[U-Boot-Users] Writing to flash device from ELDK Linux Shell prompt
Hi ,
Is it possible to copy(store) a binary file into the flash device from the Linux shell prompt of ELDK.
Thank You, Verma.
This is Off-Topic here! You can access your Flash using the MTD device structure from Linux: http://www.linux-mtd.infradead.org/
Regards,
I need some help about JFFS2 and MMU.
I have a writtable JFFS2 partition on a NAND flash. I find that mounting the JFFS2 partition is very slow (about 5 minutes for a partition of 8MB having 133 files) compare with running under Linux. The MMU is not enabled, neither the DCache.
Should I enable MMU and DCache ? How can I do that ? I've checked the source code on Linux, and it seems very complex.
I'm working on a ARM 926 ejs core and I'm using UBoot V1.1.6.
Thanks for your help,
Yves
Clemens Koller
Verma
yves.lallaizon@crealie.com
