[PATCH v2 00/22] log: Add commands for manipulating filters
This series adds several commands for adding, listing, and removing log filters. It also adds getopt, since the filter-add command needs to have several optional arguments to be complete, and positional specification of those arguments would have been difficult.
Changes in v2: - Add % before constants in kerneldocs - Add compiletime assert on size of log_cat_name - Add const qualifier to log_*_name - Add option to remove all filters to filter-remove - Clarify filter-* help text - Clarify wording of filter documentation - Converted log filter-* tests to C from python - Document log_level_t and log_category_t members - Expand documentation of getopt() to include examples - Expose log_has_cat and log_has_file for filter tests - Include enum definitions instead of re-documenting them - Print an error message if the log level is invalid. - Remove opt prefix from getopt_state members - Reorganize log documentation; related sections should now be more proximate
Sean Anderson (22): log: Fix missing negation of ENOMEM log: Fix incorrect documentation of log_filter.cat_list log: Add additional const qualifier to arrays log: Add new category names to log_cat_name log: Use CONFIG_IS_ENABLED() for LOG_TEST log: Expose some helper functions log: Add function to create a filter with flags log: Add filter flag to deny on match test: Add tests for LOGFF_DENY log: Add filter flag to match greater than a log level test: Add test for LOGFF_MIN cmd: log: Use sub-commands for log cmd: log: Split off log level parsing cmd: log: Move log test to end of help string cmd: log: Add commands to list categories and drivers cmd: log: Make "log level" print all log levels lib: Add getopt test: Add a test for getopt cmd: log: Add commands to manipulate filters test: Add a test for log filter-* doc: Add log kerneldocs to documentation doc: Update logging documentation
MAINTAINERS | 1 + cmd/Kconfig | 1 + cmd/log.c | 360 +++++++++++++++++++++++++++++++++----- common/log.c | 65 ++++--- doc/api/getopt.rst | 8 + doc/api/index.rst | 1 + doc/develop/logging.rst | 238 ++++++++++++------------- include/getopt.h | 130 ++++++++++++++ include/log.h | 205 ++++++++++++++++------ include/test/log.h | 1 + lib/Kconfig | 5 + lib/Makefile | 1 + lib/getopt.c | 125 +++++++++++++ test/lib/Makefile | 1 + test/lib/getopt.c | 123 +++++++++++++ test/log/Makefile | 1 + test/log/log_filter.c | 111 ++++++++++++ test/log/log_test.c | 94 +++++++++- test/py/tests/test_log.py | 26 ++- 19 files changed, 1253 insertions(+), 244 deletions(-) create mode 100644 doc/api/getopt.rst create mode 100644 include/getopt.h create mode 100644 lib/getopt.c create mode 100644 test/lib/getopt.c create mode 100644 test/log/log_filter.c
Errors returned should be negative.
Fixes: 45fac9fc18 ("log: Correct missing free() on error in log_add_filter()")
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
(no changes since v1)
common/log.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/log.c b/common/log.c index 9a5f100da3..3f6f4bdc2a 100644 --- a/common/log.c +++ b/common/log.c @@ -268,7 +268,7 @@ int log_add_filter(const char *drv_name, enum log_category_t cat_list[], if (file_list) { filt->file_list = strdup(file_list); if (!filt->file_list) { - ret = ENOMEM; + ret = -ENOMEM; goto err; } }
Logging category lists are terminated by LOGC_END, not LOGC_NONE.
Fixes: e9c8d49d54 ("log: Add an implementation of logging")
Changes in v2: - Also fix misdocumentation of for log_add_filter()
include/log.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/log.h b/include/log.h index 2859ce1f2e..1e29c94fd3 100644 --- a/include/log.h +++ b/include/log.h @@ -349,7 +349,7 @@ enum log_filter_flags { * new filter, and must be provided when removing a previously added * filter. * @flags: Flags for this filter (LOGFF_...) - * @cat_list: List of categories to allow (terminated by LOGC_none). If empty + * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries * can be provided * @max_level: Maximum log level to allow @@ -423,7 +423,7 @@ int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); * * @drv_name: Driver name to add the filter to (since each driver only has a * single device) - * @cat_list: List of categories to allow (terminated by LOGC_none). If empty + * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries * can be provided * @max_level: Maximum log level to allow
Both these arrays and their members are const. Fixes checkpatch complaint.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
Changes in v2: - New
common/log.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/log.c b/common/log.c index 3f6f4bdc2a..bda5139b69 100644 --- a/common/log.c +++ b/common/log.c @@ -13,7 +13,7 @@
DECLARE_GLOBAL_DATA_PTR;
-static const char *log_cat_name[LOGC_COUNT - LOGC_NONE] = { +static const char *const log_cat_name[LOGC_COUNT - LOGC_NONE] = { "none", "arch", "board", @@ -23,7 +23,7 @@ static const char *log_cat_name[LOGC_COUNT - LOGC_NONE] = { "efi", };
-static const char *log_level_name[LOGL_COUNT] = { +static const char *const log_level_name[LOGL_COUNT] = { "EMERG", "ALERT", "CRIT",
Changes in v2:
- New
Without every category between LOGC_NONE and LOGC_COUNT present in log_cat_name, log_get_cat_by_name will dereference NULL pointers if it doesn't find a name early enough.
Fixes: c3aed5db59 ("sandbox: spi: Add more logging") Fixes: a5c13b68e7 ("sandbox: log: Add a category for sandbox") Fixes: 9f407d4ef0 ("Add core support for a bloblist to convey data from SPL") Fixes: cce61fc428 ("dm: devres: Convert to use logging") Fixes: 7ca2850cbc ("dm: core: Add basic ACPI support")
Changes in v2: - Add compiletime assert on size of log_cat_name
common/log.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/common/log.c b/common/log.c index bda5139b69..11f488d71d 100644 --- a/common/log.c +++ b/common/log.c @@ -13,7 +13,7 @@
-static const char *const log_cat_name[LOGC_COUNT - LOGC_NONE] = { +static const char *const log_cat_name[] = { "none", "arch", "board", @@ -21,6 +21,11 @@ static const char *const log_cat_name[LOGC_COUNT - LOGC_NONE] = { "driver-model", "device-tree", "efi", + "alloc", + "sandbox", + "bloblist", + "devres", + "acpi", };
static const char *const log_level_name[LOGL_COUNT] = { @@ -40,6 +45,9 @@ const char *log_get_cat_name(enum log_category_t cat) { const char *name;
+ compiletime_assert(ARRAY_SIZE(log_cat_name) == LOGC_COUNT - LOGC_NONE, + "missing logging category name"); + if (cat < 0 || cat >= LOGC_COUNT) return "<invalid>"; if (cat >= LOGC_NONE)
Changes in v2:
Checkpatch complains about using #ifdef for CONFIG variables.
cmd/log.c | 4 ++-- test/log/log_test.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cmd/log.c b/cmd/log.c index 6afe6ead25..16a6ef7539 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -105,7 +105,7 @@ static int do_log_rec(struct cmd_tbl *cmdtp, int flag, int argc,
static struct cmd_tbl log_sub[] = { U_BOOT_CMD_MKENT(level, CONFIG_SYS_MAXARGS, 1, do_log_level, "", ""), -#ifdef CONFIG_LOG_TEST +#if CONFIG_IS_ENABLED(LOG_TEST) U_BOOT_CMD_MKENT(test, 2, 1, do_log_test, "", ""), #endif U_BOOT_CMD_MKENT(format, CONFIG_SYS_MAXARGS, 1, do_log_format, "", ""), @@ -133,7 +133,7 @@ static int do_log(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #ifdef CONFIG_SYS_LONGHELP static char log_help_text[] = "level - get/set log level\n" -#ifdef CONFIG_LOG_TEST +#if CONFIG_IS_ENABLED(LOG_TEST) "log test - run log tests\n" #endif "log format <fmt> - set log output format. <fmt> is a string where\n" diff --git a/test/log/log_test.c b/test/log/log_test.c index 4245372d65..787f680971 100644 --- a/test/log/log_test.c +++ b/test/log/log_test.c @@ -201,7 +201,7 @@ static int log_test(int testnum) return 0; }
-#ifdef CONFIG_LOG_TEST +#if CONFIG_IS_ENABLED(LOG_TEST) int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { int testnum = 0;
You can ignore this warning.
Perhaps it should be downgraded to a check instead of a warning?
--Sean
Hi Sean,
That sounds like a good idea. There are quite a few places where #if is needed, despite this useful exhortation.
These functions are required by "cmd: log: Add commands to manipulate filters" and "test: Add a test for log filter-*".
Changes in v2: - Expose log_has_cat and log_has_file for filter tests
common/log.c | 23 +++-------------------- include/log.h | 31 +++++++++++++++++++++++++++++++ 2 files changed, 34 insertions(+), 20 deletions(-)
diff --git a/common/log.c b/common/log.c index 11f488d71d..5e9ce3184f 100644 --- a/common/log.c +++ b/common/log.c @@ -96,7 +96,7 @@ enum log_level_t log_get_level_by_name(const char *name) return LOGL_NONE; }
-static struct log_device *log_device_find_by_name(const char *drv_name) +struct log_device *log_device_find_by_name(const char *drv_name) { struct log_device *ldev;
@@ -108,15 +108,7 @@ static struct log_device *log_device_find_by_name(const char *drv_name) return NULL; }
-/** - * log_has_cat() - check if a log category exists within a list - * - * @cat_list: List of categories to check, at most LOGF_MAX_CATEGORIES entries - * long, terminated by LC_END if fewer - * @cat: Category to search for - * @return true if @cat is in @cat_list, else false - */ -static bool log_has_cat(enum log_category_t cat_list[], enum log_category_t cat) +bool log_has_cat(enum log_category_t cat_list[], enum log_category_t cat) { int i;
@@ -128,16 +120,7 @@ static bool log_has_cat(enum log_category_t cat_list[], enum log_category_t cat) return false; }
-/** - * log_has_file() - check if a file is with a list - * - * @file_list: List of files to check, separated by comma - * @file: File to check for. This string is matched against the end of each - * file in the list, i.e. ignoring any preceding path. The list is - * intended to consist of relative pathnames, e.g. common/main.c,cmd/log.c - * @return true if @file is in @file_list, else false - */ -static bool log_has_file(const char *file_list, const char *file) +bool log_has_file(const char *file_list, const char *file) { int file_len = strlen(file); const char *s, *p; diff --git a/include/log.h b/include/log.h index 1e29c94fd3..d84514a898 100644 --- a/include/log.h +++ b/include/log.h @@ -402,6 +402,37 @@ const char *log_get_level_name(enum log_level_t level); */ enum log_level_t log_get_level_by_name(const char *name);
+/** + * log_device_find_by_name() - Look up a log device by its driver's name + * + * @drv_name: Name of the driver + * @return the log device, or NULL if not found + */ +struct log_device *log_device_find_by_name(const char *drv_name); + +/** + * log_has_cat() - check if a log category exists within a list + * + * @cat_list: List of categories to check, at most %LOGF_MAX_CATEGORIES entries + * long, terminated by %LC_END if fewer + * @cat: Category to search for + * + * Return: ``true`` if @cat is in @cat_list, else ``false`` + */ +bool log_has_cat(enum log_category_t cat_list[], enum log_category_t cat); + +/** + * log_has_file() - check if a file is with a list + * + * @file_list: List of files to check, separated by comma + * @file: File to check for. This string is matched against the end of each + * file in the list, i.e. ignoring any preceding path. The list is + * intended to consist of relative pathnames, e.g. common/main.c,cmd/log.c + * + * Return: ``true`` if @file is in @file_list, else ``false`` + */ +bool log_has_file(const char *file_list, const char *file); + /* Log format flags (bit numbers) for gd->log_fmt. See log_fmt_chars */ enum log_fmt { LOGF_CAT = 0,
Changes in v2:
This function exposes a way to specify flags when creating a filter.
common/log.c | 6 ++++-- include/log.h | 29 +++++++++++++++++++++++++++-- 2 files changed, 31 insertions(+), 4 deletions(-)
diff --git a/common/log.c b/common/log.c index 5e9ce3184f..1066ead9e5 100644 --- a/common/log.c +++ b/common/log.c @@ -228,8 +228,9 @@ int _log(enum log_category_t cat, enum log_level_t level, const char *file, return 0; }
-int log_add_filter(const char *drv_name, enum log_category_t cat_list[], - enum log_level_t max_level, const char *file_list) +int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], + enum log_level_t max_level, const char *file_list, + int flags) { struct log_filter *filt; struct log_device *ldev; @@ -243,6 +244,7 @@ int log_add_filter(const char *drv_name, enum log_category_t cat_list[], if (!filt) return -ENOMEM;
+ filt->flags = flags; if (cat_list) { filt->flags |= LOGFF_HAS_CAT; for (i = 0; ; i++) { diff --git a/include/log.h b/include/log.h index d84514a898..43935a1e34 100644 --- a/include/log.h +++ b/include/log.h @@ -449,6 +449,25 @@ enum log_fmt { /* Handle the 'log test' command */ int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
+/** + * log_add_filter_flags() - Add a new filter to a log device, specifying flags + * + * @drv_name: Driver name to add the filter to (since each driver only has a + * single device) + * @flags: Flags for this filter (LOGFF_...) + * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty + * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries + * can be provided + * @max_level: Maximum log level to allow + * @file_list: List of files to allow, separated by comma. If NULL then all + * files are permitted + * @return the sequence number of the new filter (>=0) if the filter was added, + * or a -ve value on error + */ +int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], + enum log_level_t max_level, const char *file_list, + int flags); + /** * log_add_filter() - Add a new filter to a log device * @@ -463,8 +482,14 @@ int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); * @return the sequence number of the new filter (>=0) if the filter was added, * or a -ve value on error */ -int log_add_filter(const char *drv_name, enum log_category_t cat_list[], - enum log_level_t max_level, const char *file_list); +static inline int log_add_filter(const char *drv_name, + enum log_category_t cat_list[], + enum log_level_t max_level, + const char *file_list) +{ + return log_add_filter_flags(drv_name, cat_list, max_level, file_list, + 0); +}
/** * log_remove_filter() - Remove a filter from a log device
Without this flag, log filters can only explicitly accept messages. Allowing denial makes it easier to filter certain subsystems. Unlike allow-ing filters, deny-ing filters are added to the beginning of the filter list. This should do the Right Thing most of the time, but it's less-universal than allowing filters to be inserted anywhere. If this becomes a problem, then perhaps log_filter_add* should take a filter number to insert before/after.
common/log.c | 12 ++++++++++-- include/log.h | 11 ++++++++++- 2 files changed, 20 insertions(+), 3 deletions(-)
diff --git a/common/log.c b/common/log.c index 1066ead9e5..910dc6b672 100644 --- a/common/log.c +++ b/common/log.c @@ -164,7 +164,11 @@ static bool log_passes_filters(struct log_device *ldev, struct log_rec *rec) if (filt->file_list && !log_has_file(filt->file_list, rec->file)) continue; - return true; + + if (filt->flags & LOGFF_DENY) + return false; + else + return true; }
return false; @@ -266,7 +270,11 @@ int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], } } filt->filter_num = ldev->next_filter_num++; - list_add_tail(&filt->sibling_node, &ldev->filter_head); + /* Add deny filters to the beginning of the list */ + if (flags & LOGFF_DENY) + list_add(&filt->sibling_node, &ldev->filter_head); + else + list_add_tail(&filt->sibling_node, &ldev->filter_head);
return filt->filter_num;
diff --git a/include/log.h b/include/log.h index 43935a1e34..9f09d3a486 100644 --- a/include/log.h +++ b/include/log.h @@ -338,13 +338,22 @@ enum { LOGF_MAX_CATEGORIES = 5, /* maximum categories per filter */ };
+/** + * enum log_filter_flags - Flags which modify a filter + */ enum log_filter_flags { - LOGFF_HAS_CAT = 1 << 0, /* Filter has a category list */ + /** @LOGFF_HAS_CAT: Filter has a category list */ + LOGFF_HAS_CAT = 1 << 0, + /** @LOGFF_DENY: Filter denies matching messages */ + LOGFF_DENY = 1 << 1, };
/** * struct log_filter - criterial to filter out log messages * + * If a message matches all criteria, then it is allowed. If LOGFF_DENY is set, + * then it is denied instead. + * * @filter_num: Sequence number of this filter. This is returned when adding a * new filter, and must be provided when removing a previously added * filter.
This adds some tests for log filters which deny if they match.
test/log/log_test.c | 69 +++++++++++++++++++++++++++++++++++++++ test/py/tests/test_log.py | 21 ++++++++++-- 2 files changed, 88 insertions(+), 2 deletions(-)
diff --git a/test/log/log_test.c b/test/log/log_test.c index 787f680971..6a71d3db7d 100644 --- a/test/log/log_test.c +++ b/test/log/log_test.c @@ -196,6 +196,75 @@ static int log_test(int testnum) log_io("level %d\n", LOGL_DEBUG_IO); break; } + case 11: { + /* Check denying based on category */ + int filt1, filt2; + enum log_category_t cat_list[] = { + log_uc_cat(UCLASS_SPI), LOGC_END + }; + + ret = log_add_filter("console", cat_list, LOGL_MAX, NULL); + if (ret < 0) + return ret; + filt1 = ret; + ret = log_add_filter_flags("console", cat_list, LOGL_MAX, NULL, + LOGFF_DENY); + if (ret < 0) + return ret; + filt2 = ret; + log_run(UCLASS_SPI, "file"); + ret = log_remove_filter("console", filt1); + if (ret < 0) + return ret; + ret = log_remove_filter("console", filt2); + if (ret < 0) + return ret; + break; + } + case 12: { + /* Check denying based on file */ + int filt1, filt2; + + ret = log_add_filter("console", NULL, LOGL_MAX, "file"); + if (ret < 0) + return ret; + filt1 = ret; + ret = log_add_filter_flags("console", NULL, LOGL_MAX, "file", + LOGFF_DENY); + if (ret < 0) + return ret; + filt2 = ret; + log_run(UCLASS_SPI, "file"); + ret = log_remove_filter("console", filt1); + if (ret < 0) + return ret; + ret = log_remove_filter("console", filt2); + if (ret < 0) + return ret; + break; + } + case 13: { + /* Check denying based on level */ + int filt1, filt2; + + ret = log_add_filter("console", NULL, LOGL_INFO, NULL); + if (ret < 0) + return ret; + filt1 = ret; + ret = log_add_filter_flags("console", NULL, LOGL_WARNING, NULL, + LOGFF_DENY); + if (ret < 0) + return ret; + filt2 = ret; + log_run(UCLASS_SPI, "file"); + ret = log_remove_filter("console", filt1); + if (ret < 0) + return ret; + ret = log_remove_filter("console", filt2); + if (ret < 0) + return ret; + break; + } }
return 0; diff --git a/test/py/tests/test_log.py b/test/py/tests/test_log.py index ddc28f19ee..fabf3001cb 100644 --- a/test/py/tests/test_log.py +++ b/test/py/tests/test_log.py @@ -15,7 +15,8 @@ LOGL_FIRST, LOGL_WARNING, LOGL_INFO = (0, 4, 6) @pytest.mark.buildconfigspec('cmd_log') def test_log(u_boot_console): """Test that U-Boot logging works correctly.""" - def check_log_entries(lines, mask, max_level=LOGL_INFO): + def check_log_entries(lines, mask, max_level=LOGL_INFO, + min_level=LOGL_FIRST): """Check that the expected log records appear in the output
Args: @@ -24,8 +25,9 @@ def test_log(u_boot_console): bit 0: standard log line bit 1: _log line max_level: maximum log level to expect in the output + min_level: minimum log level to expect in the output """ - for i in range(max_level): + for i in range(min_level, max_level + 1): if mask & 1: assert 'log_run() log %d' % i == next(lines) if mask & 3: @@ -92,6 +94,18 @@ def test_log(u_boot_console): for i in range(7): assert 'log_test() level %d' % i == next(lines)
+ def test11(): + lines = run_test(11) + assert next(lines, None) == None + + def test12(): + lines = run_test(12) + assert next(lines, None) == None + + def test13(): + lines = run_test(13) + check_log_entries(lines, 1, LOGL_INFO, LOGL_WARNING + 1) + # TODO(sjg@chromium.org): Consider structuring this as separate tests cons = u_boot_console test0() @@ -105,6 +119,9 @@ def test_log(u_boot_console): test8() test9() test10() + test11() + test12() + test13()
@pytest.mark.buildconfigspec('cmd_log') def test_log_format(u_boot_console):
This is the compliment of the existing behavior to match only messages with a log level less than a threshold. This is primarily useful in conjunction with LOGFF_DENY.
common/log.c | 12 +++++++++--- include/log.h | 10 ++++++---- 2 files changed, 15 insertions(+), 7 deletions(-)
diff --git a/common/log.c b/common/log.c index 910dc6b672..7a9906a9b0 100644 --- a/common/log.c +++ b/common/log.c @@ -156,11 +156,17 @@ static bool log_passes_filters(struct log_device *ldev, struct log_rec *rec) }
list_for_each_entry(filt, &ldev->filter_head, sibling_node) { - if (rec->level > filt->max_level) + if (filt->flags & LOGFF_LEVEL_MIN) { + if (rec->level < filt->level) + continue; + } else if (rec->level > filt->level) { continue; + } + if ((filt->flags & LOGFF_HAS_CAT) && !log_has_cat(filt->cat_list, rec->cat)) continue; + if (filt->file_list && !log_has_file(filt->file_list, rec->file)) continue; @@ -233,7 +239,7 @@ int _log(enum log_category_t cat, enum log_level_t level, const char *file, }
int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], - enum log_level_t max_level, const char *file_list, + enum log_level_t level, const char *file_list, int flags) { struct log_filter *filt; @@ -261,7 +267,7 @@ int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], break; } } - filt->max_level = max_level; + filt->level = level; if (file_list) { filt->file_list = strdup(file_list); if (!filt->file_list) { diff --git a/include/log.h b/include/log.h index 9f09d3a486..9dd4484095 100644 --- a/include/log.h +++ b/include/log.h @@ -346,6 +346,8 @@ enum log_filter_flags { LOGFF_HAS_CAT = 1 << 0, /** @LOGFF_DENY: Filter denies matching messages */ LOGFF_DENY = 1 << 1, + /** @LOGFF_LEVEL_MIN: Filter's level is a minimum, not a maximum */ + LOGFF_LEVEL_MIN = 1 << 2, };
/** @@ -361,7 +363,7 @@ enum log_filter_flags { * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries * can be provided - * @max_level: Maximum log level to allow + * @level: Maximum (or minimum, if LOGFF_MIN_LEVEL) log level to allow * @file_list: List of files to allow, separated by comma. If NULL then all * files are permitted * @sibling_node: Next filter in the list of filters for this log device @@ -370,7 +372,7 @@ struct log_filter { int filter_num; int flags; enum log_category_t cat_list[LOGF_MAX_CATEGORIES]; - enum log_level_t max_level; + enum log_level_t level; const char *file_list; struct list_head sibling_node; }; @@ -467,14 +469,14 @@ int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries * can be provided - * @max_level: Maximum log level to allow + * @level: Maximum (or minimum, if LOGFF_LEVEL_MIN) log level to allow * @file_list: List of files to allow, separated by comma. If NULL then all * files are permitted * @return the sequence number of the new filter (>=0) if the filter was added, * or a -ve value on error */ int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], - enum log_level_t max_level, const char *file_list, + enum log_level_t level, const char *file_list, int flags);
complement
This tests log filters matching on a minimum level.
test/log/log_test.c | 23 +++++++++++++++++++++++ test/py/tests/test_log.py | 5 +++++ 2 files changed, 28 insertions(+)
diff --git a/test/log/log_test.c b/test/log/log_test.c index 6a71d3db7d..da433e332b 100644 --- a/test/log/log_test.c +++ b/test/log/log_test.c @@ -265,6 +265,29 @@ static int log_test(int testnum) return ret; break; } + case 14: { + /* Check matching based on minimum level */ + int filt1, filt2; + + ret = log_add_filter_flags("console", NULL, LOGL_WARNING, NULL, + LOGFF_LEVEL_MIN); + if (ret < 0) + return ret; + filt1 = ret; + ret = log_add_filter_flags("console", NULL, LOGL_INFO, NULL, + LOGFF_DENY | LOGFF_LEVEL_MIN); + if (ret < 0) + return ret; + filt2 = ret; + log_run(UCLASS_SPI, "file"); + ret = log_remove_filter("console", filt1); + if (ret < 0) + return ret; + ret = log_remove_filter("console", filt2); + if (ret < 0) + return ret; + break; + } }
return 0; diff --git a/test/py/tests/test_log.py b/test/py/tests/test_log.py index fabf3001cb..f191c84c02 100644 --- a/test/py/tests/test_log.py +++ b/test/py/tests/test_log.py @@ -106,6 +106,10 @@ def test_log(u_boot_console): lines = run_test(13) check_log_entries(lines, 1, LOGL_INFO, LOGL_WARNING + 1)
+ def test14(): + lines = run_test(14) + check_log_entries(lines, 1, LOGL_INFO - 1, LOGL_WARNING) + # TODO(sjg@chromium.org): Consider structuring this as separate tests cons = u_boot_console test0() @@ -122,6 +126,7 @@ def test_log(u_boot_console): test11() test12() test13() + test14()
This reduces duplicate code, and makes adding new sub-commands easier.
cmd/log.c | 37 +++++++------------------------------ 1 file changed, 7 insertions(+), 30 deletions(-)
diff --git a/cmd/log.c b/cmd/log.c index 16a6ef7539..e55ace9e14 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -103,33 +103,6 @@ static int do_log_rec(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
-static struct cmd_tbl log_sub[] = { - U_BOOT_CMD_MKENT(level, CONFIG_SYS_MAXARGS, 1, do_log_level, "", ""), -#if CONFIG_IS_ENABLED(LOG_TEST) - U_BOOT_CMD_MKENT(test, 2, 1, do_log_test, "", ""), -#endif - U_BOOT_CMD_MKENT(format, CONFIG_SYS_MAXARGS, 1, do_log_format, "", ""), - U_BOOT_CMD_MKENT(rec, CONFIG_SYS_MAXARGS, 1, do_log_rec, "", ""), -}; - -static int do_log(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct cmd_tbl *cp; - - if (argc < 2) - return CMD_RET_USAGE; - - /* drop initial "log" arg */ - argc--; - argv++; - - cp = find_cmd_tbl(argv[0], log_sub, ARRAY_SIZE(log_sub)); - if (cp) - return cp->cmd(cmdtp, flag, argc, argv); - - return CMD_RET_USAGE; -} - #ifdef CONFIG_SYS_LONGHELP static char log_help_text[] = "level - get/set log level\n" @@ -145,7 +118,11 @@ static char log_help_text[] = ; #endif
-U_BOOT_CMD( - log, CONFIG_SYS_MAXARGS, 1, do_log, - "log system", log_help_text +U_BOOT_CMD_WITH_SUBCMDS(log, "log system", log_help_text, + U_BOOT_SUBCMD_MKENT(level, 2, 1, do_log_level), +#if CONFIG_IS_ENABLED(LOG_TEST) + U_BOOT_SUBCMD_MKENT(test, 2, 1, do_log_test), +#endif + U_BOOT_SUBCMD_MKENT(format, 2, 1, do_log_format), + U_BOOT_SUBCMD_MKENT(rec, 7, 1, do_log_rec), );
Move parsing of log level into its own function so it can be re-used. This also adds support for using log level names instead of just the integer equivalent.
Changes in v2: - Print an error message if the log level is invalid.
cmd/log.c | 29 +++++++++++++++++++++++------ 1 file changed, 23 insertions(+), 6 deletions(-)
diff --git a/cmd/log.c b/cmd/log.c index e55ace9e14..5387aab551 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -11,23 +11,40 @@
static char log_fmt_chars[LOGF_COUNT] = "clFLfm";
+static enum log_level_t parse_log_level(char *const arg) +{ + enum log_level_t ret; + ulong level; + + if (!strict_strtoul(arg, 10, &level)) { + if (level > _LOG_MAX_LEVEL) { + printf("Only log levels <= %d are supported\n", + _LOG_MAX_LEVEL); + return LOGL_NONE; + } + return level; + } + + ret = log_get_level_by_name(arg); + if (ret == LOGL_NONE) + printf("Unknown log level "%s"\n", arg); + return ret; +} + static int do_log_level(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { if (argc > 1) { - long log_level = simple_strtol(argv[1], NULL, 10); + enum log_level_t log_level = parse_log_level(argv[1]);
- if (log_level < 0 || log_level > _LOG_MAX_LEVEL) { - printf("Only log levels <= %d are supported\n", - _LOG_MAX_LEVEL); + if (log_level == LOGL_NONE) return CMD_RET_FAILURE; - } gd->default_log_level = log_level; } else { printf("Default log level: %d\n", gd->default_log_level); }
- return 0; + return CMD_RET_SUCCESS; }
static int do_log_format(struct cmd_tbl *cmdtp, int flag, int argc,
Changes in v2:
This is probably what a typical user is least interested in. Move it to the end of the description.
cmd/log.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/cmd/log.c b/cmd/log.c index 5387aab551..9076e220f0 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -123,23 +123,23 @@ static int do_log_rec(struct cmd_tbl *cmdtp, int flag, int argc, #ifdef CONFIG_SYS_LONGHELP static char log_help_text[] = "level - get/set log level\n" -#if CONFIG_IS_ENABLED(LOG_TEST) - "log test - run log tests\n" -#endif "log format <fmt> - set log output format. <fmt> is a string where\n" "\teach letter indicates something that should be displayed:\n" "\tc=category, l=level, F=file, L=line number, f=function, m=msg\n" "\tor 'default', or 'all' for all\n" "log rec <category> <level> <file> <line> <func> <message> - " "output a log record" +#if CONFIG_IS_ENABLED(LOG_TEST) + "\nlog test - run log tests" +#endif ; #endif
U_BOOT_CMD_WITH_SUBCMDS(log, "log system", log_help_text, U_BOOT_SUBCMD_MKENT(level, 2, 1, do_log_level), + U_BOOT_SUBCMD_MKENT(format, 2, 1, do_log_format), + U_BOOT_SUBCMD_MKENT(rec, 7, 1, do_log_rec), #if CONFIG_IS_ENABLED(LOG_TEST) U_BOOT_SUBCMD_MKENT(test, 2, 1, do_log_test), #endif - U_BOOT_SUBCMD_MKENT(format, 2, 1, do_log_format), - U_BOOT_SUBCMD_MKENT(rec, 7, 1, do_log_rec), );
This allows users to query which categories and drivers are available on their system. This allows them to construct filter-add commands without (e.g.) adjusting the log format to show categories and drivers.
cmd/log.c | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/cmd/log.c b/cmd/log.c index 9076e220f0..ea458f36f4 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -47,6 +47,38 @@ static int do_log_level(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_SUCCESS; }
+static int do_log_categories(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + enum log_category_t cat; + const char *name; + + for (cat = LOGC_FIRST; cat < LOGC_COUNT; cat++) { + name = log_get_cat_name(cat); + /* + * Invalid category names (e.g. <invalid> or <missing>) begin + * with '<'. TODO: perhaps change the interface of + * log_get_cat_name to return an error code? + */ + if (name[0] == '<') + continue; + printf("%s\n", name); + } + + return CMD_RET_SUCCESS; +} + +static int do_log_drivers(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct log_device *ldev; + + list_for_each_entry(ldev, &gd->log_head, sibling_node) + printf("%s\n", ldev->drv->name); + + return CMD_RET_SUCCESS; +} + static int do_log_format(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -123,6 +155,8 @@ static int do_log_rec(struct cmd_tbl *cmdtp, int flag, int argc, #ifdef CONFIG_SYS_LONGHELP static char log_help_text[] = "level - get/set log level\n" + "categories - list log categories\n" + "drivers - list log drivers\n" "log format <fmt> - set log output format. <fmt> is a string where\n" "\teach letter indicates something that should be displayed:\n" "\tc=category, l=level, F=file, L=line number, f=function, m=msg\n" @@ -137,6 +171,8 @@ static char log_help_text[] =
U_BOOT_CMD_WITH_SUBCMDS(log, "log system", log_help_text, U_BOOT_SUBCMD_MKENT(level, 2, 1, do_log_level), + U_BOOT_SUBCMD_MKENT(categories, 1, 1, do_log_categories), + U_BOOT_SUBCMD_MKENT(drivers, 1, 1, do_log_drivers), U_BOOT_SUBCMD_MKENT(format, 2, 1, do_log_format), U_BOOT_SUBCMD_MKENT(rec, 7, 1, do_log_rec), #if CONFIG_IS_ENABLED(LOG_TEST)
Changes in v2:
- New
char *const argv[])
const char *name;
I think that might be cleaner, but this is OK so long as you document the function return value accordingly.
if (name[0] == '<')
continue;
char *const argv[])
2.28.0
This makes the log level command print all valid log levels. The default log level is annotated. This provides an easy way to see which log levels are compiled-in.
cmd/log.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/cmd/log.c b/cmd/log.c index ea458f36f4..f3a265798c 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -34,14 +34,20 @@ static enum log_level_t parse_log_level(char *const arg) static int do_log_level(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + enum log_level_t log_level; + if (argc > 1) { - enum log_level_t log_level = parse_log_level(argv[1]); + log_level = parse_log_level(argv[1]);
if (log_level == LOGL_NONE) return CMD_RET_FAILURE; gd->default_log_level = log_level; } else { - printf("Default log level: %d\n", gd->default_log_level); + for (log_level = LOGL_FIRST; log_level <= _LOG_MAX_LEVEL; + log_level++) + printf("%s%s\n", log_get_level_name(log_level), + log_level == gd->default_log_level ? + " (default)" : ""); }
return CMD_RET_SUCCESS; @@ -154,7 +160,7 @@ static int do_log_rec(struct cmd_tbl *cmdtp, int flag, int argc,
#ifdef CONFIG_SYS_LONGHELP static char log_help_text[] = - "level - get/set log level\n" + "level [<level>] - get/set log level\n" "categories - list log categories\n" "drivers - list log drivers\n" "log format <fmt> - set log output format. <fmt> is a string where\n"
Changes in v2:
- New
Some commands can get very unweildy if they have too many positional arguments. Adding options makes them easier to read, remember, and understand.
This implementation of getopt has been taken from barebox, which has had option support for quite a while. I have made a few modifications to their version, such as the removal of opterr in favor of a separate getopt_silent function. In addition, I have moved all global variables into struct getopt_context.
The getopt from barebox also re-orders the arguments passed to it so that non-options are placed last. This allows users to specify options anywhere. For example, `ls -l foo/ -R` would be re-ordered to `ls -l -R foo/` as getopt parsed the options. However, this feature conflicts with the const argv in cmd_tbl->cmd. This was originally added in 54841ab50c ("Make sure that argv[] argument pointers are not modified."). The reason stated in that commit is that hush requires argv to stay unmodified. Has this situation changed? Barebox also uses hush, and does not have this problem. Perhaps we could use their fix?
I have assigned maintenance of getopt to Simon Glass, as it is currently only used by the log command. I would also be fine maintaining it.
Changes in v2: - Expand documentation of getopt() to include examples - Remove opt prefix from getopt_state members
MAINTAINERS | 1 + doc/api/getopt.rst | 8 +++ doc/api/index.rst | 1 + include/getopt.h | 130 +++++++++++++++++++++++++++++++++++++++++++++ lib/Kconfig | 5 ++ lib/Makefile | 1 + lib/getopt.c | 125 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 271 insertions(+) create mode 100644 doc/api/getopt.rst create mode 100644 include/getopt.h create mode 100644 lib/getopt.c
diff --git a/MAINTAINERS b/MAINTAINERS index fb9ba37984..0f8e1f6d4c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -747,6 +747,7 @@ T: git https://gitlab.denx.de/u-boot/u-boot.git F: common/log* F: cmd/log.c F: doc/develop/logging.rst +F: lib/getopt.c F: test/log/ F: test/py/tests/test_log.py
diff --git a/doc/api/getopt.rst b/doc/api/getopt.rst new file mode 100644 index 0000000000..773f79aeb6 --- /dev/null +++ b/doc/api/getopt.rst @@ -0,0 +1,8 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2020 Sean Anderson seanga2@gmail.com + +Option Parsing +============== + +.. kernel-doc:: include/getopt.h + :internal: diff --git a/doc/api/index.rst b/doc/api/index.rst index 1c261bcb73..d90e70e16a 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -8,6 +8,7 @@ U-Boot API documentation
dfu efi + getopt linker_lists pinctrl rng diff --git a/include/getopt.h b/include/getopt.h new file mode 100644 index 0000000000..6f5811e64b --- /dev/null +++ b/include/getopt.h @@ -0,0 +1,130 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * getopt.h - a simple getopt(3) implementation. + * + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + * Copyright (c) 2007 Sascha Hauer s.hauer@pengutronix.de, Pengutronix + */ + +#ifndef __GETOPT_H +#define __GETOPT_H + +/** + * struct getopt_state - Saved state across getopt() calls + */ +struct getopt_state { + /** + * @index: Index of the next unparsed argument of @argv. If getopt() has + * parsed all of @argv, then @index will equal @argc. + */ + int index; + /* private: */ + /** @arg_index: Index within the current argument */ + int arg_index; + union { + /* public: */ + /** + * @opt: Option being parsed when an error occurs. @opt is only + * valid when getopt() returns ``?`` or ``:``. + */ + int opt; + /** + * @arg: The argument to an option, NULL if there is none. @arg + * is only valid when getopt() returns an option character. + */ + char *arg; + /* private: */ + }; +}; + +/** + * getopt_init_state() - Initialize a &struct getopt_state + * @gs: The state to initialize + * + * This must be called before using @gs with getopt(). + */ +void getopt_init_state(struct getopt_state *gs); + +int __getopt(struct getopt_state *gs, int argc, char *const argv[], + const char *optstring, bool silent); + +/** + * getopt() - Parse short command-line options + * @gs: Internal state and out-of-band return arguments. This must be + * initialized with getopt_init_context() beforehand. + * @argc: Number of arguments, not including the %NULL terminator + * @argv: Argument list, terminated by %NULL + * @optstring: Option specification, as described below + * + * getopt() parses short options. Short options are single characters. They may + * be followed by a required argument or an optional argument. Arguments to + * options may occur in the same argument as an option (like ``-larg``), or + * in the following argument (like ``-l arg``). An argument containing + * options begins with a ``-``. If an option expects no arguments, then it may + * be immediately followed by another option (like ``ls -alR``). + * + * @optstring is a list of accepted options. If an option is followed by ``:`` + * in @optstring, then it expects a mandatory argument. If an option is followed + * by ``::`` in @optstring, it expects an optional argument. @gs.arg points + * to the argument, if one is parsed. + * + * getopt() stops parsing options when it encounters the first non-option + * argument, when it encounters the argument ``--``, or when it runs out of + * arguments. For example, in ``ls -l foo -R``, option parsing will stop when + * getopt() encounters ``foo``, if ``l`` does not expect an argument. However, + * the whole list of arguments would be parsed if ``l`` expects an argument. + * + * An example invocation of getopt() might look like:: + * + * char *argv[] = { "program", "-cbx", "-a", "foo", "bar", 0 }; + * int opt, argc = ARRAY_SIZE(argv) - 1; + * struct getopt_state gs; + * + * getopt_init_state(&gs); + * while ((opt = getopt(&gs, argc, argv, "a::b:c")) != -1) + * printf("opt = %c, index = %d, arg = "%s"\n", opt, gs.index, gs.arg); + * printf("%d argument(s) left\n", argc - gs.index); + * + * and would produce an output of:: + * + * opt = c, index = 1, arg = "<NULL>" + * opt = b, index = 2, arg = "x" + * opt = a, index = 4, arg = "foo" + * 1 argument(s) left + * + * For further information, refer to the getopt(3) man page. + * + * Return: + * * An option character if an option is found. @gs.arg is set to the + * argument if there is one, otherwise it is set to ``NULL``. + * * ``-1`` if there are no more options, if a non-option argument is + * encountered, or if an ``--`` argument is encountered. + * * ``'?'`` if we encounter an option not in @optstring. @gs.opt is set to + * the unknown option. + * * ``':'`` if an argument is required, but no argument follows the + * option. @gs.opt is set to the option missing its argument. + * + * @gs.index is always set to the index of the next unparsed argument in @argv. + */ +static inline int getopt(struct getopt_state *gs, int argc, + char *const argv[], const char *optstring) +{ + return __getopt(gs, argc, argv, optstring, false); +} + +/** + * getopt_silent() - Parse short command-line options silently + * @gs: State + * @argc: Argument count + * @argv: Argument list + * @optstring: Option specification + * + * Same as getopt(), except no error messages are printed. + */ +static inline int getopt_silent(struct getopt_state *gs, int argc, + char *const argv[], const char *optstring) +{ + return __getopt(gs, argc, argv, optstring, true); +} + +#endif /* __GETOPT_H */ diff --git a/lib/Kconfig b/lib/Kconfig index 8efb154f73..a3346eee04 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -542,6 +542,11 @@ config HEXDUMP help This enables functions for printing dumps of binary data.
+config GETOPT + bool "Enable getopt" + help + This enables functions for parsing command-line options. + config OF_LIBFDT bool "Enable the FDT library" default y if OF_CONTROL diff --git a/lib/Makefile b/lib/Makefile index 0cd7bea282..7c7fb9aae7 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -106,6 +106,7 @@ obj-y += string.o obj-y += tables_csum.o obj-y += time.o obj-y += hexdump.o +obj-$(CONFIG_GETOPT) += getopt.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_LIB_UUID) += uuid.o obj-$(CONFIG_LIB_RAND) += rand.o diff --git a/lib/getopt.c b/lib/getopt.c new file mode 100644 index 0000000000..8b4515dc19 --- /dev/null +++ b/lib/getopt.c @@ -0,0 +1,125 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * getopt.c - a simple getopt(3) implementation. See getopt.h for explanation. + * + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + * Copyright (c) 2007 Sascha Hauer s.hauer@pengutronix.de, Pengutronix + */ + +#define LOG_CATEGORY LOGC_CORE + +#include <common.h> +#include <getopt.h> +#include <log.h> + +void getopt_init_state(struct getopt_state *gs) +{ + gs->index = 1; + gs->arg_index = 1; +} + +int __getopt(struct getopt_state *gs, int argc, char *const argv[], + const char *optstring, bool silent) +{ + char curopt; /* current option character */ + const char *curoptp; /* pointer to the current option in optstring */ + + while (1) { + log_debug("arg_index: %d index: %d\n", gs->arg_index, + gs->index); + + /* `--` indicates the end of options */ + if (gs->arg_index == 1 && argv[gs->index] && + !strcmp(argv[gs->index], "--")) { + gs->index++; + return -1; + } + + /* Out of arguments */ + if (gs->index >= argc) + return -1; + + /* Can't parse non-options */ + if (*argv[gs->index] != '-') + return -1; + + /* We have found an option */ + curopt = argv[gs->index][gs->arg_index]; + if (curopt) + break; + /* + * no more options in current argv[] element; try the next one + */ + gs->index++; + gs->arg_index = 1; + } + + /* look up current option in optstring */ + curoptp = strchr(optstring, curopt); + + if (!curoptp) { + if (!silent) + printf("%s: invalid option -- %c\n", argv[0], curopt); + gs->opt = curopt; + gs->arg_index++; + return '?'; + } + + if (*(curoptp + 1) != ':') { + /* option with no argument. Just return it */ + gs->arg = NULL; + gs->arg_index++; + return curopt; + } + + if (*(curoptp + 1) && *(curoptp + 2) == ':') { + /* optional argument */ + if (argv[gs->index][gs->arg_index + 1]) { + /* optional argument with directly following arg */ + gs->arg = argv[gs->index++] + gs->arg_index + 1; + gs->arg_index = 1; + return curopt; + } + if (gs->index + 1 == argc) { + /* We are at the last argv[] element */ + gs->arg = NULL; + gs->index++; + return curopt; + } + if (*argv[gs->index + 1] != '-') { + /* + * optional argument with arg in next argv[] element + */ + gs->index++; + gs->arg = argv[gs->index++]; + gs->arg_index = 1; + return curopt; + } + + /* no optional argument found */ + gs->arg = NULL; + gs->arg_index = 1; + gs->index++; + return curopt; + } + + if (argv[gs->index][gs->arg_index + 1]) { + /* required argument with directly following arg */ + gs->arg = argv[gs->index++] + gs->arg_index + 1; + gs->arg_index = 1; + return curopt; + } + + gs->index++; + gs->arg_index = 1; + + if (gs->index >= argc || argv[gs->index][0] == '-') { + if (!silent) + printf("option requires an argument -- %c\n", curopt); + gs->opt = curopt; + return ':'; + } + + gs->arg = argv[gs->index++]; + return curopt; +}
A few of these tests were inspired by those in glibc. The syntax for invoking test_getopt is a bit funky, but it's necessary so that the CPP can parse the arguments correctly.
test/lib/Makefile | 1 + test/lib/getopt.c | 123 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 124 insertions(+) create mode 100644 test/lib/getopt.c
diff --git a/test/lib/Makefile b/test/lib/Makefile index 22236f8587..3140c2dad7 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_ERRNO_STR) += test_errno_str.o obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o +obj-$(CONFIG_GETOPT) += getopt.o diff --git a/test/lib/getopt.c b/test/lib/getopt.c new file mode 100644 index 0000000000..3c68b93c8a --- /dev/null +++ b/test/lib/getopt.c @@ -0,0 +1,123 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + * + * Portions of these tests were inspired by glibc's posix/bug-getopt1.c and + * posix/tst-getopt-cancel.c + */ + +#include <common.h> +#include <getopt.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +static int do_test_getopt(struct unit_test_state *uts, int line, + struct getopt_state *gs, const char *optstring, + int args, char *argv[], int expected_count, + int expected[]) +{ + int opt; + + getopt_init_state(gs); + for (int i = 0; i < expected_count; i++) { + opt = getopt_silent(gs, args, argv, optstring); + if (expected[i] != opt) { + /* + * Fudge the line number so we can tell which test + * failed + */ + ut_failf(uts, __FILE__, line, __func__, + "expected[i] == getopt()", + "Expected '%c' (%d) with i=%d, got '%c' (%d)", + expected[i], expected[i], i, opt, opt); + return CMD_RET_FAILURE; + } + } + + opt = getopt_silent(gs, args, argv, optstring); + if (opt != -1) { + ut_failf(uts, __FILE__, line, __func__, + "getopt() != -1", + "Expected -1, got '%c' (%d)", opt, opt); + return CMD_RET_FAILURE; + } + + return 0; +} + +#define test_getopt(optstring, argv, expected) do { \ + int ret = do_test_getopt(uts, __LINE__, &gs, optstring, \ + ARRAY_SIZE(argv) - 1, argv, \ + ARRAY_SIZE(expected), expected); \ + if (ret) \ + return ret; \ +} while (0) + +static int lib_test_getopt(struct unit_test_state *uts) +{ + struct getopt_state gs; + + /* Happy path */ + test_getopt("ab:c", + ((char *[]){ "program", "-cb", "x", "-a", "foo", 0 }), + ((int []){ 'c', 'b', 'a' })); + ut_asserteq(4, gs.index); + + /* Make sure we pick up the optional argument */ + test_getopt("a::b:c", + ((char *[]){ "program", "-cbx", "-a", "foo", 0 }), + ((int []){ 'c', 'b', 'a' })); + ut_asserteq(4, gs.index); + + /* Test required arguments */ + test_getopt("a:b", ((char *[]){ "program", "-a", 0 }), + ((int []){ ':' })); + ut_asserteq('a', gs.opt); + test_getopt("a:b", ((char *[]){ "program", "-b", "-a", 0 }), + ((int []){ 'b', ':' })); + ut_asserteq('a', gs.opt); + + /* Test invalid arguments */ + test_getopt("ab:c", ((char *[]){ "program", "-d", 0 }), + ((int []){ '?' })); + ut_asserteq('d', gs.opt); + + /* Test arg */ + test_getopt("a::b:c", + ((char *[]){ "program", "-a", 0 }), + ((int []){ 'a' })); + ut_asserteq(2, gs.index); + ut_assertnull(gs.arg); + + test_getopt("a::b:c", + ((char *[]){ "program", "-afoo", 0 }), + ((int []){ 'a' })); + ut_asserteq(2, gs.index); + ut_assertnonnull(gs.arg); + ut_asserteq_str("foo", gs.arg); + + test_getopt("a::b:c", + ((char *[]){ "program", "-a", "foo", 0 }), + ((int []){ 'a' })); + ut_asserteq(3, gs.index); + ut_assertnonnull(gs.arg); + ut_asserteq_str("foo", gs.arg); + + test_getopt("a::b:c", + ((char *[]){ "program", "-bfoo", 0 }), + ((int []){ 'b' })); + ut_asserteq(2, gs.index); + ut_assertnonnull(gs.arg); + ut_asserteq_str("foo", gs.arg); + + test_getopt("a::b:c", + ((char *[]){ "program", "-b", "foo", 0 }), + ((int []){ 'b' })); + ut_asserteq(3, gs.index); + ut_assertnonnull(gs.arg); + ut_asserteq_str("foo", gs.arg); + + return 0; +} +LIB_TEST(lib_test_getopt, 0);
This adds several commands to add, list, and remove log filters. Due to the complexity of adding a filter, `log filter-list` uses options instead of positional arguments.
These commands have been added as subcommands to log by using a dash to join the subcommand and subsubcommand. This is stylistic, and they could be converted to proper subsubcommands if it is wished.
Changes in v2: - Add option to remove all filters to filter-remove - Clarify filter-* help text
cmd/Kconfig | 1 + cmd/log.c | 240 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 241 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4cb171790b..e7e5d88bdb 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2147,6 +2147,7 @@ config CMD_KGDB config CMD_LOG bool "log - Generation, control and access to logging" select LOG + select GETOPT help This provides access to logging features. It allows the output of log data to be controlled to a limited extent (setting up the default diff --git a/cmd/log.c b/cmd/log.c index f3a265798c..3c27b35025 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -7,7 +7,9 @@ #include <common.h> #include <command.h> #include <dm.h> +#include <getopt.h> #include <log.h> +#include <malloc.h>
@@ -85,6 +87,220 @@ static int do_log_drivers(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_SUCCESS; }
+static int do_log_filter_list(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + int opt; + const char *drv_name = "console"; + struct getopt_state gs; + struct log_filter *filt; + struct log_device *ldev; + + getopt_init_state(&gs); + while ((opt = getopt(&gs, argc, argv, "d:")) > 0) { + switch (opt) { + case 'd': + drv_name = gs.arg; + break; + default: + return CMD_RET_USAGE; + } + } + + if (gs.index != argc) + return CMD_RET_USAGE; + + ldev = log_device_find_by_name(drv_name); + if (!ldev) { + printf("Could not find log device for "%s"\n", drv_name); + return CMD_RET_FAILURE; + } + + printf("num policy level categories files\n"); + list_for_each_entry(filt, &ldev->filter_head, sibling_node) { + printf("%3d %6.6s %s%-7.7s ", filt->filter_num, + filt->flags & LOGFF_DENY ? "deny" : "allow", + filt->flags & LOGFF_LEVEL_MIN ? ">=" : "<=", + log_get_level_name(filt->level)); + + if (filt->flags & LOGFF_HAS_CAT) { + int i; + + if (filt->cat_list[0] != LOGC_END) + printf("%16.16s %s\n", + log_get_cat_name(filt->cat_list[0]), + filt->file_list ? filt->file_list : ""); + + for (i = 1; i < LOGF_MAX_CATEGORIES && + filt->cat_list[i] != LOGC_END; i++) + printf("%20c %16.16s\n", ' ', + log_get_cat_name(filt->cat_list[i])); + } else { + printf("%16c %s\n", ' ', + filt->file_list ? filt->file_list : ""); + } + } + + return CMD_RET_SUCCESS; +} + +static int do_log_filter_add(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + bool level_set = false; + bool print_num = false; + bool type_set = false; + char *file_list = NULL; + const char *drv_name = "console"; + int opt, err; + int cat_count = 0; + int flags = 0; + enum log_category_t cat_list[LOGF_MAX_CATEGORIES + 1]; + enum log_level_t level = LOGL_MAX; + struct getopt_state gs; + + getopt_init_state(&gs); + while ((opt = getopt(&gs, argc, argv, "Ac:d:Df:l:L:p")) > 0) { + switch (opt) { + case 'A': +#define do_type() do { \ + if (type_set) { \ + printf("Allow or deny set twice\n"); \ + return CMD_RET_USAGE; \ + } \ + type_set = true; \ +} while (0) + do_type(); + break; + case 'c': { + enum log_category_t cat; + + if (cat_count >= LOGF_MAX_CATEGORIES) { + printf("Too many categories\n"); + return CMD_RET_FAILURE; + } + + cat = log_get_cat_by_name(gs.arg); + if (cat == LOGC_NONE) { + printf("Unknown category "%s"\n", gs.arg); + return CMD_RET_FAILURE; + } + + cat_list[cat_count++] = cat; + break; + } + case 'd': + drv_name = gs.arg; + break; + case 'D': + do_type(); + flags |= LOGFF_DENY; + break; + case 'f': + file_list = gs.arg; + break; + case 'l': +#define do_level() do { \ + if (level_set) { \ + printf("Log level set twice\n"); \ + return CMD_RET_USAGE; \ + } \ + level = parse_log_level(gs.arg); \ + if (level == LOGL_NONE) \ + return CMD_RET_FAILURE; \ + level_set = true; \ +} while (0) + do_level(); + break; + case 'L': + do_level(); + flags |= LOGFF_LEVEL_MIN; + break; + case 'p': + print_num = true; + break; + default: + return CMD_RET_USAGE; + } + } + + if (gs.index != argc) + return CMD_RET_USAGE; + + cat_list[cat_count] = LOGC_END; + err = log_add_filter_flags(drv_name, cat_count ? cat_list : NULL, level, + file_list, flags); + if (err < 0) { + printf("Could not add filter (err = %d)\n", err); + return CMD_RET_FAILURE; + } else if (print_num) { + printf("%d\n", err); + } + + return CMD_RET_SUCCESS; +} + +static int do_log_filter_remove(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + bool all = false; + int opt, err; + ulong filter_num; + const char *drv_name = "console"; + struct getopt_state gs; + + getopt_init_state(&gs); + while ((opt = getopt(&gs, argc, argv, "ad:")) > 0) { + switch (opt) { + case 'a': + all = true; + break; + case 'd': + drv_name = gs.arg; + break; + default: + return CMD_RET_USAGE; + } + } + + if (all) { + struct log_filter *filt, *tmp_filt; + struct log_device *ldev; + + if (gs.index != argc) + return CMD_RET_USAGE; + + ldev = log_device_find_by_name(drv_name); + if (!ldev) { + printf("Could not find log device for "%s"\n", + drv_name); + return CMD_RET_FAILURE; + } + + list_for_each_entry_safe(filt, tmp_filt, &ldev->filter_head, + sibling_node) { + list_del(&filt->sibling_node); + free(filt); + } + } else { + if (gs.index + 1 != argc) + return CMD_RET_USAGE; + + if (strict_strtoul(argv[gs.index], 10, &filter_num)) { + printf("Invalid filter number "%s"\n", argv[gs.index]); + return CMD_RET_FAILURE; + } + + err = log_remove_filter(drv_name, filter_num); + if (err) { + printf("Could not remove filter (err = %d)\n", err); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} + static int do_log_format(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -163,6 +379,26 @@ static char log_help_text[] = "level [<level>] - get/set log level\n" "categories - list log categories\n" "drivers - list log drivers\n" + "log filter-list [OPTIONS] - list all filters for a log driver\n" + "\t-d <driver> - Specify the log driver to list filters from; defaults\n" + "\t to console\n" + "log filter-add [OPTIONS] - add a new filter to a driver\n" + "\t-A - Allow messages matching this filter; mutually exclusive with -D\n" + "\t This is the default.\n" + "\t-c <category> - Category to match; may be specified multiple times\n" + "\t-d <driver> - Specify the log driver to add the filter to; defaults\n" + "\t to console\n" + "\t-D - Deny messages matching this filter; mutually exclusive with -A\n" + "\t-f <files_list> - A comma-separated list of files to match\n" + "\t-l <level> - Match log levels less than or equal to <level>;\n" + "\t mutually-exclusive with -L\n" + "\t-L <level> - Match log levels greather than or equal to <level>;\n" + "\t mutually-exclusive with -l\n" + "\t-p - Print the filter number on success\n" + "log filter-remove [OPTIONS] [<num>] - Remove filter number <num>\n" + "\t-a - Remove ALL filters\n" + "\t-d <driver> - Specify the log driver to remove the filter from;\n" + "\t defaults to console\n" "log format <fmt> - set log output format. <fmt> is a string where\n" "\teach letter indicates something that should be displayed:\n" "\tc=category, l=level, F=file, L=line number, f=function, m=msg\n" @@ -179,6 +415,10 @@ U_BOOT_CMD_WITH_SUBCMDS(log, "log system", log_help_text, U_BOOT_SUBCMD_MKENT(level, 2, 1, do_log_level), U_BOOT_SUBCMD_MKENT(categories, 1, 1, do_log_categories), U_BOOT_SUBCMD_MKENT(drivers, 1, 1, do_log_drivers), + U_BOOT_SUBCMD_MKENT(filter-list, 3, 1, do_log_filter_list), + U_BOOT_SUBCMD_MKENT(filter-add, CONFIG_SYS_MAXARGS, 1, + do_log_filter_add), + U_BOOT_SUBCMD_MKENT(filter-remove, 4, 1, do_log_filter_remove), U_BOOT_SUBCMD_MKENT(format, 2, 1, do_log_format), U_BOOT_SUBCMD_MKENT(rec, 7, 1, do_log_rec), #if CONFIG_IS_ENABLED(LOG_TEST)
Changes in v2:
This exercises a few success and failure modes of the log filter-* commands. log filter-list is not tested because it's purely informational. I don't think there's a good way to test it except by testing if the output of the command exactly matches a sample run.
Changes in v2: - Converted log filter-* tests to C from python
include/test/log.h | 1 + test/log/Makefile | 1 + test/log/log_filter.c | 111 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 113 insertions(+) create mode 100644 test/log/log_filter.c
diff --git a/include/test/log.h b/include/test/log.h index c661cde75a..99988d65ea 100644 --- a/include/test/log.h +++ b/include/test/log.h @@ -12,5 +12,6 @@
/* Declare a new logging test */ #define LOG_TEST(_name) UNIT_TEST(_name, 0, log_test) +#define LOG_TEST_FLAGS(_name, _flags) UNIT_TEST(_name, _flags, log_test)
#endif /* __TEST_LOG_H__ */ diff --git a/test/log/Makefile b/test/log/Makefile index 4c92550f6e..6cb0f81a91 100644 --- a/test/log/Makefile +++ b/test/log/Makefile @@ -3,6 +3,7 @@ # Copyright (c) 2017 Google, Inc
obj-$(CONFIG_LOG_TEST) += log_test.o +obj-$(CONFIG_CMD_LOG) += log_filter.o
ifdef CONFIG_UT_LOG
diff --git a/test/log/log_filter.c b/test/log/log_filter.c new file mode 100644 index 0000000000..4ae4d95308 --- /dev/null +++ b/test/log/log_filter.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Tests for memory commands + * + * Copyright 2020 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <console.h> +#include <log.h> +#include <test/log.h> +#include <test/ut.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Test invalid options */ +static int log_test_filter_invalid(struct unit_test_state *uts) +{ + ut_asserteq(1, run_command("log filter-add -AD", 0)); + ut_asserteq(1, run_command("log filter-add -l1 -L1", 0)); + ut_asserteq(1, run_command("log filter-add -l1 -L1", 0)); + ut_asserteq(1, run_command("log filter-add -lfoo", 0)); + ut_asserteq(1, run_command("log filter-add -cfoo", 0)); + ut_asserteq(1, run_command("log filter-add -ccore -ccore -ccore -ccore " + "-ccore -ccore", 0)); + + return 0; +} +LOG_TEST_FLAGS(log_test_filter_invalid, UT_TESTF_CONSOLE_REC); + +/* Test adding and removing filters */ +static int log_test_filter(struct unit_test_state *uts) +{ + bool any_found = false; + bool filt1_found = false; + bool filt2_found = false; + char cmd[32]; + struct log_filter *filt; + struct log_device *ldev; + ulong filt1, filt2; + +#define create_filter(args, filter_num) do {\ + ut_assertok(console_record_reset_enable()); \ + ut_assertok(run_command("log filter-add -p " args, 0)); \ + ut_assert_skipline(); \ + ut_assertok(strict_strtoul(uts->actual_str, 10, &(filter_num))); \ + ut_assert_console_end(); \ +} while (0) + + create_filter("", filt1); + create_filter("-DL warning -cmmc -cspi -ffile", filt2); + + ldev = log_device_find_by_name("console"); + ut_assertnonnull(ldev); + list_for_each_entry(filt, &ldev->filter_head, sibling_node) { + if (filt->filter_num == filt1) { + filt1_found = true; + ut_asserteq(0, filt->flags); + ut_asserteq(LOGL_MAX, filt->level); + ut_assertnull(filt->file_list); + } else if (filt->filter_num == filt2) { + filt2_found = true; + ut_asserteq(LOGFF_HAS_CAT | LOGFF_DENY | + LOGFF_LEVEL_MIN, filt->flags); + ut_asserteq(true, log_has_cat(filt->cat_list, + UCLASS_MMC)); + ut_asserteq(true, log_has_cat(filt->cat_list, + UCLASS_SPI)); + ut_asserteq(LOGL_WARNING, filt->level); + ut_asserteq_str("file", filt->file_list); + } + } + ut_asserteq(true, filt1_found); + ut_asserteq(true, filt2_found); + +#define remove_filter(filter_num) do { \ + ut_assertok(console_record_reset_enable()); \ + snprintf(cmd, sizeof(cmd), "log filter-remove %lu", filter_num); \ + ut_assertok(run_command(cmd, 0)); \ + ut_assert_console_end(); \ +} while (0) + + remove_filter(filt1); + remove_filter(filt2); + + filt1_found = false; + filt2_found = false; + list_for_each_entry(filt, &ldev->filter_head, sibling_node) { + if (filt->filter_num == filt1) + filt1_found = true; + else if (filt->filter_num == filt2) + filt2_found = true; + } + ut_asserteq(false, filt1_found); + ut_asserteq(false, filt2_found); + + create_filter("", filt1); + create_filter("", filt2); + + ut_assertok(console_record_reset_enable()); + ut_assertok(run_command("log filter-remove -a", 0)); + ut_assert_console_end(); + + list_for_each_entry(filt, &ldev->filter_head, sibling_node) + any_found = true; + ut_asserteq(false, any_found); + + return 0; +} +LOG_TEST_FLAGS(log_test_filter, UT_TESTF_CONSOLE_REC);
Changes in v2:
The functions in log.h are already mostly documented, so add them to the generated documentation.
Changes in v2: - Add % before constants in kerneldocs - Document log_level_t and log_category_t members
doc/develop/logging.rst | 5 ++ include/log.h | 138 +++++++++++++++++++++++++--------------- 2 files changed, 92 insertions(+), 51 deletions(-)
diff --git a/doc/develop/logging.rst b/doc/develop/logging.rst index 7ce8482ab6..6a22062073 100644 --- a/doc/develop/logging.rst +++ b/doc/develop/logging.rst @@ -288,3 +288,8 @@ information Add a command to add new log records and delete existing records.
Provide additional log() functions - e.g. logc() to specify the category + +Logging API +----------- +.. kernel-doc:: include/log.h + :internal: diff --git a/include/log.h b/include/log.h index 9dd4484095..1aae3e3ef1 100644 --- a/include/log.h +++ b/include/log.h @@ -17,49 +17,81 @@
struct cmd_tbl;
-/** Log levels supported, ranging from most to least important */ +/** + * enum log_level_t - Log levels supported, ranging from most to least important + */ enum log_level_t { - LOGL_EMERG = 0, /* U-Boot is unstable */ - LOGL_ALERT, /* Action must be taken immediately */ - LOGL_CRIT, /* Critical conditions */ - LOGL_ERR, /* Error that prevents something from working */ - LOGL_WARNING, /* Warning may prevent optimial operation */ - LOGL_NOTICE, /* Normal but significant condition, printf() */ - LOGL_INFO, /* General information message */ - LOGL_DEBUG, /* Basic debug-level message */ - LOGL_DEBUG_CONTENT, /* Debug message showing full message content */ - LOGL_DEBUG_IO, /* Debug message showing hardware I/O access */ + /** @LOGL_EMERG: U-Boot is unstable */ + LOGL_EMERG = 0, + /** @LOGL_ALERT: Action must be taken immediately */ + LOGL_ALERT, + /** @LOGL_CRIT: Critical conditions */ + LOGL_CRIT, + /** @LOGL_ERR: Error that prevents something from working */ + LOGL_ERR, + /** @LOGL_WARNING: Warning may prevent optimial operation */ + LOGL_WARNING, + /** @LOGL_NOTICE: Normal but significant condition, printf() */ + LOGL_NOTICE, + /** @LOGL_INFO: General information message */ + LOGL_INFO, + /** @LOGL_DEBUG: Basic debug-level message */ + LOGL_DEBUG, + /** @LOGL_DEBUG_CONTENT: Debug message showing full message content */ + LOGL_DEBUG_CONTENT, + /** @LOGL_DEBUG_IO: Debug message showing hardware I/O access */ + LOGL_DEBUG_IO,
+ /** @LOGL_COUNT: Total number of valid log levels */ LOGL_COUNT, + /** @LOGL_NONE: Used to indicate that there is no valid log level */ LOGL_NONE,
+ /** @LOGL_FIRST: The first, most-important log level */ LOGL_FIRST = LOGL_EMERG, + /** @LOGL_MAX: The last, least-important log level */ LOGL_MAX = LOGL_DEBUG_IO, };
/** - * Log categories supported. Most of these correspond to uclasses (i.e. - * enum uclass_id) but there are also some more generic categories + * enum log_category_t - Log categories supported. + * + * Log categories between %LOGC_FIRST and %LOGC_NONE correspond to uclasses + * (i.e. &enum uclass_id), but there are also some more generic categories. */ enum log_category_t { + /** @LOGC_FIRST: First log category */ LOGC_FIRST = 0, /* First part mirrors UCLASS_... */
+ /** @LOGC_NONE: Default log category */ LOGC_NONE = UCLASS_COUNT, /* First number is after all uclasses */ - LOGC_ARCH, /* Related to arch-specific code */ - LOGC_BOARD, /* Related to board-specific code */ - LOGC_CORE, /* Related to core features (non-driver-model) */ - LOGC_DM, /* Core driver-model */ - LOGC_DT, /* Device-tree */ - LOGC_EFI, /* EFI implementation */ - LOGC_ALLOC, /* Memory allocation */ - LOGC_SANDBOX, /* Related to the sandbox board */ - LOGC_BLOBLIST, /* Bloblist */ - LOGC_DEVRES, /* Device resources (devres_... functions) */ - /* Advanced Configuration and Power Interface (ACPI) */ + /** @LOGC_ARCH: Related to arch-specific code */ + LOGC_ARCH, + /** @LOGC_BOARD: Related to board-specific code */ + LOGC_BOARD, + /** @LOGC_CORE: Related to core features (non-driver-model) */ + LOGC_CORE, + /** @LOGC_DM: Core driver-model */ + LOGC_DM, + /** @LOGC_DT: Device-tree */ + LOGC_DT, + /** @LOGC_EFI: EFI implementation */ + LOGC_EFI, + /** @LOGC_ALLOC: Memory allocation */ + LOGC_ALLOC, + /** @LOGC_SANDBOX: Related to the sandbox board */ + LOGC_SANDBOX, + /** @LOGC_BLOBLIST: Bloblist */ + LOGC_BLOBLIST, + /** @LOGC_DEVRES: Device resources (``devres_...`` functions) */ + LOGC_DEVRES, + /** @LOGC_ACPI: Advanced Configuration and Power Interface (ACPI) */ LOGC_ACPI,
- LOGC_COUNT, /* Number of log categories */ - LOGC_END, /* Sentinel value for a list of log categories */ + /** @LOGC_COUNT: Number of log categories */ + LOGC_COUNT, + /** @LOGC_END: Sentinel value for lists of log categories */ + LOGC_END, };
/* Helper to cast a uclass ID to a log category */ @@ -78,7 +110,7 @@ static inline int log_uc_cat(enum uclass_id id) * @func: Function where log record was generated * @fmt: printf() format string for log record * @...: Optional parameters, according to the format string @fmt - * @return 0 if log record was emitted, -ve on error + * Return: 0 if log record was emitted, -ve on error */ int _log(enum log_category_t cat, enum log_level_t level, const char *file, int line, const char *func, const char *fmt, ...) @@ -231,7 +263,7 @@ void __assert_fail(const char *assertion, const char *file, unsigned int line, * full pathname as it may be huge. Only use this when the user should be * warning, similar to BUG_ON() in linux. * - * @return true if assertion succeeded (condition is true), else false + * Return: true if assertion succeeded (condition is true), else false */ #define assert_noisy(x) \ ({ bool _val = (x); \ @@ -304,8 +336,9 @@ struct log_device; */ struct log_driver { const char *name; + /** - * emit() - emit a log record + * @emit: emit a log record * * Called by the log system to pass a log record to a particular driver * for processing. The filter is checked before calling this function. @@ -359,11 +392,11 @@ enum log_filter_flags { * @filter_num: Sequence number of this filter. This is returned when adding a * new filter, and must be provided when removing a previously added * filter. - * @flags: Flags for this filter (LOGFF_...) + * @flags: Flags for this filter (``LOGFF_...``) * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty - * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries + * then all categories are permitted. Up to %LOGF_MAX_CATEGORIES entries * can be provided - * @level: Maximum (or minimum, if LOGFF_MIN_LEVEL) log level to allow + * @level: Maximum (or minimum, if %LOGFF_MIN_LEVEL) log level to allow * @file_list: List of files to allow, separated by comma. If NULL then all * files are permitted * @sibling_node: Next filter in the list of filters for this log device @@ -384,8 +417,8 @@ struct log_filter { * log_get_cat_name() - Get the name of a category * * @cat: Category to look up - * @return category name (which may be a uclass driver name) if found, or - * "<invalid>" if invalid, or "<missing>" if not found + * Return: category name (which may be a uclass driver name) if found, or + * "<invalid>" if invalid, or "<missing>" if not found */ const char *log_get_cat_name(enum log_category_t cat);
@@ -393,7 +426,7 @@ const char *log_get_cat_name(enum log_category_t cat); * log_get_cat_by_name() - Look up a category by name * * @name: Name to look up - * @return category ID, or LOGC_NONE if not found + * Return: Category, or %LOGC_NONE if not found */ enum log_category_t log_get_cat_by_name(const char *name);
@@ -401,7 +434,7 @@ enum log_category_t log_get_cat_by_name(const char *name); * log_get_level_name() - Get the name of a log level * * @level: Log level to look up - * @return log level name (in ALL CAPS) + * Return: Log level name (in ALL CAPS) */ const char *log_get_level_name(enum log_level_t level);
@@ -409,7 +442,7 @@ const char *log_get_level_name(enum log_level_t level); * log_get_level_by_name() - Look up a log level by name * * @name: Name to look up - * @return log level ID, or LOGL_NONE if not found + * Return: Log level, or %LOGL_NONE if not found */ enum log_level_t log_get_level_by_name(const char *name);
@@ -417,7 +450,7 @@ enum log_level_t log_get_level_by_name(const char *name); * log_device_find_by_name() - Look up a log device by its driver's name * * @drv_name: Name of the driver - * @return the log device, or NULL if not found + * Return: the log device, or %NULL if not found */ struct log_device *log_device_find_by_name(const char *drv_name);
@@ -465,15 +498,16 @@ int do_log_test(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); * * @drv_name: Driver name to add the filter to (since each driver only has a * single device) - * @flags: Flags for this filter (LOGFF_...) + * @flags: Flags for this filter (``LOGFF_...``) * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty - * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries + * then all categories are permitted. Up to %LOGF_MAX_CATEGORIES entries * can be provided - * @level: Maximum (or minimum, if LOGFF_LEVEL_MIN) log level to allow + * @level: Maximum (or minimum, if %LOGFF_LEVEL_MIN) log level to allow * @file_list: List of files to allow, separated by comma. If NULL then all * files are permitted - * @return the sequence number of the new filter (>=0) if the filter was added, - * or a -ve value on error + * Return: + * the sequence number of the new filter (>=0) if the filter was added, or a + * -ve value on error */ int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], enum log_level_t level, const char *file_list, @@ -485,13 +519,14 @@ int log_add_filter_flags(const char *drv_name, enum log_category_t cat_list[], * @drv_name: Driver name to add the filter to (since each driver only has a * single device) * @cat_list: List of categories to allow (terminated by %LOGC_END). If empty - * then all categories are permitted. Up to LOGF_MAX_CATEGORIES entries + * then all categories are permitted. Up to %LOGF_MAX_CATEGORIES entries * can be provided * @max_level: Maximum log level to allow - * @file_list: List of files to allow, separated by comma. If NULL then all + * @file_list: List of files to allow, separated by comma. If %NULL then all * files are permitted - * @return the sequence number of the new filter (>=0) if the filter was added, - * or a -ve value on error + * Return: + * the sequence number of the new filter (>=0) if the filter was added, or a + * -ve value on error */ static inline int log_add_filter(const char *drv_name, enum log_category_t cat_list[], @@ -508,8 +543,9 @@ static inline int log_add_filter(const char *drv_name, * @drv_name: Driver name to remove the filter from (since each driver only has * a single device) * @filter_num: Filter number to remove (as returned by log_add_filter()) - * @return 0 if the filter was removed, -ENOENT if either the driver or the - * filter number was not found + * Return: + * 0 if the filter was removed, -%ENOENT if either the driver or the filter + * number was not found */ int log_remove_filter(const char *drv_name, int filter_num);
@@ -517,7 +553,7 @@ int log_remove_filter(const char *drv_name, int filter_num); /** * log_init() - Set up the log system ready for use * - * @return 0 if OK, -ENOMEM if out of memory + * Return: 0 if OK, -%ENOMEM if out of memory */ int log_init(void); #else @@ -531,7 +567,7 @@ static inline int log_init(void) * log_get_default_format() - get default log format * * The default log format is configurable via - * CONFIG_LOGF_FILE, CONFIG_LOGF_LINE, CONFIG_LOGF_FUNC. + * %CONFIG_LOGF_FILE, %CONFIG_LOGF_LINE, and %CONFIG_LOGF_FUNC. * * Return: default log format */
Signed-off-by: Sean Anderson seanga2@gmail.com
Changes in v2:
This updates logging documentation with some examples of the new commands added in the previous commits. It also removes some items from the to-do list which have been implemented.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
Changes in v2: - Clarify wording of filter documentation - Include enum definitions instead of re-documenting them - Reorganize log documentation; related sections should now be more proximate
doc/develop/logging.rst | 233 ++++++++++++++++++++-------------------- 1 file changed, 114 insertions(+), 119 deletions(-)
diff --git a/doc/develop/logging.rst b/doc/develop/logging.rst index 6a22062073..e2ac643c36 100644 --- a/doc/develop/logging.rst +++ b/doc/develop/logging.rst @@ -21,23 +21,13 @@ is visible from the basic console output. U-Boot's logging feature aims to satisfy this goal for both users and developers.
- Logging levels --------------
-There are a number logging levels available, in increasing order of verbosity: - -* LOGL_EMERG - Printed before U-Boot halts -* LOGL_ALERT - Indicates action must be taken immediate or U-Boot will crash -* LOGL_CRIT - Indicates a critical error that will cause boot failure -* LOGL_ERR - Indicates an error that may cause boot failure -* LOGL_WARNING - Warning about an unexpected condition -* LOGL_NOTE - Important information about progress -* LOGL_INFO - Information about normal boot progress -* LOGL_DEBUG - Debug information (useful for debugging a driver or subsystem) -* LOGL_DEBUG_CONTENT - Debug message showing full message content -* LOGL_DEBUG_IO - Debug message showing hardware I/O access +There are a number logging levels available.
+.. kernel-doc:: include/log.h + :identifiers: log_level_t
Logging category ---------------- @@ -46,16 +36,8 @@ Logging can come from a wide variety of places within U-Boot. Each log message has a category which is intended to allow messages to be filtered according to their source.
-The following main categories are defined: - -* LOGC_NONE - Unknown category (e.g. a debug() statement) -* UCLASS_... - Related to a particular uclass (e.g. UCLASS_USB) -* LOGC_ARCH - Related to architecture-specific code -* LOGC_BOARD - Related to board-specific code -* LOGC_CORE - Related to core driver-model support -* LOGC_DT - Related to device tree control -* LOGC_EFI - Related to EFI implementation - +.. kernel-doc:: include/log.h + :identifiers: log_category_t
Enabling logging ---------------- @@ -72,7 +54,6 @@ If CONFIG_LOG is not set, then no logging will be available. The above have SPL and TPL versions also, e.g. CONFIG_SPL_LOG_MAX_LEVEL and CONFIG_TPL_LOG_MAX_LEVEL.
- Temporary logging within a single file --------------------------------------
@@ -86,46 +67,8 @@ to enable building in of all logging statements in a single file. Put it at the top of the file, before any #includes.
To actually get U-Boot to output this you need to also set the default logging -level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (LOGL_DEBUG) or more. Otherwise -debug output is suppressed and will not be generated. - - -Convenience functions ---------------------- - -A number of convenience functions are available to shorten the code needed -for logging: - -* log_err(_fmt...) -* log_warning(_fmt...) -* log_notice(_fmt...) -* log_info(_fmt...) -* log_debug(_fmt...) -* log_content(_fmt...) -* log_io(_fmt...) - -With these the log level is implicit in the name. The category is set by -LOG_CATEGORY, which you can only define once per file, above all #includes, e.g. - -.. code-block:: c - - #define LOG_CATEGORY LOGC_ALLOC - -Remember that all uclasses IDs are log categories too. - - -Log command ------------ - -The 'log' command provides access to several features: - -* level - access the default log level -* format - access the console log format -* rec - output a log record -* test - run tests - -Type 'help log' for details. - +level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (:c:type:`LOGL_DEBUG`) or more. +Otherwise debug output is suppressed and will not be generated.
Using DEBUG ----------- @@ -142,51 +85,6 @@ at the top of a file, then it takes precedence. This means that debug() statements will result in output to the console and this output will not be logged.
- -Logging destinations --------------------- - -If logging information goes nowhere then it serves no purpose. U-Boot provides -several possible determinations for logging information, all of which can be -enabled or disabled independently: - -* console - goes to stdout -* syslog - broadcast RFC 3164 messages to syslog servers on UDP port 514 - -The syslog driver sends the value of environmental variable 'log_hostname' as -HOSTNAME if available. - - -Log format ----------- - -You can control the log format using the 'log format' command. The basic -format is:: - - LEVEL.category,file.c:123-func() message - -In the above, file.c:123 is the filename where the log record was generated and -func() is the function name. By default ('log format default') only the -function name and message are displayed on the console. You can control which -fields are present, but not the field order. - - -Filters -------- - -Filters are attached to log drivers to control what those drivers emit. Only -records that pass through the filter make it to the driver. - -Filters can be based on several criteria: - -* maximum log level -* in a set of categories -* in a set of files - -If no filters are attached to a driver then a default filter is used, which -limits output to records with a level less than CONFIG_MAX_LOG_LEVEL. - - Logging statements ------------------
@@ -210,6 +108,113 @@ can be used whenever your function returns an error value: This will write a log record when an error code is detected (a value < 0). This can make it easier to trace errors that are generated deep in the call stack.
+Convenience functions +~~~~~~~~~~~~~~~~~~~~~ + +A number of convenience functions are available to shorten the code needed +for logging: + +* log_err(_fmt...) +* log_warning(_fmt...) +* log_notice(_fmt...) +* log_info(_fmt...) +* log_debug(_fmt...) +* log_content(_fmt...) +* log_io(_fmt...) + +With these the log level is implicit in the name. The category is set by +LOG_CATEGORY, which you can only define once per file, above all #includes, e.g. + +.. code-block:: c + + #define LOG_CATEGORY LOGC_ALLOC + +Remember that all uclasses IDs are log categories too. + +Logging destinations +-------------------- + +If logging information goes nowhere then it serves no purpose. U-Boot provides +several possible determinations for logging information, all of which can be +enabled or disabled independently: + +* console - goes to stdout +* syslog - broadcast RFC 3164 messages to syslog servers on UDP port 514 + +The syslog driver sends the value of environmental variable 'log_hostname' as +HOSTNAME if available. + +Filters +~~~~~~~ + +Filters are attached to log drivers to control what those drivers emit. FIlters +can either allow or deny a log message when they match it. Only records which +are allowed by a filter make it to the driver. + +Filters can be based on several criteria: + +* minimum or maximum log level +* in a set of categories +* in a set of files + +If no filters are attached to a driver then a default filter is used, which +limits output to records with a level less than CONFIG_MAX_LOG_LEVEL. + +Log command +----------- + +The 'log' command provides access to several features: + +* level - get/set the log level +* categories - list log categories +* drivers - list log drivers +* filter-list - list filters +* filter-add - add a new filter +* filter-remove - remove filters +* format - access the console log format +* rec - output a log record +* test - run tests + +Type 'help log' for details. + +Log format +~~~~~~~~~~ + +You can control the log format using the 'log format' command. The basic +format is:: + + LEVEL.category,file.c:123-func() message + +In the above, file.c:123 is the filename where the log record was generated and +func() is the function name. By default ('log format default') only the message +is displayed on the console. You can control which fields are present, but not +the field order. + +Adding Filters +~~~~~~~~~~~~~~ + +To add new filters at runtime, use the 'log filter-add' command. For example, to +suppress messages from the SPI subsystem, run:: + + log filter-add -D -c spi + +You will also need to add another filter to allow other messages (because the +default filter no longer applies):: + + log filter-add -A -l debug + +To view active filters, use the 'log filter-list' command. Some example output +is:: + + => log filter-list + num policy level categories files + 0 deny <=IO spi + 1 allow <=DEBUG + +Note that filters are processed in-order from top to bottom, not in the order of +their filter number. Filters are added to the top of the list if they deny when +they match, and to the bottom if they allow when they match. For more +information, consult the usage of the 'log' command, by running 'help log'.
Code size --------- @@ -226,7 +231,6 @@ The last option turns every debug() statement into a logging call, which bloats the code hugely. The advantage is that it is then possible to enable all logging within U-Boot.
- To Do -----
@@ -259,8 +263,6 @@ Add a way to browse log records
Add a way to record log records for browsing using an external tool
-Add commands to add and remove filters - Add commands to add and remove log devices
Allow sharing of printf format strings in log records to reduce storage size @@ -268,10 +270,6 @@ for large numbers of log records
Add a command-line option to sandbox to set the default logging level
-Convert core driver model code to use logging - -Convert uclasses to use logging with the correct category - Consider making log() calls emit an automatic newline, perhaps with a logn() function to avoid that
@@ -282,9 +280,6 @@ number dropped due to them being generated before the log system was ready.
Add a printf() format string pragma so that log statements are checked properly
-Enhance the log console driver to show level / category / file / line -information - Add a command to add new log records and delete existing records.
Changes in v2:
Sean Anderson
