[U-Boot] [PATCH] rockchip: Add basic support for phyCORE-RK3288 SoM based carrier board
The phyCORE-RK3288 is a SoM (System on Module) containing a RK3288 SoC. The module can be connected to different carrier boards. It can be also equipped with different RAM, SPI flash and eMMC variants. The Rapid Development Kit option is using the following setup:
- 1 GB DDR3 RAM (2 Banks) - 1x 4 KB EEPROM - DP83867 Gigabit Ethernet PHY - 16 MB SPI Flash - 4 GB eMMC Flash
Add basic support for the PCM-947 carrier board, a RK3288 based development board made by PHYTEC. This board works in a combination with the phyCORE-RK3288 System on Module.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-phycore-rdk.dts | 289 +++++++++++++++ arch/arm/dts/rk3288-phycore-som.dtsi | 503 +++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 33 +- arch/arm/mach-rockchip/rk3288/Kconfig | 11 + board/phytec/phycore_rk3288/Kconfig | 15 + board/phytec/phycore_rk3288/MAINTAINERS | 6 + board/phytec/phycore_rk3288/Makefile | 8 + board/phytec/phycore_rk3288/phycore-rk3288.c | 16 + configs/phycore-rk3288_defconfig | 69 ++++ include/configs/phycore_rk3288.h | 23 ++ 11 files changed, 973 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3288-phycore-rdk.dts create mode 100644 arch/arm/dts/rk3288-phycore-som.dtsi create mode 100644 board/phytec/phycore_rk3288/Kconfig create mode 100644 board/phytec/phycore_rk3288/MAINTAINERS create mode 100644 board/phytec/phycore_rk3288/Makefile create mode 100644 board/phytec/phycore_rk3288/phycore-rk3288.c create mode 100644 configs/phycore-rk3288_defconfig create mode 100644 include/configs/phycore_rk3288.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f3f53f3..51d68d1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -34,6 +34,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-fennec.dtb \ rk3288-firefly.dtb \ rk3288-miqi.dtb \ + rk3288-phycore-rdk.dtb \ rk3288-popmetal.dtb \ rk3288-rock2-square.dtb \ rk3288-tinker.dtb \ diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts new file mode 100644 index 0000000..cc39210 --- /dev/null +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -0,0 +1,289 @@ +/* + * Device tree file for Phytec PCM-947 carrier board + * Copyright (C) 2017 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include "rk3288-phycore-som.dtsi" + +/ { + model = "Phytec RK3288 PCM-947"; + compatible = "phytec,rk3288-pcm-947", "phytec,rk3288-phycore-som", "rockchip,rk3288"; + + chosen { + stdout-path = &uart2; + }; + + user_buttons: user-buttons { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&user_button_pins>; + + button@0 { + label = "home"; + linux,code = <KEY_HOME>; + gpios = <&gpio8 0 GPIO_ACTIVE_HIGH>; + wakeup-source; + }; + + button@1 { + label = "menu"; + linux,code = <KEY_MENU>; + gpios = <&gpio8 3 GPIO_ACTIVE_HIGH>; + wakeup-source; + }; + }; + + vcc_host0_5v: usb-host0-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host0_vbus_drv>; + regulator-name = "vcc_host0_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vdd_in_otg_out>; + }; + + vcc_host1_5v: usb-host1-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio2 0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host1_vbus_drv>; + regulator-name = "vcc_host1_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vdd_in_otg_out>; + }; + + vcc_otg_5v: usb-otg-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "vcc_otg_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vdd_in_otg_out>; + }; +}; + +&dmc { + rockchip,num-channels = <2>; + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xe 0xe>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 5 1>; +}; + +&gmac { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&i2c1 { + status = "okay"; + + touchscreen@44 { + compatible = "st,stmpe811"; + reg = <0x44>; + }; + + adc@64 { + compatible = "maxim,max1037"; + reg = <0x64>; + }; + + i2c_rtc: rtc@68 { + compatible = "rv4162"; + reg = <0x68>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c_rtc_int>; + interrupt-parent = <&gpio5>; + interrupts = <10 0>; + }; +}; + +&i2c3 { + status = "okay"; + + i2c_eeprom_cb: eeprom@51 { + compatible = "atmel,24c32"; + reg = <0x51>; + pagesize = <32>; + }; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&pinctrl { + u-boot,dm-pre-reloc; + + pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { + bias-pull-up; + drive-strength = <12>; + }; + + buttons { + user_button_pins: user-button-pins { + /* button 1 */ + rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_pull_up>, + /* button 2 */ + <8 0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rv4162 { + i2c_rtc_int: i2c-rtc-int { + rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdmmc { + /* + * Default drive strength isn't enough to achieve even + * high-speed mode on pcm-947 board so bump up to 12 mA. + */ + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, + <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, + <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, + <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + touchscreen { + ts_irq_pin: ts-irq-pin { + rockchip,pins = <5 15 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_host { + host0_vbus_drv: host0-vbus-drv { + rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + host1_vbus_drv: host1-vbus-drv { + rockchip,pins = <2 0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_otg { + otg_vbus_drv: otg-vbus-drv { + rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vdd_io_sd>; + vqmmc-supply = <&vdd_io_sd>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; +}; + +&uart2 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi new file mode 100644 index 0000000..5acd075 --- /dev/null +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -0,0 +1,503 @@ +/* + * Device tree file for Phytec phyCORE-RK3288 SoM + * Copyright (C) 2017 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/net/ti-dp83867.h> +#include "rk3288.dtsi" + +/ { + model = "Phytec RK3288 phyCORE"; + compatible = "phytec,rk3288-phycore-som", "rockchip,rk3288"; + + /* + * Set the minimum memory size here and + * let the bootloader set the real size. + */ + memory { + device_type = "memory"; + reg = <0 0x8000000>; + }; + + aliases { + rtc0 = &i2c_rtc; + rtc1 = &rk818; + }; + + ext_gmac: external-gmac-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + }; + + io_domains: io_domains { + compatible = "rockchip,rk3288-io-voltage-domain"; + + status = "okay"; + sdcard-supply = <&vdd_io_sd>; + flash0-supply = <&vdd_emmc_io>; + flash1-supply = <&vdd_misc_1v8>; + gpio1830-supply = <&vdd_3v3_io>; + gpio30-supply = <&vdd_3v3_io>; + bb-supply = <&vdd_3v3_io>; + dvp-supply = <&vdd_3v3_io>; + lcdc-supply = <&vdd_3v3_io>; + wifi-supply = <&vdd_3v3_io>; + audio-supply = <&vdd_3v3_io>; + }; + + leds: user-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&user_led>; + + user { + label = "green_led"; + gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "keep"; + }; + }; + + vdd_emmc_io: vdd-emmc-io { + compatible = "regulator-fixed"; + regulator-name = "vdd_emmc_io"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vdd_3v3_io>; + }; + + vdd_in_otg_out: vdd-in-otg-out { + compatible = "regulator-fixed"; + regulator-name = "vdd_in_otg_out"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vdd_misc_1v8: vdd-misc-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vdd_misc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; +}; + +&cpu0 { + cpu0-supply = <&vdd_cpu>; + operating-points = < + /* KHz uV */ + 1800000 1400000 + 1608000 1350000 + 1512000 1300000 + 1416000 1200000 + 1200000 1100000 + 1008000 1050000 + 816000 1000000 + 696000 950000 + 600000 900000 + 408000 900000 + 312000 900000 + 216000 900000 + 126000 900000 + >; +}; + +&emmc { + status = "okay"; + u-boot,dm-pre-reloc; + + bus-width = <8>; + cap-mmc-highspeed; + disable-wp; + non-removable; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; + vmmc-supply = <&vdd_3v3_io>; + vqmmc-supply = <&vdd_emmc_io>; +}; + +&gmac { + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + clock_in_out = "input"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins &phy_rst &phy_int>; + phy-handle = <&phy0>; + phy-supply = <&vdd_eth_2v5>; + phy-mode = "rgmii-id"; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_HIGH>; + tx_delay = <0x0>; + rx_delay = <0x0>; + + mdio0 { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + phy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + interrupt-parent = <&gpio4>; + interrupts = <2 IRQ_TYPE_EDGE_FALLING>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + enet-phy-lane-no-swap; + }; + }; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; +}; + +&i2c0 { + status = "okay"; + u-boot,dm-pre-reloc; + + clock-frequency = <400000>; + + rk818: pmic@1c { + compatible = "rockchip,rk818"; + reg = <0x1c>; + interrupt-parent = <&gpio0>; + interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + + vcc1-supply = <&vdd_sys>; + vcc2-supply = <&vdd_sys>; + vcc3-supply = <&vdd_sys>; + vcc4-supply = <&vdd_sys>; + boost-supply = <&vdd_in_otg_out>; + vcc6-supply = <&vdd_sys>; + vcc7-supply = <&vdd_misc_1v8>; + vcc8-supply = <&vdd_misc_1v8>; + vcc9-supply = <&vdd_3v3_io>; + vddio-supply = <&vdd_3v3_io>; + + regulators { + vdd_log: DCDC_REG1 { + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1250000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_3v3_io: DCDC_REG4 { + regulator-name = "vdd_3v3_io"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vdd_sys: DCDC_BOOST { + regulator-name = "vdd_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <5000000>; + }; + }; + + /* vcc9 */ + vdd_sd: SWITCH_REG { + regulator-name = "vdd_sd"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* vcc6 */ + vdd_eth_2v5: LDO_REG2 { + regulator-name = "vdd_eth_2v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2500000>; + }; + }; + + /* vcc7 */ + vdd_1v0: LDO_REG3 { + regulator-name = "vdd_1v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + /* vcc8 */ + vdd_1v8_lcd_ldo: LDO_REG4 { + regulator-name = "vdd_1v8_lcd_ldo"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + /* vcc8 */ + vdd_1v0_lcd: LDO_REG6 { + regulator-name = "vdd_1v0_lcd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + /* vcc7 */ + vdd_1v8_ldo: LDO_REG7 { + regulator-name = "vdd_1v8_ldo"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + /* vcc9 */ + vdd_io_sd: LDO_REG9 { + regulator-name = "vdd_io_sd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + }; + }; + + /* M24C32-D */ + i2c_eeprom: eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + }; + + vdd_cpu: regulator@60 { + compatible = "fcs,fan53555"; + reg = <0x60>; + fcs,suspend-voltage-selector = <1>; + regulator-always-on; + regulator-boot-on; + regulator-enable-ramp-delay = <300>; + regulator-name = "vdd_cpu"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1430000>; + regulator-ramp-delay = <8000>; + vin-supply = <&vdd_sys>; + }; +}; + +&pinctrl { + pcfg_output_high: pcfg-output-high { + output-high; + }; + + emmc { + /* + * We run eMMC at max speed; bump up drive strength. + * We also have external pulls, so disable the internal ones. + */ + emmc_clk: emmc-clk { + rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_12ma>; + }; + + emmc_cmd: emmc-cmd { + rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_12ma>; + }; + + emmc_bus8: emmc-bus8 { + rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 1 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 2 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 3 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 4 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 5 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 6 RK_FUNC_2 &pcfg_pull_none_12ma>, + <3 7 RK_FUNC_2 &pcfg_pull_none_12ma>; + }; + }; + + gmac { + phy_int: phy-int { + rockchip,pins = <4 2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_rst: phy-rst { + rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + leds { + user_led: user-led { + rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + /* Pin for switching state between sleep and non-sleep state */ + pmic_sleep: pmic-sleep { + rockchip,pins = <RK_GPIO0 0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm1 { + status = "okay"; +}; + +&saradc { + status = "okay"; + vref-supply = <&vdd_1v8_ldo>; +}; + +&spi2 { + status = "okay"; + + serial_flash: flash@0 { + compatible = "micron,n25q128a13", "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <50000000>; + m25p,fast-read; + #address-cells = <1>; + #size-cells = <1>; + status = "okay"; + }; +}; + +&tsadc { + status = "okay"; + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&wdt { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index 74f3379..d1cdc91 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -8,6 +8,7 @@ #include <debug_uart.h> #include <dm.h> #include <fdtdec.h> +#include <i2c.h> #include <led.h> #include <malloc.h> #include <ram.h> @@ -25,6 +26,7 @@ #include <dm/test.h> #include <dm/util.h> #include <power/regulator.h> +#include <power/rk8xx_pmic.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -162,7 +164,10 @@ void board_init_f(ulong dummy) struct udevice *pinctrl; struct udevice *dev; int ret; - +#if defined(CONFIG_TARGET_PHYCORE_RK3288) + struct udevice *pmic; + uint reg; +#endif /* Example code showing how to enable the debug UART on RK3288 */ #ifdef EARLY_UART #include <asm/arch/grf_rk3288.h> @@ -206,6 +211,32 @@ void board_init_f(ulong dummy) return; }
+#if defined(CONFIG_TARGET_PHYCORE_RK3288) + ret = uclass_get_device(UCLASS_I2C, 0, &dev); + if (ret) { + debug("I2C init failed: %d\n", ret); + return; + } + + ret = i2c_get_chip(dev, 0x1c, 1, &pmic); + if (ret) { + debug("Cannot find RK818: %d\n", ret); + return; + } + + reg = dm_i2c_reg_read(pmic, REG_USB_CTRL); + + /* + * Increase USB input current selection to 2A and close charger + * when usb lower then 3.4V. + */ + reg |= 0x77; + ret = dm_i2c_reg_write(pmic, REG_USB_CTRL, reg); + if (ret) { + debug("Unable to set RK818 REG_USB_CTRL: %d\n", ret); + return; + } +#endif ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { debug("DRAM init failed: %d\n", ret); diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index 8e7355e..796d731 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -66,6 +66,15 @@ config TARGET_MIQI_RK3288 has 1 or 2 GiB SDRAM. Expansion connectors provide access to I2C, SPI, UART, GPIOs and fan control.
+config TARGET_PHYCORE_RK3288 + bool "phyCORE-RK3288" + select BOARD_LATE_INIT + help + Add basic support for the PCM-947 carrier board, a RK3288 based + development board made by PHYTEC. This board works in a combination + with the phyCORE-RK3288 System on Module. + + config TARGET_POPMETAL_RK3288 bool "PopMetal-RK3288" select BOARD_LATE_INIT @@ -129,6 +138,8 @@ source "board/google/veyron/Kconfig"
source "board/mqmaker/miqi_rk3288/Kconfig"
+source "board/phytec/phycore_rk3288/Kconfig" + source "board/radxa/rock2/Kconfig"
source "board/rockchip/evb_rk3288/Kconfig" diff --git a/board/phytec/phycore_rk3288/Kconfig b/board/phytec/phycore_rk3288/Kconfig new file mode 100644 index 0000000..57cd8e2 --- /dev/null +++ b/board/phytec/phycore_rk3288/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PHYCORE_RK3288 + +config SYS_BOARD + default "phycore_rk3288" + +config SYS_VENDOR + default "phytec" + +config SYS_CONFIG_NAME + default "phycore_rk3288" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/phytec/phycore_rk3288/MAINTAINERS b/board/phytec/phycore_rk3288/MAINTAINERS new file mode 100644 index 0000000..9c0de3c --- /dev/null +++ b/board/phytec/phycore_rk3288/MAINTAINERS @@ -0,0 +1,6 @@ +phyCORE-RK3288 +M: Wadim Egorov w.egorov@phytec.de +S: Maintained +F: board/phytec/phycore_rk3288 +F: include/configs/phycore_rk3288.h +F: configs/phycore-rk3288_defconfig diff --git a/board/phytec/phycore_rk3288/Makefile b/board/phytec/phycore_rk3288/Makefile new file mode 100644 index 0000000..f379fbe --- /dev/null +++ b/board/phytec/phycore_rk3288/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2017 PHYTEC Messtechnik GmbH +# Author: Wadim Egorov w.egorov@phytec.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += phycore-rk3288.o diff --git a/board/phytec/phycore_rk3288/phycore-rk3288.c b/board/phytec/phycore_rk3288/phycore-rk3288.c new file mode 100644 index 0000000..c8c24e8 --- /dev/null +++ b/board/phytec/phycore_rk3288/phycore-rk3288.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2017 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +void board_boot_order(u32 *spl_boot_list) +{ + /* eMMC prior to sdcard. */ + spl_boot_list[0] = BOOT_DEVICE_MMC2; + spl_boot_list[1] = BOOT_DEVICE_MMC1; +} diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig new file mode 100644 index 0000000..2c608d1 --- /dev/null +++ b/configs/phycore-rk3288_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ROCKCHIP_RK3288=y +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_TARGET_PHYCORE_RK3288=y +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3288-phycore-rdk" +CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_PINCTRL_ROCKCHIP_RK3288=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xff690000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/phycore_rk3288.h b/include/configs/phycore_rk3288.h new file mode 100644 index 0000000..aab43ed --- /dev/null +++ b/include/configs/phycore_rk3288.h @@ -0,0 +1,23 @@ +/* + * Copyright (C) 2017 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define ROCKCHIP_DEVICE_SETTINGS +#include <configs/rk3288_common.h> + +#undef BOOT_TARGET_DEVICES + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#endif
- 1x 4 KB EEPROM
- 16 MB SPI Flash
- 4 GB eMMC Flash
But a few comments below.
uint reg;
Can you please put all of this in a separate function? Also does it bloat the code too much to use of_machine_is_compatible() instead of #ifdef?
if (ret) {
return;
if (ret) {
return;
reg |= 0x77;
if (ret) {
return;
help
+config SYS_BOARD
+config SYS_VENDOR
default "phytec"
def_bool y
- Copyright (C) 2017 PHYTEC Messtechnik GmbH
- Author: Wadim Egorov w.egorov@phytec.de
For this, can you use the device tree and spl_boot_device() ?
func(MMC, mmc, 0) \
func(MMC, mmc, 1)
1.9.1
Am 15.05.2017 um 05:02 schrieb Simon Glass:
- 1x 4 KB EEPROM
- 16 MB SPI Flash
- 4 GB eMMC Flash
uint reg;
I will add a separate function for the phycore initialization in v2. No other rockchip board used of_machine_is_compatible(). But I can do this. This increases the SPL about 500 bytes, so I think it should be fine.
if (ret) {
return;
if (ret) {
return;
reg |= 0x77;
if (ret) {
return;
help
+config SYS_BOARD
+config SYS_VENDOR
default "phytec"
def_bool y
Yes, I can do this.
Thanks Wadim
func(MMC, mmc, 0) \
func(MMC, mmc, 1)
1.9.1
Wadim Egorov
