Please pull u-boot-samsung master
Dear Tom,
The following changes since commit 15e7927b5a2d33666af19879577bf0c30ab088fe:
Merge patch series "omap3: Make SPL_OMAP3_ID_NAND depend on NAND_OMAP_GPMC" (2024-01-22 14:18:55 -0500)
git@source.denx.de:u-boot/custodians/u-boot-samsung.git master
for you to fetch changes up to 1e81d12e34e874319e041652198a4ba561d751ab:
MAINTAINERS: Add new Samsung subsystems (2024-01-24 11:23:20 +0900)
---------------------------------------------------------------- Sam Protsenko (13): dt-bindings: soc: samsung: Add Exynos USI dt-bindings: soc: samsung: Add Exynos PMU dt-bindings: clock: Add Exynos850 clock controller soc: samsung: Add Exynos USI driver soc: samsung: Add Exynos PMU driver clk: exynos: Move pll code into clk-exynos7420 clk: exynos: Add Samsung clock framework clk: exynos: Add Exynos850 clock driver pinctrl: exynos: Add pinctrl support for Exynos850 serial: s5p: Add Exynos850 compatible arm: exynos: Add Exynos850 SoC support board: samsung: Add support for E850-96 board MAINTAINERS: Add new Samsung subsystems
MAINTAINERS | 25 + arch/arm/dts/Makefile | 1 + arch/arm/dts/exynos-pinctrl.h | 79 +++ arch/arm/dts/exynos850-e850-96-u-boot.dtsi | 37 ++ arch/arm/dts/exynos850-e850-96.dts | 273 +++++++++ arch/arm/dts/exynos850-pinctrl.dtsi | 663 ++++++++++++++++++++++ arch/arm/dts/exynos850.dtsi | 809 ++++++++++++++++++++++++++ arch/arm/mach-exynos/Kconfig | 28 +- arch/arm/mach-exynos/mmu-arm64.c | 34 ++ board/samsung/e850-96/Kconfig | 16 + board/samsung/e850-96/MAINTAINERS | 9 + board/samsung/e850-96/Makefile | 6 + board/samsung/e850-96/e850-96.c | 22 + configs/e850-96_defconfig | 21 + doc/board/samsung/e850-96.rst | 87 +++ doc/board/samsung/img/exynos850-boot-architecture.svg | 1283 ++++++++++++++++++++++++++++++++++++++++++ doc/board/samsung/index.rst | 1 + doc/device-tree-bindings/clock/samsung,exynos850-clock.yaml | 307 ++++++++++ doc/device-tree-bindings/soc/samsung/exynos-pmu.yaml | 85 +++ doc/device-tree-bindings/soc/samsung/exynos-usi.yaml | 162 ++++++ drivers/clk/exynos/Kconfig | 7 + drivers/clk/exynos/Makefile | 11 +- drivers/clk/exynos/clk-exynos7420.c | 25 +- drivers/clk/exynos/clk-exynos850.c | 189 +++++++ drivers/clk/exynos/clk-pll.c | 167 +++++- drivers/clk/exynos/clk-pll.h | 16 +- drivers/clk/exynos/clk.c | 121 ++++ drivers/clk/exynos/clk.h | 228 ++++++++ drivers/pinctrl/exynos/Kconfig | 8 + drivers/pinctrl/exynos/Makefile | 1 + drivers/pinctrl/exynos/pinctrl-exynos850.c | 125 ++++ drivers/serial/serial_s5p.c | 1 + drivers/soc/Kconfig | 1 + drivers/soc/Makefile | 1 + drivers/soc/samsung/Kconfig | 33 ++ drivers/soc/samsung/Makefile | 4 + drivers/soc/samsung/exynos-pmu.c | 102 ++++ drivers/soc/samsung/exynos-usi.c | 208 +++++++ include/configs/e850-96.h | 12 + include/dt-bindings/clock/exynos850.h | 337 +++++++++++ include/dt-bindings/soc/samsung,exynos-usi.h | 17 + 41 files changed, 5538 insertions(+), 24 deletions(-) create mode 100644 arch/arm/dts/exynos-pinctrl.h create mode 100644 arch/arm/dts/exynos850-e850-96-u-boot.dtsi create mode 100644 arch/arm/dts/exynos850-e850-96.dts create mode 100644 arch/arm/dts/exynos850-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos850.dtsi create mode 100644 board/samsung/e850-96/Kconfig create mode 100644 board/samsung/e850-96/MAINTAINERS create mode 100644 board/samsung/e850-96/Makefile create mode 100644 board/samsung/e850-96/e850-96.c create mode 100644 configs/e850-96_defconfig create mode 100644 doc/board/samsung/e850-96.rst create mode 100644 doc/board/samsung/img/exynos850-boot-architecture.svg create mode 100644 doc/device-tree-bindings/clock/samsung,exynos850-clock.yaml create mode 100644 doc/device-tree-bindings/soc/samsung/exynos-pmu.yaml create mode 100644 doc/device-tree-bindings/soc/samsung/exynos-usi.yaml create mode 100644 drivers/clk/exynos/clk-exynos850.c create mode 100644 drivers/clk/exynos/clk.c create mode 100644 drivers/clk/exynos/clk.h create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos850.c create mode 100644 drivers/soc/samsung/Kconfig create mode 100644 drivers/soc/samsung/Makefile create mode 100644 drivers/soc/samsung/exynos-pmu.c create mode 100644 drivers/soc/samsung/exynos-usi.c create mode 100644 include/configs/e850-96.h create mode 100644 include/dt-bindings/clock/exynos850.h create mode 100644 include/dt-bindings/soc/samsung,exynos-usi.h
Thanks, Minkyu Kang.
On Tue, Feb 20, 2024 at 01:25:44PM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
