[PATCH 1/1] tools: binman: etype: Allow to replace 'NAME' in node names
This change allows to replace both 'SEQ' and 'NAME' keywords by respectively a sequence number and the name of the FDT to provide more flexibility in the node name for the device trees included in the FIT.
Signed-off-by: Paul HENRYS paul.henrys_ext@softathome.com --- tools/binman/etype/fit.py | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index e0c1ac08d8..b9ebc3afd0 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -732,6 +732,7 @@ class Entry_fit(Entry_section): # Generate nodes for each FDT for seq, fdt_fname in enumerate(self._fdts): node_name = node.name[1:].replace('SEQ', str(seq + 1)) + node_name = node_name.replace('NAME', fdt_fname) if self._fdt_dir: fname = os.path.join(self._fdt_dir, fdt_fname + '.dtb') else:
Hi Paul,
On Wed, 20 Nov 2024 at 03:40, Paul HENRYS paul.henrys_ext@softathome.com wrote:
This seems OK to me, but it would help to understand the motivation better. Can you expand this a bit?
-- 2.43.0
Please update the documentation (near the top of this file) and regenerate entries.rst
It also needs a test so that coverage passes (binman test -T)...
Hi Simon,
On 20/11/2024 14:35, Simon Glass wrote:
This Mail comes from Outside of SoftAtHome: Do not answer, click links or open attachments unless you recognize the sender and know the content is safe.
Hi Paul,
The rational behind this change is because some projects uses some kind of board data to look for the right config in a FIT image in U-Boot. The default sequence number (config-1, config-2...) does not make it easy to retrieve the right config in such a case. For instance, OpenWrt uses the script "scripts/mkits.sh" to create an ITS passed to mkimage, where the config node names can be customized when supporting multiple configs and typically uses the device tree name appended to "config-". The idea is thus to provide the flexibility in binman to use the traditional scheme with the sequence numbers (config-1, config-2...) or use NAME instead (e.g. config-myboard1, config-myboard2...) or a combination of both.
-- 2.43.0
Ok. I am going to update the documentation and add a test.
Regards, Paul
Paul HENRYS
