RE: [PATCH v2] net: tsec: add option to set device max-speed via dts
Current tsec adapter sets adapter gigabit capabilities by default, and in reality this must not always be the case. It is possible that tsec adapter is used for 100Mbit connection, and in this case setting 1000Mbit capabilities can lead to some side effects such longer autoneg process.
In our ls102x designs this problem leads to long autoneg times (> 4 sec) in case board rgmii link is 100Mbs capble only. Limiting the rgmii link capabilities provides smother and faster link establishment.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com --- Changes for v2: - keep the variable sort order in a decreasing order of line length - fix comment typo --- drivers/net/tsec.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index c68e4b7..ee820aa 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -828,6 +828,7 @@ int tsec_probe(struct udevice *dev) const char *phy_mode; ofnode parent, child; fdt_addr_t reg; + u32 max_speed; int ret;
data = (struct tsec_data *)dev_get_driver_data(dev); @@ -893,8 +894,12 @@ int tsec_probe(struct udevice *dev) } priv->interface = pdata->phy_interface;
+ /* Check for speed limit, default is 1000Mbps */ + max_speed = dev_read_u32_default(dev, "max-speed", 1000); + /* Initialize flags */ - priv->flags = TSEC_GIGABIT; + if (max_speed == 1000) + priv->flags = TSEC_GIGABIT; if (priv->interface == PHY_INTERFACE_MODE_SGMII) priv->flags |= TSEC_SGMII;
On Fri, Jun 4, 2021 at 8:05 PM Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com wrote:
typo: capable?
typo: smoother?
link establishment.
Changes for v2:
- fix comment typo
u32 max_speed; int ret; data = (struct tsec_data *)dev_get_driver_data(dev);
Could you please send the new version as a separate thread, instead of replying the old version thread?
Regards, Bin
Bin Meng
