[PATCH] rockchip: Fix spl mmc boot device ofpath
Linux v5.7-rc1 dts(i) sync has changed the sdmmc node from dwmmc@fe320000 to mmc@fe320000 and this ofpath is being used in rockchip spl bootdevice code.
So, update the ofpath with a new node name.
Fixes: 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux" Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-rockchip/rk3399/rk3399.c | 4 ++-- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 09b0d6e..4fda93b 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -28,7 +28,7 @@ DECLARE_GLOBAL_DATA_PTR; const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/sdhci@fe330000", [BROM_BOOTSOURCE_SPINOR] = "/spi@ff1d0000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@fe320000", + [BROM_BOOTSOURCE_SD] = "/mmc@fe320000", };
static struct mm_region rk3399_mem_map[] = { @@ -176,7 +176,7 @@ const char *spl_decode_boot_device(u32 boot_device) u32 boot_device; const char *ofpath; } spl_boot_devices_tbl[] = { - { BOOT_DEVICE_MMC1, "/dwmmc@fe320000" }, + { BOOT_DEVICE_MMC1, "/mmc@fe320000" }, { BOOT_DEVICE_MMC2, "/sdhci@fe330000" }, { BOOT_DEVICE_SPI, "/spi@ff1d0000" }, }; diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 561579d..f7f08ae 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -77,7 +77,7 @@ static int setup_boottargets(void) }
/* - * Only run, if booting from mmc1 (i.e. /dwmmc@fe320000) and + * Only run, if booting from mmc1 (i.e. /mmc@fe320000) and * only consider cases where the default boot-order first * tries to boot from mmc0 (eMMC) and then from mmc1 * (i.e. external SD). @@ -85,7 +85,7 @@ static int setup_boottargets(void) * In other words: the SD card will be moved to earlier in the * order, if U-Boot was also loaded from the SD-card. */ - if (!strcmp(boot_device, "/dwmmc@fe320000")) { + if (!strcmp(boot_device, "/mmc@fe320000")) { char *mmc0, *mmc1;
debug("%s: booted from SD-Card\n", __func__);
sunilï¼ amarulasolutions.com
