[U-Boot] GCC 7.x vs. C++ comments
Tom,
I recently ran a local buildman with a came across these:
cc -Wp,-MD,tools/.gen_eth_addr.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include ./include/compiler.h -idirafterinclude -idirafter./arch/arm/include -I./scripts/dtc/libfdt -I./tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -o tools/gen_eth_addr tools/gen_eth_addr.c tools/gen_eth_addr.c:1:1: warning: C++ style comments are not allowed in ISO C90 // SPDX-License-Identifier: GPL-2.0+ ^ tools/gen_eth_addr.c:1:1: warning: (this will be reported only once per input file) cc -Wp,-MD,tools/.gen_ethaddr_crc.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include ./include/compiler.h -idirafterinclude -idirafter./arch/arm/include -I./scripts/dtc/libfdt -I./tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -c -o tools/gen_ethaddr_crc.o tools/gen_ethaddr_crc.c tools/gen_ethaddr_crc.c:1:1: warning: C++ style comments are not allowed in ISO C90 // SPDX-License-Identifier: GPL-2.0+ ^ tools/gen_ethaddr_crc.c:1:1: warning: (this will be reported only once per input file) echo "#include <../lib/crc8.c>" >tools/lib/crc8.c cc -Wp,-MD,tools/lib/.crc8.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include ./include/compiler.h -idirafterinclude -idirafter./arch/arm/include -I./scripts/dtc/libfdt -I./tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -c -o tools/lib/crc8.o tools/lib/crc8.c In file included from tools/lib/crc8.c:1:0: ./tools/../lib/crc8.c:1:1: warning: C++ style comments are not allowed in ISO C90 // SPDX-License-Identifier: GPL-2.0+ ^
The system compiler was a
Using built-in specs. COLLECT_GCC=cc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.9/lto-wrapper Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Debian 4.9.2-10+deb8u1' --with-bugurl=file:///usr/share/doc/gcc-4.9/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.9 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.9 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.9-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --with-arch-32=i586 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Thread model: posix gcc version 4.9.2 (Debian 4.9.2-10+deb8u1)
What’s your preferred solution: (a) change these comments (b) change our Makefiles to let GCC know that we are compiling gnu99/C99?
Neither solution is too appealing to me, so I am asking...
Thanks, Philipp.
On Wed, May 09, 2018 at 10:46:10AM +0200, Dr. Philipp Tomsich wrote:
Tom,
Lets go with (b) which I guess what a more modern toolchain defaults to anyhow. Thanks!
Dear Tom,
I disagree. UI-Boot always discouraged the use of C++ comments, see for example bullet # 5 at [1]. We should clearly fix the comments, please.
[1] http://www.denx.de/wiki/U-Boot/Coding
On Wed, May 09, 2018 at 01:38:37PM +0200, Wolfgang Denk wrote:
Dear Tom,
We should go and update [1] to note some special exemptions to the rule. I see you missed out on the SPDX thread over here: https://lists.denx.de/pipermail/u-boot/2018-May/327544.html and repeat myself, I see it as more worthwhile to (a) follow the kernel in this area (for both tooling and consistency and ease of development for our overlapping community) (b) save space (in just about every conversion we went from 2 lines to 1 line). Thanks!
Dear Tom,
I'm not happy about this.
Marek already said what was on my mind, and got ignored. Would it have changed anything if I had posted another complaint?
I'm doing now, and apparently I get ignored, too. So what exactly is your argument?
OK, so you decided, and any additional discussion is futile...
On Wed, May 09, 2018 at 02:46:54PM +0200, Wolfgang Denk wrote:
Dear Tom,
Ignored, no. Counts as a veto? No. And if you had chimed in too, I don't know if that would have gotten anyone else to also chime in. Looking over the thread again there's two yes votes, two no votes, two people that chimed in on the thread but didn't express a yes or no to the change, and then no one else has said anything. The main thing I see currently is a whole lot of ambivalence.
It's not futile, but here's as best I can tell, the arguments: Against Linux Kernel style SPDX tags: - Don't like // style comments - Visually inconsistent / jarring
For Linux Kernel style SPDX tags: - Has higher visibility. - Has tooling to enforce correctly formatted tags. - Shorter (enforced as a single line comment means we don't have people spacing around it). - Consistent expectations for our overlapping developer community.
Things that could be taken, without changing overall formatting: - Logic operators for exceptions/dual-license/etc
If people speak up against the change now that we've done it, we could revert and then add in the "LICENSE-A OR LICENSE-B" change. Thanks!
Dear Tom,
Although I am ambivalent to the underlying discussion, I have strong opinions regarding the language/standard-compliance...
My vote goes to C++ comments and upgrading the language standard to C99 (or rather gnu99, as our code uses extensions). This will (at least somewhat) match how the default C compliance level in GCC has evolved over the GCC 6 through GCC 8 release cycles.
And while we’re at it, we should allow "for (int i = 0; …”-style C99 declaration of loop iterations within the loop-head.
spacing around it).
-- Tom
Dear Tom,
This does not really convince me.
IMO it makes no sense to blow up mailing list traffic with extensive voting for such things. Marek said everything that needed to be said, and repeating it would IMO not add any weight to it. If you really want a poll including more people, then explicitly start one - but please not on the mailing list, at least not fuch such details.
I think this argument is wrong from the start. This is not about "Linux Kernel style SPDX tags". There is two different topics, which are actually independent, and should be treated as such:
- Linux Kernel style SPDX tags, or rather more modern SPDX tags including the needed operators to deal with exceptions, multiple licenses, etc. When I invented the SPDX tags I did not foresee this need (my fault), but I'm still proud that U-Boot introduced this mechanism at all.
Yes, it is necessary to adapt the new developments in this area.
- Comment style. This is just a matter of coding style and preferences. Whether you use C comments (single line or multi-line) or C++ comments does not make any difference technically.
U-Boot has been discouraging the use of C++ comments for 18 years, and I still see no good reason to change this. [And yes, we also have the rule not to meddle with code copied from other projects.]
- Against existing coding style.
??? I can't parse this. In which way has
"higher visibility" than
/* SPDX-License-Identifier: GPL-2.0+ */
or even
/* * SPDX-License-Identifier: GPL-2.0+ */
[IMO, the last form is the most visible one.]
And since when do we care about a single line of white space or two when it comes to consistency or readability?
Come on, this argument is really lame.
Please explain? Who associates SPDX tags with C++ comments? This is silly. We don't use these in Makefiles, or in shell scripts, or in ...
And when talking about consistency - what about this in the current Linux Kernel tree:
arch/x86/kernel/apic/apic_common.c: * SPDX-License-Identifier: GPL-2.0 arch/s390/tools/gen_opcode_table.c:/* SPDX-License-Identifier: GPL-2.0 */ arch/arm64/crypto/sha3-ce-glue.c:/* SPDX-License-Identifier: GPL-2.0 */ arch/arm64/crypto/sha512-ce-glue.c:/* SPDX-License-Identifier: GPL-2.0 */ arch/riscv/kernel/ftrace.c:/* SPDX-License-Identifier: GPL-2.0 */ arch/riscv/kernel/module-sections.c:/* SPDX-License-Identifier: GPL-2.0 drivers/tty/hvc/hvc_riscv_sbi.c:/* SPDX-License-Identifier: GPL-2.0 */ drivers/memory/brcmstb_dpfe.c: * SPDX-License-Identifier: GPL-2.0 drivers/soc/amlogic/meson-mx-socinfo.c: * SPDX-License-Identifier: GPL-2.0+ drivers/soc/amlogic/meson-gx-pwrc-vpu.c: * SPDX-License-Identifier: GPL-2.0+ drivers/soc/amlogic/meson-gx-socinfo.c: * SPDX-License-Identifier: GPL-2.0+ drivers/i2c/busses/i2c-sprd.c: * SPDX-License-Identifier: (GPL-2.0+ OR MIT) drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c: * SPDX-License-Identifier: (GPL-2.0+ or MIT) drivers/pinctrl/meson/pinctrl-meson-axg.c: * SPDX-License-Identifier: (GPL-2.0+ or MIT) drivers/virt/vboxguest/vboxguest_core.c:/* SPDX-License-Identifier: (GPL-2.0 OR CDDL-1.0) */ drivers/virt/vboxguest/vboxguest_linux.c:/* SPDX-License-Identifier: GPL-2.0 */ drivers/virt/vboxguest/vboxguest_utils.c:/* SPDX-License-Identifier: (GPL-2.0 OR CDDL-1.0) */ drivers/watchdog/rtd119x_wdt.c: * SPDX-License-Identifier: GPL-2.0+ drivers/rtc/rtc-rtd119x.c: * SPDX-License-Identifier: GPL-2.0+ drivers/rtc/rtc-sc27xx.c: * SPDX-License-Identifier: GPL-2.0 ...
Yes, 47 files is only a small fraction compared against the 5261 C files with C++ commented tags. But consistency of apparently not a real issue when it comes to comment style in Linux.
Right, this is completely independent and out of question here.
I have always been against the use of C++ comments in U-Boot (and in general in non C++ code), and I still am against it.
Not that this matters much.
Dear Tom,
Also, the SPDX tag is rarely a separate comment line. In most cases, it is part of a larger file header, say for example:
common/main.c:
/* * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * SPDX-License-Identifier: GPL-2.0+ */
Do you suggest to reformat this into something like:
/* * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. */
If yes, then please explain which sense this would make? It is just unnecessay work, and the result is inconsistent and ugly.
I forgot to ask which "tooling" you have in mind here? I did not see anything like that in the kernel source tree. What am I missing?
On Wed, May 09, 2018 at 06:07:50PM +0200, Wolfgang Denk wrote:
Dear Tom,
common/main.c:
- (C) Copyright 2000
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
I know it's going to annoy you more, but yes, that's already _done_: $ head -n5 common/main.c // SPDX-License-Identifier: GPL-2.0+ /* * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. */
It was about 97% automatic perl regex + sed insert and 3% "Ugh, this file does not follow the normal conventional comment style at all".
This started because I updated checkpatch.pl and that in turn checks if new files have an SPDX tag and if so, does it match the kernel style formatting. The first email: https://lists.denx.de/pipermail/u-boot/2018-April/325510.html that brought this up. And yes, I run checkpatch.pl on everything before every pull/push.
On Wed, May 09, 2018 at 05:40:52PM +0200, Wolfgang Denk wrote:
Dear Tom,
details.
I honestly couldn't think of a better way to see if anyone cared besides an RFC to the mailing list.
And for the record, it's a good thing you did. Since we were the best example of a project going all-in on the tags for a long while I know the people that did the kernel scheme looked at what we had.
I disagree on these being separate. I copy/pasted the relevant part of the kernel documentation as an update to our doc but where it goes (first line) and how it goes (comments like ....) are as much a part of the style as the syntax. I'd argue that where the license copies go and some directory structure there-of is also part of it but I think our locations are more set in stone, but we can live with it.
I don't want to have it buried here but maybe it's time to talk about fully adopting C99 (or, GNU C99). Did you happen to read https://lkml.org/lkml/2017/11/25/133 that Yamada-san passed along? Having read that after converting the tags that my first regex missed, maybe we were wrong 18 years ago.
or even
I was pointing out first line vs somewhere within the top comment block as I don't consider comment format vs location different items.
That the SPDX tag meant the same as the whole license text was part of the reason to convert.
This is again part of the difference in counting comment format as part of it, or not.
We sometimes do for Makefiles, almost always do in shell scripts.
Inconsistent rollout? Tags went in good bit before the document that said how/where they should be was finally merged. I'm sure it's on the kernel janitors list for someone to fixup, or there's patches slowly in-flight to do so.
Agreed.
Dear Tom,
OK. You know my opinion.
You misunderstand. I meant: we do not use C++ comments in Makefiles or in shell scripts, or in most other non-C code...
I drop out of this discussion here - thanks.
Tom Rini trini@konsulko.com writes:
- Shorter
Please explain how
// SPDX
is significantly shorter than
/* SPDX */
Having // comments next to /* ones is just hideously ugly. If some scanning tool is too stupid to handle standard C comments, it's the tool that needs to be fixed.
Dr. Philipp Tomsich
Måns Rullgård
