[PATCH] arm: kirkwood: Pogoplug E02 : Convert Ethernet to Driver Model
The Pogoplug E02 board has the network chip Marvell 88E1116R. Convert to Driver Model and use uclass mvgbe and the compatible driver M88E1118R to bring up Ethernet.
- Add board_eth_init(), CONFIG_DM_ETH, and CONFIG_PHY_MARVELL to bring up Ethernet. - Currently, CONFIG_RESET_PHY_R symbol is used in arch/arm/mach-kirkwood/include/mach/config.h for all Kirkwood boards with mv8831116 PHY, with each board defines the function reset_phy(). Undefine it for this board. - As the result of the migration to Driver Model, this u-boot image has grown substantially (about 100K, give or take). The old envs location at 0x60000 (384k) is no longer possible. Move it to 0xC0000 (768K). - Miscellaneous changes: Move constants to .c file and remove header file board/cloudengines/pogo_e02/pogo_e02.h, use CONFIG_SYS_THUMB_BUILD to keep u-boot image under 512K, use BIT macro, and cleanup comments.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
board/cloudengines/pogo_e02/pogo_e02.c | 51 +++++++------------------- board/cloudengines/pogo_e02/pogo_e02.h | 29 --------------- configs/pogo_e02_defconfig | 6 ++- include/configs/pogo_e02.h | 13 ++----- 4 files changed, 22 insertions(+), 77 deletions(-) delete mode 100644 board/cloudengines/pogo_e02/pogo_e02.h
diff --git a/board/cloudengines/pogo_e02/pogo_e02.c b/board/cloudengines/pogo_e02/pogo_e02.c index 039fd6e3dd..59e1218b41 100644 --- a/board/cloudengines/pogo_e02/pogo_e02.c +++ b/board/cloudengines/pogo_e02/pogo_e02.c @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * Copyright (C) 2022 Tony Dinh mibodhi@gmail.com * Copyright (C) 2012 * David Purdy david.c.purdy@gmail.com * @@ -12,16 +13,21 @@ #include <common.h> #include <init.h> #include <log.h> -#include <miiphy.h> -#include <net.h> +#include <netdev.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> #include <asm/global_data.h> -#include "pogo_e02.h" +#include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR;
+/* GPIO configuration */ +#define POGO_E02_OE_LOW (~(0)) +#define POGO_E02_OE_HIGH (~(0)) +#define POGO_E02_OE_VAL_LOW BIT(29) +#define POGO_E02_OE_VAL_HIGH 0 + int board_early_init_f(void) { /* @@ -64,6 +70,11 @@ int board_early_init_f(void) return 0; }
+int board_eth_init(struct bd_info *bis) +{ + return cpu_eth_init(bis); +} + int board_init(void) { /* Boot parameters address */ @@ -71,37 +82,3 @@ int board_init(void)
return 0; } - -#ifdef CONFIG_RESET_PHY_R -/* Configure and initialize PHY */ -void reset_phy(void) -{ - u16 reg; - u16 devadr; - char *name = "egiga0"; - - if (miiphy_set_current_dev(name)) - return; - - /* command to read PHY dev address */ - if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { - printf("Err..(%s) could not read PHY dev address\n", __func__); - return; - } - - /* - * Enable RGMII delay on Tx and Rx for CPU port - * Ref: sec 4.7.2 of chip datasheet - */ - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); - miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); - reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); - miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); - - /* reset the phy */ - miiphy_reset(name, devadr); - - debug("88E1116 Initialized on %s\n", name); -} -#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/cloudengines/pogo_e02/pogo_e02.h b/board/cloudengines/pogo_e02/pogo_e02.h deleted file mode 100644 index c8397b4d4f..0000000000 --- a/board/cloudengines/pogo_e02/pogo_e02.h +++ /dev/null @@ -1,29 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2012 - * David Purdy david.c.purdy@gmail.com - * - * Based on Kirkwood support: - * (C) Copyright 2009 - * Marvell Semiconductor <www.marvell.com> - * Written-by: Prafulla Wadaskar prafulla@marvell.com - */ - -#ifndef __POGO_E02_H -#define __POGO_E02_H - -/* GPIO configuration */ -#define POGO_E02_OE_LOW (~(0)) -#define POGO_E02_OE_HIGH (~(0)) -#define POGO_E02_OE_VAL_LOW (1 << 29) -#define POGO_E02_OE_VAL_HIGH 0 - -/* PHY related */ -#define MV88E1116_LED_FCTRL_REG 10 -#define MV88E1116_CPRSP_CR3_REG 21 -#define MV88E1116_MAC_CTRL_REG 21 -#define MV88E1116_PGADR_REG 22 -#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) -#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) - -#endif /* __POGO_E02_H */ diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 10f08a515d..7853cc7b24 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -2,13 +2,14 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y +CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/cloudengines/pogo_e02/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_POGO_E02=y CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x60000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" CONFIG_IDENT_STRING="\nPogo E02" # CONFIG_SYS_MALLOC_F is not set @@ -36,11 +37,14 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 3e94125cb3..51c802f2b3 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -14,10 +14,6 @@
#include "mv-common.h"
-/* - * Environment variables configurations - */ - /* * Default environment variables */ @@ -33,13 +29,10 @@ /* * Ethernet Driver configuration */ -#ifdef CONFIG_CMD_NET #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0 -#endif /* CONFIG_CMD_NET */ - -/* - * File system - */ +#ifdef CONFIG_RESET_PHY_R +#undef CONFIG_RESET_PHY_R /* remove legacy reset_phy() */ +#endif
#endif /* _CONFIG_POGO_E02_H */
Thanks, Stefan
- Copyright (C) 2022 Tony Dinh mibodhi@gmail.com
- Copyright (C) 2012
- David Purdy david.c.purdy@gmail.com
- int board_early_init_f(void) { /*
- return cpu_eth_init(bis);
- int board_init(void) { /* Boot parameters address */
return 0; }
- u16 reg;
- u16 devadr;
return;
return;
- Based on Kirkwood support:
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- Environment variables configurations
- Default environment variables
- Ethernet Driver configuration
- File system
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
return 0; }
- u16 reg;
- u16 devadr;
return;
return;
- File system
Stefan Roese
Tony Dinh
