[U-Boot] [PATCH] arm64: mvebu: use single defconfig for Armada8K development boards
Currently, Marvell Armada8k development board use 3 different defconfigs: mvebu_db-88f7040-nand_defconfig mvebu_db-88f7040_defconfig mvebu_db-88f8040_defconfig Having 3 different defconfigs makes maintenance difficult.
This patch removes the defconfigs mentioned above and introduce a new defconfig which represents the Armada8k family.
With this patch, no device-tree is set in the defconfig, so the device-tree should be set during compilation, using:
Configure u-boot:
make mvebu_db_armada8k_defconfig
Select the desired device-tree during compilation:
make DEVICE_TREE=armada-7040-db make DEVICE_TREE=armada-8040-db make DEVICE_TREE=armada-7040-db-nand
Change-Id: I98515b6306498358f3722ecf7ac4c87f236ebbd8 Signed-off-by: Igal Liberman igall@marvell.com --- configs/mvebu_db-88f7040-nand_defconfig | 72 --------------------------------- configs/mvebu_db-88f7040_defconfig | 70 -------------------------------- configs/mvebu_db-88f8040_defconfig | 70 -------------------------------- configs/mvebu_db_armada8k_defconfig | 69 +++++++++++++++++++++++++++++++ 4 files changed, 69 insertions(+), 212 deletions(-) delete mode 100644 configs/mvebu_db-88f7040-nand_defconfig delete mode 100644 configs/mvebu_db-88f7040_defconfig delete mode 100644 configs/mvebu_db-88f8040_defconfig create mode 100644 configs/mvebu_db_armada8k_defconfig
diff --git a/configs/mvebu_db-88f7040-nand_defconfig b/configs/mvebu_db-88f7040-nand_defconfig deleted file mode 100644 index 8d48cb6..0000000 --- a/configs/mvebu_db-88f7040-nand_defconfig +++ /dev/null @@ -1,72 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MVEBU=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_MVEBU_ARMADA_8K=y -CONFIG_DEFAULT_DEVICE_TREE="armada-7040-db-nand" -CONFIG_SMBIOS_PRODUCT_NAME="" -CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_EARLY_INIT_R=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_MVEBU_BUBT=y -CONFIG_MVEBU_NAND_BOOT=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_MAC_PARTITION=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -CONFIG_BLOCK_CACHE=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_MVTWSI=y -CONFIG_MISC=y -CONFIG_DM_MMC=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_XENON=y -CONFIG_NAND_PXA3XX=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PHYLIB=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_PCIE_DW_MVEBU=y -CONFIG_MVEBU_COMPHY_SUPPORT=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_ARMADA_8K=y -# CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_DEBUG_UART=y -CONFIG_DEBUG_UART_BASE=0xf0512000 -CONFIG_DEBUG_UART_CLOCK=200000000 -CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig deleted file mode 100644 index 9f7b2c4..0000000 --- a/configs/mvebu_db-88f7040_defconfig +++ /dev/null @@ -1,70 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MVEBU=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_MVEBU_ARMADA_8K=y -CONFIG_DEFAULT_DEVICE_TREE="armada-7040-db" -CONFIG_SMBIOS_PRODUCT_NAME="" -CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_EARLY_INIT_R=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_MVEBU_BUBT=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_MAC_PARTITION=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -CONFIG_BLOCK_CACHE=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_MVTWSI=y -CONFIG_MISC=y -CONFIG_DM_MMC=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_XENON=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PHY_MARVELL=y -CONFIG_MVPP2=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_PCIE_DW_MVEBU=y -CONFIG_MVEBU_COMPHY_SUPPORT=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_ARMADA_8K=y -# CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_DEBUG_UART=y -CONFIG_DEBUG_UART_BASE=0xf0512000 -CONFIG_DEBUG_UART_CLOCK=200000000 -CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/mvebu_db-88f8040_defconfig b/configs/mvebu_db-88f8040_defconfig deleted file mode 100644 index c21c977..0000000 --- a/configs/mvebu_db-88f8040_defconfig +++ /dev/null @@ -1,70 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MVEBU=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_MVEBU_ARMADA_8K=y -CONFIG_DEFAULT_DEVICE_TREE="armada-8040-db" -CONFIG_SMBIOS_PRODUCT_NAME="" -CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_EARLY_INIT_R=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_MVEBU_BUBT=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_MAC_PARTITION=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -CONFIG_BLOCK_CACHE=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_MVTWSI=y -CONFIG_MISC=y -CONFIG_DM_MMC=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_XENON=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PHY_MARVELL=y -CONFIG_MVPP2=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_PCIE_DW_MVEBU=y -CONFIG_MVEBU_COMPHY_SUPPORT=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_ARMADA_8K=y -# CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_DEBUG_UART=y -CONFIG_DEBUG_UART_BASE=0xf0512000 -CONFIG_DEBUG_UART_CLOCK=200000000 -CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig new file mode 100644 index 0000000..bee3ae5 --- /dev/null +++ b/configs/mvebu_db_armada8k_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_BLOCK_CACHE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_MVPP2=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_SMBIOS_MANUFACTURER=""
Hi Igal,
Configure u-boot:
I like the idea to consolidate the defconfigs in general. One question though. This patch results in one build target for the automated tests (Travis). Does compiling without the additional DEVICE_TREE= work without generating compilation errors? Otherwise the Travis tests will fail.
Thanks, Stefan
Hi Stefan
Regards, Igal
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: Thursday, June 08, 2017 08:38 To: Igal Liberman; u-boot@lists.denx.de Cc: Kostya Porotchkin; Nadav Haklai; Neta Zur Hershkovits Subject: Re: [PATCH] arm64: mvebu: use single defconfig for Armada8K development boards
Hi Igal,
Configure u-boot:
If you compile without DEVICE_TREE= it won't compile (unless you exported DEVICE_TREE before). Basically, I did it on purpose - to make sure that user doesn't rely on some possible incorrect default settings. If it causes a compilation issues for the automated tests - I guess we can set a default value after all. What do you think?
Thanks, Stefan
Hi Igal,
Configure u-boot:
Makes sense.
Yes, please do. We need to compile clean for the automated tests, otherwise this patch simply can't be accepted (sorry).
Thanks, Stefan
Hi Stefan
Regards, Igal
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: Thursday, June 08, 2017 09:10 To: Igal Liberman; u-boot@lists.denx.de Cc: Kostya Porotchkin; Nadav Haklai; Neta Zur Hershkovits Subject: Re: [PATCH] arm64: mvebu: use single defconfig for Armada8K development boards
Hi Igal,
Configure u-boot:
though.
Makes sense.
I'll submit a new patch with default device-tree. Thank you for the review.
Thanks, Stefan
Igal Liberman
igall@marvell.com
Stefan Roese
