[U-Boot] [PATCH 1/2 v2] driver/ddr/fsl: Add address parity support for DDR4 UDIMM/discrete
Add support of address parity for DDR4 UDIMM or discrete memory. It requires to configurate corresponding MR5[2:0] and TIMING_CFG_7[PAR_LAT]. Parity can be turned on/off by hwconfig, e.g. hwconfig=fsl_ddr:parity=on.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- v2: Integrated York's comments.
doc/README.fsl-ddr | 9 ++++++++ drivers/ddr/fsl/ctrl_regs.c | 55 ++++++++++++++++++++++++++++++++++++++++----- drivers/ddr/fsl/options.c | 15 +++++++++++-- include/fsl_ddr_sdram.h | 11 ++++++++- 4 files changed, 82 insertions(+), 8 deletions(-)
diff --git a/doc/README.fsl-ddr b/doc/README.fsl-ddr index cd71ec8..cec5d94 100644 --- a/doc/README.fsl-ddr +++ b/doc/README.fsl-ddr @@ -123,6 +123,14 @@ ECC can be turned on/off by hwconfig. Syntax is hwconfig=fsl_ddr:ecc=off
+ +Memory address parity on/off +============================ +address parity can be turned on/off by hwconfig. +Syntax is: +hwconfig=fsl_ddr:parity=on + + Memory testing options for mpc85xx ================================== 1. Memory test can be done once U-Boot prompt comes up using mtest, or @@ -143,6 +151,7 @@ platform
hwconfig=fsl_ddr:addr_hash=true,ctlr_intlv=cacheline,bank_intlv=cs0_cs1_cs2_cs3,ecc=on
+ Table for dynamic ODT for DDR3 ============================== For single-slot system with quad-rank DIMM and dual-slot system, dynamic ODT may diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 0bfcd34..9073917 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -895,11 +895,15 @@ static void set_ddr_sdram_cfg_2(const unsigned int ctrl_num, slow = get_ddr_freq(ctrl_num) < 1249000000; #endif
- if (popts->registered_dimm_en) { + if (popts->registered_dimm_en) rcw_en = 1; - ap_en = popts->ap_en; - } else { + + /* DDR4 can have address parity for UDIMM and discrete */ + if ((CONFIG_FSL_SDRAM_TYPE != SDRAM_TYPE_DDR4) && + (!popts->registered_dimm_en)) { ap_en = 0; + } else { + ap_en = popts->ap_en; }
x4_en = popts->x4_en ? 1 : 0; @@ -1135,6 +1139,7 @@ static void set_ddr_sdram_mode_9(fsl_ddr_cfg_regs_t *ddr, unsigned short esdmode5; /* Extended SDRAM mode 5 */ int rtt_park = 0; bool four_cs = false; + const unsigned int mclk_ps = get_memory_clk_period_ps(0);
#if CONFIG_CHIP_SELECTS_PER_CTRL == 4 if ((ddr->cs[0].config & SDRAM_CS_CONFIG_EN) && @@ -1150,6 +1155,19 @@ static void set_ddr_sdram_mode_9(fsl_ddr_cfg_regs_t *ddr, esdmode5 = 0x00000400; /* Data mask enabled */ }
+ /* set command/address parity latency */ + if (ddr->ddr_sdram_cfg_2 & SDRAM_CFG2_AP_EN) { + if (mclk_ps >= 935) { + /* for DDR4-1600/1866/2133 */ + esdmode5 |= DDR_MR5_CA_PARITY_LAT_4_CLK; + } else if (mclk_ps >= 833) { + /* for DDR4-2400 */ + esdmode5 |= DDR_MR5_CA_PARITY_LAT_5_CLK; + } else { + printf("parity: mclk_ps = %d not supported\n", mclk_ps); + } + } + ddr->ddr_sdram_mode_9 = (0 | ((esdmode4 & 0xffff) << 16) | ((esdmode5 & 0xffff) << 0) @@ -1170,6 +1188,20 @@ static void set_ddr_sdram_mode_9(fsl_ddr_cfg_regs_t *ddr, } else { esdmode5 = 0x00000400; } + + if (ddr->ddr_sdram_cfg_2 & SDRAM_CFG2_AP_EN) { + if (mclk_ps >= 935) { + /* for DDR4-1600/1866/2133 */ + esdmode5 |= DDR_MR5_CA_PARITY_LAT_4_CLK; + } else if (mclk_ps >= 833) { + /* for DDR4-2400 */ + esdmode5 |= DDR_MR5_CA_PARITY_LAT_5_CLK; + } else { + printf("parity: mclk_ps = %d not supported\n", + mclk_ps); + } + } + switch (i) { case 1: ddr->ddr_sdram_mode_11 = (0 @@ -1925,12 +1957,25 @@ static void set_timing_cfg_7(const unsigned int ctrl_num, const common_timing_params_t *common_dimm) { unsigned int txpr, tcksre, tcksrx; - unsigned int cke_rst, cksre, cksrx, par_lat, cs_to_cmd; + unsigned int cke_rst, cksre, cksrx, par_lat = 0, cs_to_cmd; + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num);
txpr = max(5U, picos_to_mclk(ctrl_num, common_dimm->trfc1_ps + 10000)); tcksre = max(5U, picos_to_mclk(ctrl_num, 10000)); tcksrx = max(5U, picos_to_mclk(ctrl_num, 10000)); - par_lat = 0; + + if (ddr->ddr_sdram_cfg_2 & SDRAM_CFG2_AP_EN) { + if (mclk_ps >= 935) { + /* parity latency 4 clocks in case of 1600/1866/2133 */ + par_lat = 4; + } else if (mclk_ps >= 833) { + /* parity latency 5 clocks for DDR4-2400 */ + par_lat = 5; + } else { + printf("parity: mclk_ps = %d not supported\n", mclk_ps); + } + } + cs_to_cmd = 0;
if (txpr <= 200) diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index 791d644..d0075ff 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -1002,8 +1002,19 @@ unsigned int populate_memctl_options(const common_timing_params_t *common_dimm, popts->twot_en = 0; popts->threet_en = 0;
- /* for RDIMM, address parity enable */ - popts->ap_en = 1; + /* for RDIMM and DDR4 UDIMM/discrete memory, address parity enable */ + if (popts->registered_dimm_en) + popts->ap_en = 1; /* 0 = disable, 1 = enable */ + else + popts->ap_en = 0; /* disabled for DDR4 UDIMM/discrete default */ + + if (hwconfig_sub_f("fsl_ddr", "parity", buf)) { + if (hwconfig_subarg_cmp_f("fsl_ddr", "parity", "on", buf)) { + if (popts->registered_dimm_en || + (CONFIG_FSL_SDRAM_TYPE == SDRAM_TYPE_DDR4)) + popts->ap_en = 1; + } + }
/* * BSTTOPRE precharge interval diff --git a/include/fsl_ddr_sdram.h b/include/fsl_ddr_sdram.h index 3699c04..cf316a4 100644 --- a/include/fsl_ddr_sdram.h +++ b/include/fsl_ddr_sdram.h @@ -123,6 +123,7 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t;
#define SDRAM_CFG2_FRC_SR 0x80000000 #define SDRAM_CFG2_D_INIT 0x00000010 +#define SDRAM_CFG2_AP_EN 0x00000020 #define SDRAM_CFG2_ODT_CFG_MASK 0x00600000 #define SDRAM_CFG2_ODT_NEVER 0 #define SDRAM_CFG2_ODT_ONLY_WRITE 1 @@ -177,6 +178,14 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; #define DDR_CDR2_VREF_TRAIN_EN 0x00000080 #define DDR_CDR2_VREF_RANGE_2 0x00000040
+/* DDR ERR_DISABLE */ +#define DDR_ERR_DISABLE_APED (1 << 8) /* Address parity error disable */ + +/* Mode Registers */ +#define DDR_MR5_CA_PARITY_LAT_4_CLK 0x1 /* for DDR4-1600/1866/2133 */ +#define DDR_MR5_CA_PARITY_LAT_5_CLK 0x2 /* for DDR4-2400 */ + + #if (defined(CONFIG_SYS_FSL_DDR_VER) && \ (CONFIG_SYS_FSL_DDR_VER >= FSL_DDR_VER_4_7)) #ifdef CONFIG_SYS_FSL_DDR3L @@ -343,7 +352,7 @@ typedef struct memctl_options_s { /* mirrior DIMMs for DDR3 */ unsigned int mirrored_dimm; unsigned int quad_rank_present; - unsigned int ap_en; /* address parity enable for RDIMM */ + unsigned int ap_en; /* address parity enable for RDIMM/DDR4-UDIMM */ unsigned int x4_en; /* enable x4 devices */
/* Global Timing Parameters */
During initial DDR training, false parity errors may be detected. This patch adds workaround to fix the erratum. Tested on LS2085QDS and LS2080RDB.
arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + drivers/ddr/fsl/fsl_ddr_gen4.c | 44 ++++++++++++++++++++--- 2 files changed, 40 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 0ef7c9d..b0c112b 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -119,6 +119,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A008751 #define CONFIG_SYS_FSL_ERRATUM_A009635 #define CONFIG_SYS_FSL_ERRATUM_A009663 +#define CONFIG_SYS_FSL_ERRATUM_A009803 #define CONFIG_SYS_FSL_ERRATUM_A009942
/* ARM A57 CORE ERRATA */ diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index 6f76980..608810d 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -12,7 +12,8 @@ #include <fsl_ddr.h> #include <fsl_errata.h>
-#ifdef CONFIG_SYS_FSL_ERRATUM_A008511 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008511) | \ + defined(CONFIG_SYS_FSL_ERRATUM_A009803) static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) { int timeout = 1000; @@ -24,9 +25,9 @@ static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) timeout--; } if (timeout <= 0) - puts("Error: A007865 wait for clear timeout.\n"); + puts("Error: wait for clear timeout.\n"); } -#endif /* CONFIG_SYS_FSL_ERRATUM_A008511 */ +#endif
#if (CONFIG_CHIP_SELECTS_PER_CTRL > 4) #error Invalid setting for CONFIG_CHIP_SELECTS_PER_CTRL @@ -201,7 +202,18 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); } + +#ifdef CONFIG_SYS_FSL_ERRATUM_A009803 + /* part 1 of 2 */ + if (regs->ddr_sdram_cfg & SDRAM_CFG_RD_EN) { /* for RDIMM */ + ddr_out32(&ddr->ddr_sdram_rcw_2, + regs->ddr_sdram_rcw_2 & ~0x0f000000); + } + + ddr_out32(&ddr->err_disable, regs->err_disable | DDR_ERR_DISABLE_APED); +#else ddr_out32(&ddr->err_disable, regs->err_disable); +#endif ddr_out32(&ddr->err_int_en, regs->err_int_en); for (i = 0; i < 32; i++) { if (regs->debug[i]) { @@ -297,7 +309,8 @@ step2: mb(); isb();
-#ifdef CONFIG_SYS_FSL_ERRATUM_A008511 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008511) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A009803) /* Part 2 of 2 */ /* This erraum only applies to verion 5.2.0 */ if (fsl_ddr_get_version(ctrl_num) == 0x50200) { @@ -313,6 +326,7 @@ step2: ctrl_num, ddr_in32(&ddr->debug[1])); }
+#ifdef CONFIG_SYS_FSL_ERRATUM_A008511 /* The vref setting sequence is different for range 2 */ if (regs->ddr_cdr2 & DDR_CDR2_VREF_RANGE_2) vref_seq = vref_seq2; @@ -359,9 +373,29 @@ step2: } /* Restore D_INIT */ ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); - } #endif /* CONFIG_SYS_FSL_ERRATUM_A008511 */
+#ifdef CONFIG_SYS_FSL_ERRATUM_A009803 + /* if it's RDIMM */ + if (regs->ddr_sdram_cfg & SDRAM_CFG_RD_EN) { + for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + if (!(regs->cs[i].config & SDRAM_CS_CONFIG_EN)) + continue; + set_wait_for_bits_clear(&ddr->sdram_md_cntl, + MD_CNTL_MD_EN | + MD_CNTL_CS_SEL(i) | + 0x070000ed, + MD_CNTL_MD_EN); + udelay(1); + } + } + + ddr_out32(&ddr->err_disable, + regs->err_disable & ~DDR_ERR_DISABLE_APED); +#endif + } +#endif + total_gb_size_per_controller = 0; for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (!(regs->cs[i].config & 0x80000000))
Applied to u-boot-fsl-qoriq, awaiting upstream.
Thanks.
York
- defined(CONFIG_SYS_FSL_ERRATUM_A009803)
Shengzhou,
I missed this error. It should be logic or "||", not bit or "|" here. Please fix it with your latest patch for 9803.
York
Minor adjustment of commit message format.
Thanks.
York
Shengzhou Liu
York Sun
york sun
