[U-Boot-Users] [PATCH 08/25] include/configs: Use new CONFIG_CMD_* in various a* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/acadia.h | 62 +++++++++++++++++++++++---------------- include/configs/adsvix.h | 17 ++++++++-- include/configs/aev.h | 49 +++++++++++++++---------------- include/configs/alpr.h | 45 +++++++++++++++------------- include/configs/armadillo.h | 8 +++-- include/configs/assabet.h | 15 ++++++--- include/configs/at91rm9200dk.h | 28 ++++++++++-------- include/configs/atc.h | 24 ++++++++------- include/configs/atstk1002.h | 57 ++++++++++++------------------------ 9 files changed, 160 insertions(+), 145 deletions(-)
diff --git a/include/configs/acadia.h b/include/configs/acadia.h index 517d130..3f5d025 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -123,10 +123,8 @@ #define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ #define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-#define _CFG_CMD_INCLUDE (CFG_CMD_ALL) #else #define CFG_NO_FLASH 1 /* No NOR on Acadia when NAND-booting */ -#define _CFG_CMD_INCLUDE ((CFG_CMD_ALL) & ~(CFG_CMD_FLASH | CFG_CMD_IMLS)) #endif
#ifdef CFG_ENV_IS_IN_FLASH @@ -301,27 +299,39 @@
#define CONFIG_SUPPORT_VFAT
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL & _CFG_CMD_INCLUDE) | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | \ - CFG_CMD_DTT | \ - CFG_CMD_DIAG | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IRQ | \ - CFG_CMD_MII | \ - CFG_CMD_NAND | \ - CFG_CMD_NET | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_REGINFO | \ - CFG_CMD_USB) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_USB + +/* + * No NOR on Acadia when NAND-booting + */ +#if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#endif + +
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -330,7 +340,7 @@ *----------------------------------------------------------------------*/ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -373,7 +383,7 @@ */ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405EZ CPU */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ #endif
@@ -489,7 +499,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/adsvix.h b/include/configs/adsvix.h index c410891..0d64013 100644 --- a/include/configs/adsvix.h +++ b/include/configs/adsvix.h @@ -68,10 +68,19 @@
#define CONFIG_DOS_PARTITION 1
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL & ~CFG_CMD_NET) | CFG_CMD_MMC | CFG_CMD_FAT | CFG_CMD_IDE | CFG_CMD_PCMCIA)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_FAT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_MMC +#define CONFIG_CMD_PCMCIA + +#undef CONFIG_CMD_NET +
#undef CONFIG_SHOW_BOOT_PROGRESS
@@ -162,7 +171,7 @@ #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ /* #define CONFIG_INITRD_TAG 1 */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/aev.h b/include/configs/aev.h index f6f530c..ecd84d3 100644 --- a/include/configs/aev.h +++ b/include/configs/aev.h @@ -44,11 +44,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -98,27 +93,26 @@ #define CFG_CMD_POST_DIAG 0 #endif
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - ADD_BMP_CMD | \ - CFG_CMD_PCI | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_ECHO | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_MII | \ - CFG_CMD_NFS | \ - CFG_CMD_PING | \ - CFG_CMD_POST_DIAG | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_POST +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SNTP +
#define CONFIG_TIMESTAMP /* display image timestamps */
@@ -324,7 +318,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -343,6 +337,11 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Enable loopw commando. This has only affect, if CFG_CMD_MEM is defined, * which is normally part of the default commands (CFV_CMD_DFL) diff --git a/include/configs/alpr.h b/include/configs/alpr.h index df057d9..27f2831 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -210,25 +210,28 @@
#define CONFIG_NETCONSOLE /* include NetConsole support */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | \ - CFG_CMD_DIAG | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_I2C | \ - CFG_CMD_IRQ | \ - CFG_CMD_MII | \ - CFG_CMD_NET | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_FPGA | \ - CFG_CMD_NAND | \ - CFG_CMD_REGINFO) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FPGA +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +
@@ -237,7 +240,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -358,7 +361,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/armadillo.h b/include/configs/armadillo.h index 9a1c559..7c77fa7 100644 --- a/include/configs/armadillo.h +++ b/include/configs/armadillo.h @@ -73,10 +73,12 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT|CONFIG_BOOTP_BOOTFILESIZE)
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL) /* | CFG_CMD_JFFS2)*/
#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTARGS "root=/dev/ram0 rootfstype=ext2 console=ttyAM0,115200" diff --git a/include/configs/assabet.h b/include/configs/assabet.h index 1a69ebe..7c6a65a 100644 --- a/include/configs/assabet.h +++ b/include/configs/assabet.h @@ -66,18 +66,23 @@
#define CONFIG_BAUDRATE 115200
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_DHCP) -#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP + + +#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT
#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTARGS "console=ttySA0,115200n8 root=/dev/nfs ip=bootp" #define CONFIG_BOOTCOMMAND "bootp;tftp;bootm" #define CFG_AUTOLOAD "n" /* No autoload */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/at91rm9200dk.h b/include/configs/at91rm9200dk.h index 8fad55d..db57dc1 100644 --- a/include/configs/at91rm9200dk.h +++ b/include/configs/at91rm9200dk.h @@ -97,18 +97,22 @@ #define CONFIG_BOOTDELAY 3 /* #define CONFIG_ENV_OVERWRITE 1 */
-#define CONFIG_COMMANDS \ - ((CONFIG_CMD_DFL | CFG_CMD_MII |\ - CFG_CMD_DHCP ) & \ - ~(CFG_CMD_BDI | \ - CFG_CMD_IMI | \ - CFG_CMD_AUTOSCRIPT | \ - CFG_CMD_FPGA | \ - CFG_CMD_MISC | \ - CFG_CMD_LOADS )) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_MII +#define CONFIG_CMD_DHCP + +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_LOADS +
#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define SECTORSIZE 512 diff --git a/include/configs/atc.h b/include/configs/atc.h index bf6c170..cb4e747 100644 --- a/include/configs/atc.h +++ b/include/configs/atc.h @@ -126,25 +126,27 @@
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_EEPROM | \ - CFG_CMD_PCI | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_DATE | \ - CFG_CMD_IDE)
-#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PCMCIA +#define CONFIG_CMD_DATE +#define CONFIG_CMD_IDE
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +#define CONFIG_DOS_PARTITION
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -285,7 +287,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index beaf385..90fe8a5 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -111,44 +111,25 @@ #define CONFIG_BOOTP_MASK (CONFIG_BOOTP_SUBNETMASK \ | CONFIG_BOOTP_GATEWAY)
-#define CONFIG_COMMANDS (CFG_CMD_BDI \ - | CFG_CMD_LOADS \ - | CFG_CMD_LOADB \ - | CFG_CMD_IMI \ - /* | CFG_CMD_CACHE */ \ - | CFG_CMD_FLASH \ - | CFG_CMD_MEMORY \ - | CFG_CMD_NET \ - | CFG_CMD_ENV \ - /* | CFG_CMD_IRQ */ \ - | CFG_CMD_BOOTD \ - | CFG_CMD_CONSOLE \ - /* | CFG_CMD_EEPROM */ \ - | CFG_CMD_ASKENV \ - | CFG_CMD_RUN \ - | CFG_CMD_ECHO \ - /* | CFG_CMD_I2C */ \ - | CFG_CMD_REGINFO \ - /* | CFG_CMD_DATE */ \ - | CFG_CMD_DHCP \ - /* | CFG_CMD_AUTOSCRIPT */ \ - /* | CFG_CMD_MII */ \ - | CFG_CMD_MISC \ - /* | CFG_CMD_SDRAM */ \ - /* | CFG_CMD_DIAG */ \ - /* | CFG_CMD_HWFLOW */ \ - /* | CFG_CMD_SAVES */ \ - /* | CFG_CMD_SPI */ \ - /* | CFG_CMD_PING */ \ - | CFG_CMD_MMC \ - | CFG_CMD_FAT \ - | CFG_CMD_IMLS \ - /* | CFG_CMD_ITEST */ \ - | CFG_CMD_EXT2 \ - | CFG_CMD_JFFS2 \ - ) - -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MMC +#define CONFIG_CMD_REGINFO + +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG + +
#define CONFIG_ATMEL_USART 1 #define CONFIG_MACB 1
Jon Loeliger
