[U-Boot] [PATCH v5 0/5] net: ethernet: ti: Introduce am654 gigabit eth switch subsystem driver
Add new driver for the TI AM65x SoC Gigabit Ethernet Switch subsystem (CPSW NUSS). It has two ports and provides Ethernet packet communication for the device and can be configured as an Ethernet switch. CPSW NUSS features: the Reduced Gigabit Media Independent Interface (RGMII), Reduced Media Independent Interface (RMII), and the Management Data Input/Output (MDIO) interface for physical layer device (PHY) management. The TI AM65x SoC has integrated two-port Gigabit Ethernet Switch subsystem into device MCU domain named MCU_CPSW0. One Ethernet port (port 1) with selectable RGMII and RMII interfaces and an internal Communications Port Programming Interface (CPPI) port (Host port 0).
Host Port 0 CPPI Packet Streaming Interface interface supports 8 TX channels and on RX channels operating by TI am654 NAVSS Unified DMA Peripheral Root Complex (UDMA-P) controller.
Tested for tftp and booting to kernel on am654-evm.
Changes in v5: * Rebased to latest which meant adapting to pinmux macro change.
Changes in v4:
* Patch1 caused dra7 config build warnings corrected them.
Grygorii Strashko (4): net: ethernet: ti: Introduce am654 gigabit eth switch subsystem driver arm64: dts: ti: k3-am65: add mcu cpsw node arm64: dts: k3-am654-base-board: add mcu cpsw nuss pinmux and phy defs configs: am65x_evm_a53: enable networking
Keerthy (1): driver: net: ti: cpsw-mdio: use phys_addr_t for mdio_base addr
arch/arm/dts/k3-am65.dtsi | 2 + arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 170 ++++ configs/am65x_evm_a53_defconfig | 7 + drivers/net/ti/Kconfig | 8 + drivers/net/ti/Makefile | 1 + drivers/net/ti/am65-cpsw-nuss.c | 794 +++++++++++++++++++ drivers/net/ti/cpsw_mdio.c | 4 +- drivers/net/ti/cpsw_mdio.h | 2 +- 8 files changed, 985 insertions(+), 3 deletions(-) create mode 100644 drivers/net/ti/am65-cpsw-nuss.c
Use phys_addr_t for mdio_base address to avoid build warnings on arm64 and dra7. Cast it to uintprt_t before assigning to regs.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- drivers/net/ti/cpsw_mdio.c | 4 ++-- drivers/net/ti/cpsw_mdio.h | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ti/cpsw_mdio.c b/drivers/net/ti/cpsw_mdio.c index 70f547e6d7..6e8f652011 100644 --- a/drivers/net/ti/cpsw_mdio.c +++ b/drivers/net/ti/cpsw_mdio.c @@ -125,7 +125,7 @@ u32 cpsw_mdio_get_alive(struct mii_dev *bus) return val & GENMASK(15, 0); }
-struct mii_dev *cpsw_mdio_init(const char *name, u32 mdio_base, +struct mii_dev *cpsw_mdio_init(const char *name, phys_addr_t mdio_base, u32 bus_freq, int fck_freq) { struct cpsw_mdio *cpsw_mdio; @@ -144,7 +144,7 @@ struct mii_dev *cpsw_mdio_init(const char *name, u32 mdio_base, return NULL; }
- cpsw_mdio->regs = (struct cpsw_mdio_regs *)mdio_base; + cpsw_mdio->regs = (struct cpsw_mdio_regs *)(uintptr_t)mdio_base;
if (!bus_freq || !fck_freq) cpsw_mdio->div = CPSW_MDIO_DIV_DEF; diff --git a/drivers/net/ti/cpsw_mdio.h b/drivers/net/ti/cpsw_mdio.h index 4a76d4e5c5..dbf4a2dcac 100644 --- a/drivers/net/ti/cpsw_mdio.h +++ b/drivers/net/ti/cpsw_mdio.h @@ -10,7 +10,7 @@
struct cpsw_mdio;
-struct mii_dev *cpsw_mdio_init(const char *name, u32 mdio_base, +struct mii_dev *cpsw_mdio_init(const char *name, phys_addr_t mdio_base, u32 bus_freq, int fck_freq); void cpsw_mdio_free(struct mii_dev *bus); u32 cpsw_mdio_get_alive(struct mii_dev *bus);
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/net/ti/Kconfig | 8 + drivers/net/ti/Makefile | 1 + drivers/net/ti/am65-cpsw-nuss.c | 794 ++++++++++++++++++++++++++++++++ 3 files changed, 803 insertions(+) create mode 100644 drivers/net/ti/am65-cpsw-nuss.c
diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index 82bc9f5d03..ecf642de10 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -18,3 +18,11 @@ config DRIVER_TI_KEYSTONE_NET bool "TI Keystone 2 Ethernet" help This driver supports the TI Keystone 2 Ethernet subsystem + +config TI_AM65_CPSW_NUSS + bool "TI K3 AM65x MCU CPSW Nuss Ethernet controller driver" + depends on ARCH_K3 + select PHYLIB + help + This driver supports TI K3 MCU CPSW Nuss Ethernet controller + in Texas Instruments K3 AM65x SoCs. diff --git a/drivers/net/ti/Makefile b/drivers/net/ti/Makefile index ee3e4eb5d6..8d3808bb4b 100644 --- a/drivers/net/ti/Makefile +++ b/drivers/net/ti/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o cpsw_mdio.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o cpsw_mdio.o +obj-$(CONFIG_TI_AM65_CPSW_NUSS) += am65-cpsw-nuss.o cpsw_mdio.o diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c new file mode 100644 index 0000000000..658cc34033 --- /dev/null +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -0,0 +1,794 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments K3 AM65 Ethernet Switch SubSystem Driver + * + * Copyright (C) 2019, Texas Instruments, Incorporated + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/processor.h> +#include <clk.h> +#include <dm.h> +#include <dm/lists.h> +#include <dma-uclass.h> +#include <dm/of_access.h> +#include <miiphy.h> +#include <net.h> +#include <phy.h> +#include <power-domain.h> +#include <linux/soc/ti/ti-udma.h> + +#include "cpsw_mdio.h" + +#define AM65_CPSW_CPSWNU_MAX_PORTS 2 + +#define AM65_CPSW_SS_BASE 0x0 +#define AM65_CPSW_SGMII_BASE 0x100 +#define AM65_CPSW_MDIO_BASE 0xf00 +#define AM65_CPSW_XGMII_BASE 0x2100 +#define AM65_CPSW_CPSW_NU_BASE 0x20000 +#define AM65_CPSW_CPSW_NU_ALE_BASE 0x1e000 + +#define AM65_CPSW_CPSW_NU_PORTS_OFFSET 0x1000 +#define AM65_CPSW_CPSW_NU_PORT_MACSL_OFFSET 0x330 + +#define AM65_CPSW_MDIO_BUS_FREQ_DEF 1000000 + +#define AM65_CPSW_CTL_REG 0x4 +#define AM65_CPSW_STAT_PORT_EN_REG 0x14 +#define AM65_CPSW_PTYPE_REG 0x18 + +#define AM65_CPSW_CTL_REG_P0_ENABLE BIT(2) +#define AM65_CPSW_CTL_REG_P0_TX_CRC_REMOVE BIT(13) +#define AM65_CPSW_CTL_REG_P0_RX_PAD BIT(14) + +#define AM65_CPSW_P0_FLOW_ID_REG 0x8 +#define AM65_CPSW_PN_RX_MAXLEN_REG 0x24 +#define AM65_CPSW_PN_REG_SA_L 0x308 +#define AM65_CPSW_PN_REG_SA_H 0x30c + +#define AM65_CPSW_ALE_CTL_REG 0x8 +#define AM65_CPSW_ALE_CTL_REG_ENABLE BIT(31) +#define AM65_CPSW_ALE_CTL_REG_RESET_TBL BIT(30) +#define AM65_CPSW_ALE_CTL_REG_BYPASS BIT(4) +#define AM65_CPSW_ALE_PN_CTL_REG(x) (0x40 + (x) * 4) +#define AM65_CPSW_ALE_PN_CTL_REG_MODE_FORWARD 0x3 +#define AM65_CPSW_ALE_PN_CTL_REG_MAC_ONLY BIT(11) + +#define AM65_CPSW_MACSL_CTL_REG 0x0 +#define AM65_CPSW_MACSL_CTL_REG_IFCTL_A BIT(15) +#define AM65_CPSW_MACSL_CTL_REG_GIG BIT(7) +#define AM65_CPSW_MACSL_CTL_REG_GMII_EN BIT(5) +#define AM65_CPSW_MACSL_CTL_REG_LOOPBACK BIT(1) +#define AM65_CPSW_MACSL_CTL_REG_FULL_DUPLEX BIT(0) +#define AM65_CPSW_MACSL_RESET_REG 0x8 +#define AM65_CPSW_MACSL_RESET_REG_RESET BIT(0) +#define AM65_CPSW_MACSL_STATUS_REG 0x4 +#define AM65_CPSW_MACSL_RESET_REG_PN_IDLE BIT(31) +#define AM65_CPSW_MACSL_RESET_REG_PN_E_IDLE BIT(30) +#define AM65_CPSW_MACSL_RESET_REG_PN_P_IDLE BIT(29) +#define AM65_CPSW_MACSL_RESET_REG_PN_TX_IDLE BIT(28) +#define AM65_CPSW_MACSL_RESET_REG_IDLE_MASK \ + (AM65_CPSW_MACSL_RESET_REG_PN_IDLE | \ + AM65_CPSW_MACSL_RESET_REG_PN_E_IDLE | \ + AM65_CPSW_MACSL_RESET_REG_PN_P_IDLE | \ + AM65_CPSW_MACSL_RESET_REG_PN_TX_IDLE) + +#define AM65_CPSW_CPPI_PKT_TYPE 0x7 + +struct am65_cpsw_port { + fdt_addr_t port_base; + fdt_addr_t macsl_base; + bool disabled; + u32 mac_control; +}; + +struct am65_cpsw_common { + struct udevice *dev; + fdt_addr_t ss_base; + fdt_addr_t cpsw_base; + fdt_addr_t mdio_base; + fdt_addr_t ale_base; + fdt_addr_t gmii_sel; + fdt_addr_t mac_efuse; + + struct clk fclk; + struct power_domain pwrdmn; + + u32 port_num; + struct am65_cpsw_port ports[AM65_CPSW_CPSWNU_MAX_PORTS]; + u32 rflow_id_base; + + struct mii_dev *bus; + u32 bus_freq; + + struct dma dma_tx; + struct dma dma_rx; + u32 rx_next; + u32 rx_pend; + bool started; +}; + +struct am65_cpsw_priv { + struct udevice *dev; + struct am65_cpsw_common *cpsw_common; + u32 port_id; + + struct phy_device *phydev; + bool has_phy; + ofnode phy_node; + u32 phy_addr; +}; + +#ifdef PKTSIZE_ALIGN +#define UDMA_RX_BUF_SIZE PKTSIZE_ALIGN +#else +#define UDMA_RX_BUF_SIZE ALIGN(1522, ARCH_DMA_MINALIGN) +#endif + +#ifdef PKTBUFSRX +#define UDMA_RX_DESC_NUM PKTBUFSRX +#else +#define UDMA_RX_DESC_NUM 4 +#endif + +#define mac_hi(mac) (((mac)[0] << 0) | ((mac)[1] << 8) | \ + ((mac)[2] << 16) | ((mac)[3] << 24)) +#define mac_lo(mac) (((mac)[4] << 0) | ((mac)[5] << 8)) + +static void am65_cpsw_set_sl_mac(struct am65_cpsw_port *slave, + unsigned char *addr) +{ + writel(mac_hi(addr), + slave->port_base + AM65_CPSW_PN_REG_SA_H); + writel(mac_lo(addr), + slave->port_base + AM65_CPSW_PN_REG_SA_L); +} + +int am65_cpsw_macsl_reset(struct am65_cpsw_port *slave) +{ + u32 i = 100; + + /* Set the soft reset bit */ + writel(AM65_CPSW_MACSL_RESET_REG_RESET, + slave->macsl_base + AM65_CPSW_MACSL_RESET_REG); + + while ((readl(slave->macsl_base + AM65_CPSW_MACSL_RESET_REG) & + AM65_CPSW_MACSL_RESET_REG_RESET) && i--) + cpu_relax(); + + /* Timeout on the reset */ + return i; +} + +static int am65_cpsw_macsl_wait_for_idle(struct am65_cpsw_port *slave) +{ + u32 i = 100; + + while ((readl(slave->macsl_base + AM65_CPSW_MACSL_STATUS_REG) & + AM65_CPSW_MACSL_RESET_REG_IDLE_MASK) && i--) + cpu_relax(); + + return i; +} + +static int am65_cpsw_update_link(struct am65_cpsw_priv *priv) +{ + struct am65_cpsw_common *common = priv->cpsw_common; + struct am65_cpsw_port *port = &common->ports[priv->port_id]; + struct phy_device *phy = priv->phydev; + u32 mac_control = 0; + + if (phy->link) { /* link up */ + mac_control = /*AM65_CPSW_MACSL_CTL_REG_LOOPBACK |*/ + AM65_CPSW_MACSL_CTL_REG_GMII_EN; + if (phy->speed == 1000) + mac_control |= AM65_CPSW_MACSL_CTL_REG_GIG; + if (phy->duplex == DUPLEX_FULL) + mac_control |= AM65_CPSW_MACSL_CTL_REG_FULL_DUPLEX; + if (phy->speed == 100) + mac_control |= AM65_CPSW_MACSL_CTL_REG_IFCTL_A; + } + + if (mac_control == port->mac_control) + goto out; + + if (mac_control) { + printf("link up on port %d, speed %d, %s duplex\n", + priv->port_id, phy->speed, + (phy->duplex == DUPLEX_FULL) ? "full" : "half"); + } else { + printf("link down on port %d\n", priv->port_id); + } + + writel(mac_control, port->macsl_base + AM65_CPSW_MACSL_CTL_REG); + port->mac_control = mac_control; + +out: + return phy->link; +} + +#define AM65_GMII_SEL_MODE_MII 0 +#define AM65_GMII_SEL_MODE_RMII 1 +#define AM65_GMII_SEL_MODE_RGMII 2 + +#define AM65_GMII_SEL_RGMII_IDMODE BIT(4) + +static void am65_cpsw_gmii_sel_k3(struct am65_cpsw_priv *priv, + phy_interface_t phy_mode, int slave) +{ + struct am65_cpsw_common *common = priv->cpsw_common; + u32 reg; + u32 mode = 0; + bool rgmii_id = false; + + reg = readl(common->gmii_sel); + + dev_dbg(common->dev, "old gmii_sel: %08x\n", reg); + + switch (phy_mode) { + case PHY_INTERFACE_MODE_RMII: + mode = AM65_GMII_SEL_MODE_RMII; + break; + + case PHY_INTERFACE_MODE_RGMII: + mode = AM65_GMII_SEL_MODE_RGMII; + break; + + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + mode = AM65_GMII_SEL_MODE_RGMII; + rgmii_id = true; + break; + + default: + dev_warn(common->dev, + "Unsupported PHY mode: %u. Defaulting to MII.\n", + phy_mode); + /* fallthrough */ + case PHY_INTERFACE_MODE_MII: + mode = AM65_GMII_SEL_MODE_MII; + break; + }; + + if (rgmii_id) + mode |= AM65_GMII_SEL_RGMII_IDMODE; + + reg = mode; + dev_dbg(common->dev, "gmii_sel PHY mode: %u, new gmii_sel: %08x\n", + phy_mode, reg); + writel(reg, common->gmii_sel); + + reg = readl(common->gmii_sel); + if (reg != mode) + dev_err(common->dev, + "gmii_sel PHY mode NOT SET!: requested: %08x, gmii_sel: %08x\n", + mode, reg); +} + +static int am65_cpsw_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + struct am65_cpsw_port *port = &common->ports[priv->port_id]; + struct am65_cpsw_port *port0 = &common->ports[0]; + int ret, i; + + ret = power_domain_on(&common->pwrdmn); + if (ret) { + dev_err(dev, "power_domain_on() failed %d\n", ret); + goto out; + } + + ret = clk_enable(&common->fclk); + if (ret) { + dev_err(dev, "clk enabled failed %d\n", ret); + goto err_off_pwrdm; + } + + common->rx_next = 0; + common->rx_pend = 0; + ret = dma_get_by_name(common->dev, "tx0", &common->dma_tx); + if (ret) { + dev_err(dev, "TX dma get failed %d\n", ret); + goto err_off_clk; + } + ret = dma_get_by_name(common->dev, "rx", &common->dma_rx); + if (ret) { + dev_err(dev, "RX dma get failed %d\n", ret); + goto err_free_tx; + } + + for (i = 0; i < UDMA_RX_DESC_NUM; i++) { + ret = dma_prepare_rcv_buf(&common->dma_rx, + net_rx_packets[i], + UDMA_RX_BUF_SIZE); + if (ret) { + dev_err(dev, "RX dma add buf failed %d\n", ret); + goto err_free_tx; + } + } + + ret = dma_enable(&common->dma_tx); + if (ret) { + dev_err(dev, "TX dma_enable failed %d\n", ret); + goto err_free_rx; + } + ret = dma_enable(&common->dma_rx); + if (ret) { + dev_err(dev, "RX dma_enable failed %d\n", ret); + goto err_dis_tx; + } + + /* Control register */ + writel(AM65_CPSW_CTL_REG_P0_ENABLE | + AM65_CPSW_CTL_REG_P0_TX_CRC_REMOVE | + AM65_CPSW_CTL_REG_P0_RX_PAD, + common->cpsw_base + AM65_CPSW_CTL_REG); + + /* disable priority elevation */ + writel(0, common->cpsw_base + AM65_CPSW_PTYPE_REG); + + /* enable statistics */ + writel(BIT(0) | BIT(priv->port_id), + common->cpsw_base + AM65_CPSW_STAT_PORT_EN_REG); + + /* Port 0 length register */ + writel(PKTSIZE_ALIGN, port0->port_base + AM65_CPSW_PN_RX_MAXLEN_REG); + + /* set base flow_id */ + writel(common->rflow_id_base, + port0->port_base + AM65_CPSW_P0_FLOW_ID_REG); + + /* Reset and enable the ALE */ + writel(AM65_CPSW_ALE_CTL_REG_ENABLE | AM65_CPSW_ALE_CTL_REG_RESET_TBL | + AM65_CPSW_ALE_CTL_REG_BYPASS, + common->ale_base + AM65_CPSW_ALE_CTL_REG); + + /* port 0 put into forward mode */ + writel(AM65_CPSW_ALE_PN_CTL_REG_MODE_FORWARD, + common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(0)); + + /* PORT x configuration */ + + /* Port x Max length register */ + writel(PKTSIZE_ALIGN, port->port_base + AM65_CPSW_PN_RX_MAXLEN_REG); + + /* Port x set mac */ + am65_cpsw_set_sl_mac(port, pdata->enetaddr); + + /* Port x ALE: mac_only, Forwarding */ + writel(AM65_CPSW_ALE_PN_CTL_REG_MAC_ONLY | + AM65_CPSW_ALE_PN_CTL_REG_MODE_FORWARD, + common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(priv->port_id)); + + port->mac_control = 0; + if (!am65_cpsw_macsl_reset(port)) { + dev_err(dev, "mac_sl reset failed\n"); + ret = -EFAULT; + goto err_dis_rx; + } + + ret = phy_startup(priv->phydev); + if (ret) { + dev_err(dev, "phy_startup failed\n"); + goto err_dis_rx; + } + + ret = am65_cpsw_update_link(priv); + if (!ret) { + ret = -ENODEV; + goto err_phy_shutdown; + } + + common->started = true; + + return 0; + +err_phy_shutdown: + phy_shutdown(priv->phydev); +err_dis_rx: + /* disable ports */ + writel(0, common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(priv->port_id)); + writel(0, common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(0)); + if (!am65_cpsw_macsl_wait_for_idle(port)) + dev_err(dev, "mac_sl idle timeout\n"); + writel(0, port->macsl_base + AM65_CPSW_MACSL_CTL_REG); + writel(0, common->ale_base + AM65_CPSW_ALE_CTL_REG); + writel(0, common->cpsw_base + AM65_CPSW_CTL_REG); + + dma_disable(&common->dma_rx); +err_dis_tx: + dma_disable(&common->dma_tx); +err_free_rx: + dma_free(&common->dma_rx); +err_free_tx: + dma_free(&common->dma_tx); +err_off_clk: + clk_disable(&common->fclk); +err_off_pwrdm: + power_domain_off(&common->pwrdmn); +out: + dev_err(dev, "%s end error\n", __func__); + + return ret; +} + +static int am65_cpsw_send(struct udevice *dev, void *packet, int length) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + struct ti_udma_drv_packet_data packet_data; + int ret; + + packet_data.pkt_type = AM65_CPSW_CPPI_PKT_TYPE; + packet_data.dest_tag = priv->port_id; + ret = dma_send(&common->dma_tx, packet, length, &packet_data); + if (ret) { + dev_err(dev, "TX dma_send failed %d\n", ret); + return ret; + } + + return 0; +} + +static int am65_cpsw_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + + /* try to receive a new packet */ + return dma_receive(&common->dma_rx, (void **)packetp, NULL); +} + +static int am65_cpsw_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + int ret; + + if (length > 0) { + u32 pkt = common->rx_next % UDMA_RX_DESC_NUM; + + ret = dma_prepare_rcv_buf(&common->dma_rx, + net_rx_packets[pkt], + UDMA_RX_BUF_SIZE); + if (ret) + dev_err(dev, "RX dma free_pkt failed %d\n", ret); + common->rx_next++; + } + + return 0; +} + +static void am65_cpsw_stop(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + struct am65_cpsw_port *port = &common->ports[priv->port_id]; + + if (!common->started) + return; + + phy_shutdown(priv->phydev); + + writel(0, common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(priv->port_id)); + writel(0, common->ale_base + AM65_CPSW_ALE_PN_CTL_REG(0)); + if (!am65_cpsw_macsl_wait_for_idle(port)) + dev_err(dev, "mac_sl idle timeout\n"); + writel(0, port->macsl_base + AM65_CPSW_MACSL_CTL_REG); + writel(0, common->ale_base + AM65_CPSW_ALE_CTL_REG); + writel(0, common->cpsw_base + AM65_CPSW_CTL_REG); + + dma_disable(&common->dma_tx); + dma_free(&common->dma_tx); + + dma_disable(&common->dma_rx); + dma_free(&common->dma_rx); + + common->started = false; +} + +static int am65_cpsw_read_rom_hwaddr(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *common = priv->cpsw_common; + struct eth_pdata *pdata = dev_get_platdata(dev); + u32 mac_hi, mac_lo; + + if (common->mac_efuse == FDT_ADDR_T_NONE) + return -1; + + mac_lo = readl(common->mac_efuse); + mac_hi = readl(common->mac_efuse + 4); + pdata->enetaddr[0] = (mac_hi >> 8) & 0xff; + pdata->enetaddr[1] = mac_hi & 0xff; + pdata->enetaddr[2] = (mac_lo >> 24) & 0xff; + pdata->enetaddr[3] = (mac_lo >> 16) & 0xff; + pdata->enetaddr[4] = (mac_lo >> 8) & 0xff; + pdata->enetaddr[5] = mac_lo & 0xff; + + return 0; +} + +static const struct eth_ops am65_cpsw_ops = { + .start = am65_cpsw_start, + .send = am65_cpsw_send, + .recv = am65_cpsw_recv, + .free_pkt = am65_cpsw_free_pkt, + .stop = am65_cpsw_stop, + .read_rom_hwaddr = am65_cpsw_read_rom_hwaddr, +}; + +static int am65_cpsw_mdio_init(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *cpsw_common = priv->cpsw_common; + + if (!priv->has_phy || cpsw_common->bus) + return 0; + + cpsw_common->bus = cpsw_mdio_init(dev->name, + cpsw_common->mdio_base, + cpsw_common->bus_freq, + clk_get_rate(&cpsw_common->fclk)); + if (!cpsw_common->bus) + return -EFAULT; + + return 0; +} + +static int am65_cpsw_phy_init(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *cpsw_common = priv->cpsw_common; + struct eth_pdata *pdata = dev_get_platdata(dev); + struct phy_device *phydev; + u32 supported = PHY_GBIT_FEATURES; + int ret; + + phydev = phy_connect(cpsw_common->bus, + priv->phy_addr, + priv->dev, + pdata->phy_interface); + + if (!phydev) { + dev_err(dev, "phy_connect() failed\n"); + return -ENODEV; + } + + phydev->supported &= supported; + if (pdata->max_speed) { + ret = phy_set_supported(phydev, pdata->max_speed); + if (ret) + return ret; + } + phydev->advertising = phydev->supported; + +#ifdef CONFIG_DM_ETH + if (ofnode_valid(priv->phy_node)) + phydev->node = priv->phy_node; +#endif + + priv->phydev = phydev; + ret = phy_config(phydev); + if (ret < 0) + pr_err("phy_config() failed: %d", ret); + + return ret; +} + +static int am65_cpsw_ofdata_parse_phy(struct udevice *dev, ofnode port_np) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args out_args; + const char *phy_mode; + int ret = 0; + + phy_mode = ofnode_read_string(port_np, "phy-mode"); + if (phy_mode) { + pdata->phy_interface = + phy_get_interface_by_name(phy_mode); + if (pdata->phy_interface == -1) { + dev_err(dev, "Invalid PHY mode '%s', port %u\n", + phy_mode, priv->port_id); + ret = -EINVAL; + goto out; + } + } + + ofnode_read_u32(port_np, "max-speed", (u32 *)&pdata->max_speed); + if (pdata->max_speed) + dev_err(dev, "Port %u speed froced to %uMbit\n", + priv->port_id, pdata->max_speed); + + priv->has_phy = true; + ret = ofnode_parse_phandle_with_args(port_np, "phy-handle", + NULL, 0, 0, &out_args); + if (ret) { + dev_err(dev, "can't parse phy-handle port %u (%d)\n", + priv->port_id, ret); + priv->has_phy = false; + ret = 0; + } + + priv->phy_node = out_args.node; + if (priv->has_phy) { + ret = ofnode_read_u32(priv->phy_node, "reg", &priv->phy_addr); + if (ret) { + dev_err(dev, "failed to get phy_addr port %u (%d)\n", + priv->port_id, ret); + goto out; + } + } + +out: + return ret; +} + +static int am65_cpsw_probe_cpsw(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct am65_cpsw_common *cpsw_common; + ofnode ports_np, node; + int ret, i; + + priv->dev = dev; + + cpsw_common = calloc(1, sizeof(*priv->cpsw_common)); + if (!cpsw_common) + return -ENOMEM; + priv->cpsw_common = cpsw_common; + + cpsw_common->dev = dev; + cpsw_common->ss_base = dev_read_addr(dev); + if (cpsw_common->ss_base == FDT_ADDR_T_NONE) + return -EINVAL; + cpsw_common->mac_efuse = devfdt_get_addr_name(dev, "mac_efuse"); + /* no err check - optional */ + + ret = power_domain_get_by_index(dev, &cpsw_common->pwrdmn, 0); + if (ret) { + dev_err(dev, "failed to get pwrdmn: %d\n", ret); + return ret; + } + + ret = clk_get_by_name(dev, "fck", &cpsw_common->fclk); + if (ret) { + power_domain_free(&cpsw_common->pwrdmn); + dev_err(dev, "failed to get clock %d\n", ret); + return ret; + } + + cpsw_common->cpsw_base = cpsw_common->ss_base + AM65_CPSW_CPSW_NU_BASE; + cpsw_common->ale_base = cpsw_common->cpsw_base + + AM65_CPSW_CPSW_NU_ALE_BASE; + cpsw_common->mdio_base = cpsw_common->ss_base + AM65_CPSW_MDIO_BASE; + + cpsw_common->rflow_id_base = 0; + cpsw_common->rflow_id_base = + dev_read_u32_default(dev, "ti,rx-flow-id-base", + cpsw_common->rflow_id_base); + + ports_np = dev_read_subnode(dev, "ports"); + if (!ofnode_valid(ports_np)) { + ret = -ENOENT; + goto out; + } + + ofnode_for_each_subnode(node, ports_np) { + const char *node_name; + u32 port_id; + bool disabled; + + node_name = ofnode_get_name(node); + + disabled = !ofnode_is_available(node); + + ret = ofnode_read_u32(node, "reg", &port_id); + if (ret) { + dev_err(dev, "%s: failed to get port_id (%d)\n", + node_name, ret); + goto out; + } + + if (port_id >= AM65_CPSW_CPSWNU_MAX_PORTS) { + dev_err(dev, "%s: invalid port_id (%d)\n", + node_name, port_id); + ret = -EINVAL; + goto out; + } + cpsw_common->port_num++; + + if (!port_id) + continue; + + priv->port_id = port_id; + cpsw_common->ports[port_id].disabled = disabled; + if (disabled) + continue; + + ret = am65_cpsw_ofdata_parse_phy(dev, node); + if (ret) + goto out; + } + + for (i = 0; i < AM65_CPSW_CPSWNU_MAX_PORTS; i++) { + struct am65_cpsw_port *port = &cpsw_common->ports[i]; + + port->port_base = cpsw_common->cpsw_base + + AM65_CPSW_CPSW_NU_PORTS_OFFSET + + (i * AM65_CPSW_CPSW_NU_PORTS_OFFSET); + port->macsl_base = port->port_base + + AM65_CPSW_CPSW_NU_PORT_MACSL_OFFSET; + } + + node = dev_read_subnode(dev, "cpsw-phy-sel"); + if (!ofnode_valid(node)) { + dev_err(dev, "can't find cpsw-phy-se\n"); + ret = -ENOENT; + goto out; + } + + cpsw_common->gmii_sel = ofnode_get_addr(node); + if (cpsw_common->gmii_sel == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get gmii_sel base\n"); + goto out; + } + + node = dev_read_subnode(dev, "mdio"); + if (!ofnode_valid(node)) { + dev_err(dev, "can't find mdio\n"); + ret = -ENOENT; + goto out; + } + + cpsw_common->bus_freq = + dev_read_u32_default(dev, "bus_freq", + AM65_CPSW_MDIO_BUS_FREQ_DEF); + + am65_cpsw_gmii_sel_k3(priv, pdata->phy_interface, priv->port_id); + + ret = am65_cpsw_mdio_init(dev); + if (ret) + goto out; + + ret = am65_cpsw_phy_init(dev); + if (ret) + goto out; + + dev_info(dev, "K3 CPSW: nuss_ver: 0x%08X cpsw_ver: 0x%08X ale_ver: 0x%08X Ports:%u rflow_id_base:%u mdio_freq:%u\n", + readl(cpsw_common->ss_base), + readl(cpsw_common->cpsw_base), + readl(cpsw_common->ale_base), + cpsw_common->port_num, + cpsw_common->rflow_id_base, + cpsw_common->bus_freq); + +out: + clk_free(&cpsw_common->fclk); + power_domain_free(&cpsw_common->pwrdmn); + return ret; +} + +static const struct udevice_id am65_cpsw_nuss_ids[] = { + { .compatible = "ti,am654-cpsw-nuss" }, + { } +}; + +U_BOOT_DRIVER(am65_cpsw_nuss_slave) = { + .name = "am65_cpsw_nuss_slave", + .id = UCLASS_ETH, + .of_match = am65_cpsw_nuss_ids, + .probe = am65_cpsw_probe_cpsw, + .ops = &am65_cpsw_ops, + .priv_auto_alloc_size = sizeof(struct am65_cpsw_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
depends on ARCH_K3
select PHYLIB
help
I'm surprised that write_hwaddr is not included.
return -EFAULT;
int ret;
priv->phy_addr,
priv->dev,
if (!phydev) {
return -ENODEV;
if (ret)
return ret;
Why is this needed? I would expect this to already be assumed.
if (ret < 0)
return ret;
int ret = 0;
if (phy_mode) {
ret = -EINVAL;
goto out;
if (ret) {
ret = 0;
if (ret) {
goto out;
+out:
return ret;
int ret, i;
priv->dev = dev;
if (!cpsw_common)
return -ENOMEM;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
return ret;
ret = -ENOENT;
goto out;
u32 port_id;
bool disabled;
if (ret) {
node_name, ret);
goto out;
ret = -EINVAL;
goto out;
if (!port_id)
continue;
if (disabled)
continue;
if (ret)
goto out;
cpsw-phy-se -> cpsw-phy-sel
ret = -ENOENT;
goto out;
goto out;
ret = -ENOENT;
goto out;
if (ret)
goto out;
if (ret)
goto out;
+out:
return ret;
.id = UCLASS_ETH,
2.17.1
depends on ARCH_K3
select PHYLIB
help
This driver is pretty much based on cpsw.c under drivers/net/ti. I believe there is no mandate to write the hw mac address to specific IP register.
return -EFAULT;
int ret;
priv->phy_addr,
priv->dev,
if (!phydev) {
return -ENODEV;
if (ret)
return ret;
Yes. This is redundant.
if (ret < 0)
return ret;
int ret = 0;
if (phy_mode) {
ret = -EINVAL;
goto out;
if (ret) {
ret = 0;
if (ret) {
goto out;
+out:
return ret;
int ret, i;
priv->dev = dev;
if (!cpsw_common)
return -ENOMEM;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
return ret;
ret = -ENOENT;
goto out;
u32 port_id;
bool disabled;
if (ret) {
node_name, ret);
goto out;
ret = -EINVAL;
goto out;
if (!port_id)
continue;
if (disabled)
continue;
if (ret)
goto out;
okay. Will correct this.
ret = -ENOENT;
goto out;
goto out;
ret = -ENOENT;
goto out;
if (ret)
goto out;
if (ret)
goto out;
+out:
return ret;
.id = UCLASS_ETH,
2.17.1
Add mcu cpsw and its components along with scm_conf node to have ethernet functional.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/dts/k3-am65.dtsi | 2 + arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 111 +++++++++++++++++++ 2 files changed, 113 insertions(+)
diff --git a/arch/arm/dts/k3-am65.dtsi b/arch/arm/dts/k3-am65.dtsi index 3d4bf369d0..9d1ed49753 100644 --- a/arch/arm/dts/k3-am65.dtsi +++ b/arch/arm/dts/k3-am65.dtsi @@ -64,6 +64,7 @@ /* MCUSS Range */ <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, <0x00 0x40200000 0x00 0x40200000 0x00 0x00900100>, + <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, @@ -75,6 +76,7 @@ #size-cells = <2>; ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/ <0x00 0x40200000 0x00 0x40200000 0x00 0x00900100>, /* First peripheral window */ + <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */ <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP */ <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */ <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */ diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index f5c8253831..18b611990f 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -13,6 +13,7 @@
aliases { serial2 = &main_uart0; + ethernet0 = &cpsw_port1; }; };
@@ -110,6 +111,116 @@ dma-coherent; }; }; + + mcu_conf: scm_conf@40f00000 { + compatible = "syscon"; + reg = <0x0 0x40f00000 0x0 0x20000>; + }; + + mcu_cpsw: cpsw_nuss@046000000 { + compatible = "ti,am654-cpsw-nuss"; + #address-cells = <2>; + #size-cells = <2>; + reg = <0x0 0x46000000 0x0 0x200000>; + reg-names = "cpsw_nuss"; + ranges; + dma-coherent; + clocks = <&k3_clks 5 10>; + clock-names = "fck"; + power-domains = <&k3_pds 5>; + ti,psil-base = <0x7000>; + + dmas = <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 1 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 2 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 3 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 4 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 5 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 6 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 7 UDMA_DIR_TX>, + <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_RX>; + dma-names = "tx0", "tx1", "tx2", "tx3", + "tx4", "tx5", "tx6", "tx7", + "rx"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + host: host@0 { + reg = <0>; + ti,label = "host"; + }; + + cpsw_port1: port@1 { + reg = <1>; + ti,mac-only; + ti,label = "port1"; + ti,syscon-efuse = <&mcu_conf 0x200>; + }; + }; + + davinci_mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + bus_freq = <1000000>; + }; + + ti,psil-config0 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config1 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config2 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config3 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config4 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config5 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config6 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config7 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + }; };
&cbass_wakeup {
Add mcu cpsw nuss pinmux and phy defs required by cpsw.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 59 ++++++++++++++++++++ 1 file changed, 59 insertions(+)
diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index 18b611990f..844a5cd96a 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -5,6 +5,7 @@
#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/dma/k3-udma.h> +#include <dt-bindings/net/ti-dp83867.h>
/ { chosen { @@ -300,6 +301,32 @@ u-boot,dm-spl; };
+&wkup_pmx0 { + mcu_cpsw_pins_default: mcu_cpsw_pins_default { + pinctrl-single,pins = < + AM65X_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* (N4) MCU_RGMII1_TX_CTL */ + AM65X_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* (N5) MCU_RGMII1_RX_CTL */ + AM65X_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* (M2) MCU_RGMII1_TD3 */ + AM65X_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* (M3) MCU_RGMII1_TD2 */ + AM65X_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* (M4) MCU_RGMII1_TD1 */ + AM65X_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* (M5) MCU_RGMII1_TD0 */ + AM65X_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* (L2) MCU_RGMII1_RD3 */ + AM65X_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* (L5) MCU_RGMII1_RD2 */ + AM65X_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* (M6) MCU_RGMII1_RD1 */ + AM65X_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* (L6) MCU_RGMII1_RD0 */ + AM65X_WKUP_IOPAD(0x0070, PIN_INPUT, 0) /* (N1) MCU_RGMII1_TXC */ + AM65X_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* (M1) MCU_RGMII1_RXC */ + >; + }; + + mcu_mdio_pins_default: mcu_mdio1_pins_default { + pinctrl-single,pins = < + AM65X_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ + AM65X_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ + >; + }; +}; + &main_uart0 { u-boot,dm-spl; pinctrl-names = "default"; @@ -323,3 +350,35 @@ pinctrl-0 = <&main_mmc1_pins_default>; sdhci-caps-mask = <0x7 0x0>; }; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; +}; + +&davinci_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + /* TODO: phy reset: TCA9555RTWR(i2c:0x21)[p04].GPIO_MCU_RGMII_RSTN */ + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-id"; + phy-handle = <&phy0>; +}; + +&mcu_cpsw { + reg = <0x0 0x46000000 0x0 0x200000>, + <0x0 0x40f00200 0x0 0x2>; + reg-names = "cpsw_nuss", "mac_efuse"; + + cpsw-phy-sel@40f04040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg= <0x0 0x40f04040 0x0 0x4>; + reg-names = "gmii-sel"; + }; +};
Enable TI K3 AM65x CPSW NUSS driver.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- configs/am65x_evm_a53_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 41cf0100fa..5d33b127b1 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y @@ -58,6 +59,11 @@ CONFIG_K3_SEC_PROXY=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_K3_ARASAN=y +CONFIG_PHY_TI=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y @@ -74,3 +80,4 @@ CONFIG_SOC_TI=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y +CONFIG_HEXDUMP=y
Question below, but...
Why is this needed?
-- 2.17.1
Why is this needed?
Ah this was needed when some debug prints were enabled in prior versions. I will remove this in v6.
Thanks for the review.
Best Regards, Keerthy
-- 2.17.1
Tom,
Please pull this series. If there are no further comments.
- Keerthy
Changes in v5:
- Rebased to latest which meant adapting to pinmux macro change.
Changes in v4:
- Patch1 caused dra7 config build warnings corrected them.
Tom,
This is next on my list to review.
Thanks, -Joe
- Keerthy
Changes in v5:
Changes in v4:
Joe Hershberger
Keerthy
