[U-Boot] [PATCH 0/8] dm: Update on serial driver progress
Only three serial drivers remain to be converted. This series drops two of those, since the boards appear to be unmaintained.
With this, only blackfin remains.
The blackfin driver probably needs to be converted as there is recent activity with these boards. I am copying the maintainer so that this work can be completed.
Simon Glass (8): arm: Remove colibri_pxa270 board arm: Remove h2200 board arm: Remove zipitz2 board arm: Drop pxa serial driver serial: Update docs to indicate mcfuart supports DM_SERIAL arm: Remove smdk2410 board arm: Remove VCMA9 board serial: Drop the s3c24x0 serial driver
arch/arm/Kconfig | 25 -- board/h2200/Kconfig | 9 - board/h2200/MAINTAINERS | 6 - board/h2200/Makefile | 14 - board/h2200/h2200-header.S | 15 - board/h2200/h2200.c | 73 ---- board/mpl/common/common_util.c | 23 -- board/mpl/vcma9/Kconfig | 15 - board/mpl/vcma9/MAINTAINERS | 6 - board/mpl/vcma9/Makefile | 11 - board/mpl/vcma9/cmd_vcma9.c | 119 ------ board/mpl/vcma9/lowlevel_init.S | 500 -------------------------- board/mpl/vcma9/vcma9.c | 209 ----------- board/mpl/vcma9/vcma9.h | 28 -- board/samsung/smdk2410/Kconfig | 15 - board/samsung/smdk2410/MAINTAINERS | 6 - board/samsung/smdk2410/Makefile | 9 - board/samsung/smdk2410/lowlevel_init.S | 146 -------- board/samsung/smdk2410/smdk2410.c | 139 ------- board/toradex/colibri_pxa270/Kconfig | 12 - board/toradex/colibri_pxa270/MAINTAINERS | 6 - board/toradex/colibri_pxa270/Makefile | 9 - board/toradex/colibri_pxa270/colibri_pxa270.c | 107 ------ board/zipitz2/Kconfig | 9 - board/zipitz2/MAINTAINERS | 6 - board/zipitz2/Makefile | 10 - board/zipitz2/zipitz2.c | 217 ----------- configs/VCMA9_defconfig | 16 - configs/colibri_pxa270_defconfig | 19 - configs/h2200_defconfig | 25 -- configs/smdk2410_defconfig | 16 - configs/zipitz2_defconfig | 19 - doc/driver-model/serial-howto.txt | 3 - drivers/serial/Makefile | 2 - drivers/serial/serial_pxa.c | 299 --------------- drivers/serial/serial_s3c24x0.c | 208 ----------- include/configs/VCMA9.h | 207 ----------- include/configs/colibri_pxa270.h | 223 ------------ include/configs/h2200.h | 155 -------- include/configs/smdk2410.h | 181 ---------- include/configs/zipitz2.h | 213 ----------- scripts/config_whitelist.txt | 6 - 42 files changed, 3336 deletions(-) delete mode 100644 board/h2200/Kconfig delete mode 100644 board/h2200/MAINTAINERS delete mode 100644 board/h2200/Makefile delete mode 100644 board/h2200/h2200-header.S delete mode 100644 board/h2200/h2200.c delete mode 100644 board/mpl/vcma9/Kconfig delete mode 100644 board/mpl/vcma9/MAINTAINERS delete mode 100644 board/mpl/vcma9/Makefile delete mode 100644 board/mpl/vcma9/cmd_vcma9.c delete mode 100644 board/mpl/vcma9/lowlevel_init.S delete mode 100644 board/mpl/vcma9/vcma9.c delete mode 100644 board/mpl/vcma9/vcma9.h delete mode 100644 board/samsung/smdk2410/Kconfig delete mode 100644 board/samsung/smdk2410/MAINTAINERS delete mode 100644 board/samsung/smdk2410/Makefile delete mode 100644 board/samsung/smdk2410/lowlevel_init.S delete mode 100644 board/samsung/smdk2410/smdk2410.c delete mode 100644 board/toradex/colibri_pxa270/Kconfig delete mode 100644 board/toradex/colibri_pxa270/MAINTAINERS delete mode 100644 board/toradex/colibri_pxa270/Makefile delete mode 100644 board/toradex/colibri_pxa270/colibri_pxa270.c delete mode 100644 board/zipitz2/Kconfig delete mode 100644 board/zipitz2/MAINTAINERS delete mode 100644 board/zipitz2/Makefile delete mode 100644 board/zipitz2/zipitz2.c delete mode 100644 configs/VCMA9_defconfig delete mode 100644 configs/colibri_pxa270_defconfig delete mode 100644 configs/h2200_defconfig delete mode 100644 configs/smdk2410_defconfig delete mode 100644 configs/zipitz2_defconfig delete mode 100644 drivers/serial/serial_pxa.c delete mode 100644 drivers/serial/serial_s3c24x0.c delete mode 100644 include/configs/VCMA9.h delete mode 100644 include/configs/colibri_pxa270.h delete mode 100644 include/configs/h2200.h delete mode 100644 include/configs/smdk2410.h delete mode 100644 include/configs/zipitz2.h
This board has not been converted to use DM_SERIAL by the deadline. Drop it.
arch/arm/Kconfig | 5 - board/toradex/colibri_pxa270/Kconfig | 12 -- board/toradex/colibri_pxa270/MAINTAINERS | 6 - board/toradex/colibri_pxa270/Makefile | 9 -- board/toradex/colibri_pxa270/colibri_pxa270.c | 107 ------------ configs/colibri_pxa270_defconfig | 19 --- include/configs/colibri_pxa270.h | 223 -------------------------- 7 files changed, 381 deletions(-) delete mode 100644 board/toradex/colibri_pxa270/Kconfig delete mode 100644 board/toradex/colibri_pxa270/MAINTAINERS delete mode 100644 board/toradex/colibri_pxa270/Makefile delete mode 100644 board/toradex/colibri_pxa270/colibri_pxa270.c delete mode 100644 configs/colibri_pxa270_defconfig delete mode 100644 include/configs/colibri_pxa270.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d7a9b11..59c7bcc 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -813,10 +813,6 @@ config TARGET_ZIPITZ2 bool "Support zipitz2" select CPU_PXA
-config TARGET_COLIBRI_PXA270 - bool "Support colibri_pxa270" - select CPU_PXA - config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select BLK @@ -1013,7 +1009,6 @@ source "board/birdland/bav335x/Kconfig" source "board/ti/ti814x/Kconfig" source "board/ti/ti816x/Kconfig" source "board/timll/devkit3250/Kconfig" -source "board/toradex/colibri_pxa270/Kconfig" source "board/toradex/colibri_vf/Kconfig" source "board/technologic/ts4800/Kconfig" source "board/vscom/baltos/Kconfig" diff --git a/board/toradex/colibri_pxa270/Kconfig b/board/toradex/colibri_pxa270/Kconfig deleted file mode 100644 index 949407a..0000000 --- a/board/toradex/colibri_pxa270/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_COLIBRI_PXA270 - -config SYS_BOARD - default "colibri_pxa270" - -config SYS_VENDOR - default "toradex" - -config SYS_CONFIG_NAME - default "colibri_pxa270" - -endif diff --git a/board/toradex/colibri_pxa270/MAINTAINERS b/board/toradex/colibri_pxa270/MAINTAINERS deleted file mode 100644 index b378d7b..0000000 --- a/board/toradex/colibri_pxa270/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -COLIBRI_PXA270 BOARD -M: Marek Vasut marek.vasut@gmail.com -S: Maintained -F: board/toradex/colibri_pxa270/ -F: include/configs/colibri_pxa270.h -F: configs/colibri_pxa270_defconfig diff --git a/board/toradex/colibri_pxa270/Makefile b/board/toradex/colibri_pxa270/Makefile deleted file mode 100644 index 57cfe9b..0000000 --- a/board/toradex/colibri_pxa270/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# Toradex Colibri PXA270 Support -# -# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := colibri_pxa270.o diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c deleted file mode 100644 index 3def0a6..0000000 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ /dev/null @@ -1,107 +0,0 @@ -/* - * Toradex Colibri PXA270 Support - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/hardware.h> -#include <asm/arch/regs-mmc.h> -#include <asm/arch/pxa.h> -#include <netdev.h> -#include <asm/io.h> -#include <serial.h> -#include <usb.h> - -DECLARE_GLOBAL_DATA_PTR; - -int board_init(void) -{ - /* We have RAM, disable cache */ - dcache_disable(); - icache_disable(); - - /* arch number of Toradex Colibri PXA270 */ - gd->bd->bi_arch_number = MACH_TYPE_COLIBRI; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0xa0000100; - - return 0; -} - -int dram_init(void) -{ - pxa2xx_dram_init(); - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_USB -int board_usb_init(int index, enum usb_init_type init) -{ - writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), - UHCHR); - - writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); - - while (UHCHR & UHCHR_FSBIR) - ; - - writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); - writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE); - - /* Clear any OTG Pin Hold */ - if (readl(PSSR) & PSSR_OTGPH) - writel(readl(PSSR) | PSSR_OTGPH, PSSR); - - writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); - writel(readl(UHCRHDA) | 0x100, UHCRHDA); - - /* Set port power control mask bits, only 3 ports. */ - writel(readl(UHCRHDB) | (0x7<<17), UHCRHDB); - - /* enable port 2 */ - writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | - UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); - - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return 0; -} - -void usb_board_stop(void) -{ - writel(readl(UHCHR) | UHCHR_FHR, UHCHR); - udelay(11); - writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR); - - writel(readl(UHCCOMS) | 1, UHCCOMS); - udelay(10); - - writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); - - return; -} -#endif - -#ifdef CONFIG_DRIVER_DM9000 -int board_eth_init(bd_t *bis) -{ - return dm9000_initialize(bis); -} -#endif - -#ifdef CONFIG_CMD_MMC -int board_mmc_init(bd_t *bis) -{ - pxa_mmc_register(0); - return 0; -} -#endif diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig deleted file mode 100644 index 9a57041..0000000 --- a/configs/colibri_pxa270_defconfig +++ /dev/null @@ -1,19 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_COLIBRI_PXA270=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h deleted file mode 100644 index ba8d93c..0000000 --- a/include/configs/colibri_pxa270.h +++ /dev/null @@ -1,223 +0,0 @@ -/* - * Toradex Colibri PXA270 configuration file - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * Copyright (C) 2015 Marcel Ziswiler marcel@ziswiler.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Board Configuration Options - */ -#define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ -#define CONFIG_SYS_TEXT_BASE 0x0 -/* Avoid overwriting factory configuration block */ -#define CONFIG_BOARD_SIZE_LIMIT 0x40000 - -/* We will never enable dcache because we have to setup MMU first */ -#define CONFIG_SYS_DCACHE_OFF - -/* - * Environment settings - */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_BOOTCOMMAND \ - "if fatload mmc 0 0xa0000000 uImage; then " \ - "bootm 0xa0000000; " \ - "fi; " \ - "if usb reset && fatload usb 0 0xa0000000 uImage; then " \ - "bootm 0xa0000000; " \ - "fi; " \ - "bootm 0xc0000;" -#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" -#define CONFIG_TIMESTAMP -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_LZMA /* LZMA compression support */ - -/* - * Serial Console Configuration - */ -#define CONFIG_PXA_SERIAL -#define CONFIG_FFUART 1 -#define CONFIG_CONS_INDEX 3 -#define CONFIG_BAUDRATE 115200 - -/* - * Bootloader Components Configuration - */ -#define CONFIG_CMD_ENV - -/* I2C support */ -#ifdef CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PXA -#define CONFIG_PXA_STD_I2C -#define CONFIG_PXA_PWR_I2C -#define CONFIG_SYS_I2C_SPEED 100000 -#endif - -/* LCD support */ -#ifdef CONFIG_LCD -#define CONFIG_PXA_LCD -#define CONFIG_PXA_VGA -#define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 -#define CONFIG_CMD_BMP -#define CONFIG_LCD_LOGO -#endif - -/* - * Networking Configuration - */ -#ifdef CONFIG_CMD_NET - -#define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000000 -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) -#define CONFIG_NET_RETRY_COUNT 10 - -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#endif - -#undef CONFIG_SYS_LONGHELP /* Saves 10 KB */ -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE \ - (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -#define CONFIG_SYS_DEVICE_NULLDEV 1 -#define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_AUTO_COMPLETE 1 - -/* - * Clock Configuration - */ -#define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */ - -/* - * DRAM Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ - -#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ -#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ - -#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR PHYS_SDRAM_1 -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR 0x5c010000 - -/* - * NOR FLASH - */ -#ifdef CONFIG_CMD_FLASH -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ -#define PHYS_FLASH_SIZE 0x02000000 /* 32 MB */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT - -#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) -#define CONFIG_SYS_MAX_FLASH_BANKS 1 - -#define CONFIG_SYS_FLASH_ERASE_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_LOCK_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25 * CONFIG_SYS_HZ) - -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_FLASH_PROTECTION 1 - -#define CONFIG_ENV_IS_IN_FLASH 1 - -#else /* No flash */ -#define CONFIG_SYS_NO_FLASH -#define CONFIG_ENV_IS_NOWHERE -#endif - -#define CONFIG_SYS_MONITOR_BASE 0x0 -#define CONFIG_SYS_MONITOR_LEN 0x40000 - -/* Skip factory configuration block */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN + 0x40000) -#define CONFIG_ENV_SIZE 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x40000 - -/* - * GPIO settings - */ -#define CONFIG_SYS_GPSR0_VAL 0x00000000 -#define CONFIG_SYS_GPSR1_VAL 0x00020000 -#define CONFIG_SYS_GPSR2_VAL 0x0002c000 -#define CONFIG_SYS_GPSR3_VAL 0x00000000 - -#define CONFIG_SYS_GPCR0_VAL 0x00000000 -#define CONFIG_SYS_GPCR1_VAL 0x00000000 -#define CONFIG_SYS_GPCR2_VAL 0x00000000 -#define CONFIG_SYS_GPCR3_VAL 0x00000000 - -#define CONFIG_SYS_GPDR0_VAL 0xc8008000 -#define CONFIG_SYS_GPDR1_VAL 0xfc02a981 -#define CONFIG_SYS_GPDR2_VAL 0x92c3ffff -#define CONFIG_SYS_GPDR3_VAL 0x0061e804 - -#define CONFIG_SYS_GAFR0_L_VAL 0x80100000 -#define CONFIG_SYS_GAFR0_U_VAL 0xa5c00010 -#define CONFIG_SYS_GAFR1_L_VAL 0x6992901a -#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50008 -#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa -#define CONFIG_SYS_GAFR2_U_VAL 0x4109a002 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000310 -#define CONFIG_SYS_GAFR3_U_VAL 0x00005401 - -#define CONFIG_SYS_PSSR_VAL 0x30 - -/* - * Clock settings - */ -#define CONFIG_SYS_CKEN 0x00500240 -#define CONFIG_SYS_CCCR 0x02000290 - -/* - * Memory settings - */ -#define CONFIG_SYS_MSC0_VAL 0x9ee1c5f2 -#define CONFIG_SYS_MSC1_VAL 0x9ee1f994 -#define CONFIG_SYS_MSC2_VAL 0x9ee19ee1 -#define CONFIG_SYS_MDCNFG_VAL 0x090009c9 -#define CONFIG_SYS_MDREFR_VAL 0x2003a031 -#define CONFIG_SYS_MDMRS_VAL 0x00220022 -#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 -#define CONFIG_SYS_SXCNFG_VAL 0x40044004 - -/* - * PCMCIA and CF Interfaces - */ -#define CONFIG_SYS_MECR_VAL 0x00000000 -#define CONFIG_SYS_MCMEM0_VAL 0x00028307 -#define CONFIG_SYS_MCMEM1_VAL 0x00014307 -#define CONFIG_SYS_MCATT0_VAL 0x00038787 -#define CONFIG_SYS_MCATT1_VAL 0x0001c787 -#define CONFIG_SYS_MCIO0_VAL 0x0002830f -#define CONFIG_SYS_MCIO1_VAL 0x0001430f - -#include "pxa-common.h" - -#endif /* __CONFIG_H */
This board has not been converted to DM_SERIAL by the deadline. Remove it.
arch/arm/Kconfig | 5 -- board/h2200/Kconfig | 9 --- board/h2200/MAINTAINERS | 6 -- board/h2200/Makefile | 14 ---- board/h2200/h2200-header.S | 15 ----- board/h2200/h2200.c | 73 -------------------- configs/h2200_defconfig | 25 ------- include/configs/h2200.h | 155 ------------------------------------------- scripts/config_whitelist.txt | 1 - 9 files changed, 303 deletions(-) delete mode 100644 board/h2200/Kconfig delete mode 100644 board/h2200/MAINTAINERS delete mode 100644 board/h2200/Makefile delete mode 100644 board/h2200/h2200-header.S delete mode 100644 board/h2200/h2200.c delete mode 100644 configs/h2200_defconfig delete mode 100644 include/configs/h2200.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 59c7bcc..26c8e2f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -805,10 +805,6 @@ config TARGET_LS1046ARDB development platform that supports the QorIQ LS1046A Layerscape Architecture processor.
-config TARGET_H2200 - bool "Support h2200" - select CPU_PXA - config TARGET_ZIPITZ2 bool "Support zipitz2" select CPU_PXA @@ -978,7 +974,6 @@ source "board/freescale/mx53smd/Kconfig" source "board/freescale/s32v234evb/Kconfig" source "board/freescale/vf610twr/Kconfig" source "board/gumstix/pepper/Kconfig" -source "board/h2200/Kconfig" source "board/hisilicon/hikey/Kconfig" source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" diff --git a/board/h2200/Kconfig b/board/h2200/Kconfig deleted file mode 100644 index c0e0c1e..0000000 --- a/board/h2200/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_H2200 - -config SYS_BOARD - default "h2200" - -config SYS_CONFIG_NAME - default "h2200" - -endif diff --git a/board/h2200/MAINTAINERS b/board/h2200/MAINTAINERS deleted file mode 100644 index b66ff51..0000000 --- a/board/h2200/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -H2200 BOARD -M: Lukasz Dalek luk0104@gmail.com -S: Maintained -F: board/h2200/ -F: include/configs/h2200.h -F: configs/h2200_defconfig diff --git a/board/h2200/Makefile b/board/h2200/Makefile deleted file mode 100644 index e516e91..0000000 --- a/board/h2200/Makefile +++ /dev/null @@ -1,14 +0,0 @@ -# -# h2200 Support -# -# Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := h2200.o - -extra-y := h2200-header.bin - -$(obj)/h2200-header.bin: $(obj)/h2200-header.o - $(OBJCOPY) -O binary $< $@ diff --git a/board/h2200/h2200-header.S b/board/h2200/h2200-header.S deleted file mode 100644 index ac2e6b4..0000000 --- a/board/h2200/h2200-header.S +++ /dev/null @@ -1,15 +0,0 @@ -/* - * iPAQ h2200 header - * - * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - .word 0xea0003fe /* b 0x1000 */ - - .org 0x40 - .ascii "ECEC" - - .org 0x1000 - 1 - .byte 0x0 diff --git a/board/h2200/h2200.c b/board/h2200/h2200.c deleted file mode 100644 index 01f8e67..0000000 --- a/board/h2200/h2200.c +++ /dev/null @@ -1,73 +0,0 @@ -/* - * iPAQ h2200 board configuration - * - * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/pxa.h> -#include <asm/arch/pxa-regs.h> -#include <asm/io.h> -#include <usb.h> - -DECLARE_GLOBAL_DATA_PTR; - -int board_eth_init(bd_t *bis) -{ - usb_eth_initialize(bis); - return 0; -} - -void reset_cpu(ulong ignore) -{ - /* Enable VLIO interface on Hamcop */ - writeb(0x1, 0x4000); - - /* Reset board (cold reset) */ - writeb(0xff, 0x4002); -} - -int board_init(void) -{ - /* We have RAM, disable cache */ - dcache_disable(); - icache_disable(); - - gd->bd->bi_arch_number = MACH_TYPE_H2200; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0xa0000100; - - /* Let host see that device is disconnected */ - udc_disconnect(); - mdelay(500); - - return 0; -} - -int dram_init(void) -{ - /* - * Everything except MSC0 was already set up by - * 1st stage bootloader. - * - * This setting enables access to companion chip. - */ - clrsetbits_le32(MSC0, 0xffffffff, CONFIG_SYS_MSC0_VAL); - gd->ram_size = CONFIG_SYS_SDRAM_SIZE; - return 0; -} - -#ifdef CONFIG_USB_GADGET_PXA2XX -int board_usb_init(int index, enum usb_init_type init) -{ - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return 0; -} -#endif diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig deleted file mode 100644 index ed2217a..0000000 --- a/configs/h2200_defconfig +++ /dev/null @@ -1,25 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_H2200=y -CONFIG_FIT=y -# CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="> " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EDITENV is not set -# CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set -# CONFIG_CMD_MEMORY is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_ECHO is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set diff --git a/include/configs/h2200.h b/include/configs/h2200.h deleted file mode 100644 index 3e419c6..0000000 --- a/include/configs/h2200.h +++ /dev/null @@ -1,155 +0,0 @@ -/* - * iPAQ h2200 board configuration - * - * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define MACH_TYPE_H2200 341 -#define CONFIG_MACH_TYPE MACH_TYPE_H2200 - -#define CONFIG_CPU_PXA25X 1 -#define CONFIG_BOARD_H2200 - -#define CONFIG_SYS_NO_FLASH - -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_SDRAM_SIZE PHYS_SDRAM_1_SIZE - -#define CONFIG_SYS_INIT_SP_ADDR 0xfffff800 - -#define CONFIG_ENV_SIZE 0x00040000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -#define CONFIG_ENV_IS_NOWHERE -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_LOAD_ADDR 0xa3000000 /* default load address */ - -/* - * iPAQ 1st stage bootloader loads 2nd stage bootloader - * at address 0xa0040000 but bootloader requires header - * which is 0x1000 long. - * - * --- Header begin --- - * .word 0xea0003fe ; b 0x1000 - * - * .org 0x40 - * .ascii "ECEC" - * - * .org 0x1000 - * --- Header end --- - */ - -#define CONFIG_SYS_TEXT_BASE 0xa0041000 - -/* - * Static chips - */ - -#define CONFIG_SYS_MSC0_VAL 0x246c7ffc -#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 -#define CONFIG_SYS_MSC2_VAL 0x7ff07ff0 - -/* - * PCMCIA and CF Interfaces - */ - -#define CONFIG_SYS_MECR_VAL 0x00000000 -#define CONFIG_SYS_MCMEM0_VAL 0x00000000 -#define CONFIG_SYS_MCMEM1_VAL 0x00000000 -#define CONFIG_SYS_MCATT0_VAL 0x00000000 -#define CONFIG_SYS_MCATT1_VAL 0x00000000 -#define CONFIG_SYS_MCIO0_VAL 0x00000000 -#define CONFIG_SYS_MCIO1_VAL 0x00000000 - -#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 -#define CONFIG_SYS_SXCNFG_VAL 0x00040004 - -#define CONFIG_SYS_MDREFR_VAL 0x0099E018 -#define CONFIG_SYS_MDCNFG_VAL 0x01C801CB -#define CONFIG_SYS_MDMRS_VAL 0x00220022 - -#define CONFIG_SYS_PSSR_VAL 0x00000000 -#define CONFIG_SYS_CKEN 0x00004840 -#define CONFIG_SYS_CCCR 0x00000161 - -/* - * GPIOs - */ - -#define CONFIG_SYS_GPSR0_VAL 0x01000000 -#define CONFIG_SYS_GPSR1_VAL 0x00000000 -#define CONFIG_SYS_GPSR2_VAL 0x00010000 - -#define CONFIG_SYS_GPCR0_VAL 0x00000000 -#define CONFIG_SYS_GPCR1_VAL 0x00000000 -#define CONFIG_SYS_GPCR2_VAL 0x00000000 - -#define CONFIG_SYS_GPDR0_VAL 0xF7E38C00 -#define CONFIG_SYS_GPDR1_VAL 0xBCFFBF83 -#define CONFIG_SYS_GPDR2_VAL 0x000157FF - -#define CONFIG_SYS_GAFR0_L_VAL 0x80401000 -#define CONFIG_SYS_GAFR0_U_VAL 0x00000112 -#define CONFIG_SYS_GAFR1_L_VAL 0x600A9550 -#define CONFIG_SYS_GAFR1_U_VAL 0x0005AAAA -#define CONFIG_SYS_GAFR2_L_VAL 0x20000000 -#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 - -/* - * Serial port - */ - -#define CONFIG_PXA_SERIAL -#define CONFIG_FFUART -#define CONFIG_CONS_INDEX 3 - -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 38400, 115200 } - -#define CONFIG_FIT_DISABLE_SHA256 -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG - -/* Monitor Command Prompt */ - -/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 256 - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) - -#define CONFIG_BOOTARGS "root=/dev/ram0 ro console=ttyS0,115200n8" - -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_USB_DEV_PULLUP_GPIO 33 -/* USB VBUS GPIO 3 */ - -#define CONFIG_BOOTCOMMAND \ - "setenv downloaded 0 ; while test $downloaded -eq 0 ; do " \ - "if bootp ; then setenv downloaded 1 ; fi ; done ; " \ - "source :script ; " \ - "bootm ; " - -#define CONFIG_USB_GADGET_PXA2XX -#define CONFIG_USB_ETHER -#define CONFIG_USB_ETH_SUBSET - -#define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:ef:00:02" -#define CONFIG_EXTRA_ENV_SETTINGS \ - "stdin=serial\0" \ - "stdout=serial\0" \ - "stderr=serial\0" - -#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 04e9536..2c10c0b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -373,7 +373,6 @@ CONFIG_BOARD_EARLY_INIT_F CONFIG_BOARD_EARLY_INIT_R CONFIG_BOARD_ECC_SUPPORT CONFIG_BOARD_EMAC_COUNT -CONFIG_BOARD_H2200 CONFIG_BOARD_IS_OPENRD_BASE CONFIG_BOARD_IS_OPENRD_CLIENT CONFIG_BOARD_IS_OPENRD_ULTIMATE
arch/arm/Kconfig | 5 -- board/zipitz2/Kconfig | 9 -- board/zipitz2/MAINTAINERS | 6 -- board/zipitz2/Makefile | 10 --- board/zipitz2/zipitz2.c | 217 ---------------------------------------------- configs/zipitz2_defconfig | 19 ---- include/configs/zipitz2.h | 213 --------------------------------------------- 7 files changed, 479 deletions(-) delete mode 100644 board/zipitz2/Kconfig delete mode 100644 board/zipitz2/MAINTAINERS delete mode 100644 board/zipitz2/Makefile delete mode 100644 board/zipitz2/zipitz2.c delete mode 100644 configs/zipitz2_defconfig delete mode 100644 include/configs/zipitz2.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 26c8e2f..cd582a7 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -805,10 +805,6 @@ config TARGET_LS1046ARDB development platform that supports the QorIQ LS1046A Layerscape Architecture processor.
-config TARGET_ZIPITZ2 - bool "Support zipitz2" - select CPU_PXA - config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select BLK @@ -1009,7 +1005,6 @@ source "board/technologic/ts4800/Kconfig" source "board/vscom/baltos/Kconfig" source "board/woodburn/Kconfig" source "board/work-microwave/work_92105/Kconfig" -source "board/zipitz2/Kconfig"
source "arch/arm/Kconfig.debug"
diff --git a/board/zipitz2/Kconfig b/board/zipitz2/Kconfig deleted file mode 100644 index c663504..0000000 --- a/board/zipitz2/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_ZIPITZ2 - -config SYS_BOARD - default "zipitz2" - -config SYS_CONFIG_NAME - default "zipitz2" - -endif diff --git a/board/zipitz2/MAINTAINERS b/board/zipitz2/MAINTAINERS deleted file mode 100644 index e027cd3..0000000 --- a/board/zipitz2/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -ZIPITZ2 BOARD -M: Vasily Khoruzhick anarsoul@gmail.com -S: Maintained -F: board/zipitz2/ -F: include/configs/zipitz2.h -F: configs/zipitz2_defconfig diff --git a/board/zipitz2/Makefile b/board/zipitz2/Makefile deleted file mode 100644 index 855f6bc..0000000 --- a/board/zipitz2/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# -# Copyright (C) 2009 -# Marek Vasut marek.vasut@gmail.com -# -# Heavily based on pxa255_idp platform -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := zipitz2.o diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c deleted file mode 100644 index d3ca939..0000000 --- a/board/zipitz2/zipitz2.c +++ /dev/null @@ -1,217 +0,0 @@ -/* - * Copyright (C) 2009 - * Marek Vasut marek.vasut@gmail.com - * - * Heavily based on pxa255_idp platform - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <serial.h> -#include <asm/arch/hardware.h> -#include <asm/arch/pxa.h> -#include <asm/arch/regs-mmc.h> -#include <spi.h> -#include <asm/io.h> -#include <usb.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_CMD_SPI -void lcd_start(void); -#else -inline void lcd_start(void) {}; -#endif - -/* - * Miscelaneous platform dependent initialisations - */ -int board_init(void) -{ - /* arch number of Z2 */ - gd->bd->bi_arch_number = MACH_TYPE_ZIPIT2; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0xa0000100; - - /* Enable LCD */ - lcd_start(); - - return 0; -} - -int dram_init(void) -{ - pxa2xx_dram_init(); - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_USB -int board_usb_init(int index, enum usb_init_type init) -{ - /* enable port 2 */ - writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | - UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); - - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return 0; -} - -void usb_board_stop(void) -{ -} -#endif - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; -} - -#ifdef CONFIG_CMD_MMC -int board_mmc_init(bd_t *bis) -{ - pxa_mmc_register(0); - return 0; -} -#endif - -#ifdef CONFIG_CMD_SPI - -struct { - unsigned char reg; - unsigned short data; - unsigned char mdelay; -} lcd_data[] = { - { 0x07, 0x0000, 0 }, - { 0x13, 0x0000, 10 }, - { 0x11, 0x3004, 0 }, - { 0x14, 0x200F, 0 }, - { 0x10, 0x1a20, 0 }, - { 0x13, 0x0040, 50 }, - { 0x13, 0x0060, 0 }, - { 0x13, 0x0070, 200 }, - { 0x01, 0x0127, 0 }, - { 0x02, 0x0700, 0 }, - { 0x03, 0x1030, 0 }, - { 0x08, 0x0208, 0 }, - { 0x0B, 0x0620, 0 }, - { 0x0C, 0x0110, 0 }, - { 0x30, 0x0120, 0 }, - { 0x31, 0x0127, 0 }, - { 0x32, 0x0000, 0 }, - { 0x33, 0x0503, 0 }, - { 0x34, 0x0727, 0 }, - { 0x35, 0x0124, 0 }, - { 0x36, 0x0706, 0 }, - { 0x37, 0x0701, 0 }, - { 0x38, 0x0F00, 0 }, - { 0x39, 0x0F00, 0 }, - { 0x40, 0x0000, 0 }, - { 0x41, 0x0000, 0 }, - { 0x42, 0x013f, 0 }, - { 0x43, 0x0000, 0 }, - { 0x44, 0x013f, 0 }, - { 0x45, 0x0000, 0 }, - { 0x46, 0xef00, 0 }, - { 0x47, 0x013f, 0 }, - { 0x48, 0x0000, 0 }, - { 0x07, 0x0015, 30 }, - { 0x07, 0x0017, 0 }, - { 0x20, 0x0000, 0 }, - { 0x21, 0x0000, 0 }, - { 0x22, 0x0000, 0 }, -}; - -void zipitz2_spi_sda(int set) -{ - /* GPIO 13 */ - if (set) - writel((1 << 13), GPSR0); - else - writel((1 << 13), GPCR0); -} - -void zipitz2_spi_scl(int set) -{ - /* GPIO 22 */ - if (set) - writel((1 << 22), GPCR0); - else - writel((1 << 22), GPSR0); -} - -unsigned char zipitz2_spi_read(void) -{ - /* GPIO 40 */ - return !!(readl(GPLR1) & (1 << 8)); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* Always valid */ - return 1; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* GPIO 88 low */ - writel((1 << 24), GPCR2); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* GPIO 88 high */ - writel((1 << 24), GPSR2); -} - -void lcd_start(void) -{ - int i; - unsigned char reg[3] = { 0x74, 0x00, 0 }; - unsigned char data[3] = { 0x76, 0, 0 }; - unsigned char dummy[3] = { 0, 0, 0 }; - - /* PWM2 AF */ - writel(readl(GAFR0_L) | 0x00800000, GAFR0_L); - /* Enable clock to all PWM */ - writel(readl(CKEN) | 0x3, CKEN); - /* Configure PWM2 */ - writel(0x4f, PWM_CTRL2); - writel(0x2ff, PWM_PWDUTY2); - writel(792, PWM_PERVAL2); - - /* Toggle the reset pin to reset the LCD */ - writel((1 << 19), GPSR0); - udelay(100000); - writel((1 << 19), GPCR0); - udelay(20000); - writel((1 << 19), GPSR0); - udelay(20000); - - /* Program the LCD init sequence */ - for (i = 0; i < sizeof(lcd_data) / sizeof(lcd_data[0]); i++) { - reg[0] = 0x74; - reg[1] = 0x0; - reg[2] = lcd_data[i].reg; - spi_xfer(NULL, 24, reg, dummy, SPI_XFER_BEGIN | SPI_XFER_END); - - data[0] = 0x76; - data[1] = lcd_data[i].data >> 8; - data[2] = lcd_data[i].data & 0xff; - spi_xfer(NULL, 24, data, dummy, SPI_XFER_BEGIN | SPI_XFER_END); - - if (lcd_data[i].mdelay) - udelay(lcd_data[i].mdelay * 1000); - } - - writel((1 << 11), GPSR0); -} -#endif diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig deleted file mode 100644 index d9819a5..0000000 --- a/configs/zipitz2_defconfig +++ /dev/null @@ -1,19 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_ZIPITZ2=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h deleted file mode 100644 index 6e83cc9..0000000 --- a/include/configs/zipitz2.h +++ /dev/null @@ -1,213 +0,0 @@ -/* - * Aeronix Zipit Z2 configuration file - * - * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Board Configuration Options - */ -#define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ -#define CONFIG_SYS_TEXT_BASE 0x0 - -#undef CONFIG_BOARD_LATE_INIT -#undef CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_PREBOOT - -/* - * Environment settings - */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR 0x40000 -#define CONFIG_ENV_SIZE 0x10000 - -#define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_ARCH_CPU_INIT - -#define CONFIG_BOOTCOMMAND \ - "if mmc rescan && ext2load mmc 0 0xa0000000 boot/uboot.script ;"\ - "then " \ - "source 0xa0000000; " \ - "else " \ - "bootm 0x50000; " \ - "fi; " -#define CONFIG_BOOTARGS \ - "console=tty0 console=ttyS2,115200 fbcon=rotate:3" -#define CONFIG_TIMESTAMP -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_SYS_TEXT_BASE 0x0 -#define CONFIG_LZMA /* LZMA compression support */ - -/* - * Serial Console Configuration - * STUART - the lower serial port on Colibri board - */ -#define CONFIG_PXA_SERIAL -#define CONFIG_STUART 1 -#define CONFIG_CONS_INDEX 2 -#define CONFIG_BAUDRATE 115200 - -/* - * Bootloader Components Configuration - */ -#define CONFIG_CMD_ENV - -/* - * MMC Card Configuration - */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_PXA_MMC_GENERIC -#define CONFIG_SYS_MMC_BASE 0xF0000000 -#define CONFIG_DOS_PARTITION -#endif - -/* - * SPI and LCD - */ -#ifdef CONFIG_CMD_SPI -#define CONFIG_SOFT_SPI -#define CONFIG_LCD -#define CONFIG_LCD_ROTATION -#define CONFIG_PXA_LCD -#define CONFIG_LMS283GF05 - -#define SPI_DELAY udelay(10) -#define SPI_SDA(val) zipitz2_spi_sda(val) -#define SPI_SCL(val) zipitz2_spi_scl(val) -#define SPI_READ zipitz2_spi_read() -#ifndef __ASSEMBLY__ -void zipitz2_spi_sda(int); -void zipitz2_spi_scl(int); -unsigned char zipitz2_spi_read(void); -#endif -#endif - -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_DEVICE_NULLDEV 1 - -/* - * Clock Configuration - */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ - -/* - * SRAM Map - */ -#define PHYS_SRAM 0x5c000000 /* SRAM Bank #1 */ -#define PHYS_SRAM_SIZE 0x00040000 /* 256k */ - -/* - * DRAM Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ - -#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ -#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ - -#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SRAM + 2048) - -/* - * NOR FLASH - */ -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ -#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ -#define PHYS_FLASH_SECT_SIZE 0x00010000 /* 64 KB sectors */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT - -#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MONITOR_LEN PHYS_FLASH_SECT_SIZE - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 256 - -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 240000 -#define CONFIG_SYS_FLASH_LOCK_TOUT 240000 -#define CONFIG_SYS_FLASH_UNLOCK_TOUT 240000 -#define CONFIG_SYS_FLASH_PROTECTION - -/* - * GPIO settings - */ -#define CONFIG_SYS_GAFR0_L_VAL 0x02000140 -#define CONFIG_SYS_GAFR0_U_VAL 0x59188000 -#define CONFIG_SYS_GAFR1_L_VAL 0x63900002 -#define CONFIG_SYS_GAFR1_U_VAL 0xaaa03950 -#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa -#define CONFIG_SYS_GAFR2_U_VAL 0x29000308 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000000 -#define CONFIG_SYS_GAFR3_U_VAL 0x000000d5 -#define CONFIG_SYS_GPCR0_VAL 0x00000000 -#define CONFIG_SYS_GPCR1_VAL 0x00000020 -#define CONFIG_SYS_GPCR2_VAL 0x00000000 -#define CONFIG_SYS_GPCR3_VAL 0x00000000 -#define CONFIG_SYS_GPDR0_VAL 0xdafcee00 -#define CONFIG_SYS_GPDR1_VAL 0xffa3aaab -#define CONFIG_SYS_GPDR2_VAL 0x8fe9ffff -#define CONFIG_SYS_GPDR3_VAL 0x001b1f8a -#define CONFIG_SYS_GPSR0_VAL 0x06080400 -#define CONFIG_SYS_GPSR1_VAL 0x007f0000 -#define CONFIG_SYS_GPSR2_VAL 0x032a0000 -#define CONFIG_SYS_GPSR3_VAL 0x00000180 - -#define CONFIG_SYS_PSSR_VAL 0x30 - -/* - * Clock settings - */ -#define CONFIG_SYS_CKEN 0x00511220 -#define CONFIG_SYS_CCCR 0x00000190 - -/* - * Memory settings - */ -#define CONFIG_SYS_MSC0_VAL 0x2ffc38f8 -#define CONFIG_SYS_MSC1_VAL 0x0000ccd1 -#define CONFIG_SYS_MSC2_VAL 0x0000b884 -#define CONFIG_SYS_MDCNFG_VAL 0x08000ba9 -#define CONFIG_SYS_MDREFR_VAL 0x2011a01e -#define CONFIG_SYS_MDMRS_VAL 0x00000000 -#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 -#define CONFIG_SYS_SXCNFG_VAL 0x40044004 - -/* - * PCMCIA and CF Interfaces - */ -#define CONFIG_SYS_MECR_VAL 0x00000001 -#define CONFIG_SYS_MCMEM0_VAL 0x00014307 -#define CONFIG_SYS_MCMEM1_VAL 0x00014307 -#define CONFIG_SYS_MCATT0_VAL 0x0001c787 -#define CONFIG_SYS_MCATT1_VAL 0x0001c787 -#define CONFIG_SYS_MCIO0_VAL 0x0001430f -#define CONFIG_SYS_MCIO1_VAL 0x0001430f - -#include "pxa-common.h" - -#endif /* __CONFIG_H */
There are no boards using this driver and it has not been converted to driver model. Drop it.
doc/driver-model/serial-howto.txt | 1 - drivers/serial/Makefile | 1 - drivers/serial/serial_pxa.c | 299 -------------------------------------- scripts/config_whitelist.txt | 1 - 4 files changed, 302 deletions(-) delete mode 100644 drivers/serial/serial_pxa.c
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index cddfb9f..ed846e5 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -6,7 +6,6 @@ ones remain:
mcfuart.c serial_bfin.c - serial_pxa.c serial_s3c24x0.c
The deadline for this work was the end of January 2016. If no one steps diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 21b1292..0c75718 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -26,7 +26,6 @@ obj-$(CONFIG_MCFUART) += mcfuart.o obj-$(CONFIG_SYS_NS16550) += ns16550.o obj-$(CONFIG_S5P) += serial_s5p.o obj-$(CONFIG_MXC_UART) += serial_mxc.o -obj-$(CONFIG_PXA_SERIAL) += serial_pxa.o obj-$(CONFIG_MESON_SERIAL) += serial_meson.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_SERIAL) += serial_rockchip.o diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c deleted file mode 100644 index 1eb19ec..0000000 --- a/drivers/serial/serial_pxa.c +++ /dev/null @@ -1,299 +0,0 @@ -/* - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/pxa-regs.h> -#include <asm/arch/regs-uart.h> -#include <asm/io.h> -#include <linux/compiler.h> -#include <serial.h> -#include <watchdog.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* - * The numbering scheme differs here for PXA25x, PXA27x and PXA3xx so we can - * easily handle enabling of clock. - */ -#ifdef CONFIG_CPU_MONAHANS -#define UART_CLK_BASE CKENA_21_BTUART -#define UART_CLK_REG CKENA -#define BTUART_INDEX 0 -#define FFUART_INDEX 1 -#define STUART_INDEX 2 -#elif CONFIG_CPU_PXA25X -#define UART_CLK_BASE (1 << 4) /* HWUART */ -#define UART_CLK_REG CKEN -#define HWUART_INDEX 0 -#define STUART_INDEX 1 -#define FFUART_INDEX 2 -#define BTUART_INDEX 3 -#else /* PXA27x */ -#define UART_CLK_BASE CKEN5_STUART -#define UART_CLK_REG CKEN -#define STUART_INDEX 0 -#define FFUART_INDEX 1 -#define BTUART_INDEX 2 -#endif - -/* - * Only PXA250 has HWUART, to avoid poluting the code with more macros, - * artificially introduce this. - */ -#ifndef CONFIG_CPU_PXA25X -#define HWUART_INDEX 0xff -#endif - -static uint32_t pxa_uart_get_baud_divider(void) -{ - if (gd->baudrate == 1200) - return 768; - else if (gd->baudrate == 9600) - return 96; - else if (gd->baudrate == 19200) - return 48; - else if (gd->baudrate == 38400) - return 24; - else if (gd->baudrate == 57600) - return 16; - else if (gd->baudrate == 115200) - return 8; - else /* Unsupported baudrate */ - return 0; -} - -static struct pxa_uart_regs *pxa_uart_index_to_regs(uint32_t uart_index) -{ - switch (uart_index) { - case FFUART_INDEX: return (struct pxa_uart_regs *)FFUART_BASE; - case BTUART_INDEX: return (struct pxa_uart_regs *)BTUART_BASE; - case STUART_INDEX: return (struct pxa_uart_regs *)STUART_BASE; - case HWUART_INDEX: return (struct pxa_uart_regs *)HWUART_BASE; - default: - return NULL; - } -} - -static void pxa_uart_toggle_clock(uint32_t uart_index, int enable) -{ - uint32_t clk_reg, clk_offset, reg; - - clk_reg = UART_CLK_REG; - clk_offset = UART_CLK_BASE << uart_index; - - reg = readl(clk_reg); - - if (enable) - reg |= clk_offset; - else - reg &= ~clk_offset; - - writel(reg, clk_reg); -} - -/* - * Enable clock and set baud rate, parity etc. - */ -void pxa_setbrg_dev(uint32_t uart_index) -{ - uint32_t divider = 0; - struct pxa_uart_regs *uart_regs; - - divider = pxa_uart_get_baud_divider(); - if (!divider) - hang(); - - uart_regs = pxa_uart_index_to_regs(uart_index); - if (!uart_regs) - hang(); - - pxa_uart_toggle_clock(uart_index, 1); - - /* Disable interrupts and FIFOs */ - writel(0, &uart_regs->ier); - writel(0, &uart_regs->fcr); - - /* Set baud rate */ - writel(LCR_WLS0 | LCR_WLS1 | LCR_DLAB, &uart_regs->lcr); - writel(divider & 0xff, &uart_regs->dll); - writel(divider >> 8, &uart_regs->dlh); - writel(LCR_WLS0 | LCR_WLS1, &uart_regs->lcr); - - /* Enable UART */ - writel(IER_UUE, &uart_regs->ier); -} - -/* - * Initialise the serial port with the given baudrate. The settings - * are always 8 data bits, no parity, 1 stop bit, no start bits. - */ -int pxa_init_dev(unsigned int uart_index) -{ - pxa_setbrg_dev (uart_index); - return 0; -} - -/* - * Output a single byte to the serial port. - */ -void pxa_putc_dev(unsigned int uart_index, const char c) -{ - struct pxa_uart_regs *uart_regs; - - /* If \n, also do \r */ - if (c == '\n') - pxa_putc_dev(uart_index, '\r'); - - uart_regs = pxa_uart_index_to_regs(uart_index); - if (!uart_regs) - hang(); - - while (!(readl(&uart_regs->lsr) & LSR_TEMT)) - WATCHDOG_RESET(); - writel(c, &uart_regs->thr); -} - -/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -int pxa_tstc_dev(unsigned int uart_index) -{ - struct pxa_uart_regs *uart_regs; - - uart_regs = pxa_uart_index_to_regs(uart_index); - if (!uart_regs) - return -1; - - return readl(&uart_regs->lsr) & LSR_DR; -} - -/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -int pxa_getc_dev(unsigned int uart_index) -{ - struct pxa_uart_regs *uart_regs; - - uart_regs = pxa_uart_index_to_regs(uart_index); - if (!uart_regs) - return -1; - - while (!(readl(&uart_regs->lsr) & LSR_DR)) - WATCHDOG_RESET(); - return readl(&uart_regs->rbr) & 0xff; -} - -void pxa_puts_dev(unsigned int uart_index, const char *s) -{ - while (*s) - pxa_putc_dev(uart_index, *s++); -} - -#define pxa_uart(uart, UART) \ - int uart##_init(void) \ - { \ - return pxa_init_dev(UART##_INDEX); \ - } \ - \ - void uart##_setbrg(void) \ - { \ - return pxa_setbrg_dev(UART##_INDEX); \ - } \ - \ - void uart##_putc(const char c) \ - { \ - return pxa_putc_dev(UART##_INDEX, c); \ - } \ - \ - void uart##_puts(const char *s) \ - { \ - return pxa_puts_dev(UART##_INDEX, s); \ - } \ - \ - int uart##_getc(void) \ - { \ - return pxa_getc_dev(UART##_INDEX); \ - } \ - \ - int uart##_tstc(void) \ - { \ - return pxa_tstc_dev(UART##_INDEX); \ - } \ - -#define pxa_uart_desc(uart) \ - struct serial_device serial_##uart##_device = \ - { \ - .name = "serial_"#uart, \ - .start = uart##_init, \ - .stop = NULL, \ - .setbrg = uart##_setbrg, \ - .getc = uart##_getc, \ - .tstc = uart##_tstc, \ - .putc = uart##_putc, \ - .puts = uart##_puts, \ - }; - -#define pxa_uart_multi(uart, UART) \ - pxa_uart(uart, UART) \ - pxa_uart_desc(uart) - -#if defined(CONFIG_HWUART) - pxa_uart_multi(hwuart, HWUART) -#endif -#if defined(CONFIG_STUART) - pxa_uart_multi(stuart, STUART) -#endif -#if defined(CONFIG_FFUART) - pxa_uart_multi(ffuart, FFUART) -#endif -#if defined(CONFIG_BTUART) - pxa_uart_multi(btuart, BTUART) -#endif - -__weak struct serial_device *default_serial_console(void) -{ -#if CONFIG_CONS_INDEX == 1 - return &serial_hwuart_device; -#elif CONFIG_CONS_INDEX == 2 - return &serial_stuart_device; -#elif CONFIG_CONS_INDEX == 3 - return &serial_ffuart_device; -#elif CONFIG_CONS_INDEX == 4 - return &serial_btuart_device; -#else -#error "Bad CONFIG_CONS_INDEX." -#endif -} - -void pxa_serial_initialize(void) -{ -#if defined(CONFIG_FFUART) - serial_register(&serial_ffuart_device); -#endif -#if defined(CONFIG_BTUART) - serial_register(&serial_btuart_device); -#endif -#if defined(CONFIG_STUART) - serial_register(&serial_stuart_device); -#endif -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2c10c0b..4d42fc5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3751,7 +3751,6 @@ CONFIG_PWM_IMX CONFIG_PXA_LCD CONFIG_PXA_MMC_GENERIC CONFIG_PXA_PWR_I2C -CONFIG_PXA_SERIAL CONFIG_PXA_STD_I2C CONFIG_PXA_VGA CONFIG_PXA_VIDEO
This driver was converted so we should remove it from the list.
doc/driver-model/serial-howto.txt | 1 - 1 file changed, 1 deletion(-)
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index ed846e5..a655464 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -4,7 +4,6 @@ How to port a serial driver to driver model Almost all of the serial drivers have been converted as at January 2016. These ones remain:
- mcfuart.c serial_bfin.c serial_s3c24x0.c
arch/arm/Kconfig | 5 - board/samsung/smdk2410/Kconfig | 15 --- board/samsung/smdk2410/MAINTAINERS | 6 -- board/samsung/smdk2410/Makefile | 9 -- board/samsung/smdk2410/lowlevel_init.S | 146 -------------------------- board/samsung/smdk2410/smdk2410.c | 139 ------------------------- configs/smdk2410_defconfig | 16 --- include/configs/smdk2410.h | 181 --------------------------------- scripts/config_whitelist.txt | 2 - 9 files changed, 519 deletions(-) delete mode 100644 board/samsung/smdk2410/Kconfig delete mode 100644 board/samsung/smdk2410/MAINTAINERS delete mode 100644 board/samsung/smdk2410/Makefile delete mode 100644 board/samsung/smdk2410/lowlevel_init.S delete mode 100644 board/samsung/smdk2410/smdk2410.c delete mode 100644 configs/smdk2410_defconfig delete mode 100644 include/configs/smdk2410.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index cd582a7..6aa5208 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -141,10 +141,6 @@ config TARGET_VCMA9 bool "Support VCMA9" select CPU_ARM920T
-config TARGET_SMDK2410 - bool "Support smdk2410" - select CPU_ARM920T - config TARGET_ASPENITE bool "Support aspenite" select CPU_ARM926EJS @@ -978,7 +974,6 @@ source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" source "board/phytec/pcm052/Kconfig" source "board/ppcag/bg0900/Kconfig" -source "board/samsung/smdk2410/Kconfig" source "board/sandisk/sansa_fuze_plus/Kconfig" source "board/schulercontrol/sc_sps_1/Kconfig" source "board/siemens/draco/Kconfig" diff --git a/board/samsung/smdk2410/Kconfig b/board/samsung/smdk2410/Kconfig deleted file mode 100644 index e987b64..0000000 --- a/board/samsung/smdk2410/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_SMDK2410 - -config SYS_BOARD - default "smdk2410" - -config SYS_VENDOR - default "samsung" - -config SYS_SOC - default "s3c24x0" - -config SYS_CONFIG_NAME - default "smdk2410" - -endif diff --git a/board/samsung/smdk2410/MAINTAINERS b/board/samsung/smdk2410/MAINTAINERS deleted file mode 100644 index 12a25e8..0000000 --- a/board/samsung/smdk2410/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -SMDK2410 BOARD -M: David Müller d.mueller@elsoft.ch -S: Maintained -F: board/samsung/smdk2410/ -F: include/configs/smdk2410.h -F: configs/smdk2410_defconfig diff --git a/board/samsung/smdk2410/Makefile b/board/samsung/smdk2410/Makefile deleted file mode 100644 index 1939a21..0000000 --- a/board/samsung/smdk2410/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := smdk2410.o -obj-y += lowlevel_init.o diff --git a/board/samsung/smdk2410/lowlevel_init.S b/board/samsung/smdk2410/lowlevel_init.S deleted file mode 100644 index c3f4187..0000000 --- a/board/samsung/smdk2410/lowlevel_init.S +++ /dev/null @@ -1,146 +0,0 @@ -/* - * Memory Setup stuff - taken from blob memsetup.S - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and - * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) - * - * Modified for the Samsung SMDK2410 by - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <config.h> - -/* some parameters for the board */ - -/* - * - * Taken from linux/arch/arm/boot/compressed/head-s3c2410.S - * - * Copyright (C) 2002 Samsung Electronics SW.LEE hitchcar@sec.samsung.com - * - */ - -#define BWSCON 0x48000000 - -/* BWSCON */ -#define DW8 (0x0) -#define DW16 (0x1) -#define DW32 (0x2) -#define WAIT (0x1<<2) -#define UBLB (0x1<<3) - -#define B1_BWSCON (DW32) -#define B2_BWSCON (DW16) -#define B3_BWSCON (DW16 + WAIT + UBLB) -#define B4_BWSCON (DW16) -#define B5_BWSCON (DW16) -#define B6_BWSCON (DW32) -#define B7_BWSCON (DW32) - -/* BANK0CON */ -#define B0_Tacs 0x0 /* 0clk */ -#define B0_Tcos 0x0 /* 0clk */ -#define B0_Tacc 0x7 /* 14clk */ -#define B0_Tcoh 0x0 /* 0clk */ -#define B0_Tah 0x0 /* 0clk */ -#define B0_Tacp 0x0 -#define B0_PMC 0x0 /* normal */ - -/* BANK1CON */ -#define B1_Tacs 0x0 /* 0clk */ -#define B1_Tcos 0x0 /* 0clk */ -#define B1_Tacc 0x7 /* 14clk */ -#define B1_Tcoh 0x0 /* 0clk */ -#define B1_Tah 0x0 /* 0clk */ -#define B1_Tacp 0x0 -#define B1_PMC 0x0 - -#define B2_Tacs 0x0 -#define B2_Tcos 0x0 -#define B2_Tacc 0x7 -#define B2_Tcoh 0x0 -#define B2_Tah 0x0 -#define B2_Tacp 0x0 -#define B2_PMC 0x0 - -#define B3_Tacs 0x0 /* 0clk */ -#define B3_Tcos 0x3 /* 4clk */ -#define B3_Tacc 0x7 /* 14clk */ -#define B3_Tcoh 0x1 /* 1clk */ -#define B3_Tah 0x0 /* 0clk */ -#define B3_Tacp 0x3 /* 6clk */ -#define B3_PMC 0x0 /* normal */ - -#define B4_Tacs 0x0 /* 0clk */ -#define B4_Tcos 0x0 /* 0clk */ -#define B4_Tacc 0x7 /* 14clk */ -#define B4_Tcoh 0x0 /* 0clk */ -#define B4_Tah 0x0 /* 0clk */ -#define B4_Tacp 0x0 -#define B4_PMC 0x0 /* normal */ - -#define B5_Tacs 0x0 /* 0clk */ -#define B5_Tcos 0x0 /* 0clk */ -#define B5_Tacc 0x7 /* 14clk */ -#define B5_Tcoh 0x0 /* 0clk */ -#define B5_Tah 0x0 /* 0clk */ -#define B5_Tacp 0x0 -#define B5_PMC 0x0 /* normal */ - -#define B6_MT 0x3 /* SDRAM */ -#define B6_Trcd 0x1 -#define B6_SCAN 0x1 /* 9bit */ - -#define B7_MT 0x3 /* SDRAM */ -#define B7_Trcd 0x1 /* 3clk */ -#define B7_SCAN 0x1 /* 9bit */ - -/* REFRESH parameter */ -#define REFEN 0x1 /* Refresh enable */ -#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ -#define Trp 0x0 /* 2clk */ -#define Trc 0x3 /* 7clk */ -#define Tchr 0x2 /* 3clk */ -#define REFCNT 1113 /* period=15.6us, HCLK=60Mhz, (2048+1-15.6*60) */ -/**************************************/ - -.globl lowlevel_init -lowlevel_init: - /* memory control configuration */ - /* make r0 relative the current location so that it */ - /* reads SMRDATA out of FLASH rather than memory ! */ - ldr r0, =SMRDATA - ldr r1, =CONFIG_SYS_TEXT_BASE - sub r0, r0, r1 - ldr r1, =BWSCON /* Bus Width Status Controller */ - add r2, r0, #13*4 -0: - ldr r3, [r0], #4 - str r3, [r1], #4 - cmp r2, r0 - bne 0b - - /* everything is fine now */ - mov pc, lr - - .ltorg -/* the literal pools origin */ - -SMRDATA: - .word (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28)) - .word ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) - .word ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) - .word ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) - .word ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) - .word ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) - .word ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) - .word ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) - .word ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) - .word ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) - .word 0x32 - .word 0x30 - .word 0x30 diff --git a/board/samsung/smdk2410/smdk2410.c b/board/samsung/smdk2410/smdk2410.c deleted file mode 100644 index 6e678c7..0000000 --- a/board/samsung/smdk2410/smdk2410.c +++ /dev/null @@ -1,139 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002, 2010 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define FCLK_SPEED 1 - -#if (FCLK_SPEED == 0) /* Fout = 203MHz, Fin = 12MHz for Audio */ -#define M_MDIV 0xC3 -#define M_PDIV 0x4 -#define M_SDIV 0x1 -#elif (FCLK_SPEED == 1) /* Fout = 202.8MHz */ -#define M_MDIV 0xA1 -#define M_PDIV 0x3 -#define M_SDIV 0x1 -#endif - -#define USB_CLOCK 1 - -#if (USB_CLOCK == 0) -#define U_M_MDIV 0xA1 -#define U_M_PDIV 0x3 -#define U_M_SDIV 0x1 -#elif (USB_CLOCK == 1) -#define U_M_MDIV 0x48 -#define U_M_PDIV 0x3 -#define U_M_SDIV 0x2 -#endif - -static inline void pll_delay(unsigned long loops) -{ - __asm__ volatile ("1:\n" - "subs %0, %1, #1\n" - "bne 1b" : "=r" (loops) : "0" (loops)); -} - -/* - * Miscellaneous platform dependent initialisations - */ - -int board_early_init_f(void) -{ - struct s3c24x0_clock_power * const clk_power = - s3c24x0_get_base_clock_power(); - struct s3c24x0_gpio * const gpio = s3c24x0_get_base_gpio(); - - /* to reduce PLL lock time, adjust the LOCKTIME register */ - writel(0xFFFFFF, &clk_power->locktime); - - /* configure MPLL */ - writel((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV, - &clk_power->mpllcon); - - /* some delay between MPLL and UPLL */ - pll_delay(4000); - - /* configure UPLL */ - writel((U_M_MDIV << 12) + (U_M_PDIV << 4) + U_M_SDIV, - &clk_power->upllcon); - - /* some delay between MPLL and UPLL */ - pll_delay(8000); - - /* set up the I/O ports */ - writel(0x007FFFFF, &gpio->gpacon); - writel(0x00044555, &gpio->gpbcon); - writel(0x000007FF, &gpio->gpbup); - writel(0xAAAAAAAA, &gpio->gpccon); - writel(0x0000FFFF, &gpio->gpcup); - writel(0xAAAAAAAA, &gpio->gpdcon); - writel(0x0000FFFF, &gpio->gpdup); - writel(0xAAAAAAAA, &gpio->gpecon); - writel(0x0000FFFF, &gpio->gpeup); - writel(0x000055AA, &gpio->gpfcon); - writel(0x000000FF, &gpio->gpfup); - writel(0xFF95FFBA, &gpio->gpgcon); - writel(0x0000FFFF, &gpio->gpgup); - writel(0x002AFAAA, &gpio->gphcon); - writel(0x000007FF, &gpio->gphup); - - return 0; -} - -int board_init(void) -{ - /* arch number of SMDK2410-Board */ - gd->bd->bi_arch_number = MACH_TYPE_SMDK2410; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0x30000100; - - icache_enable(); - dcache_enable(); - - return 0; -} - -int dram_init(void) -{ - /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_CS8900 - rc = cs8900_initialize(0, CONFIG_CS8900_BASE); -#endif - return rc; -} -#endif - -/* - * Hardcoded flash setup: - * Flash 0 is a non-CFI AMD AM29LV800BB flash. - */ -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - info->portwidth = FLASH_CFI_16BIT; - info->chipwidth = FLASH_CFI_BY16; - info->interface = FLASH_CFI_X16; - return 1; -} diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig deleted file mode 100644 index d6aa2dd..0000000 --- a/configs/smdk2410_defconfig +++ /dev/null @@ -1,16 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_SMDK2410=y -CONFIG_BOOTDELAY=5 -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="SMDK2410 # " -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_UBI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h deleted file mode 100644 index f76fa75..0000000 --- a/include/configs/smdk2410.h +++ /dev/null @@ -1,181 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * Gary Jennejohn garyj@denx.de - * David Mueller d.mueller@elsoft.ch - * - * Configuation settings for the SAMSUNG SMDK2410 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_S3C24X0 /* This is a SAMSUNG S3C24x0-type SoC */ -#define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ -#define CONFIG_SMDK2410 /* on a SAMSUNG SMDK2410 Board */ - -#define CONFIG_SYS_TEXT_BASE 0x0 - -#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH - -/* input clock of PLL (the SMDK2410 has 12MHz input clock) */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG - -/* - * Hardware drivers - */ -#define CONFIG_CS8900 /* we have a CS8900 on-board */ -#define CONFIG_CS8900_BASE 0x19000300 -#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */ - -/* - * select serial console configuration - */ -#define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK2410 */ - -/************************************************************ - * USB support (currently only works with D-cache off) - ************************************************************/ -#define CONFIG_USB_OHCI -#define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD -#define CONFIG_DOS_PARTITION - -/************************************************************ - * RTC - ************************************************************/ -#define CONFIG_RTC_S3C24X0 - -#define CONFIG_BAUDRATE 115200 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Command line configuration. - */ -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_NAND -#define CONFIG_CMD_REGINFO - -#define CONFIG_CMDLINE_EDITING - -/* autoboot */ -#define CONFIG_BOOT_RETRY_TIME -1 -#define CONFIG_RESET_TO_RETRY - -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 10.0.0.110 -#define CONFIG_SERVERIP 10.0.0.1 - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_CBSIZE 256 -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x30800000 - -/* support additional compression methods */ -#define CONFIG_BZIP2 -#define CONFIG_LZO -#define CONFIG_LZMA - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ - -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #0 */ - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_LEGACY_512Kx16 -#define CONFIG_FLASH_SHOW_PROGRESS 45 - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_MAX_FLASH_SECT (19) - -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x070000) -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SIZE 0x10000 -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* - * Size of malloc() pool - * BZIP2 / LZO / LZMA need a lot of RAM - */ -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) - -#define CONFIG_SYS_MONITOR_LEN (448 * 1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE - -/* - * NAND configuration - */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_S3C2410 -#define CONFIG_SYS_S3C2410_NAND_HWECC -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x4E000000 -#endif - -/* - * File system - */ -#define CONFIG_CMD_UBIFS -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE -#define CONFIG_MTD_PARTITIONS -#define CONFIG_YAFFS2 -#define CONFIG_RBTREE - -/* additions for new relocation code, must be added to all boards */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_BOARD_EARLY_INIT_F - -#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4d42fc5..337407f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -165,7 +165,6 @@ CONFIG_ARCH_RMOBILE_EXTRAM_BOOT CONFIG_ARCH_RPC CONFIG_ARCH_S3C2440 CONFIG_ARCH_SHARK -CONFIG_ARCH_SMDK2410 CONFIG_ARCH_TEGRA CONFIG_ARCH_USE_BUILTIN_BSWAP CONFIG_ARCH_VERSATILE_PB @@ -4119,7 +4118,6 @@ CONFIG_SMC_B3TIM_VAL CONFIG_SMC_GCTL_VAL CONFIG_SMC_USE_32_BIT CONFIG_SMC_USE_IOFUNCS -CONFIG_SMDK2410 CONFIG_SMDK5420 CONFIG_SMDKC100 CONFIG_SMDKV310
arch/arm/Kconfig | 5 - board/mpl/common/common_util.c | 23 -- board/mpl/vcma9/Kconfig | 15 -- board/mpl/vcma9/MAINTAINERS | 6 - board/mpl/vcma9/Makefile | 11 - board/mpl/vcma9/cmd_vcma9.c | 119 ---------- board/mpl/vcma9/lowlevel_init.S | 500 ---------------------------------------- board/mpl/vcma9/vcma9.c | 209 ----------------- board/mpl/vcma9/vcma9.h | 28 --- configs/VCMA9_defconfig | 16 -- include/configs/VCMA9.h | 207 ----------------- scripts/config_whitelist.txt | 1 - 12 files changed, 1140 deletions(-) delete mode 100644 board/mpl/vcma9/Kconfig delete mode 100644 board/mpl/vcma9/MAINTAINERS delete mode 100644 board/mpl/vcma9/Makefile delete mode 100644 board/mpl/vcma9/cmd_vcma9.c delete mode 100644 board/mpl/vcma9/lowlevel_init.S delete mode 100644 board/mpl/vcma9/vcma9.c delete mode 100644 board/mpl/vcma9/vcma9.h delete mode 100644 configs/VCMA9_defconfig delete mode 100644 include/configs/VCMA9.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6aa5208..5036379 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -137,10 +137,6 @@ config TARGET_EDB93XX bool "Support edb93xx" select CPU_ARM920T
-config TARGET_VCMA9 - bool "Support VCMA9" - select CPU_ARM920T - config TARGET_ASPENITE bool "Support aspenite" select CPU_ARM926EJS @@ -969,7 +965,6 @@ source "board/gumstix/pepper/Kconfig" source "board/hisilicon/hikey/Kconfig" source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" -source "board/mpl/vcma9/Kconfig" source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" source "board/phytec/pcm052/Kconfig" diff --git a/board/mpl/common/common_util.c b/board/mpl/common/common_util.c index 3c110fa..aa40d10 100644 --- a/board/mpl/common/common_util.c +++ b/board/mpl/common/common_util.c @@ -272,29 +272,6 @@ mpl_prg(uchar *src, ulong size) return (1); } #endif /* defined(CONFIG_PATI) */ - -#elif defined(CONFIG_VCMA9) - start = 0; - - /* search end sector */ - for (i = 0; i < info->sector_count; i++) - if (size < info->start[i]) - break; - - flash_protect(FLAG_PROTECT_CLEAR, - start, - size, - info); - - /* now erase flash */ - printf("Erasing at %lx (sector %d) (start %lx)\n", - start,0,info->start[0]); - if ((rc = flash_erase (info, 0, i)) != 0) { - puts("ERROR "); - flash_perror(rc); - return (1); - } - #endif printf("flash erased, programming from 0x%lx 0x%lx Bytes\n", (ulong)src, size); diff --git a/board/mpl/vcma9/Kconfig b/board/mpl/vcma9/Kconfig deleted file mode 100644 index a156452..0000000 --- a/board/mpl/vcma9/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_VCMA9 - -config SYS_BOARD - default "vcma9" - -config SYS_VENDOR - default "mpl" - -config SYS_SOC - default "s3c24x0" - -config SYS_CONFIG_NAME - default "VCMA9" - -endif diff --git a/board/mpl/vcma9/MAINTAINERS b/board/mpl/vcma9/MAINTAINERS deleted file mode 100644 index 3817436..0000000 --- a/board/mpl/vcma9/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -VCMA9 BOARD -M: David Müller d.mueller@elsoft.ch -S: Maintained -F: board/mpl/vcma9/ -F: include/configs/VCMA9.h -F: configs/VCMA9_defconfig diff --git a/board/mpl/vcma9/Makefile b/board/mpl/vcma9/Makefile deleted file mode 100644 index 175a19f..0000000 --- a/board/mpl/vcma9/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := ../common/common_util.o -obj-y += vcma9.o cmd_vcma9.o - -obj-y += lowlevel_init.o diff --git a/board/mpl/vcma9/cmd_vcma9.c b/board/mpl/vcma9/cmd_vcma9.c deleted file mode 100644 index c2d62e4..0000000 --- a/board/mpl/vcma9/cmd_vcma9.c +++ /dev/null @@ -1,119 +0,0 @@ -/* - * (C) Copyright 2002 - * Denis Peter, MPL AG Switzerland, d.peter@mpl.ch - * - * adapted for VCMA9 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <net.h> -#include "vcma9.h" -#include "../common/common_util.h" - -#if defined(CONFIG_CS8900) -#include <../drivers/net/cs8900.h> - -static uchar cs8900_chksum(ushort data) -{ - return((data >> 8) & 0x00FF) + (data & 0x00FF); -} - -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ - -int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - struct eth_device *dev; - char cs8900_name[10]; - if (strcmp(argv[1], "info") == 0) - { - vcma9_print_info(); - return 0; - } -#if defined(CONFIG_CS8900) - if (strcmp(argv[1], "cs8900") == 0) { - sprintf(cs8900_name, "%s-0", CS8900_DRIVERNAME); - dev = eth_get_dev_by_name(cs8900_name); - if (!dev) { - printf("Couldn't find CS8900 driver"); - return 0; - } - if (strcmp(argv[2], "read") == 0) { - uchar addr; ushort data; - - addr = simple_strtoul(argv[3], NULL, 16); - cs8900_e2prom_read(dev, addr, &data); - printf("0x%2.2X: 0x%4.4X\n", addr, data); - } else if (strcmp(argv[2], "write") == 0) { - uchar addr; ushort data; - - addr = simple_strtoul(argv[3], NULL, 16); - data = simple_strtoul(argv[4], NULL, 16); - cs8900_e2prom_write(dev, addr, data); - } else if (strcmp(argv[2], "setaddr") == 0) { - uchar addr, i, csum; ushort data; - uchar ethaddr[6]; - - /* check for valid ethaddr */ - if (eth_getenv_enetaddr("ethaddr", ethaddr)) { - addr = 1; - data = 0x2158; - cs8900_e2prom_write(dev, addr, data); - csum = cs8900_chksum(data); - addr++; - for (i = 0; i < 6; i+=2) { - data = ethaddr[i+1] << 8 | - ethaddr[i]; - cs8900_e2prom_write(dev, addr, data); - csum += cs8900_chksum(data); - addr++; - } - /* calculate header link byte */ - data = 0xA100 | (addr * 2); - cs8900_e2prom_write(dev, 0, data); - csum += cs8900_chksum(data); - /* write checksum word */ - cs8900_e2prom_write(dev, addr, (0 - csum) << 8); - } else { - puts("\nplease defined 'ethaddr'\n"); - } - } else if (strcmp(argv[2], "dump") == 0) { - uchar addr = 0, endaddr, csum; ushort data; - - puts("Dump of CS8900 config device: "); - cs8900_e2prom_read(dev, addr, &data); - if ((data & 0xE000) == 0xA000) { - endaddr = (data & 0x00FF) / 2; - csum = cs8900_chksum(data); - for (addr = 1; addr <= endaddr; addr++) { - cs8900_e2prom_read(dev, addr, &data); - printf("\n0x%2.2X: 0x%4.4X", addr, data); - csum += cs8900_chksum(data); - } - printf("\nChecksum: %s", (csum == 0) ? "ok" : "wrong"); - } else { - puts("no valid config found"); - } - puts("\n"); - } - - return 0; - } -#endif - - return (do_mplcommon(cmdtp, flag, argc, argv)); -} - -U_BOOT_CMD( - vcma9, 6, 1, do_vcma9, - "VCMA9 specific commands", - "flash mem [SrcAddr] - updates U-Boot with image in memory\n" - "vcma9 info - displays board information" -); diff --git a/board/mpl/vcma9/lowlevel_init.S b/board/mpl/vcma9/lowlevel_init.S deleted file mode 100644 index c0d6cc8..0000000 --- a/board/mpl/vcma9/lowlevel_init.S +++ /dev/null @@ -1,500 +0,0 @@ -/* - * Memory Setup stuff - taken from blob memsetup.S - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and - * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) - * - * Modified for MPL VCMA9 by - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * (C) Copyright 2002, 2003, 2004, 2005 - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <config.h> - -/* register definitions */ - -#define PLD_BASE 0x28000000 -#define MISC_REG 0x103 -#define SDRAM_REG 0x106 -#define BWSCON 0x48000000 -#define CLKBASE 0x4C000000 -#define LOCKTIME 0x0 -#define MPLLCON 0x4 -#define UPLLCON 0x8 -#define GPIOBASE 0x56000000 -#define GSTATUS1 0xB0 -#define FASTCPU 0x02 - -/* some parameters for the board */ -/* BWSCON */ -#define DW8 (0x0) -#define DW16 (0x1) -#define DW32 (0x2) -#define WAIT (0x1<<2) -#define UBLB (0x1<<3) - -/* BANKSIZE */ -#define BURST_EN (0x1<<7) - -/* BANK0CON 200 */ -#define B0_Tacs_200 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_200 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_200 0x5 /* 8clk (or 0x6 10clk) */ -#define B0_Tcoh_200 0x0 /* 0clk */ -#define B0_Tcah_200 0x3 /* 4clk (or0x01 1clk) */ -#define B0_Tacp_200 0x0 /* page mode is not used */ -#define B0_PMC_200 0x0 /* page mode disabled */ - -/* BANK0CON 250 */ -#define B0_Tacs_250 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_250 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_250 0x5 /* 8clk (or 0x7 14clk) */ -#define B0_Tcoh_250 0x0 /* 0clk */ -#define B0_Tcah_250 0x3 /* 4clk (or 0x1 1clk) */ -#define B0_Tacp_250 0x0 /* page mode is not used */ -#define B0_PMC_250 0x0 /* page mode disabled */ - -/* BANK0CON 266 */ -#define B0_Tacs_266 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_266 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_266 0x6 /* 10clk (or 0x7 14clk) */ -#define B0_Tcoh_266 0x0 /* 0clk */ -#define B0_Tcah_266 0x3 /* 4clk (or 0x1 1clk) */ -#define B0_Tacp_266 0x0 /* page mode is not used */ -#define B0_PMC_266 0x0 /* page mode disabled */ - -/* BANK1CON 200 */ -#define B1_Tacs_200 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_200 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_200 0x5 /* 8clk (or 0x6 10clk) */ -#define B1_Tcoh_200 0x0 /* 0clk */ -#define B1_Tcah_200 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_200 0x0 /* page mode is not used */ -#define B1_PMC_200 0x0 /* page mode disabled */ - -/* BANK1CON 250 */ -#define B1_Tacs_250 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_250 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_250 0x5 /* 8clk (or 0x7 14clk) */ -#define B1_Tcoh_250 0x0 /* 0clk */ -#define B1_Tcah_250 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_250 0x0 /* page mode is not used */ -#define B1_PMC_250 0x0 /* page mode disabled */ - -/* BANK1CON 266 */ -#define B1_Tacs_266 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_266 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_266 0x6 /* 10clk (or 0x7 14clk) */ -#define B1_Tcoh_266 0x0 /* 0clk */ -#define B1_Tcah_266 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_266 0x0 /* page mode is not used */ -#define B1_PMC_266 0x0 /* page mode disabled */ - -/* BANK2CON 200 + 250 + 266 */ -#define B2_Tacs 0x3 /* 4clk */ -#define B2_Tcos 0x3 /* 4clk */ -#define B2_Tacc 0x7 /* 14clk */ -#define B2_Tcoh 0x3 /* 4clk */ -#define B2_Tcah 0x3 /* 4clk */ -#define B2_Tacp 0x0 /* page mode is not used */ -#define B2_PMC 0x0 /* page mode disabled */ - -/* BANK3CON 200 + 250 + 266 */ -#define B3_Tacs 0x3 /* 4clk */ -#define B3_Tcos 0x3 /* 4clk */ -#define B3_Tacc 0x7 /* 14clk */ -#define B3_Tcoh 0x3 /* 4clk */ -#define B3_Tcah 0x3 /* 4clk */ -#define B3_Tacp 0x0 /* page mode is not used */ -#define B3_PMC 0x0 /* page mode disabled */ - -/* BANK4CON 200 */ -#define B4_Tacs_200 0x1 /* 1clk */ -#define B4_Tcos_200 0x3 /* 4clk */ -#define B4_Tacc_200 0x7 /* 14clk */ -#define B4_Tcoh_200 0x3 /* 4clk */ -#define B4_Tcah_200 0x2 /* 2clk */ -#define B4_Tacp_200 0x0 /* page mode is not used */ -#define B4_PMC_200 0x0 /* page mode disabled */ - -/* BANK4CON 250 */ -#define B4_Tacs_250 0x1 /* 1clk */ -#define B4_Tcos_250 0x3 /* 4clk */ -#define B4_Tacc_250 0x7 /* 14clk */ -#define B4_Tcoh_250 0x3 /* 4clk */ -#define B4_Tcah_250 0x2 /* 2clk */ -#define B4_Tacp_250 0x0 /* page mode is not used */ -#define B4_PMC_250 0x0 /* page mode disabled */ - -/* BANK4CON 266 */ -#define B4_Tacs_266 0x1 /* 1clk */ -#define B4_Tcos_266 0x3 /* 4clk */ -#define B4_Tacc_266 0x7 /* 14clk */ -#define B4_Tcoh_266 0x3 /* 4clk */ -#define B4_Tcah_266 0x2 /* 2clk */ -#define B4_Tacp_266 0x0 /* page mode is not used */ -#define B4_PMC_266 0x0 /* page mode disabled */ - -/* BANK5CON 200 */ -#define B5_Tacs_200 0x0 /* 0clk */ -#define B5_Tcos_200 0x3 /* 4clk */ -#define B5_Tacc_200 0x4 /* 6clk */ -#define B5_Tcoh_200 0x3 /* 4clk */ -#define B5_Tcah_200 0x1 /* 1clk */ -#define B5_Tacp_200 0x0 /* page mode is not used */ -#define B5_PMC_200 0x0 /* page mode disabled */ - -/* BANK5CON 250 */ -#define B5_Tacs_250 0x0 /* 0clk */ -#define B5_Tcos_250 0x3 /* 4clk */ -#define B5_Tacc_250 0x5 /* 8clk */ -#define B5_Tcoh_250 0x3 /* 4clk */ -#define B5_Tcah_250 0x1 /* 1clk */ -#define B5_Tacp_250 0x0 /* page mode is not used */ -#define B5_PMC_250 0x0 /* page mode disabled */ - -/* BANK5CON 266 */ -#define B5_Tacs_266 0x0 /* 0clk */ -#define B5_Tcos_266 0x3 /* 4clk */ -#define B5_Tacc_266 0x5 /* 8clk */ -#define B5_Tcoh_266 0x3 /* 4clk */ -#define B5_Tcah_266 0x1 /* 1clk */ -#define B5_Tacp_266 0x0 /* page mode is not used */ -#define B5_PMC_266 0x0 /* page mode disabled */ - -#define B6_MT 0x3 /* SDRAM */ -#define B6_Trcd_200 0x0 /* 2clk */ -#define B6_Trcd_250 0x1 /* 3clk */ -#define B6_Trcd_266 0x1 /* 3clk */ -#define B6_SCAN 0x2 /* 10bit */ - -#define B7_MT 0x3 /* SDRAM */ -#define B7_Trcd_200 0x0 /* 2clk */ -#define B7_Trcd_250 0x1 /* 3clk */ -#define B7_Trcd_266 0x1 /* 3clk */ -#define B7_SCAN 0x2 /* 10bit */ - -/* REFRESH parameter */ -#define REFEN 0x1 /* Refresh enable */ -#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ -#define Trp_200 0x0 /* 2clk */ -#define Trp_250 0x1 /* 3clk */ -#define Trp_266 0x1 /* 3clk */ -#define Tsrc_200 0x1 /* 5clk */ -#define Tsrc_250 0x2 /* 6clk */ -#define Tsrc_266 0x3 /* 7clk */ - -/* period=15.6us, HCLK=100Mhz, (2048+1-15.6*100) */ -#define REFCNT_200 489 -/* period=15.6us, HCLK=125Mhz, (2048+1-15.6*125) */ -#define REFCNT_250 99 -/* period=15.6us, HCLK=133Mhz, (2048+1-15.6*133) */ -#define REFCNT_266 0 -/**************************************/ - -.globl lowlevel_init -lowlevel_init: - /* use r0 to relocate DATA read/write to flash rather than memory ! */ - ldr r0, =CONFIG_SYS_TEXT_BASE - ldr r13, =BWSCON - - /* enable minimal access to PLD */ - ldr r1, [r13] /* load default BWSCON */ - orr r1, r1, #(DW8 + UBLB) << 20 /* set necessary CS attrs */ - str r1, [r13] /* set BWSCON */ - ldr r1, =0x7FF0 /* select slowest timing */ - str r1, [r13, #0x18] /* set BANKCON5 */ - - ldr r1, =PLD_BASE - ldr r2, =SETUPDATA - ldrb r1, [r1, #MISC_REG] - sub r2, r2, r0 - tst r1, #FASTCPU /* FASTCPU available ? */ - addeq r2, r2, #SETUPENTRY_SIZE - - /* memory control configuration */ - /* r2 = pointer into timing table */ - /* r13 = pointer to MEM controller regs (starting with BWSCON) */ - add r3, r2, #CSDATA_OFFSET - add r4, r3, #CSDATAENTRY_SIZE -0: - ldr r1, [r3], #4 - str r1, [r13], #4 - cmp r3, r4 - bne 0b - - /* PLD access is now possible */ - /* r3 = SDRAMDATA */ - /* r13 = pointer to MEM controller regs */ - ldr r1, =PLD_BASE - mov r4, #SDRAMENTRY_SIZE - ldrb r1, [r1, #SDRAM_REG] - /* calculate start and end point */ - mla r3, r4, r1, r3 - add r4, r3, r4 -0: - ldr r1, [r3], #4 - str r1, [r13], #4 - cmp r3, r4 - bne 0b - - /* setup MPLL registers */ - ldr r1, =CLKBASE - ldr r4, =0xFFFFFF - add r3, r2, #4 /* r3 points to PLL values */ - str r4, [r1, #LOCKTIME] - ldmia r3, {r4,r5} - str r5, [r1, #UPLLCON] /* writing PLL register */ - /* !! order seems to be important !! */ - /* a little delay */ - ldr r3, =0x4000 -0: - subs r3, r3, #1 - bne 0b - - str r4, [r1, #MPLLCON] /* writing PLL register */ - /* !! order seems to be important !! */ - /* a little delay */ - ldr r3, =0x4000 -0: - subs r3, r3, #1 - bne 0b - - /* everything is fine now */ - mov pc, lr - - .ltorg -/* the literal pools origin */ - -#define MK_BWSCON(bws1, bws2, bws3, bws4, bws5, bws6, bws7) \ - ((bws1) << 4) + \ - ((bws2) << 8) + \ - ((bws3) << 12) + \ - ((bws4) << 16) + \ - ((bws5) << 20) + \ - ((bws6) << 24) + \ - ((bws7) << 28) - -#define MK_BANKCON(tacs, tcos, tacc, tcoh, tcah, tacp, pmc) \ - ((tacs) << 13) + \ - ((tcos) << 11) + \ - ((tacc) << 8) + \ - ((tcoh) << 6) + \ - ((tcah) << 4) + \ - ((tacp) << 2) + \ - (pmc) - -#define MK_BANKCON_SDRAM(trcd, scan) \ - ((0x03) << 15) + \ - ((trcd) << 2) + \ - (scan) - -#define MK_SDRAM_REFRESH(enable, trefmd, trp, tsrc, cnt) \ - ((enable) << 23) + \ - ((trefmd) << 22) + \ - ((trp) << 20) + \ - ((tsrc) << 18) + \ - (cnt) - -SETUPDATA: - .word 0x32410002 - /* PLL values (MDIV, PDIV, SDIV) for 250 MHz */ - .word (0x75 << 12) + (0x01 << 4) + (0x01 << 0) - /* PLL values for USB clock */ - .word (0x48 << 12) + (0x03 << 4) + (0x02 << 0) - - /* timing for 250 MHz*/ -0: - .equiv CSDATA_OFFSET, (. - SETUPDATA) - .word MK_BWSCON(DW16, \ - DW32, \ - DW32, \ - DW16 + WAIT + UBLB, \ - DW8 + UBLB, \ - DW32, \ - DW32) - - .word MK_BANKCON(B0_Tacs_250, \ - B0_Tcos_250, \ - B0_Tacc_250, \ - B0_Tcoh_250, \ - B0_Tcah_250, \ - B0_Tacp_250, \ - B0_PMC_250) - - .word MK_BANKCON(B1_Tacs_250, \ - B1_Tcos_250, \ - B1_Tacc_250, \ - B1_Tcoh_250, \ - B1_Tcah_250, \ - B1_Tacp_250, \ - B1_PMC_250) - - .word MK_BANKCON(B2_Tacs, \ - B2_Tcos, \ - B2_Tacc, \ - B2_Tcoh, \ - B2_Tcah, \ - B2_Tacp, \ - B2_PMC) - - .word MK_BANKCON(B3_Tacs, \ - B3_Tcos, \ - B3_Tacc, \ - B3_Tcoh, \ - B3_Tcah, \ - B3_Tacp, \ - B3_PMC) - - .word MK_BANKCON(B4_Tacs_250, \ - B4_Tcos_250, \ - B4_Tacc_250, \ - B4_Tcoh_250, \ - B4_Tcah_250, \ - B4_Tacp_250, \ - B4_PMC_250) - - .word MK_BANKCON(B5_Tacs_250, \ - B5_Tcos_250, \ - B5_Tacc_250, \ - B5_Tcoh_250, \ - B5_Tcah_250, \ - B5_Tacp_250, \ - B5_PMC_250) - - .equiv CSDATAENTRY_SIZE, (. - 0b) - /* 4Mx8x4 */ -0: - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - .equiv SDRAMENTRY_SIZE, (. - 0b) - - /* 8Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 2Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 4Mx8x2 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - .equiv SETUPENTRY_SIZE, (. - SETUPDATA) - - .word 0x32410000 - /* PLL values (MDIV, PDIV, SDIV) for 200 MHz (Fout = 202.8MHz) */ - .word (0xA1 << 12) + (0x03 << 4) + (0x01 << 0) - /* PLL values for USB clock */ - .word (0x48 << 12) + (0x03 << 4) + (0x02 << 0) - - /* timing for 200 MHz and default*/ - .word MK_BWSCON(DW16, \ - DW32, \ - DW32, \ - DW16 + WAIT + UBLB, \ - DW8 + UBLB, \ - DW32, \ - DW32) - - .word MK_BANKCON(B0_Tacs_200, \ - B0_Tcos_200, \ - B0_Tacc_200, \ - B0_Tcoh_200, \ - B0_Tcah_200, \ - B0_Tacp_200, \ - B0_PMC_200) - - .word MK_BANKCON(B1_Tacs_200, \ - B1_Tcos_200, \ - B1_Tacc_200, \ - B1_Tcoh_200, \ - B1_Tcah_200, \ - B1_Tacp_200, \ - B1_PMC_200) - - .word MK_BANKCON(B2_Tacs, \ - B2_Tcos, \ - B2_Tacc, \ - B2_Tcoh, \ - B2_Tcah, \ - B2_Tacp, \ - B2_PMC) - - .word MK_BANKCON(B3_Tacs, \ - B3_Tcos, \ - B3_Tacc, \ - B3_Tcoh, \ - B3_Tcah, \ - B3_Tacp, \ - B3_PMC) - - .word MK_BANKCON(B4_Tacs_200, \ - B4_Tcos_200, \ - B4_Tacc_200, \ - B4_Tcoh_200, \ - B4_Tcah_200, \ - B4_Tacp_200, \ - B4_PMC_200) - - .word MK_BANKCON(B5_Tacs_200, \ - B5_Tcos_200, \ - B5_Tacc_200, \ - B5_Tcoh_200, \ - B5_Tcah_200, \ - B5_Tacp_200, \ - B5_PMC_200) - - /* 4Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 8Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 2Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 4Mx8x2 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - .equiv SETUPDATA_SIZE, (. - SETUPDATA) diff --git a/board/mpl/vcma9/vcma9.c b/board/mpl/vcma9/vcma9.c deleted file mode 100644 index 43a3d47..0000000 --- a/board/mpl/vcma9/vcma9.c +++ /dev/null @@ -1,209 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002, 2010 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#include <i2c.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -#include "vcma9.h" -#include "../common/common_util.h" - -DECLARE_GLOBAL_DATA_PTR; - -/* - * Miscellaneous platform dependent initialisations - */ - -int board_early_init_f(void) -{ - struct s3c24x0_gpio * const gpio = s3c24x0_get_base_gpio(); - - /* set up the I/O ports */ - writel(0x007FFFFF, &gpio->gpacon); - writel(0x002AAAAA, &gpio->gpbcon); - writel(0x000002BF, &gpio->gpbup); - writel(0xAAAAAAAA, &gpio->gpccon); - writel(0x0000FFFF, &gpio->gpcup); - writel(0xAAAAAAAA, &gpio->gpdcon); - writel(0x0000FFFF, &gpio->gpdup); - writel(0xAAAAAAAA, &gpio->gpecon); - writel(0x000037F7, &gpio->gpeup); - writel(0x00000000, &gpio->gpfcon); - writel(0x00000000, &gpio->gpfup); - writel(0xFFEAFF5A, &gpio->gpgcon); - writel(0x0000F0DC, &gpio->gpgup); - writel(0x0028AAAA, &gpio->gphcon); - writel(0x00000656, &gpio->gphup); - - /* setup correct IRQ modes for NIC (rising edge mode) */ - writel((readl(&gpio->extint2) & ~(7<<8)) | (4<<8), &gpio->extint2); - - /* select USB port 2 to be host or device (setup as host for now) */ - writel(readl(&gpio->misccr) | 0x08, &gpio->misccr); - - return 0; -} - -int board_init(void) -{ - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0x30000100; - - icache_enable(); - dcache_enable(); - - return 0; -} - -/* - * Get some Board/PLD Info - */ - -static u8 get_pld_reg(enum vcma9_pld_regs reg) -{ - return readb(VCMA9_PLD_BASE + reg); -} - -static u8 get_pld_version(void) -{ - return (get_pld_reg(VCMA9_PLD_ID) >> 4) & 0x0F; -} - -static u8 get_pld_revision(void) -{ - return get_pld_reg(VCMA9_PLD_ID) & 0x0F; -} - -static uchar get_board_pcb(void) -{ - return ((get_pld_reg(VCMA9_PLD_BOARD) >> 4) & 0x03) + 'A'; -} - -static u8 get_nr_chips(void) -{ - switch ((get_pld_reg(VCMA9_PLD_SDRAM) >> 4) & 0x0F) { - case 0: return 4; - case 1: return 1; - case 2: return 2; - default: return 0; - } -} - -static ulong get_chip_size(void) -{ - switch (get_pld_reg(VCMA9_PLD_SDRAM) & 0x0F) { - case 0: return 16 * (1024*1024); - case 1: return 32 * (1024*1024); - case 2: return 8 * (1024*1024); - case 3: return 8 * (1024*1024); - default: return 0; - } -} - -static const char *get_chip_geom(void) -{ - switch (get_pld_reg(VCMA9_PLD_SDRAM) & 0x0F) { - case 0: return "4Mx8x4"; - case 1: return "8Mx8x4"; - case 2: return "2Mx8x4"; - case 3: return "4Mx8x2"; - default: return "unknown"; - } -} - -static void vcma9_show_info(char *board_name, char *serial) -{ - printf("Board: %s SN: %s PCB Rev: %c PLD(%d,%d)\n", - board_name, serial, - get_board_pcb(), get_pld_version(), get_pld_revision()); - printf("SDRAM: %d chips %s\n", get_nr_chips(), get_chip_geom()); -} - -int dram_init(void) -{ - /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_chip_size() * get_nr_chips(); - return 0; -} - -/* - * Check Board Identity: - */ - -int checkboard(void) -{ - char s[50]; - int i; - backup_t *b = (backup_t *) s; - - i = getenv_f("serial#", s, 32); - if ((i < 0) || strncmp (s, "VCMA9", 5)) { - get_backup_values (b); - if (strncmp (b->signature, "MPL\0", 4) != 0) { - puts ("### No HW ID - assuming VCMA9"); - } else { - b->serial_name[5] = 0; - vcma9_show_info(b->serial_name, &b->serial_name[6]); - } - } else { - s[5] = 0; - vcma9_show_info(s, &s[6]); - } - - return 0; -} - -int board_late_init(void) -{ - /* - * check if environment is healthy, otherwise restore values - * from shadow copy - */ - check_env(); - return 0; -} - -void vcma9_print_info(void) -{ - char *s = getenv("serial#"); - - if (!s) { - puts ("### No HW ID - assuming VCMA9"); - } else { - s[5] = 0; - vcma9_show_info(s, &s[6]); - } -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_CS8900 - rc = cs8900_initialize(0, CONFIG_CS8900_BASE); -#endif - return rc; -} -#endif - -/* - * Hardcoded flash setup: - * Flash 0 is a non-CFI AMD AM29F400BB flash. - */ -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - info->portwidth = FLASH_CFI_16BIT; - info->chipwidth = FLASH_CFI_BY16; - info->interface = FLASH_CFI_X16; - return 1; -} diff --git a/board/mpl/vcma9/vcma9.h b/board/mpl/vcma9/vcma9.h deleted file mode 100644 index c585c8e..0000000 --- a/board/mpl/vcma9/vcma9.h +++ /dev/null @@ -1,28 +0,0 @@ -/* - * (C) Copyright 2002, 2003 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - /**************************************************************************** - * Global routines used for VCMA9 - *****************************************************************************/ - -#include <asm/arch/s3c24x0_cpu.h> - -extern void vcma9_print_info(void); -extern int do_mplcommon(cmd_tbl_t *cmdtp, int flag, - int argc, char *const argv[]); - -/* VCMA9 PLD registers */ -enum vcma9_pld_regs { - VCMA9_PLD_ID, - VCMA9_PLD_NIC, - VCMA9_PLD_CAN, - VCMA9_PLD_MISC, - VCMA9_PLD_GPCD, - VCMA9_PLD_BOARD, - VCMA9_PLD_SDRAM -}; - -#define VCMA9_PLD_BASE (0x2C000100) diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig deleted file mode 100644 index da568a1..0000000 --- a/configs/VCMA9_defconfig +++ /dev/null @@ -1,16 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_VCMA9=y -CONFIG_IDENT_STRING="\n(c) 2003 - 2011 by MPL AG Switzerland, MEV-10080-001 unstable" -CONFIG_BOOTDELAY=5 -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="VCMA9 # " -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_UBI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h deleted file mode 100644 index e012417..0000000 --- a/include/configs/VCMA9.h +++ /dev/null @@ -1,207 +0,0 @@ -/* - * (C) Copyright 2002, 2003 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * Gary Jennejohn garyj@denx.de - * David Mueller d.mueller@elsoft.ch - * - * Configuation settings for the MPL VCMA9 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define MACH_TYPE_MPL_VCMA9 227 - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SYS_THUMB_BUILD - -#define CONFIG_S3C24X0 /* This is a SAMSUNG S3C24x0-type SoC */ -#define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ -#define CONFIG_VCMA9 /* on a MPL VCMA9 Board */ -#define CONFIG_MACH_TYPE MACH_TYPE_MPL_VCMA9 /* Machine type */ - -#define CONFIG_SYS_TEXT_BASE 0x0 - -#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH - -/* input clock of PLL (VCMA9 has 12MHz input clock) */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Command line configuration. - */ -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_DATE -#define CONFIG_CMD_BSP -#define CONFIG_CMD_NAND - -#define CONFIG_BOARD_LATE_INIT - -#define CONFIG_CMDLINE_EDITING - -/* - * I2C stuff: - * the MPL VCMA9 is equipped with an ATMEL 24C256 EEPROM at - * address 0x50 with 16bit addressing - */ -#define CONFIG_SYS_I2C - -/* we use the built-in I2C controller */ -#define CONFIG_SYS_I2C_S3C24X0 -#define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 /* I2C speed */ -#define CONFIG_SYS_I2C_S3C24X0_SLAVE 0x7F /* I2C slave addr */ - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -/* use EEPROM for environment vars */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -/* environment starts at offset 0 */ -#define CONFIG_ENV_OFFSET 0x000 -/* 2KB should be more than enough */ -#define CONFIG_ENV_SIZE 0x800 - -#undef CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW -/* 64 bytes page write mode on 24C256 */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* - * Hardware drivers - */ -#define CONFIG_CS8900 /* we have a CS8900 on-board */ -#define CONFIG_CS8900_BASE 0x20000300 -#define CONFIG_CS8900_BUS16 - -/* - * select serial console configuration - */ -#define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on VCMA9 */ - -/* USB support (currently only works with D-cache off) */ -#define CONFIG_USB_OHCI -#define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD -#define CONFIG_DOS_PARTITION - -/* Enable needed helper functions */ -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ - -/* RTC */ -#define CONFIG_RTC_S3C24X0 - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -#define CONFIG_BAUDRATE 9600 - -#define CONFIG_BOOT_RETRY_TIME -1 -#define CONFIG_RESET_TO_RETRY - -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 10.0.0.110 -#define CONFIG_SERVERIP 10.0.0.1 - -#if defined(CONFIG_CMD_KGDB) -/* speed to run kgdb serial port */ -#define CONFIG_KGDB_BAUDRATE 115200 -#endif - -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_CBSIZE 256 -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x31FFFFFF /* 32 MB in DRAM */ - -#define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_SYS_LOAD_ADDR 0x30800000 - -/* we configure PWM Timer 4 to 1ms 1000Hz */ - -/* support additional compression methods */ -#define CONFIG_BZIP2 -#define CONFIG_LZO -#define CONFIG_LZMA - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -/* FLASH and environment organization */ - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_LEGACY_512Kx16 -#define CONFIG_FLASH_SHOW_PROGRESS 45 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_MAX_FLASH_SECT (19) - -/* - * Size of malloc() pool - * BZIP2 / LZO / LZMA need a lot of RAM - */ -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE - -/* NAND configuration */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_S3C2410 -#define CONFIG_SYS_S3C2410_NAND_HWECC -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x4E000000 -#define CONFIG_S3C24XX_CUSTOM_NAND_TIMING -#define CONFIG_S3C24XX_TACLS 1 -#define CONFIG_S3C24XX_TWRPH0 5 -#define CONFIG_S3C24XX_TWRPH1 3 -#endif - -#define MULTI_PURPOSE_SOCKET_ADDR 0x08000000 - -/* File system */ -#define CONFIG_CMD_UBIFS -#define CONFIG_CMD_JFFS2 -#define CONFIG_YAFFS2 -#define CONFIG_RBTREE -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_MTD_PARTITIONS -#define CONFIG_CMD_MTDPARTS -#define CONFIG_LZO - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_BOARD_EARLY_INIT_F - -#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 337407f..b637599 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8253,7 +8253,6 @@ CONFIG_U_QE CONFIG_V38B CONFIG_VAL CONFIG_VAR_SIZE_SPL -CONFIG_VCMA9 CONFIG_VCO_HZ CONFIG_VCO_MULT CONFIG_VCT_NOR
This is not used by any boards. Drop it.
doc/driver-model/serial-howto.txt | 1 - drivers/serial/Makefile | 1 - drivers/serial/serial_s3c24x0.c | 208 -------------------------------------- scripts/config_whitelist.txt | 1 - 4 files changed, 211 deletions(-) delete mode 100644 drivers/serial/serial_s3c24x0.c
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index a655464..67d0983 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -5,7 +5,6 @@ Almost all of the serial drivers have been converted as at January 2016. These ones remain:
serial_bfin.c - serial_s3c24x0.c
The deadline for this work was the end of January 2016. If no one steps forward to convert these, at some point there may come a patch to remove them! diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 0c75718..9e7207a 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -30,7 +30,6 @@ obj-$(CONFIG_MESON_SERIAL) += serial_meson.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_SERIAL) += serial_rockchip.o endif -obj-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o obj-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o obj-$(CONFIG_SANDBOX_SERIAL) += sandbox.o obj-$(CONFIG_SCIF_CONSOLE) += serial_sh.o diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c deleted file mode 100644 index 0f0878a..0000000 --- a/drivers/serial/serial_s3c24x0.c +++ /dev/null @@ -1,208 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/compiler.h> -#include <asm/arch/s3c24x0_cpu.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_SERIAL1 -#define UART_NR S3C24X0_UART0 - -#elif defined(CONFIG_SERIAL2) -#define UART_NR S3C24X0_UART1 - -#elif defined(CONFIG_SERIAL3) -#define UART_NR S3C24X0_UART2 - -#else -#error "Bad: you didn't configure serial ..." -#endif - -#include <asm/io.h> -#include <serial.h> - -/* Multi serial device functions */ -#define DECLARE_S3C_SERIAL_FUNCTIONS(port) \ - int s3serial##port##_init(void) \ - { \ - return serial_init_dev(port); \ - } \ - void s3serial##port##_setbrg(void) \ - { \ - serial_setbrg_dev(port); \ - } \ - int s3serial##port##_getc(void) \ - { \ - return serial_getc_dev(port); \ - } \ - int s3serial##port##_tstc(void) \ - { \ - return serial_tstc_dev(port); \ - } \ - void s3serial##port##_putc(const char c) \ - { \ - serial_putc_dev(port, c); \ - } \ - void s3serial##port##_puts(const char *s) \ - { \ - serial_puts_dev(port, s); \ - } - -#define INIT_S3C_SERIAL_STRUCTURE(port, __name) { \ - .name = __name, \ - .start = s3serial##port##_init, \ - .stop = NULL, \ - .setbrg = s3serial##port##_setbrg, \ - .getc = s3serial##port##_getc, \ - .tstc = s3serial##port##_tstc, \ - .putc = s3serial##port##_putc, \ - .puts = s3serial##port##_puts, \ -} - -static void _serial_setbrg(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - unsigned int reg = 0; - int i; - - /* value is calculated so : (int)(PCLK/16./baudrate) -1 */ - reg = get_PCLK() / (16 * gd->baudrate) - 1; - - writel(reg, &uart->ubrdiv); - for (i = 0; i < 100; i++) - /* Delay */ ; -} - -static inline void serial_setbrg_dev(unsigned int dev_index) -{ - _serial_setbrg(dev_index); -} - -/* Initialise the serial port. The settings are always 8 data bits, no parity, - * 1 stop bit, no start bits. - */ -static int serial_init_dev(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - /* FIFO enable, Tx/Rx FIFO clear */ - writel(0x07, &uart->ufcon); - writel(0x0, &uart->umcon); - - /* Normal,No parity,1 stop,8 bit */ - writel(0x3, &uart->ulcon); - /* - * tx=level,rx=edge,disable timeout int.,enable rx error int., - * normal,interrupt or polling - */ - writel(0x245, &uart->ucon); - - _serial_setbrg(dev_index); - - return (0); -} - -/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -static int _serial_getc(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - while (!(readl(&uart->utrstat) & 0x1)) - /* wait for character to arrive */ ; - - return readb(&uart->urxh) & 0xff; -} - -static inline int serial_getc_dev(unsigned int dev_index) -{ - return _serial_getc(dev_index); -} - -/* - * Output a single byte to the serial port. - */ -static void _serial_putc(const char c, const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - /* If \n, also do \r */ - if (c == '\n') - serial_putc('\r'); - - while (!(readl(&uart->utrstat) & 0x2)) - /* wait for room in the tx FIFO */ ; - - writeb(c, &uart->utxh); -} - -static inline void serial_putc_dev(unsigned int dev_index, const char c) -{ - _serial_putc(c, dev_index); -} - -/* - * Test whether a character is in the RX buffer - */ -static int _serial_tstc(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - return readl(&uart->utrstat) & 0x1; -} - -static inline int serial_tstc_dev(unsigned int dev_index) -{ - return _serial_tstc(dev_index); -} - -static void _serial_puts(const char *s, const int dev_index) -{ - while (*s) { - _serial_putc(*s++, dev_index); - } -} - -static inline void serial_puts_dev(int dev_index, const char *s) -{ - _serial_puts(s, dev_index); -} - -DECLARE_S3C_SERIAL_FUNCTIONS(0); -struct serial_device s3c24xx_serial0_device = -INIT_S3C_SERIAL_STRUCTURE(0, "s3ser0"); -DECLARE_S3C_SERIAL_FUNCTIONS(1); -struct serial_device s3c24xx_serial1_device = -INIT_S3C_SERIAL_STRUCTURE(1, "s3ser1"); -DECLARE_S3C_SERIAL_FUNCTIONS(2); -struct serial_device s3c24xx_serial2_device = -INIT_S3C_SERIAL_STRUCTURE(2, "s3ser2"); - -__weak struct serial_device *default_serial_console(void) -{ -#if defined(CONFIG_SERIAL1) - return &s3c24xx_serial0_device; -#elif defined(CONFIG_SERIAL2) - return &s3c24xx_serial1_device; -#elif defined(CONFIG_SERIAL3) - return &s3c24xx_serial2_device; -#else -#error "CONFIG_SERIAL? missing." -#endif -} - -void s3c24xx_serial_initialize(void) -{ - serial_register(&s3c24xx_serial0_device); - serial_register(&s3c24xx_serial1_device); - serial_register(&s3c24xx_serial2_device); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b637599..5719ede 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3890,7 +3890,6 @@ CONFIG_S3C2410_NAND_BBT CONFIG_S3C2410_NAND_HWECC CONFIG_S3C2440 CONFIG_S3C24X0 -CONFIG_S3C24X0_SERIAL CONFIG_S3C24XX_CUSTOM_NAND_TIMING CONFIG_S3C24XX_TACLS CONFIG_S3C24XX_TWRPH0
Hi Simon
On Thu, 2016-10-20 at 13:06 -0600, Simon Glass wrote:
Only three serial drivers remain to be converted. This series drops two of those, since the boards appear to be unmaintained.
With this, only blackfin remains.
The blackfin driver probably needs to be converted as there is recent activity with these boards. I am copying the maintainer so that this work can be completed.
Could you please hold off with dropping the PXA serial driver and accompanying PXA270 support. I will have a look at it ASAP. We do actually continue to sell the Colibri PXA270 (as we are the Colibri PXA320) and I have been maintaining it lately with sending patches as recently as last week! It would be rather sad to see it drop like the PXA3xx support did a couple years back when we were too busy with other issues.
Cheers
Marcel
Simon Glass (8): arm: Remove colibri_pxa270 board arm: Remove h2200 board arm: Remove zipitz2 board arm: Drop pxa serial driver serial: Update docs to indicate mcfuart supports DM_SERIAL arm: Remove smdk2410 board arm: Remove VCMA9 board serial: Drop the s3c24x0 serial driver
arch/arm/Kconfig | 25 -- board/h2200/Kconfig | 9 - board/h2200/MAINTAINERS | 6 - board/h2200/Makefile | 14 - board/h2200/h2200-header.S | 15 - board/h2200/h2200.c | 73 ---- board/mpl/common/common_util.c | 23 -- board/mpl/vcma9/Kconfig | 15 - board/mpl/vcma9/MAINTAINERS | 6 - board/mpl/vcma9/Makefile | 11 - board/mpl/vcma9/cmd_vcma9.c | 119 ------ board/mpl/vcma9/lowlevel_init.S | 500 ----------------
board/mpl/vcma9/vcma9.c | 209 ----------- board/mpl/vcma9/vcma9.h | 28 -- board/samsung/smdk2410/Kconfig | 15 - board/samsung/smdk2410/MAINTAINERS | 6 - board/samsung/smdk2410/Makefile | 9 - board/samsung/smdk2410/lowlevel_init.S | 146 -------- board/samsung/smdk2410/smdk2410.c | 139 ------- board/toradex/colibri_pxa270/Kconfig | 12 - board/toradex/colibri_pxa270/MAINTAINERS | 6 - board/toradex/colibri_pxa270/Makefile | 9 - board/toradex/colibri_pxa270/colibri_pxa270.c | 107 ------ board/zipitz2/Kconfig | 9 - board/zipitz2/MAINTAINERS | 6 - board/zipitz2/Makefile | 10 - board/zipitz2/zipitz2.c | 217 ----------- configs/VCMA9_defconfig | 16 - configs/colibri_pxa270_defconfig | 19 - configs/h2200_defconfig | 25 -- configs/smdk2410_defconfig | 16 - configs/zipitz2_defconfig | 19 - doc/driver-model/serial-howto.txt | 3 - drivers/serial/Makefile | 2 - drivers/serial/serial_pxa.c | 299 --------------- drivers/serial/serial_s3c24x0.c | 208 ----------- include/configs/VCMA9.h | 207 ----------- include/configs/colibri_pxa270.h | 223 ------------ include/configs/h2200.h | 155 -------- include/configs/smdk2410.h | 181 ---------- include/configs/zipitz2.h | 213 ----------- scripts/config_whitelist.txt | 6 - 42 files changed, 3336 deletions(-) delete mode 100644 board/h2200/Kconfig delete mode 100644 board/h2200/MAINTAINERS delete mode 100644 board/h2200/Makefile delete mode 100644 board/h2200/h2200-header.S delete mode 100644 board/h2200/h2200.c delete mode 100644 board/mpl/vcma9/Kconfig delete mode 100644 board/mpl/vcma9/MAINTAINERS delete mode 100644 board/mpl/vcma9/Makefile delete mode 100644 board/mpl/vcma9/cmd_vcma9.c delete mode 100644 board/mpl/vcma9/lowlevel_init.S delete mode 100644 board/mpl/vcma9/vcma9.c delete mode 100644 board/mpl/vcma9/vcma9.h delete mode 100644 board/samsung/smdk2410/Kconfig delete mode 100644 board/samsung/smdk2410/MAINTAINERS delete mode 100644 board/samsung/smdk2410/Makefile delete mode 100644 board/samsung/smdk2410/lowlevel_init.S delete mode 100644 board/samsung/smdk2410/smdk2410.c delete mode 100644 board/toradex/colibri_pxa270/Kconfig delete mode 100644 board/toradex/colibri_pxa270/MAINTAINERS delete mode 100644 board/toradex/colibri_pxa270/Makefile delete mode 100644 board/toradex/colibri_pxa270/colibri_pxa270.c delete mode 100644 board/zipitz2/Kconfig delete mode 100644 board/zipitz2/MAINTAINERS delete mode 100644 board/zipitz2/Makefile delete mode 100644 board/zipitz2/zipitz2.c delete mode 100644 configs/VCMA9_defconfig delete mode 100644 configs/colibri_pxa270_defconfig delete mode 100644 configs/h2200_defconfig delete mode 100644 configs/smdk2410_defconfig delete mode 100644 configs/zipitz2_defconfig delete mode 100644 drivers/serial/serial_pxa.c delete mode 100644 drivers/serial/serial_s3c24x0.c delete mode 100644 include/configs/VCMA9.h delete mode 100644 include/configs/colibri_pxa270.h delete mode 100644 include/configs/h2200.h delete mode 100644 include/configs/smdk2410.h delete mode 100644 include/configs/zipitz2.h
On 10/21/2016 08:52 AM, Marcel Ziswiler wrote:
Hi Simon
Cheers
Marcel
Whoa, would be nice to keep me on Cc regarding PXA stuff. Thanks for CCing me, Marcel. And I would like to NAK these first four patches.
Hi Simon
OK we can hold off - when do you expect to do this?
Also re PXA3xx, please feel free to bring it back. If I recall it was only removed long after the deadline for conversion.
Cheers
Marcel
-- Best regards, Marek Vasut
Hi Simon
Thanks Simon, I'm looking into it right now.
Yeah, I guess the only constant is change (;-p).
Cheers
Marcel
Hi Marcel,
On 28 October 2016 at 04:44, Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Simon
Great. Also are you going to bring back the other PXA boards? It should be really easy - I very much doubt that there will be any odd bugs with generic board.
Well I wish it could happen for free :-) This was signaled for a long long time. I think we missed an email to maintainers for the generic board stuff, but I thought that serial drivers were well communicated. I hope that maintainers can take on a little work every now and then.
On Tue, 2016-11-01 at 19:55 -0600, Simon Glass wrote:
Hi Marcel,
... OK we can hold off - when do you expect to do this?
I once considered looking at Colibri PXA3xx again but since did not really have much time. I am also missing any other PXA3xx hardware to do any kind of cross testing.
Yes, no pun intended.
Yes, agreed. I also remember Marek having enquired about me doing this once but I did not take the bait back then.
Agreed but I am not really the PXA270 maintainer nor was the one of PXA3xx.
Cheers
Marcel
Marcel Ziswiler
