[U-Boot] [PATCH] SPL: ext: remove redundant ifdef statement
Remove redundant #if defined(CONFIG_SPL_OS_BOOT) statement around getenv() calls in spl_load_image_ext_os().
The whole function is surrounded by #ifdef CONFIG_SPL_OS_BOOT.
No functional change.
Signed-off-by: Petr Kulhavy brain@jikos.cz CC: Guillaume GARDET guillaume.gardet@free.fr --- common/spl/spl_ext.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 074b31e..9a230d5 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -88,8 +88,7 @@ int spl_load_image_ext_os(struct blk_desc *block_dev, int partition) #endif return -1; } - -#if defined(CONFIG_SPL_ENV_SUPPORT) && defined(CONFIG_SPL_OS_BOOT) +#if defined(CONFIG_SPL_ENV_SUPPORT) file = getenv("falcon_args_file"); if (file) { err = ext4fs_open(file, &filelen);
Acked-by: Guillaume GARDET guillaume.gardet@free.fr
Signed-off-by: Petr Kulhavy brain@jikos.cz CC: Guillaume GARDET guillaume.gardet@free.fr Acked-by: Guillaume GARDET guillaume.gardet@free.fr
Guillaume Gardet
Petr Kulhavy
