[U-Boot] [PATCH v6 1/4] mx28: Let imx_get_mac_from_fuse be common for mx28
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: - Allow the MAC vendor to be overriden Changes since v4: - No changes Change since v3: - Add a note about the first two MAC addresses being from Freescale vendor. arch/arm/cpu/arm926ejs/mx28/mx28.c | 44 ++++++++++++++++++++++++++++++++++++ board/denx/m28evk/m28evk.c | 35 ---------------------------- 2 files changed, 44 insertions(+), 35 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 088c019..a25814e 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -214,6 +214,50 @@ int cpu_eth_init(bd_t *bis) } #endif
+static void __set_mac_vendor(char *mac) +{ + mac[0] = 0x00; + mac[1] = 0x04; /* Use FSL vendor MAC address by default */ +} + +void set_mac_vendor(char *mac) + __attribute__((weak, alias("__set_mac_vendor"))); + +#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP + +#define MXS_OCOTP_MAX_TIMEOUT 1000000 + +void imx_get_mac_from_fuse(char *mac) +{ + struct mx28_ocotp_regs *ocotp_regs = + (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; + uint32_t data; + + memset(mac, 0, 6); + + writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); + + if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, + MXS_OCOTP_MAX_TIMEOUT)) { + printf("MXS FEC: Can't get MAC from OCOTP\n"); + return; + } + + data = readl(&ocotp_regs->hw_ocotp_cust0); + + mac[2] = (data >> 24) & 0xff; + mac[3] = (data >> 16) & 0xff; + mac[4] = (data >> 8) & 0xff; + mac[5] = data & 0xff; + set_mac_vendor(mac); +} +#else +void imx_get_mac_from_fuse(char *mac) +{ + memset(mac, 0, 6); +} +#endif + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index fcee046..005446a 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -178,39 +178,4 @@ int board_eth_init(bd_t *bis) return ret; }
-#ifdef CONFIG_M28_FEC_MAC_IN_OCOTP - -#define MXS_OCOTP_MAX_TIMEOUT 1000000 -void imx_get_mac_from_fuse(char *mac) -{ - struct mx28_ocotp_regs *ocotp_regs = - (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; - uint32_t data; - - memset(mac, 0, 6); - - writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); - - if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, - MXS_OCOTP_MAX_TIMEOUT)) { - printf("MXS FEC: Can't get MAC from OCOTP\n"); - return; - } - - data = readl(&ocotp_regs->hw_ocotp_cust0); - - mac[0] = 0x00; - mac[1] = 0x04; - mac[2] = (data >> 24) & 0xff; - mac[3] = (data >> 16) & 0xff; - mac[4] = (data >> 8) & 0xff; - mac[5] = data & 0xff; -} -#else -void imx_get_mac_from_fuse(char *mac) -{ - memset(mac, 0, 6); -} -#endif - #endif
MX28 has two built-in FECs (Fast Ethernet Controller).
OCOTP register can be used to only store 4 bytes of MAC addresses.
In order to workaround this limitation, let the MAC address of FEC1 be the FEC0 address plus one.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: No changes. Newly introduced on this series
arch/arm/cpu/arm926ejs/mx28/mx28.c | 8 ++++++-- drivers/net/fec_mxc.c | 16 ++++++++++++++++ drivers/net/fec_mxc.h | 1 + 3 files changed, 23 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index a25814e..79b4001 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -227,7 +227,7 @@ void set_mac_vendor(char *mac)
-void imx_get_mac_from_fuse(char *mac) +void mx28_get_mac_from_fuse(int dev_id, char *mac) { struct mx28_ocotp_regs *ocotp_regs = (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; @@ -249,10 +249,14 @@ void imx_get_mac_from_fuse(char *mac) mac[3] = (data >> 16) & 0xff; mac[4] = (data >> 8) & 0xff; mac[5] = data & 0xff; + /* Assume that FEC1 MAC address is MAC0 + 1 */ + if (dev_id == 1) + mac[5]+= 1; + set_mac_vendor(mac); } #else -void imx_get_mac_from_fuse(char *mac) +void mx28_get_mac_from_fuse(int dev_id, char *mac) { memset(mac, 0, 6); } diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index b05a4c0..a6bf597 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -345,11 +345,20 @@ static void fec_rbd_clean(int last, struct fec_bd *pRbd) writew(0, &pRbd->data_length); }
+#ifndef CONFIG_MX28 static int fec_get_hwaddr(struct eth_device *dev, unsigned char *mac) { imx_get_mac_from_fuse(mac); return !is_valid_ether_addr(mac); } +#else +static int mx28_fec_get_hwaddr(struct eth_device *dev, int dev_id, + unsigned char *mac) +{ + mx28_get_mac_from_fuse(dev_id, mac); + return !is_valid_ether_addr(mac); +} +#endif
static int fec_set_hwaddr(struct eth_device *dev) { @@ -812,10 +821,17 @@ static int fec_probe(bd_t *bd, int dev_id, int phy_id, uint32_t base_addr)
eth_register(edev);
+#ifndef CONFIG_MX28 if (fec_get_hwaddr(edev, ethaddr) == 0) { debug("got MAC address from fuse: %pM\n", ethaddr); memcpy(edev->enetaddr, ethaddr, 6); } +#else + if (mx28_fec_get_hwaddr(edev, dev_id, ethaddr) == 0) { + debug("got MAC%d address from fuse: %pM\n", dev_id, ethaddr); + memcpy(edev->enetaddr, ethaddr, 6); + } +#endif
return ret;
diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 8b26645..e2cfe4a 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -33,6 +33,7 @@ #define __FEC_MXC_H
void imx_get_mac_from_fuse(unsigned char *mac); +void mx28_get_mac_from_fuse(int dev_id, unsigned char *mac);
/** * Layout description of the FEC
- /* Assume that FEC1 MAC address is MAC0 + 1 */
- if (dev_id == 1)
mac[5]+= 1;
No, please don't ... user might want to do this the other way around so just give him the freedom (and you're missing space before +) :) You can move exactly this code to the default implementation of mx28_mac_adjust().
- set_mac_vendor(mac);
unsigned char *mac)
- mx28_get_mac_from_fuse(dev_id, mac);
- return !is_valid_ether_addr(mac);
+} +#endif
eth_register(edev);
- if (mx28_fec_get_hwaddr(edev, dev_id, ethaddr) == 0) {
return ret;
- Layout description of the FEC
M
Hi Fabio,
but imx_get_mac_from_fuse() is common to all IMX SOCs. Why do we need another name only for MX28 ? I think it is better to adjust imx_get_mac_from_fuse() to allow a second parameter (dev_id), that can be ignored in other SOCs implementations.
- if (dev_id == 1)
mac[5]+= 1;
Should be not better that the additional mac is computed by the (weak) board function ? Then it is responsibility of the board and his maintainer to change (if needed) the MAC for the second interface.
Best regards, Stefano Babic
Let dram_init function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: - Change return value on dram_init() Changes since v4: - Call mx28_dram_init from m28evk.c Changes since v3: - Rename dram_init to mx28_dram_init arch/arm/cpu/arm926ejs/mx28/mx28.c | 21 +++++++++++++++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 2 ++ board/denx/m28evk/m28evk.c | 18 +----------------- 3 files changed, 24 insertions(+), 17 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 79b4001..722efbf 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -262,6 +262,27 @@ void mx28_get_mac_from_fuse(int dev_id, char *mac) } #endif
+#define HW_DIGCTRL_SCRATCH0 0x8001c280 +#define HW_DIGCTRL_SCRATCH1 0x8001c290 +int mx28_dram_init(void) +{ + uint32_t sz[2]; + + sz[0] = readl(HW_DIGCTRL_SCRATCH0); + sz[1] = readl(HW_DIGCTRL_SCRATCH1); + + if (sz[0] != sz[1]) { + printf("MX28:\n" + "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" + "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" + "verify these two registers contain valid RAM size!\n"); + hang(); + } + + gd->ram_size = sz[0]; + return 0; +} + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index be1f7db..f101494 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -35,4 +35,6 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, const unsigned int iomux_size); #endif
+int mx28_dram_init(void); + #endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index 005446a..53df476 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -70,25 +70,9 @@ int board_init(void) return 0; }
-#define HW_DIGCTRL_SCRATCH0 0x8001c280 -#define HW_DIGCTRL_SCRATCH1 0x8001c290 int dram_init(void) { - uint32_t sz[2]; - - sz[0] = readl(HW_DIGCTRL_SCRATCH0); - sz[1] = readl(HW_DIGCTRL_SCRATCH1); - - if (sz[0] != sz[1]) { - printf("MX28:\n" - "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" - "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" - "verify these two registers contain valid RAM size!\n"); - hang(); - } - - gd->ram_size = sz[0]; - return 0; + return mx28_dram_init(); }
#ifdef CONFIG_CMD_MMC
Changes since v5:
Changes since v4:
Changes since v3:
- uint32_t sz[2];
printf("MX28:\n"
hang();
- uint32_t sz[2];
printf("MX28:\n"
hang();
- return mx28_dram_init();
Acked-by: Marek Vasut marek.vasut@gmail.com
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through the FEC interface.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- - For correct operation of saving environment variables into the SD card, the following patch is needed: http://lists.denx.de/pipermail/u-boot/2011-November/111448.html Changes since v5: - Fix tab vs spaces on mx28evk.h - Change return value on dram_init() Changes since v4: - No changes Changes since v3: - Fix Copyright in mx28evk.h - Call mx28_dram_init from dram_init Changes since v2: - Generate the patch again due to error in applying unrelated changes Changes since v1: - Read the MAC from fuses - Use tabs instead of space in u-boot.bd - Use puts instead of print - Factor out mac reading function - Factor out ddr size calculation function - Use GENERATED_GBL_DATA_SIZE - Protect CONFIG_ENV_IS_IN_MMC MAINTAINERS | 1 + board/freescale/mx28evk/Makefile | 49 ++++++++++ board/freescale/mx28evk/iomux.c | 138 +++++++++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 169 +++++++++++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ boards.cfg | 1 + include/configs/mx28evk.h | 176 +++++++++++++++++++++++++++++++++++++ 7 files changed, 548 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
diff --git a/MAINTAINERS b/MAINTAINERS index a56ca10..72e1089 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -639,6 +639,7 @@ Kristoffer Ericson kristoffer.ericson@gmail.com Fabio Estevam fabio.estevam@freescale.com
mx25pdk i.MX25 + mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53 diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile new file mode 100644 index 0000000..7459107 --- /dev/null +++ b/board/freescale/mx28evk/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := mx28evk.o +else +COBJS := iomux.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +all: $(ALL) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx28evk/iomux.c b/board/freescale/mx28evk/iomux.c new file mode 100644 index 0000000..904e3f3 --- /dev/null +++ b/board/freescale/mx28evk/iomux.c @@ -0,0 +1,138 @@ +/* + * Freescale MX28EVK IOMUX setup + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* DUART */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* MMC0 */ + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT | + (MXS_PAD_8MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + MX28_PAD_SSP0_SCK__SSP0_SCK | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + /* write protect */ + MX28_PAD_SSP1_SCK__GPIO_2_12, + /* MMC0 slot power enable */ + MX28_PAD_PWM3__GPIO_3_28 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC0 */ + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + /* FEC0 Enable */ + MX28_PAD_SSP1_DATA3__GPIO_2_15 | + (MXS_PAD_12MA | MXS_PAD_3V3), + /* FEC0 Reset */ + MX28_PAD_ENET0_RX_CLK__GPIO_4_13 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC1 */ + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, +}; + +void board_init_ll(void) +{ + mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c new file mode 100644 index 0000000..0d04d44 --- /dev/null +++ b/board/freescale/mx28evk/mx28evk.c @@ -0,0 +1,169 @@ +/* + * Freescale MX28EVK board + * + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.c: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK2, 96000, 0); + + return 0; +} + +int dram_init(void) +{ + return mx28_dram_init(); +} + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_CMD_MMC +static int mx28evk_mmc_wp(int id) +{ + if (id != 0) { + printf("MXS MMC: Invalid card selected (card id = %d)\n", id); + return 1; + } + + return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12); +} + +int board_mmc_init(bd_t *bis) +{ + /* Configure WP as input */ + gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12); + + /* Configure MMC0 Power Enable */ + gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0); + + return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp); +} +#endif + +#ifdef CONFIG_CMD_NET + +#define MII_OPMODE_STRAP_OVERRIDE 0x16 +#define MII_PHY_CTRL1 0x1e +#define MII_PHY_CTRL2 0x1f + +int fecmxc_mii_postcall(int phy) +{ + miiphy_write("FEC1", phy, MII_BMCR, 0x9000); + miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202); + if (phy == 3) + miiphy_write("FEC1", 3, MII_PHY_CTRL2, 0x8180); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct eth_device *dev; + int ret; + + ret = cpu_eth_init(bis); + + /* MX28EVK uses ENET_CLK PAD to drive FEC clock */ + writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN, + &clkctrl_regs->hw_clkctrl_enet); + + /* Power-on FECs */ + gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0); + + /* Reset FEC PHYs */ + gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0); + udelay(200); + gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1); + + ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC0\n"); + return ret; + } + + ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC1\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC0"); + if (!dev) { + puts("FEC MXS: Unable to get FEC0 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC0 mii postcall\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC1"); + if (!dev) { + puts("FEC MXS: Unable to get FEC1 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC1 mii postcall\n"); + return ret; + } + + return ret; +} + +#endif diff --git a/board/freescale/mx28evk/u-boot.bd b/board/freescale/mx28evk/u-boot.bd new file mode 100644 index 0000000..c60615a --- /dev/null +++ b/board/freescale/mx28evk/u-boot.bd @@ -0,0 +1,14 @@ +sources { + u_boot_spl="spl/u-boot-spl.bin"; + u_boot="u-boot.bin"; +} + +section (0) { + load u_boot_spl > 0x0000; + load ivt (entry = 0x0014) > 0x8000; + hab call 0x8000; + + load u_boot > 0x40000100; + load ivt (entry = 0x40000100) > 0x8000; + hab call 0x8000; +} diff --git a/boards.cfg b/boards.cfg index 1e5b3e0..e859024 100644 --- a/boards.cfg +++ b/boards.cfg @@ -160,6 +160,7 @@ zmx25 arm arm926ejs zmx25 syteco imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 m28evk arm arm926ejs - denx mx28 +mx28evk arm arm926ejs - freescale mx28 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap1610h2 arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h new file mode 100644 index 0000000..5b8a1bf --- /dev/null +++ b/include/configs/mx28evk.h @@ -0,0 +1,176 @@ +/* + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.h: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/regs-base.h> + +/* + * SoC configurations + */ +#define CONFIG_MX28 /* i.MX28 SoC */ +#define CONFIG_MXS_GPIO /* GPIO control */ +#define CONFIG_SYS_HZ 1000 /* Ticks per second */ + +#define CONFIG_MACH_TYPE MACH_TYPE_MX28EVK + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_ARCH_MISC_INIT + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_NO_CPU_SUPPORT_CODE +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x40000000 /* Max 1 GB RAM */ +#define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ +#define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ +#define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */ +#define CONFIG_SYS_MEMTEST_END 0x40400000 /* 4 MB RAM test */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +/* Point initial SP in SRAM so SPL can use it too. */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x00002000 +#define CONFIG_SYS_INIT_RAM_SIZE (128 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* + * We need to sacrifice first 4 bytes of RAM here to avoid triggering some + * strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot + * binary. In case there was more of this mess, 0x100 bytes are skipped. + */ +#define CONFIG_SYS_TEXT_BASE 0x40000100 + +#define CONFIG_ENV_OVERWRITE +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "MX28EVK U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Serial Driver + */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * MMC Driver + */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (256 * 1024) +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_CMD_SAVEENV +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MXS_MMC +#endif + +/* + * Ethernet on SOC (FEC) + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_ETHPRIME "FEC0" +#define CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_MX28_FEC_MAC_IN_OCOTP +#endif + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTCOMMAND "run bootcmd_net" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Extra Environments + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console_fsl=console=ttyAM0" \ + "console_mainline=console=ttyAMA0" \ + "netargs=setenv bootargs console=${console_mainline}" \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot}\0" \ + "bootcmd_net=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#endif /* __CONFIG_H */
Changes since v4:
- No changes
Changes since v3:
Changes since v2:
Changes since v1:
mx25pdk i.MX25
- mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53
- $(call cmd_link_o_target, $(OBJS))
+all: $(ALL)
- Freescale MX28EVK IOMUX setup
- Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com
- on behalf of DENX Software Engineering GmbH
- project.
- /* DUART */
- MX28_PAD_PWM0__DUART_RX,
- MX28_PAD_PWM1__DUART_TX,
- /* MMC0 */
- MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT |
- MX28_PAD_SSP0_SCK__SSP0_SCK |
- /* write protect */
- MX28_PAD_SSP1_SCK__GPIO_2_12,
- /* MMC0 slot power enable */
- MX28_PAD_PWM3__GPIO_3_28 |
- /* FEC0 */
- MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET,
- /* FEC0 Enable */
- MX28_PAD_SSP1_DATA3__GPIO_2_15 |
- /* FEC0 Reset */
- MX28_PAD_ENET0_RX_CLK__GPIO_4_13 |
- /* FEC1 */
- MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET,
- /* EMI */
- MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI,
- mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup));
- Freescale MX28EVK board
- (C) Copyright 2011 Freescale Semiconductor, Inc.
- Author: Fabio Estevam fabio.estevam@freescale.com
- Based on m28evk.c:
- project.
- Functions
- /* IO0 clock at 480MHz */
- mx28_set_ioclk(MXC_IOCLK0, 480000);
- /* IO1 clock at 480MHz */
- mx28_set_ioclk(MXC_IOCLK1, 480000);
- /* SSP0 clock at 96MHz */
- mx28_set_sspclk(MXC_SSPCLK0, 96000, 0);
- /* SSP2 clock at 96MHz */
- mx28_set_sspclk(MXC_SSPCLK2, 96000, 0);
- /* Adress of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
- if (id != 0) {
return 1;
- return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12);
- /* Configure WP as input */
- gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12);
- /* Configure MMC0 Power Enable */
- gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0);
- return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp);
+} +#endif
- miiphy_write("FEC1", phy, MII_BMCR, 0x9000);
- miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202);
- if (phy == 3)
- struct mx28_clkctrl_regs *clkctrl_regs =
- struct eth_device *dev;
- int ret;
- ret = cpu_eth_init(bis);
- /* MX28EVK uses ENET_CLK PAD to drive FEC clock */
- writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN,
- /* Power-on FECs */
- gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0);
- /* Reset FEC PHYs */
- gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0);
- udelay(200);
- gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1);
- ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE);
- if (ret) {
return ret;
- ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE);
- if (ret) {
return ret;
- dev = eth_get_dev_by_name("FEC0");
- if (!dev) {
return -EINVAL;
- ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall);
- if (ret) {
return ret;
- dev = eth_get_dev_by_name("FEC1");
- if (!dev) {
return -EINVAL;
- if (ret) {
return ret;
- return ret;
- u_boot_spl="spl/u-boot-spl.bin";
- u_boot="u-boot.bin";
+section (0) {
- load u_boot_spl > 0x0000;
- load ivt (entry = 0x0014) > 0x8000;
- hab call 0x8000;
- load u_boot > 0x40000100;
- load ivt (entry = 0x40000100) > 0x8000;
- hab call 0x8000;
diff --git
- Based on m28evk.h:
- SoC configurations
- SPL
- U-Boot Commands
- Memory configurations
malloc */
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
- We need to sacrifice first 4 bytes of RAM here to avoid triggering some
- strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot
- binary. In case there was more of this mess, 0x100 bytes are skipped.
- U-Boot general configurations
- (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
- Serial Driver
- MMC Driver
- Ethernet on SOC (FEC)
- Boot Linux
- Extra Environments
- "console_fsl=console=ttyAM0" \
- "console_mainline=console=ttyAMA0" \
- "netargs=setenv bootargs console=${console_mainline}" \
"root=/dev/nfs " \
- "bootcmd_net=echo Booting from net ...; " \
"run netargs; " \
Hi Stefano,
Does the mx28evk patch series look fine now?
Regards,
Fabio Estevam
On 28/12/2011 13:20, Fabio Estevam wrote:
Hi Stefano,
Hi Fabio,
there are still open answers from me and Marek for the first patch:
My main concern is that I dislike to have a new function name only for the MX.28, and I would like to maintain the same set of functions for all i.MX SOCs. The rest of the patchset is ok for me, I will send also my Ack.
Hi Stefano,
On Wed, Dec 28, 2011 at 10:36 AM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
I thought that v8 took care of your concern: http://marc.info/?l=u-boot&m=132440146104071&w=2
Please let me know if you still would like me to rework this patch.
Regards,
Fabio Estevam
Hi Stefano,
Here is the latest series:
1/4: http://patchwork.ozlabs.org/patch/132438/
2/4: http://patchwork.ozlabs.org/patch/132447/
3/4: http://patchwork.ozlabs.org/patch/132440/
4/4: http://patchwork.ozlabs.org/patch/132441/
Regards,
Fabio Estevam
On 28/12/2011 13:46, Fabio Estevam wrote:
Hi Stefano,
Hi Fabio,
Sorry, I was not in CC and I missed it.
No, you fixed exactly the point ! I will merge it now.
Thanks, Stefano Babic
Acked-by: Stefano Babic sbabic@denx.de
Changes since v5:
Changes since v4:
- No changes
Change since v3:
- mac[0] = 0x00;
- mac[1] = 0x04; /* Use FSL vendor MAC address by default */
- __attribute__((weak, alias("__set_mac_vendor")));
- uint32_t data;
return;
+} +#endif
- uint32_t data;
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
-} -#endif
#endif
It's good, but why not make it completely generic -- like mx28_adjust_mac() -- so the users can for example change the last bit of the mac depending on the NIC that's used (FEC0 or FEC1). I think I proposed that. It's only a matter of adding a parameter (nic #) and renaming it :)
M
[snip]
[snip]
What is stored in MX28EVK CUST1 fuse? It seems to be CUST0 increased by one. So maybe we should read it from there for FEC1?
It would be nice to have very generic fuse reading function that could be used to read a serial number or similar user data. I will work this out if you don't like to do it. I'm quite busy now so it might take a week or two.
-- Veli-Pekka Peltola
[snip]
[snip]
The release'll be early xmas present from Wolfgang, so you have those two weeks no problem ;-) Please go ahead and do it.
Thanks!
M
Fabio Estevam
Stefano Babic
Veli-Pekka Peltola
