[U-Boot] [PATCH v2] ubifs: Fix ubifsload when using ZLIB
Using ZLIB compression with UBIFS fails if last data node is not a size of UBIFS_BLOCK_SIZE (4096 bytes).
Easiest way to test this is trying to read a file smaller than 4k: => ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... UBIFS error (pid 0): read_block: bad data node (block 0, inode 2506) UBIFS error (pid 0): do_readpage: cannot read page 0 of inode 2506, error -22 Error reading file '/etc/fstab' /etc/fstab not found! exit not allowed from main input shell. =>
With this patch:
=> ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... Done =>
Signed-off-by: Veli-Pekka Peltola veli-pekka.peltola@bluegiga.com Cc: kmpark@infradead.org --- Changes for v2: use proper variable type
fs/ubifs/ubifs.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index c68802b..d241774 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -37,8 +37,7 @@ DECLARE_GLOBAL_DATA_PTR; static int gzip_decompress(const unsigned char *in, size_t in_len, unsigned char *out, size_t *out_len) { - unsigned long len = in_len; - return zunzip(out, *out_len, (unsigned char *)in, &len, 0, 0); + return zunzip(out, *out_len, (unsigned char *)in, (unsigned long *)out_len, 0, 0); }
/* Fake description object for the "none" compressor */
With this patch:
Tested-by: Andreas Bießmann andreas.devel@googlemail.com
With this patch:
Thanks for this fix.
Applied to u-boot-ubi/master after minor coding style fix (line over 80 chars).
Thanks, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Andreas Bießmann
Stefan Roese
Veli-Pekka Peltola
