[U-Boot] [PATCH] clk: uniphier: add ethernet clock control support
Add clock control for ethernet controller on each SoC.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/clk/uniphier/clk-uniphier-sys.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/clk/uniphier/clk-uniphier-sys.c b/drivers/clk/uniphier/clk-uniphier-sys.c index c852c78..0230a18 100644 --- a/drivers/clk/uniphier/clk-uniphier-sys.c +++ b/drivers/clk/uniphier/clk-uniphier-sys.c @@ -21,7 +21,10 @@ const struct uniphier_clk_data uniphier_pxs2_sys_clk_data[] = { defined(CONFIG_ARCH_UNIPHIER_PRO4) || defined(CONFIG_ARCH_UNIPHIER_PRO5) ||\ defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) UNIPHIER_LD4_SYS_CLK_NAND(2), + UNIPHIER_CLK_GATE_SIMPLE(6, 0x2104, 12), /* ether (Pro4, PXs2) */ + UNIPHIER_CLK_GATE_SIMPLE(7, 0x2104, 5), /* ether-gb (Pro4) */ UNIPHIER_CLK_GATE_SIMPLE(8, 0x2104, 10), /* stdmac */ + UNIPHIER_CLK_GATE_SIMPLE(10, 0x2260, 0), /* ether-phy (Pro4) */ UNIPHIER_CLK_GATE_SIMPLE(12, 0x2104, 6), /* gio (Pro4, Pro5) */ UNIPHIER_CLK_GATE_SIMPLE(14, 0x2104, 16), /* usb30 (Pro4, Pro5, PXs2) */ UNIPHIER_CLK_GATE_SIMPLE(15, 0x2104, 17), /* usb31 (Pro4, Pro5, PXs2) */ @@ -34,6 +37,7 @@ const struct uniphier_clk_data uniphier_pxs2_sys_clk_data[] = { const struct uniphier_clk_data uniphier_ld20_sys_clk_data[] = { #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) UNIPHIER_LD11_SYS_CLK_NAND(2), + UNIPHIER_CLK_GATE_SIMPLE(6, 0x210c, 6), /* ether */ UNIPHIER_CLK_GATE_SIMPLE(8, 0x210c, 8), /* stdmac */ UNIPHIER_CLK_GATE_SIMPLE(14, 0x210c, 14), /* usb30 (LD20) */ UNIPHIER_CLK_GATE_SIMPLE(16, 0x210c, 12), /* usb30-phy0 (LD20) */ @@ -45,6 +49,8 @@ const struct uniphier_clk_data uniphier_ld20_sys_clk_data[] = { const struct uniphier_clk_data uniphier_pxs3_sys_clk_data[] = { #if defined(CONFIG_ARCH_UNIPHIER_PXS3) UNIPHIER_LD11_SYS_CLK_NAND(2), + UNIPHIER_CLK_GATE_SIMPLE(6, 0x210c, 9), /* ether0 */ + UNIPHIER_CLK_GATE_SIMPLE(7, 0x210c, 10), /* ether1 */ UNIPHIER_CLK_GATE_SIMPLE(12, 0x210c, 4), /* usb30 (gio0) */ UNIPHIER_CLK_GATE_SIMPLE(13, 0x210c, 5), /* usb31-0 (gio1) */ UNIPHIER_CLK_GATE_SIMPLE(14, 0x210c, 6), /* usb31-1 (gio1-1) */
2018-04-18 10:05 GMT+09:00 Kunihiko Hayashi hayashi.kunihiko@socionext.com:
Applied to u-boot-uniphier. Thanks!
Kunihiko Hayashi
Masahiro Yamada
