[U-Boot-Users] [PATCH 1/2] mpc83xx: add support for more system clock performance controls
System registers that are modified are the Arbiter Configuration Register (ACR), the System Priority Control Register (SPCR), and the System Clock Configuration Register (SCCR).
Signed-off by: Michael F. Reiss Michael.F.Reiss@freescale.com Signed-off by: Joe D'Abbraccio ljd015@freescale.com Signed-off-by: Kim Phillips kim.phillips@freescale.com --- cpu/mpc83xx/cpu_init.c | 73 +++++++++++++++++++++++++++++++++-------------- cpu/mpc83xx/speed.c | 12 ++++---- include/mpc83xx.h | 13 ++++++-- 3 files changed, 67 insertions(+), 31 deletions(-)
diff --git a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c index 18d5a76..3337d8c 100644 --- a/cpu/mpc83xx/cpu_init.c +++ b/cpu/mpc83xx/cpu_init.c @@ -78,59 +78,88 @@ void cpu_init_f (volatile immap_t * im) im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSECEP) | (CFG_SPCR_TSECEP << SPCR_TSECEP_SHIFT); #endif
+#ifdef CFG_ACR_RPTCNT + /* Arbiter repeat count */ + im->arbiter.acr = (im->arbiter.acr & ~(ACR_RPTCNT)) | + (CFG_ACR_RPTCNT << ACR_RPTCNT_SHIFT); +#endif + +#ifdef CFG_SPCR_TSECEP + /* all TSEC's Emergency priority */ + im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSECEP) | + (CFG_SPCR_TSECEP << SPCR_TSECEP_SHIFT); +#endif + #ifdef CFG_SPCR_TSEC1EP /* TSEC1 Emergency priority */ - im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSEC1EP) | (CFG_SPCR_TSEC1EP << SPCR_TSEC1EP_SHIFT); + im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSEC1EP) | + (CFG_SPCR_TSEC1EP << SPCR_TSEC1EP_SHIFT); #endif
#ifdef CFG_SPCR_TSEC2EP /* TSEC2 Emergency priority */ - im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSEC2EP) | (CFG_SPCR_TSEC2EP << SPCR_TSEC2EP_SHIFT); + im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSEC2EP) | + (CFG_SPCR_TSEC2EP << SPCR_TSEC2EP_SHIFT); +#endif + +#ifdef CFG_SCCR_ENCCM + /* Encryption clock mode */ + im->clk.sccr = (im->clk.sccr & ~SCCR_ENCCM) | + (CFG_SCCR_ENCCM << SCCR_PCICM_SHIFT); +#endif + +#ifdef CFG_SCCR_PCICM + /* PCI & DMA clock mode */ + im->clk.sccr = (im->clk.sccr & ~SCCR_PCICM) | + (CFG_SCCR_PCICM << SCCR_PCICM_SHIFT); +#endif + +#ifdef CFG_SCCR_TSECCM + /* all TSEC's clock mode */ + im->clk.sccr = (im->clk.sccr & ~SCCR_TSECCM) | + (CFG_SCCR_TSECCM << SCCR_TSECCM_SHIFT); #endif
#ifdef CFG_SCCR_TSEC1CM /* TSEC1 clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC1CM) | (CFG_SCCR_TSEC1CM << SCCR_TSEC1CM_SHIFT); + im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC1CM) | + (CFG_SCCR_TSEC1CM << SCCR_TSEC1CM_SHIFT); #endif
#ifdef CFG_SCCR_TSEC2CM - /* TSEC2 & I2C1 clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC2CM) | (CFG_SCCR_TSEC2CM << SCCR_TSEC2CM_SHIFT); + /* TSEC2 clock mode */ + im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC2CM) | + (CFG_SCCR_TSEC2CM << SCCR_TSEC2CM_SHIFT); #endif
#ifdef CFG_SCCR_TSEC1ON /* TSEC1 clock switch */ - im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC1ON) | (CFG_SCCR_TSEC1ON << SCCR_TSEC1ON_SHIFT); + im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC1ON) | + (CFG_SCCR_TSEC1ON << SCCR_TSEC1ON_SHIFT); #endif
#ifdef CFG_SCCR_TSEC2ON /* TSEC2 clock switch */ - im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC2ON) | (CFG_SCCR_TSEC2ON << SCCR_TSEC2ON_SHIFT); + im->clk.sccr = (im->clk.sccr & ~SCCR_TSEC2ON) | + (CFG_SCCR_TSEC2ON << SCCR_TSEC2ON_SHIFT); #endif
#ifdef CFG_SCCR_USBMPHCM /* USB MPH clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_USBMPHCM) | (CFG_SCCR_USBMPHCM << SCCR_USBMPHCM_SHIFT); -#endif - -#ifdef CFG_SCCR_PCICM - /* PCI & DMA clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_PCICM) | (CFG_SCCR_PCICM << SCCR_PCICM_SHIFT); + im->clk.sccr = (im->clk.sccr & ~SCCR_USBMPHCM) | + (CFG_SCCR_USBMPHCM << SCCR_USBMPHCM_SHIFT); #endif
#ifdef CFG_SCCR_USBDRCM /* USB DR clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_USBDRCM) | (CFG_SCCR_USBDRCM << SCCR_USBDRCM_SHIFT); + im->clk.sccr = (im->clk.sccr & ~SCCR_USBDRCM) | + (CFG_SCCR_USBDRCM << SCCR_USBDRCM_SHIFT); #endif
-#ifdef CFG_SCCR_ENCCM - /* Encryption clock mode */ - im->clk.sccr = (im->clk.sccr & ~SCCR_ENCCM) | (CFG_SCCR_ENCCM << SCCR_PCICM_SHIFT); -#endif - -#ifdef CFG_ACR_RPTCNT - /* Arbiter repeat count */ - im->arbiter.acr = ((im->arbiter.acr & ~(ACR_RPTCNT)) | (CFG_ACR_RPTCNT << ACR_RPTCNT_SHIFT)); +#ifdef CFG_SCCR_SATACM + /* SATA controller clock mode */ + im->clk.sccr = (im->clk.sccr & ~SCCR_SATACM) | + (CFG_SCCR_SATACM << SCCR_SATACM_SHIFT); #endif
/* RSR - Reset Status Register - clear all status (4.6.1.3) */ diff --git a/cpu/mpc83xx/speed.c b/cpu/mpc83xx/speed.c index 4f5a866..61c9379 100644 --- a/cpu/mpc83xx/speed.c +++ b/cpu/mpc83xx/speed.c @@ -367,21 +367,21 @@ int get_clocks(void) #endif
#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) - switch ((sccr & SCCR_SATA1CM) >> SCCR_SATA1CM_SHIFT) { - case 0: + switch ((sccr & SCCR_SATACM) >> SCCR_SATACM_SHIFT) { + case SCCR_SATACM_0: sata_clk = 0; break; - case 1: + case SCCR_SATACM_1: sata_clk = csb_clk; break; - case 2: + case SCCR_SATACM_2: sata_clk = csb_clk / 2; break; - case 3: + case SCCR_SATACM_3: sata_clk = csb_clk / 3; break; default: - /* unkown SCCR_SATA1CM value */ + /* unkown SCCR_SATACM value */ return -11; } #endif diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 7299ca0..39cecf2 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -725,13 +725,20 @@ #define SCCR_USBCM_3 0x00F00000
#elif defined(CONFIG_MPC8313) -/* TSEC1 bits are for TSEC2 as well */ #define SCCR_TSEC1CM 0xc0000000 #define SCCR_TSEC1CM_SHIFT 30 +#define SCCR_TSEC1CM_0 0x00000000 #define SCCR_TSEC1CM_1 0x40000000 #define SCCR_TSEC1CM_2 0x80000000 #define SCCR_TSEC1CM_3 0xC0000000
+#define SCCR_TSEC2CM 0x30000000 +#define SCCR_TSEC2CM_SHIFT 28 +#define SCCR_TSEC2CM_0 0x00000000 +#define SCCR_TSEC2CM_1 0x10000000 +#define SCCR_TSEC2CM_2 0x20000000 +#define SCCR_TSEC2CM_3 0x30000000 + #define SCCR_TSEC1ON 0x20000000 #define SCCR_TSEC1ON_SHIFT 29 #define SCCR_TSEC2ON 0x10000000 @@ -831,8 +838,6 @@ #define SCCR_PCIEXP2CM_3 0x000c0000
/* All of the four SATA controllers must have the same clock ratio */ -#define SCCR_SATA1CM 0x000000c0 -#define SCCR_SATA1CM_SHIFT 6 #define SCCR_SATACM 0x000000ff #define SCCR_SATACM_SHIFT 0 #define SCCR_SATACM_0 0x00000000 @@ -852,6 +857,7 @@ */ #define CSCONFIG_EN 0x80000000 #define CSCONFIG_AP 0x00800000 +#define CSCONFIG_ODT_WR_ACS 0x00010000 #define CSCONFIG_ROW_BIT 0x00000700 #define CSCONFIG_ROW_BIT_12 0x00000000 #define CSCONFIG_ROW_BIT_13 0x00000100 @@ -1480,6 +1486,7 @@
/* DDRCDR - DDR Control Driver Register */ +#define DDRCDR_DHC_EN 0x80000000 #define DDRCDR_EN 0x40000000 #define DDRCDR_PZ 0x3C000000 #define DDRCDR_PZ_MAXZ 0x00000000
- im->arbiter.acr = (im->arbiter.acr & ~(ACR_RPTCNT)) |
- /* all TSEC's Emergency priority */
- im->sysconf.spcr = (im->sysconf.spcr & ~SPCR_TSECEP) |
The file has one CFG_SPCR_TSECEP before this, so I will send one patch to remove redundant one.
Thanks, Dave
Kim,
The patch also cause the MPC8315ERDB broken, the 8315ERDB can not boot up.
The root cause is that the SATA clock is not correct. I will send one patch to fix it.
Please merge it.
Thanks, Dave
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Phillips Kim Sent: 2008?1?16? 2:38 PM To: u-boot-users@lists.sourceforge.net Cc: D'Abbraccio Joe; Reiss Michael Subject: [U-Boot-Users] [PATCH 1/2] mpc83xx: add support for more system clock performance controls
#endif
- /* all TSEC's clock mode */
- im->clk.sccr = (im->clk.sccr & ~SCCR_TSECCM) |
#endif
#endif
- /* TSEC2 clock mode */
#endif
#endif
#endif
#endif
#endif
- /* SATA controller clock mode */
- im->clk.sccr = (im->clk.sccr & ~SCCR_SATACM) |
#endif
- case 0:
- switch ((sccr & SCCR_SATACM) >> SCCR_SATACM_SHIFT) {
- case SCCR_SATACM_0: sata_clk = 0; break;
- case 1:
- case SCCR_SATACM_1: sata_clk = csb_clk; break;
- case 2:
- case SCCR_SATACM_2: sata_clk = csb_clk / 2; break;
- case 3:
- case SCCR_SATACM_3: sata_clk = csb_clk / 3; break; default:
return -11; }/* unkown SCCR_SATACM value */
1.5.3
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Dave Liu
Kim Phillips
Liu Dave
