[U-Boot] [PATCH] blackfin: delete unused header files
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
.../include/asm/mach-common/bits/lockbox.h | 62 --------------- arch/blackfin/include/asm/mach-common/bits/sport.h | 89 ---------------------- 2 files changed, 151 deletions(-) delete mode 100644 arch/blackfin/include/asm/mach-common/bits/lockbox.h delete mode 100644 arch/blackfin/include/asm/mach-common/bits/sport.h
diff --git a/arch/blackfin/include/asm/mach-common/bits/lockbox.h b/arch/blackfin/include/asm/mach-common/bits/lockbox.h deleted file mode 100644 index 17d22ab..0000000 --- a/arch/blackfin/include/asm/mach-common/bits/lockbox.h +++ /dev/null @@ -1,62 +0,0 @@ -/* - * Lockbox/Security Masks - */ - -#ifndef __BFIN_PERIPHERAL_LOCKBOX__ -#define __BFIN_PERIPHERAL_LOCKBOX__ - -#ifndef __ASSEMBLY__ - -#include "bootrom.h" - -/* SESR argument structure. Expected to reside at 0xFF900018. */ -typedef struct SESR_args { - unsigned short usFlags; /* security firmware flags */ - unsigned short usIRQMask; /* interrupt mask */ - unsigned long ulMessageSize; /* message length in bytes */ - unsigned long ulSFEntryPoint; /* entry point of secure function */ - unsigned long ulMessagePtr; /* pointer to the buffer containing - the digital signature and message */ - unsigned long ulReserved1; /* reserved */ - unsigned long ulReserved2; /* reserved */ -} tSESR_args; - -/* Secure Entry Service Routine */ -static void (* const sesr)(void) = (void *)_BOOTROM_SESR; - -#endif - -/* SESR flags argument bitfields */ -#define SESR_FLAGS_STAY_AT_NMI 0x0000 -#define SESR_FLAGS_DROP_BELOW_NMI 0x0001 -#define SESR_FLAGS_NO_SF_DMA 0x0000 -#define SESR_FLAGS_DMA_SF_TO_RUN_DEST 0x0002 -#define SESR_FLAGS_USE_ADI_PUB_KEY 0x0000 -#define SESR_FLAGS_USE_CUST_PUB_KEY 0x0100 - -/* Bit masks for SECURE_SYSSWT */ -#define EMUDABL 0x00000001 /* Emulation Disable */ -#define RSTDABL 0x00000002 /* Reset Disable */ -#define L1IDABL 0x0000001c /* L1 Instruction Memory Disable */ -#define L1DADABL 0x000000e0 /* L1 Data Bank A Memory Disable */ -#define L1DBDABL 0x00000700 /* L1 Data Bank B Memory Disable */ -#define DMA0OVR 0x00000800 /* DMA0 Memory Access Override */ -#define DMA1OVR 0x00001000 /* DMA1 Memory Access Override */ -#define EMUOVR 0x00004000 /* Emulation Override */ -#define OTPSEN 0x00008000 /* OTP Secrets Enable */ -#define L2DABL 0x00070000 /* L2 Memory Disable */ - -/* Bit masks for SECURE_CONTROL */ -#define SECURE0 0x0001 /* SECURE 0 */ -#define SECURE1 0x0002 /* SECURE 1 */ -#define SECURE2 0x0004 /* SECURE 2 */ -#define SECURE3 0x0008 /* SECURE 3 */ - -/* Bit masks for SECURE_STATUS */ -#define SECMODE 0x0003 /* Secured Mode Control State */ -#define NMI 0x0004 /* Non Maskable Interrupt */ -#define AFVALID 0x0008 /* Authentication Firmware Valid */ -#define AFEXIT 0x0010 /* Authentication Firmware Exit */ -#define SECSTAT 0x00e0 /* Secure Status */ - -#endif diff --git a/arch/blackfin/include/asm/mach-common/bits/sport.h b/arch/blackfin/include/asm/mach-common/bits/sport.h deleted file mode 100644 index 88e7a5d..0000000 --- a/arch/blackfin/include/asm/mach-common/bits/sport.h +++ /dev/null @@ -1,89 +0,0 @@ -/* - * SPORT Masks - */ - -#ifndef __BFIN_PERIPHERAL_SPORT__ -#define __BFIN_PERIPHERAL_SPORT__ - -/* SPORTx_TCR1 Masks */ -#define TSPEN 0x0001 /* TX enable */ -#define ITCLK 0x0002 /* Internal TX Clock Select */ -#define TDTYPE 0x000C /* TX Data Formatting Select */ -#define DTYPE_NORM 0x0004 /* Data Format Normal */ -#define DTYPE_ULAW 0x0008 /* Compand Using u-Law */ -#define DTYPE_ALAW 0x000C /* Compand Using A-Law */ -#define TLSBIT 0x0010 /* TX Bit Order */ -#define ITFS 0x0200 /* Internal TX Frame Sync Select */ -#define TFSR 0x0400 /* TX Frame Sync Required Select */ -#define DITFS 0x0800 /* Data Independent TX Frame Sync Select */ -#define LTFS 0x1000 /* Low TX Frame Sync Select */ -#define LATFS 0x2000 /* Late TX Frame Sync Select */ -#define TCKFE 0x4000 /* TX Clock Falling Edge Select */ - -/* SPORTx_TCR2 Masks */ -#define SLEN 0x001F /* TX Word Length */ -#define TXSE 0x0100 /* TX Secondary Enable */ -#define TSFSE 0x0200 /* TX Stereo Frame Sync Enable */ -#define TRFST 0x0400 /* TX Right-First Data Order */ - -/* SPORTx_RCR1 Masks */ -#define RSPEN 0x0001 /* RX enable */ -#define IRCLK 0x0002 /* Internal RX Clock Select */ -#define RDTYPE 0x000C /* RX Data Formatting Select */ -#define DTYPE_NORM 0x0004 /* Data Format Normal */ -#define DTYPE_ULAW 0x0008 /* Compand Using u-Law */ -#define DTYPE_ALAW 0x000C /* Compand Using A-Law */ -#define RLSBIT 0x0010 /* RX Bit Order */ -#define IRFS 0x0200 /* Internal RX Frame Sync Select */ -#define RFSR 0x0400 /* RX Frame Sync Required Select */ -#define LRFS 0x1000 /* Low RX Frame Sync Select */ -#define LARFS 0x2000 /* Late RX Frame Sync Select */ -#define RCKFE 0x4000 /* RX Clock Falling Edge Select */ - -/* SPORTx_RCR2 Masks */ -#define SLEN 0x001F /* RX Word Length */ -#define RXSE 0x0100 /* RX Secondary Enable */ -#define RSFSE 0x0200 /* RX Stereo Frame Sync Enable */ -#define RRFST 0x0400 /* Right-First Data Order */ - -/* SPORTx_STAT Masks */ -#define RXNE 0x0001 /* RX FIFO Not Empty Status */ -#define RUVF 0x0002 /* RX Underflow Status */ -#define ROVF 0x0004 /* RX Overflow Status */ -#define TXF 0x0008 /* TX FIFO Full Status */ -#define TUVF 0x0010 /* TX Underflow Status */ -#define TOVF 0x0020 /* TX Overflow Status */ -#define TXHRE 0x0040 /* TX Hold Register Empty */ - -/* SPORTx_MCMC1 Masks */ -#define WSIZE 0xF000 /* Multichannel Window Size Field */ -#define WOFF 0x03FF /* Multichannel Window Offset Field */ - -/* SPORTx_MCMC2 Masks */ -#define MCCRM 0x0003 /* Multichannel Clock Recovery Mode */ -#define REC_BYPASS 0x0000 /* Bypass Mode (No Clock Recovery) */ -#define REC_2FROM4 0x0002 /* Recover 2 MHz Clock from 4 MHz Clock */ -#define REC_8FROM16 0x0003 /* Recover 8 MHz Clock from 16 MHz Clock */ -#define MCDTXPE 0x0004 /* Multichannel DMA Transmit Packing */ -#define MCDRXPE 0x0008 /* Multichannel DMA Receive Packing */ -#define MCMEN 0x0010 /* Multichannel Frame Mode Enable */ -#define FSDR 0x0080 /* Multichannel Frame Sync to Data Relationship */ -#define MFD 0xF000 /* Multichannel Frame Delay */ -#define MFD_0 0x0000 /* Multichannel Frame Delay = 0 */ -#define MFD_1 0x1000 /* Multichannel Frame Delay = 1 */ -#define MFD_2 0x2000 /* Multichannel Frame Delay = 2 */ -#define MFD_3 0x3000 /* Multichannel Frame Delay = 3 */ -#define MFD_4 0x4000 /* Multichannel Frame Delay = 4 */ -#define MFD_5 0x5000 /* Multichannel Frame Delay = 5 */ -#define MFD_6 0x6000 /* Multichannel Frame Delay = 6 */ -#define MFD_7 0x7000 /* Multichannel Frame Delay = 7 */ -#define MFD_8 0x8000 /* Multichannel Frame Delay = 8 */ -#define MFD_9 0x9000 /* Multichannel Frame Delay = 9 */ -#define MFD_10 0xA000 /* Multichannel Frame Delay = 10 */ -#define MFD_11 0xB000 /* Multichannel Frame Delay = 11 */ -#define MFD_12 0xC000 /* Multichannel Frame Delay = 12 */ -#define MFD_13 0xD000 /* Multichannel Frame Delay = 13 */ -#define MFD_14 0xE000 /* Multichannel Frame Delay = 14 */ -#define MFD_15 0xF000 /* Multichannel Frame Delay = 15 */ - -#endif
Masahiro Yamada
