[PATCH] board: dragonboard410c: Load U-Boot directly without LK
At the moment the U-Boot port for the DragonBoard 410c is designed to be loaded as an Android boot image after Qualcomm's Little Kernel (LK) bootloader. This is simple to set up but LK is redundant in this case, since everything done by LK can be also done directly by U-Boot.
Dropping LK entirely has at least the following advantages: - Easier installation/board code (no need for Android boot images) - (Slightly) faster boot - Boot directly in 64-bit without a round trip to 32-bit for LK
So far this was not possible yet because of unsolved problems:
1. Signing tool: The firmware expects a "signed" ELF image with extra (Qualcomm-specific) ELF headers, usually used for secure boot. The DragonBoard 410c does not have secure boot by default but the extra ELF headers are still required.
2. PSCI bug: There seems to be a bug in the PSCI implementation (part of the TrustZone/tz firmware) that causes all other CPU cores to be started in 32-bit mode if LK is missing in the boot chain. This causes Linux to hang early during boot.
There is a solution for both problems now:
1. qtestsign (https://github.com/msm8916-mainline/qtestsign) can be used as a "signing" tool for U-Boot and other firmware.
2. A workaround for the "PSCI bug" is to execute the TZ syscall when entering U-Boot. That way PSCI is made aware of the 64-bit switch and starts all other CPU cores in 64-bit mode as well.
Simplify the dragonboard410c board by removing all the extra code that is only used to build an Android boot image that can be loaded by LK. This allows dropping the custom linker script, special image magic, as well as most of the special build/installation instructions.
CONFIG_REMAKE_ELF is used to build a new ELF image that has both U-Boot and the appended DTB combined. The resulting u-boot.elf can then be passed to the "signing" tool (e.g. qtestsign).
The PSCI workaround is placed in the "boot0" hook that is enabled with CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK. The extra check for EL1 allows compatibility with custom firmware that enters U-Boot in EL2 or EL3, e.g. qhypstub (https://github.com/msm8916-mainline/qhypstub).
As a first step these changes apply only to DragonBoard410c. Similar changes could likely also work for the DragonBoard 820c.
Note that removing LK wouldn't be possible that easily without a lot of work already done three years ago by Ramon Fried. A lot of missing initialization, pinctrl etc was already added back then even though it was not strictly needed yet.
Cc: Ramon Fried rfried.dev@gmail.com Signed-off-by: Stephan Gerhold stephan@gerhold.net ---
Related RFC with even more detailed explanations: https://lore.kernel.org/u-boot/YN2F1c926HFF+JA2@gerhold.net/
In my tests both U-Boot and Linux are fully functional with this patch. However, I would appreciate further testing, since my testing does likely not represent a typical usage scenario for the DragonBoard 410c.
When testing, please pick the following pending patch additionally: https://lore.kernel.org/u-boot/20210705121847.48432-1-stephan@gerhold.net/ on top of u-boot/master.
--- arch/arm/mach-snapdragon/Kconfig | 1 + arch/arm/mach-snapdragon/include/mach/boot0.h | 54 ++++++++ board/qualcomm/dragonboard410c/MAINTAINERS | 1 + board/qualcomm/dragonboard410c/Makefile | 2 - .../dragonboard410c/dragonboard410c.c | 13 -- board/qualcomm/dragonboard410c/head.S | 33 ----- .../qualcomm/dragonboard410c/lowlevel_init.S | 27 ---- board/qualcomm/dragonboard410c/readme.txt | 73 +---------- board/qualcomm/dragonboard410c/u-boot.lds | 118 ------------------ configs/dragonboard410c_defconfig | 2 +- doc/board/index.rst | 1 + doc/board/qualcomm/dragonboard410c.rst | 45 +++++++ doc/board/qualcomm/index.rst | 9 ++ include/configs/dragonboard410c.h | 3 + 14 files changed, 120 insertions(+), 262 deletions(-) create mode 100644 arch/arm/mach-snapdragon/include/mach/boot0.h delete mode 100644 board/qualcomm/dragonboard410c/head.S delete mode 100644 board/qualcomm/dragonboard410c/lowlevel_init.S delete mode 100644 board/qualcomm/dragonboard410c/u-boot.lds create mode 100644 doc/board/qualcomm/dragonboard410c.rst create mode 100644 doc/board/qualcomm/index.rst
diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index e562d693c6..0ec74fa5d3 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -15,6 +15,7 @@ choice config TARGET_DRAGONBOARD410C bool "96Boards Dragonboard 410C" select BOARD_LATE_INIT + select ENABLE_ARM_SOC_BOOT0_HOOK help Support for 96Boards Dragonboard 410C. This board complies with 96Board Open Platform Specifications. Features: diff --git a/arch/arm/mach-snapdragon/include/mach/boot0.h b/arch/arm/mach-snapdragon/include/mach/boot0.h new file mode 100644 index 0000000000..953cccad79 --- /dev/null +++ b/arch/arm/mach-snapdragon/include/mach/boot0.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Workaround for "PSCI bug" on DragonBoard 410c + * Copyright (C) 2021 Stephan Gerhold stephan@gerhold.net + * + * Syscall parameters taken from Qualcomm's LK fork (scm.h): + * Copyright (c) 2011-2015, The Linux Foundation. All rights reserved. + * + * The PSCI implementation in the TrustZone/tz firmware on DragonBoard 410c has + * a bug that starts all other CPU cores in 32-bit mode unless the TZ syscall + * that switches from 32-bit to 64-bit mode is executed at least once. + * + * Normally this happens inside Qualcomm's LK bootloader which runs in 32-bit + * mode and uses the TZ syscall to boot a kernel in 64-bit mode. However, if + * U-Boot is installed to the "aboot" partition (replacing LK) the switch to + * 64-bit mode never happens since U-Boot is already running in 64-bit mode. + * + * A workaround for this "PSCI bug" is to execute the TZ syscall when entering + * U-Boot. That way PSCI is made aware of the 64-bit switch and starts all other + * CPU cores in 64-bit mode as well. + */ +#include <linux/arm-smccc.h> + +#define ARM_SMCCC_SIP32_FAST_CALL \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, ARM_SMCCC_SMC_32, ARM_SMCCC_OWNER_SIP, 0) + + /* + * U-Boot might be started in EL2 or EL3 with custom firmware. + * In that case, we assume that the workaround is not necessary or is + * handled already by the alternative firmware. Using the syscall in EL2 + * would demote U-Boot to EL1; in EL3 it would probably just crash. + */ + mrs x0, CurrentEL + cmp x0, #(1 << 2) /* EL1 */ + bne reset + + /* Prepare TZ syscall parameters */ + mov x0, #ARM_SMCCC_SIP32_FAST_CALL + movk x0, #0x10f /* SCM_SVC_MILESTONE_CMD_ID */ + mov x1, #0x12 /* MAKE_SCM_ARGS(0x2, SMC_PARAM_TYPE_BUFFER_READ) */ + adr x2, el1_system_param + mov x3, el1_system_param_end - el1_system_param + + /* Switch PSCI to 64-bit mode. Resets CPU and returns at el1_elr */ + smc #0 + + /* Something went wrong, perhaps PSCI is already in 64-bit mode? */ + b reset + + .align 3 +el1_system_param: + .quad 0, 0, 0, 0, 0, 0, 0, 0, 0 /* el1_x0-x8 */ + .quad reset /* el1_elr */ +el1_system_param_end: diff --git a/board/qualcomm/dragonboard410c/MAINTAINERS b/board/qualcomm/dragonboard410c/MAINTAINERS index 83448f5c13..e78f5b2d64 100644 --- a/board/qualcomm/dragonboard410c/MAINTAINERS +++ b/board/qualcomm/dragonboard410c/MAINTAINERS @@ -4,3 +4,4 @@ S: Maintained F: board/qualcomm/dragonboard410c/ F: include/configs/dragonboard410c.h F: configs/dragonboard410c_defconfig +F: doc/board/qualcomm/dragonboard410c.rst diff --git a/board/qualcomm/dragonboard410c/Makefile b/board/qualcomm/dragonboard410c/Makefile index 9b452041f4..1b99c8b0ef 100644 --- a/board/qualcomm/dragonboard410c/Makefile +++ b/board/qualcomm/dragonboard410c/Makefile @@ -3,5 +3,3 @@ # (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com
obj-y := dragonboard410c.o -obj-y += lowlevel_init.o -extra-y += head.o diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 0d282de958..3b71881cac 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -22,19 +22,6 @@
DECLARE_GLOBAL_DATA_PTR;
-/* pointer to the device tree ammended by the firmware */ -extern void *fw_dtb; - -void *board_fdt_blob_setup(void) -{ - if (fdt_magic(fw_dtb) != FDT_MAGIC) { - printf("Firmware provided invalid dtb!\n"); - return NULL; - } - - return fw_dtb; -} - int dram_init(void) { gd->ram_size = PHYS_SDRAM_1_SIZE; diff --git a/board/qualcomm/dragonboard410c/head.S b/board/qualcomm/dragonboard410c/head.S deleted file mode 100644 index 33e9d305f9..0000000000 --- a/board/qualcomm/dragonboard410c/head.S +++ /dev/null @@ -1,33 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * ARM64 header for proper chain-loading with Little Kernel. - * - * Little Kernel shipped with Dragonboard410C boots standard Linux images for - * ARM64. This file adds header that is required to boot U-Boot properly. - * - * For details see: - * https://www.kernel.org/doc/Documentation/arm64/booting.txt - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - */ - -#include <config.h> - -.global _arm64_header -_arm64_header: - b _start - .word 0 - /* Image load offset from start of RAM, little-endian */ - .quad CONFIG_SYS_TEXT_BASE-PHYS_SDRAM_1 - /* Effective size of kernel image, little-endian */ - .quad 0 /* 0x60000 - ignored */ - /* Informative flags, little-endian */ - .quad 0 - .quad 0 /* reserved */ - .quad 0 /* reserved */ - .quad 0 /* reserved */ - .byte 0x41 /* Magic number, "ARM\x64" */ - .byte 0x52 - .byte 0x4d - .byte 0x64 - .word 0 /* reserved */ diff --git a/board/qualcomm/dragonboard410c/lowlevel_init.S b/board/qualcomm/dragonboard410c/lowlevel_init.S deleted file mode 100644 index 762fed5617..0000000000 --- a/board/qualcomm/dragonboard410c/lowlevel_init.S +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2016 - * Cédric Schieli cschieli@gmail.com - */ - -#include <config.h> - -.align 8 -.global fw_dtb -fw_dtb: - .dword 0x0 - -/* - * Routine: save_boot_params (called after reset from start.S) - * Description: save ATAG/FDT address provided by the firmware at boot time - */ - -.global save_boot_params -save_boot_params: - - /* The firmware provided ATAG/FDT address can be found in r2/x0 */ - adr x8, fw_dtb - str x0, [x8] - - /* Returns */ - b save_boot_params_ret diff --git a/board/qualcomm/dragonboard410c/readme.txt b/board/qualcomm/dragonboard410c/readme.txt index a90d0f52e7..dfdb299fb7 100644 --- a/board/qualcomm/dragonboard410c/readme.txt +++ b/board/qualcomm/dragonboard410c/readme.txt @@ -1,69 +1,6 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com +Documentation for DragonBoard 410c is now located at: + doc/board/qualcomm/dragonboard410c.rst
-Build & Run instructions: - -1) Install mkbootimg and dtbTool from - git://codeaurora.org/quic/kernel/skales (15ece94f09 worked for me) -2) Setup CROSS_COMPILE to aarch64 compiler -3) make dragonboard410c_config -4) make -5) generate fake, empty ramdisk (can have 0 bytes) -$ touch rd - -6) Generate qualcomm device tree table with dtbTool [1] -$ dtbTool -o dt.img arch/arm/dts - -7) Generate Android boot image with mkbootimg [2]: -$ mkbootimg --kernel=u-boot-dtb.bin --output=u-boot.img --dt=dt.img \ - --pagesize 2048 --base 0x80000000 --ramdisk=rd --cmdline="" - -8) Enter fastboot (reboot board with vol- button pressed) - -9) Boot it: -$ fastboot boot u-boot.img -or flash as kernel: -$ fastboot flash boot u-boot.img -$ fastboot reboot - - -What is working: -- UART -- GPIO (SoC) -- SD -- eMMC -- Reset -- USB in EHCI mode (usb starts does switch device->host, usb stop does the opposite) -- PMIC GPIOS (but not in generic subsystem) -- PMIC "special" buttons (power, vol-) - -What is not working / known bugs: -- SDHCI is slow (~2.5MiB/s for SD and eMMC) - -[1] To boot any kernel image, Little Kernel requires valid device tree for the -platform it runs on. dtbTool creates device tree table that Little Kernel scans. -Later on proper device tree is passed to next boot stage. -Full device tree is not required to boot u-boot. Enough would be: -/dts-v1/; - -/ { - model = "Qualcomm Technologies, Inc. Dragonboard 410c"; - compatible = "qcom,dragonboard", "qcom,apq8016-sbc"; - qcom,msm-id = <0xce 0x0 0xf8 0x0 0xf9 0x0 0xfa 0x0 0xf7 0x0>; - qcom,board-id = <0x10018 0x0>; - #address-cells = <0x2>; - #size-cells = <0x2>; - chosen { }; - aliases { }; - - memory { - device_type = "memory"; - reg = <0 0x80000000 0 0x3da00000>; - }; -}; - -but for simplicity (and because size of image is not that critical) we use -existing Qualcomm device trees. - -[2] Note that ramdisk is required, even if it is unused. +Note that the installation method has changed: U-Boot is now installed into the +"aboot" partition (replacing Little Kernel/LK). It is no longer packaged into +an Android boot image and loaded through Qualcomm's LK bootloader. diff --git a/board/qualcomm/dragonboard410c/u-boot.lds b/board/qualcomm/dragonboard410c/u-boot.lds deleted file mode 100644 index fc1bba8cf0..0000000000 --- a/board/qualcomm/dragonboard410c/u-boot.lds +++ /dev/null @@ -1,118 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Override linker script for fastboot-readable images - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - * - * Based on arch/arm/cpu/armv8/u-boot.lds (Just add header) - */ - -OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") -OUTPUT_ARCH(aarch64) -ENTRY(_arm64_header) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(8); - .text : - { - *(.__image_copy_start) - board/qualcomm/dragonboard410c/head.o (.text*) - CPUDIR/start.o (.text*) - } - - /* This needs to come before *(.text*) */ - .efi_runtime : { - __efi_runtime_start = .; - *(.text.efi_runtime*) - *(.rodata.efi_runtime*) - *(.data.efi_runtime*) - __efi_runtime_stop = .; - } - - .text_rest : - { - *(.text*) - } - - . = ALIGN(8); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(8); - .data : { - *(.data*) - } - - . = ALIGN(8); - - . = .; - - . = ALIGN(8); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - . = ALIGN(8); - - .efi_runtime : { - __efi_runtime_start = .; - *(efi_runtime_text) - *(efi_runtime_data) - __efi_runtime_stop = .; - } - - .efi_runtime_rel : { - __efi_runtime_rel_start = .; - *(.rel*.efi_runtime) - *(.rel*.efi_runtime.*) - __efi_runtime_rel_stop = .; - } - - . = ALIGN(8); - - .image_copy_end : - { - *(.__image_copy_end) - } - - . = ALIGN(8); - - .rel_dyn_start : - { - *(.__rel_dyn_start) - } - - .rela.dyn : { - *(.rela*) - } - - .rel_dyn_end : - { - *(.__rel_dyn_end) - } - - _end = .; - - . = ALIGN(8); - - .bss_start : { - KEEP(*(.__bss_start)); - } - - .bss : { - *(.bss*) - . = ALIGN(8); - } - - .bss_end : { - KEEP(*(.__bss_end)); - } - - /DISCARD/ : { *(.dynsym) } - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 7b7b32c0a2..dc9d0d893c 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_SNAPDRAGON=y -CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_SYS_TEXT_BASE=0x8f600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 diff --git a/doc/board/index.rst b/doc/board/index.rst index 196b597609..a6b395238a 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -20,6 +20,7 @@ Board-specific doc kontron/index microchip/index openpiton/index + qualcomm/index rockchip/index sifive/index sipeed/index diff --git a/doc/board/qualcomm/dragonboard410c.rst b/doc/board/qualcomm/dragonboard410c.rst new file mode 100644 index 0000000000..d0de9dbcbc --- /dev/null +++ b/doc/board/qualcomm/dragonboard410c.rst @@ -0,0 +1,45 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Stephan Gerhold stephan@gerhold.net + +DragonBoard 410c +================ + +The DragonBoard 410c is a development board based on the Qualcomm APQ8016E SoC. +More information can be found on the `96Boards product page`_. + +U-Boot can be used as a replacement for Qualcomm's original Android bootloader +(a fork of Little Kernel/LK). Like LK, it is installed directly into the ``aboot`` +partition. Note that the U-Boot port used to be loaded as an Android boot image +through LK. This is no longer the case, now U-Boot can replace LK entirely. + +.. _96Boards product page: https://www.96boards.org/product/dragonboard410c/ + +Installation +------------ +First, setup ``CROSS_COMPILE`` for aarch64. Then, build U-Boot for ``dragonboard410c``:: + + $ export CROSS_COMPILE=<aarch64 toolchain prefix> + $ make dragonboard410c_defconfig + $ make + +This will build ``u-boot.elf`` in the configured output directory. + +Although the DragonBoard 410c does not have secure boot set up by default, +the firmware still expects firmware ELF images to be "signed". The signature +does not provide any security in this case, but it provides the firmware with +some required metadata. + +To "sign" ``u-boot.elf`` you can use e.g. `qtestsign`_:: + + $ ./qtestsign.py aboot u-boot.elf + +Then install the resulting ``u-boot-test-signed.mbn`` to the ``aboot`` partition +on your device, e.g. with ``fastboot flash aboot u-boot-test-signed.mbn``. + +U-Boot should be running after a reboot (``fastboot reboot``). + +.. _qtestsign: https://github.com/msm8916-mainline/qtestsign + +Usage +----- +Press Volume Down during boot to enter Fastboot mode. diff --git a/doc/board/qualcomm/index.rst b/doc/board/qualcomm/index.rst new file mode 100644 index 0000000000..f7e0aa9298 --- /dev/null +++ b/doc/board/qualcomm/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Qualcomm +======== + +.. toctree:: + :maxdepth: 2 + + dragonboard410c diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index 65537e4778..1f08508c4d 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -11,6 +11,9 @@ #include <linux/sizes.h> #include <asm/arch/sysmap-apq8016.h>
+/* Build new ELF image from u-boot.bin (U-Boot + appended DTB) */ +#define CONFIG_REMAKE_ELF + /* Physical Memory Map */ #define PHYS_SDRAM_1 0x80000000 /* 1008 MB (the last ~30Mb are secured for TrustZone by ATF*/
- Workaround for "PSCI bug" on DragonBoard 410c
- Copyright (C) 2021 Stephan Gerhold stephan@gerhold.net
- Syscall parameters taken from Qualcomm's LK fork (scm.h):
- Copyright (c) 2011-2015, The Linux Foundation. All rights reserved.
- The PSCI implementation in the TrustZone/tz firmware on DragonBoard 410c has
- a bug that starts all other CPU cores in 32-bit mode unless the TZ syscall
- that switches from 32-bit to 64-bit mode is executed at least once.
- Normally this happens inside Qualcomm's LK bootloader which runs in 32-bit
- mode and uses the TZ syscall to boot a kernel in 64-bit mode. However, if
- U-Boot is installed to the "aboot" partition (replacing LK) the switch to
- 64-bit mode never happens since U-Boot is already running in 64-bit mode.
- A workaround for this "PSCI bug" is to execute the TZ syscall when entering
- U-Boot. That way PSCI is made aware of the 64-bit switch and starts all other
- CPU cores in 64-bit mode as well.
mrs x0, CurrentEL
bne reset
smc #0
b reset
.align 3
+el1_system_param:
return NULL;
return fw_dtb;
- ARM64 header for proper chain-loading with Little Kernel.
- Little Kernel shipped with Dragonboard410C boots standard Linux images for
- ARM64. This file adds header that is required to boot U-Boot properly.
- For details see:
- (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com
b _start
.word 0
.quad 0
.byte 0x52
.byte 0x4d
.byte 0x64
- (C) Copyright 2016
- Cédric Schieli cschieli@gmail.com
.dword 0x0
- Routine: save_boot_params (called after reset from start.S)
- Description: save ATAG/FDT address provided by the firmware at boot time
adr x8, fw_dtb
str x0, [x8]
/* Returns */
- doc/board/qualcomm/dragonboard410c.rst
chosen { };
aliases { };
memory {
- Override linker script for fastboot-readable images
- Based on arch/arm/cpu/armv8/u-boot.lds (Just add header)
. = 0x00000000;
. = ALIGN(8);
.text :
.efi_runtime : {
.text_rest :
*(.text*)
. = ALIGN(8);
. = ALIGN(8);
.data : {
*(.data*)
. = ALIGN(8);
. = ALIGN(8);
.u_boot_list : {
. = ALIGN(8);
.efi_runtime : {
*(efi_runtime_text)
*(efi_runtime_data)
. = ALIGN(8);
.image_copy_end :
. = ALIGN(8);
.rel_dyn_start :
*(.__rel_dyn_start)
.rela.dyn : {
*(.rela*)
.rel_dyn_end :
*(.__rel_dyn_end)
_end = .;
. = ALIGN(8);
.bss_start : {
.bss : {
*(.bss*)
. = ALIGN(8);
.bss_end : {
- qualcomm/index rockchip/index sifive/index sipeed/index
- $ export CROSS_COMPILE=<aarch64 toolchain prefix>
- $ make dragonboard410c_defconfig
- $ make
- $ ./qtestsign.py aboot u-boot.elf
+Qualcomm +========
+.. toctree::
- :maxdepth: 2
- dragonboard410c
/* Physical Memory Map */ #define PHYS_SDRAM_1 0x80000000 /* 1008 MB (the last ~30Mb are secured for TrustZone by ATF*/ -- 2.32.0
Thanks Stephan, it looks very good. I started testing it, it builds correctly and I flashed and everything seems to work. I do have a problem with my TFTP setup, so I didn't boot Linux yet, but I will get to it, if it will boot successfully we can merge this one.
U-boot doesn't know how to boot qcom android kernel partitions, I'm not sure this is something I even want to start supporting in U-boot. Nico, do you think you can change the format of the BOOT partition to host a u-boot FIT image ?
Thanks, Ramon
It's probably not too hard to support this (I actually boot the same Android boot images on both LK and U-Boot via "fastboot boot", because this is the workflow I'm used to). But I agree that anything else (i.e. reading the images from partitions) is not worth the effort.
Is a "boot" partition with a binary image even useful at all? I would expect that all typical Linux distributions except Android have a separate boot partition with a file system, so setting something up that works with the generic distro configuration (doc/README.distro) would be probably best. This would also avoid having to re-build the image just to change the cmdline for example.
Stephan
Ramon Fried
Stephan Gerhold
