[U-Boot] Please pull u-boot-x86
Hi Tom,
This PR includes the following changes in x86: - QEMU build warning fix when CONFIG_DISTRO_DEFAULTS=n - Small fixes on x86 reST docs - Allow CBFS to be used in SPL - Remove x86 specific GD flags
The following changes since commit 81fed78c0a59af0d5698b13608eb4d26be84f397:
Merge tag 'efi-2019-10-rc3' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2019-08-17 10:31:25 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to d117f917bfd2ccf4eaf90bddfa256501a554b1a4:
global_data: Remove comment of reserved arch-specific GD flags (2019-08-18 21:54:10 +0800)
---------------------------------------------------------------- Bin Meng (1): x86: qemu: Fix build warnings with CONFIG_DISTRO_DEFAULTS=n
Heinrich Schuchardt (2): doc: formatting slimbootloader.rst doc: arch: correct links in x86.rst
Simon Glass (6): cbfs: Allow CBFS to be used in SPL cbfs: Move declarations above functions cbfs: Move static variables into a struct cbfs: Move result variable into the struct cbfs: Add functions to support multiple CBFSs cbfs: Rename camel-case variables
Stefan Roese (2): x86: Remove x86 specific GD flags as they are not referenced at all global_data: Remove comment of reserved arch-specific GD flags
arch/x86/cpu/coreboot/coreboot.c | 3 -- arch/x86/cpu/start.S | 9 +---- arch/x86/cpu/start16.S | 3 -- arch/x86/include/asm/global_data.h | 6 ---- cmd/cbfs.c | 4 +-- doc/arch/x86.rst | 3 +- doc/board/intel/slimbootloader.rst | 2 +- fs/Makefile | 1 + fs/cbfs/Kconfig | 12 +++++++ fs/cbfs/cbfs.c | 231 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------ include/asm-generic/global_data.h | 2 +- include/cbfs.h | 29 ++++++++++++++++ include/configs/x86-common.h | 11 +++--- 13 files changed, 210 insertions(+), 106 deletions(-)
Regards, Bin
On Mon, Aug 19, 2019 at 09:07:00AM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
