[U-Boot] [PATCH] libfdt: Drop -FDT_ERR_TOODEEP
This error code has not been upstreamed and is not really needed since it is unlikely to be triggered. Drop it to maintain compatability with upstream.
Reported-by: Peter Robinson pbrobinson@gmail.com
lib/libfdt/fdt_region.c | 2 +- lib/libfdt/libfdt.h | 7 +------ 2 files changed, 2 insertions(+), 7 deletions(-)
diff --git a/lib/libfdt/fdt_region.c b/lib/libfdt/fdt_region.c index 8b8a547555..63099f1d96 100644 --- a/lib/libfdt/fdt_region.c +++ b/lib/libfdt/fdt_region.c @@ -397,7 +397,7 @@ int fdt_next_region(const void *fdt, last_node = offset; p.depth++; if (p.depth == FDT_MAX_DEPTH) - return -FDT_ERR_TOODEEP; + return -FDT_ERR_BADSTRUCTURE; name = fdt_get_name(fdt, offset, &len); if (p.end - path + 2 + len >= path_len) return -FDT_ERR_NOSPACE; diff --git a/lib/libfdt/libfdt.h b/lib/libfdt/libfdt.h index 2f7ebf8e06..f3f9cad184 100644 --- a/lib/libfdt/libfdt.h +++ b/lib/libfdt/libfdt.h @@ -93,12 +93,7 @@ /* FDT_ERR_NOPHANDLES: The device tree doesn't have any * phandle available anymore without causing an overflow */
-#define FDT_ERR_TOODEEP 18 - /* FDT_ERR_TOODEEP: The depth of a node has exceeded the internal - * libfdt limit. This can happen if you have more than - * FDT_MAX_DEPTH nested nodes. */ - -#define FDT_ERR_MAX 18 +#define FDT_ERR_MAX 17
/**********************************************************************/ /* Low-level functions (you probably don't need these) */
Tested-by: Peter Robinson pbrobinson@gmail.com
/**********************************************************************/ /* Low-level functions (you probably don't need these) */ -- 2.13.2.725.g09c95d1e9-goog
Signed-off-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com
Peter Robinson
