + +out: + return eth_env_set_enetaddr("ethaddr", enetaddr); +} + +static int dh_imx8_setup_eth1addr(void) +{ + unsigned char enetaddr[6]; + + if (dh_mac_is_in_env("eth1addr")) + return 0; + + if (!dh_imx_get_mac_from_fuse(enetaddr)) + goto increment_out; + + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom1")) + goto out;
/* * Populate second ethernet MAC from first ethernet EEPROM with MAC * address LSByte incremented by 1. This is only used on SoMs without * second ethernet EEPROM, i.e. early prototypes. */ - if (odd) - enetaddr[5]++; + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) + goto increment_out;
- eth_env_set_enetaddr(env, enetaddr); + return -ENXIO;
- return 0; +increment_out: + enetaddr[5]++; + +out: + return eth_env_set_enetaddr("eth1addr", enetaddr); }
-static void setup_mac_address(void) +int dh_setup_mac_address(void) { - unsigned char enetaddr[6]; - bool skip_eth0 = false; - bool skip_eth1 = false; int ret;
- ret = eth_env_get_enetaddr("ethaddr", enetaddr); - if (ret) /* ethaddr is already set */ - skip_eth0 = true; - - ret = eth_env_get_enetaddr("eth1addr", enetaddr); - if (ret) /* eth1addr is already set */ - skip_eth1 = true; + ret = dh_imx8_setup_ethaddr(); + if (ret) + printf("%s: Unable to setup ethaddr! ret = %d\n", __func__, ret);
- /* Both MAC addresses are already set in U-Boot environment. */ - if (skip_eth0 && skip_eth1) - return; + ret = dh_imx8_setup_eth1addr(); + if (ret) + printf("%s: Unable to setup eth1addr! ret = %d\n", __func__, ret);
- /* - * If IIM fuses contain valid MAC address, use it. - * The IIM MAC address fuses are NOT programmed by default. - */ - imx_get_mac_from_fuse(0, enetaddr); - if (is_valid_ethaddr(enetaddr)) { - if (!skip_eth0) - eth_env_set_enetaddr("ethaddr", enetaddr); - /* - * The LSbit of MAC address in fuses is always 0, use the - * next consecutive MAC address for the second ethernet. - */ - enetaddr[5]++; - if (!skip_eth1) - eth_env_set_enetaddr("eth1addr", enetaddr); - return; - } - - /* Use on-SoM EEPROMs with pre-programmed MAC address. */ - if (!skip_eth0) { - /* We cannot do much more if this returns -ve . */ - setup_mac_address_from_eeprom("eeprom0", "ethaddr", false); - } - - if (!skip_eth1) { - ret = setup_mac_address_from_eeprom("eeprom1", "eth1addr", - false); - if (ret) { /* Second EEPROM might not be populated. */ - /* We cannot do much more if this returns -ve . */ - setup_mac_address_from_eeprom("eeprom0", "eth1addr", - true); - } - } + return ret; }
int board_init(void) @@ -176,7 +151,7 @@ int board_init(void)
int board_late_init(void) { - setup_mac_address(); + dh_setup_mac_address(); return 0; }
To reduce code duplication, let the stm32 based DH boards use the common code for setting up their MAC addresses.
Changes in v2: - convert to livetree (rebase on commit 5a605b7c86152) - Tested-by Marek
board/dhelectronics/dh_stm32mp1/board.c | 102 +++++++++++------------- 1 file changed, 45 insertions(+), 57 deletions(-)
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 7a4c08cb7f..ab354e3e33 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -42,6 +42,7 @@ #include <usb/dwc2_udc.h> #include <watchdog.h> #include <dm/ofnode.h> +#include "../common/dh_common.h" #include "../../st/common/stpmic1.h"
/* SYSCFG registers */ @@ -84,36 +85,17 @@ #define KS_CIDER 0xC0 #define CIDER_ID 0x8870
-int setup_mac_address(void) +static bool dh_stm32_mac_is_in_ks8851(void) { - unsigned char enetaddr[6]; - bool skip_eth0 = false; - bool skip_eth1 = false; - struct udevice *dev; - int ret; ofnode node; - - ret = eth_env_get_enetaddr("ethaddr", enetaddr); - if (ret) /* ethaddr is already set */ - skip_eth0 = true; + u32 reg, cider, ccr;
node = ofnode_path("ethernet1"); - if (!ofnode_valid(node)) { - /* ethernet1 is not present in the system */ - skip_eth1 = true; - goto out_set_ethaddr; - } + if (!ofnode_valid(node)) + return false;
- ret = eth_env_get_enetaddr("eth1addr", enetaddr); - if (ret) { - /* eth1addr is already set */ - skip_eth1 = true; - goto out_set_ethaddr; - } - - ret = ofnode_device_is_compatible(node, "micrel,ks8851-mll"); - if (ret) - goto out_set_ethaddr; + if (ofnode_device_is_compatible(node, "micrel,ks8851-mll")) + return false;
/* * KS8851 with EEPROM may use custom MAC from EEPROM, read @@ -121,56 +103,62 @@ int setup_mac_address(void) * is present. If EEPROM is present, it must contain valid * MAC address. */ - u32 reg, cider, ccr; reg = ofnode_get_addr(node); if (!reg) - goto out_set_ethaddr; + return false;
writew(KS_BE0 | KS_BE1 | KS_CIDER, reg + 2); cider = readw(reg); - if ((cider & 0xfff0) != CIDER_ID) { - skip_eth1 = true; - goto out_set_ethaddr; - } + if ((cider & 0xfff0) != CIDER_ID) + return true;
writew(KS_BE0 | KS_BE1 | KS_CCR, reg + 2); ccr = readw(reg); - if (ccr & KS_CCR_EEPROM) { - skip_eth1 = true; - goto out_set_ethaddr; - } + if (ccr & KS_CCR_EEPROM) + return true; + + return false; +}
-out_set_ethaddr: - if (skip_eth0 && skip_eth1) +static int dh_stm32_setup_ethaddr(void) +{ + unsigned char enetaddr[6]; + + if (dh_mac_is_in_env("ethaddr")) return 0;
- node = ofnode_path("eeprom0"); - if (!ofnode_valid(node)) { - printf("%s: No eeprom0 path offset\n", __func__); - return -ENOENT; - } + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) + return eth_env_set_enetaddr("ethaddr", enetaddr);
- ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, node, &dev); - if (ret) { - printf("Cannot find EEPROM!\n"); - return ret; - } + return -ENXIO; +}
- ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6); - if (ret) { - printf("Error reading configuration EEPROM!\n"); - return ret; - } +static int dh_stm32_setup_eth1addr(void) +{ + unsigned char enetaddr[6];
- if (is_valid_ethaddr(enetaddr)) { - if (!skip_eth0) - eth_env_set_enetaddr("ethaddr", enetaddr); + if (dh_mac_is_in_env("eth1addr")) + return 0;
+ if (dh_stm32_mac_is_in_ks8851()) + return 0; + + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) { enetaddr[5]++; - if (!skip_eth1) - eth_env_set_enetaddr("eth1addr", enetaddr); + return eth_env_set_enetaddr("eth1addr", enetaddr); }
+ return -ENXIO; +} + +int setup_mac_address(void) +{ + if (dh_stm32_setup_ethaddr()) + printf("%s: Unable to setup ethaddr!\n", __func__); + + if (dh_stm32_setup_eth1addr()) + printf("%s: Unable to setup eth1addr!\n", __func__); + return 0; }
skip_eth0 = true;
skip_eth1 = true;
return false;
- if (ret) {
skip_eth1 = true;
- if (ret)
return false;
- KS8851 with EEPROM may use custom MAC from EEPROM, read
return false;
skip_eth1 = true;
return true;
skip_eth1 = true;
return true;
- return false;
-out_set_ethaddr:
- if (dh_mac_is_in_env("ethaddr")) return 0;
return -ENOENT;
- if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0"))
- if (ret) {
return ret;
- return -ENXIO;
- if (ret) {
return ret;
if (!skip_eth0)
if (!skip_eth1)
return -ENXIO;
- if (dh_stm32_setup_ethaddr())
- if (dh_stm32_setup_eth1addr())
- return 0; }
Minor remarks on the last function:
the 2 'printf' calls can be replaced by log_error() call (or log_debug ?)
to correctly handle this trace with CONFIG_LOG_LEVEL
=> printf should avoid except in command result to handle log features during initialization
Anyway
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Patrick DELAUNAY
Philip Oberfichtner
