[PATCH v3 0/3] rockchip: rk35xx: Implement checkboard() to print SoC variant
Information about what SoC model and variant can be found in OTP. This series use this information in checkboard() to print out the running SoC model and variant, should match what is printed on the SoC.
There are some asumptions taken on how some of the OTP values are encoded, however for my boards this seem to match and something like one of the following is shown with this applied:
SoC: RK3566 SoC: RK3566T SoC: RK3568 SoC: RK3568B2 SoC: RK3568J
SoC: RK3582 SoC: RK3588 SoC: RK3588S SoC: RK3588S2
SoC: RK3308B SoC: RK3308B-S
Changes in v3: - Fix build issue with MISC=n or ROCKCHIP_OTP=n - Remove use of cpu-version - Use log_debug() instead of debug()
Changes in v2: - Drop changes in generic-rk35xx_defconfig - Update code comments - Add patch for rk3308
This can probably be converted into an sysinfo driver in a future series, once other pending changes to sysinfo core have settled.
Jonas Karlman (3): rockchip: rk356x: Implement checkboard() to print SoC variant rockchip: rk3588: Implement checkboard() to print SoC variant rockchip: rk3308: Implement checkboard() to print SoC variant
arch/arm/dts/rk356x-u-boot.dtsi | 4 ++ arch/arm/dts/rk3588s-u-boot.dtsi | 4 ++ arch/arm/mach-rockchip/rk3308/rk3308.c | 16 +++++++ arch/arm/mach-rockchip/rk3568/rk3568.c | 61 ++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3588/rk3588.c | 52 ++++++++++++++++++++++ 5 files changed, 137 insertions(+)
Implement checkboard() to print current SoC model used by a board, e.g. one of:
when U-Boot proper is running.
U-Boot 2025.01-rc1 (Nov 10 2024 - 00:39:37 +0000)
Model: Generic RK3566/RK3568 SoC: RK3568J DRAM: 8 GiB (effective 7.7 GiB)
Information about the SoC model and variant is read from OTP.
Also update rk356x-u-boot.dtsi to include OTP in U-Boot pre-reloc phase, where checkboard() is called.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v3: - Fix build issue with MISC=n or ROCKCHIP_OTP=n - Remove use of cpu-version - Use log_debug() instead of debug() v2: - Update commit message - Update code comments - Drop generic-rk3568_defconfig change --- arch/arm/dts/rk356x-u-boot.dtsi | 4 ++ arch/arm/mach-rockchip/rk3568/rk3568.c | 61 ++++++++++++++++++++++++++ 2 files changed, 65 insertions(+)
diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index 0a0943b462a9..24a976cf7e21 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -87,6 +87,10 @@ bootph-all; };
+&otp { + bootph-some-ram; +}; + &pcfg_pull_none { bootph-all; }; diff --git a/arch/arm/mach-rockchip/rk3568/rk3568.c b/arch/arm/mach-rockchip/rk3568/rk3568.c index c9a32287e924..c2b96902d2dd 100644 --- a/arch/arm/mach-rockchip/rk3568/rk3568.c +++ b/arch/arm/mach-rockchip/rk3568/rk3568.c @@ -3,7 +3,10 @@ * (C) Copyright 2021 Rockchip Electronics Co., Ltd */
+#define LOG_CATEGORY LOGC_ARCH + #include <dm.h> +#include <misc.h> #include <asm/armv8/mmu.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/grf_rk3568.h> @@ -139,3 +142,61 @@ int arch_cpu_init(void) #endif return 0; } + +#define RK3568_OTP_CPU_CODE_OFFSET 0x02 +#define RK3568_OTP_SPECIFICATION_OFFSET 0x07 +#define RK3568_OTP_PERFORMANCE_OFFSET 0x22 + +int checkboard(void) +{ + u8 cpu_code[2], specification, package, performance; + struct udevice *dev; + char suffix[3]; + int ret; + + if (!IS_ENABLED(CONFIG_ROCKCHIP_OTP) || !CONFIG_IS_ENABLED(MISC)) + return 0; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(rockchip_otp), &dev); + if (ret) { + log_debug("Could not find otp device, ret=%d\n", ret); + return 0; + } + + /* cpu-code: SoC model, e.g. 0x35 0x66 or 0x35 0x68 */ + ret = misc_read(dev, RK3568_OTP_CPU_CODE_OFFSET, cpu_code, 2); + if (ret < 0) { + log_debug("Could not read cpu-code, ret=%d\n", ret); + return 0; + } + + /* specification: SoC variant, e.g. 0x2 for RK3568B2 and 0xA for RK3568J */ + ret = misc_read(dev, RK3568_OTP_SPECIFICATION_OFFSET, &specification, 1); + if (ret < 0) { + log_debug("Could not read specification, ret=%d\n", ret); + return 0; + } + /* package: likely SoC variant revision, 0x2 for RK3568B2 */ + package = specification >> 5; + specification &= 0x1f; + + /* performance: used to identify RK3566T SoC variant */ + ret = misc_read(dev, RK3568_OTP_PERFORMANCE_OFFSET, &performance, 1); + if (ret < 0) { + log_debug("Could not read performance, ret=%d\n", ret); + return 0; + } + if (performance & 0x0f) + specification = 0x14; /* T-variant */ + + /* for RK3568J i.e. '@' + 0xA = 'J' */ + suffix[0] = specification > 1 ? '@' + specification : '\0'; + /* for RK3568B2 i.e. '0' + 0x2 = '2' */ + suffix[1] = package > 1 ? '0' + package : '\0'; + suffix[2] = '\0'; + + printf("SoC: RK%02x%02x%s\n", cpu_code[0], cpu_code[1], suffix); + + return 0; +}
Tested-by: FUKAUMI Naoki naoki@radxa.com
SoC: RK3566 SoC: RK3566T SoC: RK3568 SoC: RK3568J
-- FUKAUMI Naoki Radxa Computer (Shenzhen) Co., Ltd.
v3:
v2:
+&otp {
- bootph-some-ram;
- &pcfg_pull_none { bootph-all; };
- (C) Copyright 2021 Rockchip Electronics Co., Ltd
- #include <dm.h>
- u8 cpu_code[2], specification, package, performance;
- struct udevice *dev;
- char suffix[3];
- int ret;
- if (!IS_ENABLED(CONFIG_ROCKCHIP_OTP) || !CONFIG_IS_ENABLED(MISC))
- ret = uclass_get_device_by_driver(UCLASS_MISC,
- if (ret) {
- /* cpu-code: SoC model, e.g. 0x35 0x66 or 0x35 0x68 */
- ret = misc_read(dev, RK3568_OTP_CPU_CODE_OFFSET, cpu_code, 2);
- if (ret < 0) {
- /* specification: SoC variant, e.g. 0x2 for RK3568B2 and 0xA for RK3568J */
- ret = misc_read(dev, RK3568_OTP_SPECIFICATION_OFFSET, &specification, 1);
- if (ret < 0) {
- /* package: likely SoC variant revision, 0x2 for RK3568B2 */
- package = specification >> 5;
- specification &= 0x1f;
- /* performance: used to identify RK3566T SoC variant */
- ret = misc_read(dev, RK3568_OTP_PERFORMANCE_OFFSET, &performance, 1);
- if (ret < 0) {
- if (performance & 0x0f)
- /* for RK3568J i.e. '@' + 0xA = 'J' */
- suffix[0] = specification > 1 ? '@' + specification : '\0';
- /* for RK3568B2 i.e. '0' + 0x2 = '2' */
- suffix[1] = package > 1 ? '0' + package : '\0';
- suffix[2] = '\0';
- printf("SoC: RK%02x%02x%s\n", cpu_code[0], cpu_code[1], suffix);
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
v3:
v2:
+&otp {
- bootph-some-ram;
- #include <dm.h>
- char suffix[3];
- int ret;
- if (ret) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- suffix[2] = '\0';
SoC: RK3582 SoC: RK3588 SoC: RK3588J SoC: RK3588S SoC: RK3588S2
U-Boot 2025.01-rc1 (Nov 10 2024 - 00:31:29 +0000)
Model: Generic RK3588S/RK3588 SoC: RK3588S2 DRAM: 8 GiB
Also update rk3588s-u-boot.dtsi to include OTP in U-Boot pre-reloc phase, where checkboard() is called.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v3: - Fix build issue with MISC=n or ROCKCHIP_OTP=n - Remove use of cpu-version - Use log_debug() instead of debug() v2: - Update commit message - Update code comments - Drop generic-rk3588_defconfig change --- arch/arm/dts/rk3588s-u-boot.dtsi | 4 ++ arch/arm/mach-rockchip/rk3588/rk3588.c | 52 ++++++++++++++++++++++++++ 2 files changed, 56 insertions(+)
diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index 09d8b311cec5..8880d162b11c 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -69,6 +69,10 @@ bootph-all; };
+&otp { + bootph-some-ram; +}; + &pcfg_pull_down { bootph-all; }; diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index e2dac2a5b806..c1dce3ee3703 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -4,6 +4,10 @@ * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. */
+#define LOG_CATEGORY LOGC_ARCH + +#include <dm.h> +#include <misc.h> #include <spl.h> #include <asm/armv8/mmu.h> #include <asm/arch-rockchip/bootrom.h> @@ -178,3 +182,51 @@ int arch_cpu_init(void) return 0; } #endif + +#define RK3588_OTP_CPU_CODE_OFFSET 0x02 +#define RK3588_OTP_SPECIFICATION_OFFSET 0x06 + +int checkboard(void) +{ + u8 cpu_code[2], specification, package; + struct udevice *dev; + char suffix[3]; + int ret; + + if (!IS_ENABLED(CONFIG_ROCKCHIP_OTP) || !CONFIG_IS_ENABLED(MISC)) + return 0; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(rockchip_otp), &dev); + if (ret) { + log_debug("Could not find otp device, ret=%d\n", ret); + return 0; + } + + /* cpu-code: SoC model, e.g. 0x35 0x82 or 0x35 0x88 */ + ret = misc_read(dev, RK3588_OTP_CPU_CODE_OFFSET, cpu_code, 2); + if (ret < 0) { + log_debug("Could not read cpu-code, ret=%d\n", ret); + return 0; + } + + /* specification: SoC variant, e.g. 0xA for RK3588J and 0x13 for RK3588S */ + ret = misc_read(dev, RK3588_OTP_SPECIFICATION_OFFSET, &specification, 1); + if (ret < 0) { + log_debug("Could not read specification, ret=%d\n", ret); + return 0; + } + /* package: likely SoC variant revision, 0x2 for RK3588S2 */ + package = specification >> 5; + specification &= 0x1f; + + /* for RK3588J i.e. '@' + 0xA = 'J' */ + suffix[0] = specification > 1 ? '@' + specification : '\0'; + /* for RK3588S2 i.e. '0' + 0x2 = '2' */ + suffix[1] = package > 1 ? '0' + package : '\0'; + suffix[2] = '\0'; + + printf("SoC: RK%02x%02x%s\n", cpu_code[0], cpu_code[1], suffix); + + return 0; +}
v3:
v2:
+&otp {
- bootph-some-ram;
- &pcfg_pull_down { bootph-all; };
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
- u8 cpu_code[2], specification, package;
- char suffix[3];
- int ret;
- if (ret) {
- /* cpu-code: SoC model, e.g. 0x35 0x82 or 0x35 0x88 */
- ret = misc_read(dev, RK3588_OTP_CPU_CODE_OFFSET, cpu_code, 2);
- if (ret < 0) {
- /* specification: SoC variant, e.g. 0xA for RK3588J and 0x13 for RK3588S */
- ret = misc_read(dev, RK3588_OTP_SPECIFICATION_OFFSET, &specification, 1);
- if (ret < 0) {
- /* package: likely SoC variant revision, 0x2 for RK3588S2 */
- /* for RK3588J i.e. '@' + 0xA = 'J' */
- /* for RK3588S2 i.e. '0' + 0x2 = '2' */
- suffix[2] = '\0';
Thanks, - Kever
v3:
v2:
+&otp {
- bootph-some-ram;
- char suffix[3];
- int ret;
- if (ret) {
- if (ret < 0) {
- if (ret < 0) {
- suffix[2] = '\0';
Implement checkboard() to print current SoC variant used by a board, e.g. one of:
SoC: RK3308 SoC: RK3308B SoC: RK3308B-S
U-Boot 2025.01-rc1 (Nov 02 2024 - 20:26:25 +0000)
Model: Radxa ROCK Pi S SoC: RK3308B DRAM: 512 MiB (effective 510 MiB)
Information about the SoC variant is read from GRF.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v3: No change v2: New patch --- arch/arm/mach-rockchip/rk3308/rk3308.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index c6b1a35f47e6..03d97e1d7460 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -216,3 +216,19 @@ int arch_cpu_init(void) return 0; } #endif + +#define RK3308_GRF_CHIP_ID 0xFF000800 + +int checkboard(void) +{ + u32 chip_id = readl(RK3308_GRF_CHIP_ID); + + if (chip_id == 0x3308) + printf("SoC: RK3308B\n"); + else if (chip_id == 0x3308c) + printf("SoC: RK3308B-S\n"); + else + printf("SoC: RK3308\n"); + + return 0; +}
Thanks, - Kever
- u32 chip_id = readl(RK3308_GRF_CHIP_ID);
- if (chip_id == 0x3308)
- else if (chip_id == 0x3308c)
- else
FUKAUMI Naoki
Jonas Karlman
Kever Yang
