[U-Boot] [PATCH 1/2] ZM7300 driver
Adds Support for PowerOne ZM7300 voltage regulator. This device is available on some Freescale Boards like B4860QDS and has to be programmed to adjust the voltage on the board.
The device is accessible via I2C interface.
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- board/freescale/common/Makefile | 1 + board/freescale/common/zm7300.c | 235 +++++++++++++++++++++++++++++++++++++++ board/freescale/common/zm7300.h | 22 ++++ 3 files changed, 258 insertions(+), 0 deletions(-) create mode 100644 board/freescale/common/zm7300.c create mode 100644 board/freescale/common/zm7300.h
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index f6a0879..22b57cc 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -48,6 +48,7 @@ obj-$(CONFIG_P5020DS) += ics307_clk.o obj-$(CONFIG_P5040DS) += ics307_clk.o obj-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o obj-$(CONFIG_IDT8T49N222A) += idt8t49n222a_serdes_clk.o +obj-$(CONFIG_ZM7300) += zm7300.o
# deal with common files for P-series corenet based devices obj-$(CONFIG_P2041RDB) += p_corenet/ diff --git a/board/freescale/common/zm7300.c b/board/freescale/common/zm7300.c new file mode 100644 index 0000000..ed79b43 --- /dev/null +++ b/board/freescale/common/zm7300.c @@ -0,0 +1,235 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Power-One ZM7300 DPM */ +#include "zm7300.h" + +#define DPM_WP 0x96 +#define WRP_OPCODE 0x01 +#define WRM_OPCODE 0x02 +#define RRP_OPCODE 0x11 + +#define DPM_SUCCESS 0x01 +#define DPM_EXEC_FAIL 0x00 + +static const uint16_t hex_to_1_10mv[] = { + 5000, + 5125, + 5250, + 5375, + 5500, + 5625, + 5750, + 5875, + 6000, + 6125, + 6250, + 6375, + 6500, + 6625, + 6750, + 6875, + 7000, + 7125, + 7250, + 7375, + 7500, + 7625, + 7750, + 7875, + 8000, + 8125, + 8250, + 8375, + 8500, + 8625, + 8750, + 8875, + 9000, + 9125, + 9250, + 9375, + 9500, /* 0.95mV */ + 9625, + 9750, + 9875, + 10000, /* 1.0V */ + 10125, + 10250, + 10375, + 10500, + 10625, + 10750, + 10875, + 11000, + 11125, + 11250, + 11375, + 11500, + 11625, + 11750, + 11875, + 12000, + 12125, + 12250, + 12375, + 0, /* reserved */ +}; + + +/* Read Data d from Register r of POL p */ +u8 dpm_rrp(uchar r) +{ + u8 dpm_rrp[5], ret[5]; + + ret[0] = RRP_OPCODE; + /* POL is 0 */ + ret[1] = 0; + ret[2] = r; + i2c_read(I2C_DPM_ADDR, 0, -3, ret, 2); + if (ret[1] == DPM_SUCCESS) { /* the DPM returned success as status */ + debug("RRP_OPCODE returned success data is %x\n", ret[0]); + return ret[0]; + } else { + return -1; + } +} + +/* Write Data d into DPM register r (RAM) */ +int dpm_wrm(u8 r, u8 d) +{ + u8 dpm_wrm[5], ret[5]; + + ret[0] = WRM_OPCODE; + ret[1] = r; + ret[2] = d; + i2c_read(I2C_DPM_ADDR, 0, -3, ret, 1); + if (ret[0] == DPM_SUCCESS) { /* the DPM returned success as status */ + debug("WRM_OPCODE returned success data is %x\n", ret[0]); + return ret[0]; + } else { + return -1; + } +} + +/* Write Data d into Register r of POL(s) a */ +int dpm_wrp(u8 r, u8 d) +{ + u8 dpm_wrp[7], ret[7]; + + ret[0] = WRP_OPCODE; + /* only POL0 is present */ + ret[1] = 0x01; + ret[2] = 0x00; + ret[3] = 0x00; + ret[4] = 0x00; + ret[5] = r; + ret[6] = d; + i2c_read(I2C_DPM_ADDR, 0, -7, ret, 1); + if (ret[0] == DPM_SUCCESS) { /* the DPM returned success as status */ + debug("WRP_OPCODE returned success data is %x\n", ret[0]); + return 0; + } else { + return -1; + } +} + +/* Uses the DPM command RRP */ +u8 zm_read(uchar reg) +{ + u8 d; + d = dpm_rrp(reg); + return d; +} + +/* ZM_write -- + Steps: + a. Write data to the register + b. Read data from register and compare to written value + c. Return return_code & voltage_read +*/ +u8 zm_write(u8 reg, u8 data) +{ + u8 d; + + /* write data to register */ + dpm_wrp(reg, data); + + /* read register and compare to written value */ + d = dpm_rrp(reg); + if (d != data) { + printf("zm_write : Comparison register data failed\n"); + return -1; + } + + return d; +} + +/* zm_write_out_voltage + * voltage in 1/10 mV + */ +int zm_write_voltage(int voltage) +{ + u8 reg = 0x7, vid; + uint16_t voltage_read; + u8 ret; + + vid = (voltage - 5000) / ZM_STEP; + + ret = zm_write(reg, vid); + if (ret != -1) { + voltage_read = hex_to_1_10mv[ret]; + debug("voltage set to %dmV\n", voltage_read/10); + return voltage_read; + } + return -1; +} + +/* zm_read_out_voltage + * voltage in 1/10 mV + */ +int zm_read_voltage(void) +{ + u8 reg = 0x7; + u8 ret; + int voltage; + + ret = zm_read(reg); + if (ret != -1) { + voltage = hex_to_1_10mv[ret]; + debug("Voltage read is %dmV\n", voltage/10); + return voltage; + } else { + return -1; + } +} + +int zm_disable_wp() +{ + u8 new_wp_value; + + /* Disable using Write-Protect register 0x96 */ + new_wp_value = 0x8; + if ((dpm_wrm(DPM_WP, new_wp_value)) < 0) { + printf("Disable Write-Protect register failed\n"); + return -1; + } + return 0; +} + +int zm_enable_wp() +{ + u8 orig_wp_value; + orig_wp_value = 0x0; + + /* Enable using Write-Protect register 0x96 */ + if ((dpm_wrm(DPM_WP, orig_wp_value)) < 0) { + printf("Enable Write-Protect register failed\n"); + return -1; + } + return 0; +} + diff --git a/board/freescale/common/zm7300.h b/board/freescale/common/zm7300.h new file mode 100644 index 0000000..6b4d035 --- /dev/null +++ b/board/freescale/common/zm7300.h @@ -0,0 +1,22 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ZM7300_H_ +#define __ZM7300_H 1_ + +#include <common.h> +#include <i2c.h> +#include <errno.h> +#include <asm/io.h> + +#define ZM_STEP 125 +int zm7300_set_voltage(int voltage_1_10mv); +int zm_write_voltage(int voltage); +int zm_read_voltage(void); +int zm_disable_wp(void); +int zm_enable_wp(void); + +#endif /* __ZM7300_H_ */
The fuse status register provides the values from on-chip voltage ID efuses programmed at the factory. These values define the voltage requirements for the chip. u-boot reads FUSESR and translates the values into the appropriate commands to set the voltage output value of an external voltage regulator. B4860QDS has a PowerOne ZM7300 programmable digital Power Manager which is programmed as per the value read from the fuses.
Reference for this code is taken from t4qds VID implementation.
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- board/freescale/b4860qds/b4860qds.c | 240 +++++++++++++++++++++++++++++++++++ include/configs/B4860QDS.h | 11 ++ 2 files changed, 251 insertions(+), 0 deletions(-)
diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c index d9c88a0..b2d5378 100644 --- a/board/freescale/b4860qds/b4860qds.c +++ b/board/freescale/b4860qds/b4860qds.c @@ -23,6 +23,7 @@ #include "../common/qixis.h" #include "../common/vsc3316_3308.h" #include "../common/idt8t49n222a_serdes_clk.h" +#include "../common/zm7300.h" #include "b4860qds.h" #include "b4860qds_qixis.h" #include "b4860qds_crossbar_con.h" @@ -94,6 +95,238 @@ int select_i2c_ch_pca(u8 ch) return 0; }
+/* + * read_voltage from sensor on I2C bus + * We use average of 4 readings, waiting for 532us befor another reading + */ +#define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ + +static inline int read_voltage(void) +{ + int i, ret, voltage_read = 0; + u16 vol_mon; + + for (i = 0; i < NUM_READINGS; i++) { + ret = i2c_read(I2C_VOL_MONITOR_ADDR, + I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&vol_mon, 2); + if (ret) { + printf("VID: failed to read core voltage\n"); + return ret; + } + if (vol_mon & I2C_VOL_MONITOR_BUS_V_OVF) { + printf("VID: Core voltage sensor error\n"); + return -1; + } + debug("VID: bus voltage reads 0x%04x\n", vol_mon); + /* LSB = 4mv */ + voltage_read += (vol_mon >> I2C_VOL_MONITOR_BUS_V_SHIFT) * 4; + udelay(WAIT_FOR_ADC); + } + /* calculate the average */ + voltage_read /= NUM_READINGS; + + return voltage_read; +} + +static int adjust_vdd(ulong vdd_override) +{ + int re_enable = disable_interrupts(); + ccsr_gur_t __iomem *gur = + (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 fusesr; + u8 vid; + int vdd_target, vdd_last; + int existing_voltage, temp_voltage, voltage; /* all in 1/10 mV */ + int ret; + unsigned int orig_i2c_speed; + unsigned long vdd_string_override; + char *vdd_string; + static const uint16_t vdd[32] = { + 0, /* unused */ + 9875, /* 0.9875V */ + 9750, + 9625, + 9500, + 9375, + 9250, + 9125, + 9000, + 8875, + 8750, + 8625, + 8500, + 8375, + 8250, + 8125, + 10000, /* 1.0000V */ + 10125, + 10250, + 10375, + 10500, + 10625, + 10750, + 10875, + 11000, + 0, /* reserved */ + }; + struct vdd_drive { + u8 vid; + unsigned voltage; + }; + + ret = select_i2c_ch_pca(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + printf("VID: I2c failed to switch channel\n"); + ret = -1; + goto exit; + } + + /* get the voltage ID from fuse status register */ + fusesr = in_be32(&gur->dcfg_fusesr); + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_VID_MASK; + if (vid == FSL_CORENET_DCFG_FUSESR_VID_MASK) { + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; + } + vdd_target = vdd[vid]; + debug("VID:Reading from from fuse,vid=%x vdd is %dmV\n", + vid, vdd_target/10); + + /* check override variable for overriding VDD */ + vdd_string = getenv("b4qds_vdd_mv"); + if (vdd_override == 0 && vdd_string && + !strict_strtoul(vdd_string, 10, &vdd_string_override)) + vdd_override = vdd_string_override; + if (vdd_override >= 819 && vdd_override <= 1212) { + vdd_target = vdd_override * 10; /* convert to 1/10 mV */ + debug("VDD override is %lu\n", vdd_override); + } else if (vdd_override != 0) { + printf("Invalid value.\n"); + } + + if (vdd_target == 0) { + printf("VID: VID not used\n"); + ret = 0; + goto exit; + } + + /* + * Read voltage monitor to check real voltage. + * Voltage monitor LSB is 4mv. + */ + vdd_last = read_voltage(); + if (vdd_last < 0) { + printf("VID: abort VID adjustment\n"); + ret = -1; + goto exit; + } + + debug("VID: Core voltage is at %d mV\n", vdd_last); + ret = select_i2c_ch_pca(I2C_MUX_CH_DPM); + if (ret) { + printf("VID: I2c failed to switch channel to DPM\n"); + ret = -1; + goto exit; + } + + /* Round up to the value of step of Voltage regulator */ + voltage = roundup(vdd_target, ZM_STEP); + debug("VID: rounded up voltage = %d\n", voltage); + + /* lower the speed to 100kHz to access ZM7300 device */ + debug("VID: Setting bus speed to 100KHz if not already set\n"); + orig_i2c_speed = i2c_get_bus_speed(); + if (orig_i2c_speed != 100000) + i2c_set_bus_speed(100000); + + /* Read the existing level on board, if equal to requsted one, + no need to re-set */ + existing_voltage = zm_read_voltage(); + + /* allowing the voltage difference of one step 0.0125V acceptable */ + if ((existing_voltage >= voltage) && + (existing_voltage < (voltage + ZM_STEP))) { + debug("VID: voltage already set as requested,returning\n"); + ret = existing_voltage; + goto out; + } + debug("VID: Changing voltage for board from %dmV to %dmV\n", + existing_voltage/10, voltage/10); + + if (zm_disable_wp() < 0) { + ret = -1; + goto out; + } + /* Change Voltage: the change is done through all the steps in the + way, to avoid reset to the board due to power good signal fail + in big voltage change gap jump. + */ + if (existing_voltage > voltage) { + temp_voltage = existing_voltage - ZM_STEP; + while (temp_voltage >= voltage) { + ret = zm_write_voltage(temp_voltage); + if (ret == temp_voltage) { + temp_voltage -= ZM_STEP; + } else { + /* ZM7300 device failed to set + * the voltage */ + printf + ("VID:Stepping down vol failed:%dmV\n", + temp_voltage/10); + ret = -1; + goto out; + } + } + } else { + temp_voltage = existing_voltage + ZM_STEP; + while (temp_voltage < (voltage + ZM_STEP)) { + ret = zm_write_voltage(temp_voltage); + if (ret == temp_voltage) { + temp_voltage += ZM_STEP; + } else { + /* ZM7300 device failed to set + * the voltage */ + printf + ("VID:Stepping up vol failed:%dmV\n", + temp_voltage/10); + ret = -1; + goto out; + } + } + } + + if (zm_enable_wp() < 0) + ret = -1; + + /* restore the speed to 400kHz */ +out: debug("VID: Restore the I2C bus speed to %dKHz\n", + orig_i2c_speed/1000); + i2c_set_bus_speed(orig_i2c_speed); + if (ret < 0) + goto exit; + + ret = select_i2c_ch_pca(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + printf("VID: I2c failed to switch channel\n"); + ret = -1; + goto exit; + } + vdd_last = read_voltage(); + select_i2c_ch_pca(I2C_CH_DEFAULT); + + if (vdd_last > 0) + printf("VID: Core voltage %d mV\n", vdd_last); + else + ret = -1; + +exit: + if (re_enable) + enable_interrupts(); + return ret; +} + int configure_vsc3316_3308(void) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -697,6 +930,13 @@ int board_early_init_r(void) #ifdef CONFIG_SYS_DPAA_QBMAN setup_portals(); #endif + /* + * Adjust core voltage according to voltage ID + * This function changes I2C mux to channel 2. + */ + if (adjust_vdd(0) < 0) + printf("Warning: Adjusting core voltage failed\n"); + /* SerDes1 refclks need to be set again, as default clks * are not suitable for CPRI and onboard SGMIIs to work * simultaneously. diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index b248302..2357f96 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -82,6 +82,17 @@ #define IDT_SERDES1_ADDRESS 0x6E #define IDT_SERDES2_ADDRESS 0x6C
+/* Voltage monitor on channel 2*/ +#define I2C_MUX_CH_VOL_MONITOR 0xa +#define I2C_VOL_MONITOR_ADDR 0x40 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 + +#define CONFIG_ZM7300 +#define I2C_MUX_CH_DPM 0xa +#define I2C_DPM_ADDR 0x28 + #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH
Shaveta Leekha
