[U-Boot] [PATCH 1/5] rockchip: i2c: rk3328: support i2c for rk3328 SoC
Add compatible to support rk3328 i2c
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/i2c/rk_i2c.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 68e6653..a051893 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -396,6 +396,7 @@ static const struct udevice_id rockchip_i2c_ids[] = { { .compatible = "rockchip,rk3066-i2c" }, { .compatible = "rockchip,rk3188-i2c" }, { .compatible = "rockchip,rk3288-i2c" }, + { .compatible = "rockchip,rk3328-i2c" }, { .compatible = "rockchip,rk3399-i2c" }, { } };
Add Rockchip pmic rk816 support.
drivers/power/pmic/rk8xx.c | 1 + drivers/power/regulator/rk8xx.c | 212 ++++++++++++++++++++++++++++++++-------- include/power/rk8xx_pmic.h | 9 +- 3 files changed, 182 insertions(+), 40 deletions(-)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index eb3ec0f..0fdea95 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -100,6 +100,7 @@ static struct dm_pmic_ops rk8xx_ops = {
static const struct udevice_id rk8xx_ids[] = { { .compatible = "rockchip,rk808" }, + { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, { } }; diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index 76fc2ef..cf3566e 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -48,6 +48,21 @@ static const struct rk8xx_reg_info rk808_buck[] = { { 1800000, 100000, REG_BUCK4_ON_VSEL, RK808_BUCK4_VSEL_MASK, }, };
+static const struct rk8xx_reg_info rk816_buck[] = { + /* buck 1 */ + { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 1800000, 200000, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 2300000, 0, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + /* buck 2 */ + { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 1800000, 200000, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 2300000, 0, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + /* buck 3 */ + { 712500, 12500, -1, RK818_BUCK_VSEL_MASK, }, + /* buck 4 */ + { 800000, 100000, REG_BUCK4_ON_VSEL, RK818_BUCK4_VSEL_MASK, }, +}; + static const struct rk8xx_reg_info rk818_buck[] = { { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, @@ -67,6 +82,15 @@ static const struct rk8xx_reg_info rk808_ldo[] = { { 1800000, 100000, REG_LDO8_ON_VSEL, RK808_LDO_VSEL_MASK, }, };
+static const struct rk8xx_reg_info rk816_ldo[] = { + { 800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO3_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO4_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO5_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO6_ON_VSEL, RK818_LDO_VSEL_MASK, }, +}; + static const struct rk8xx_reg_info rk818_ldo[] = { { 1800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, }, { 1800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, }, @@ -88,10 +112,24 @@ static const uint rk818_chrg_shutdown_vsel_array[] = { };
static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic, - int num) + int num, int uvolt) { struct rk8xx_priv *priv = dev_get_priv(pmic); + switch (priv->variant) { + case RK816_ID: + switch (num) { + case 0: + case 1: + if (uvolt <= 1450000) + return &rk816_buck[num * 3 + 0]; + else if (uvolt <= 2200000) + return &rk816_buck[num * 3 + 1]; + else + return &rk816_buck[num * 3 + 2]; + default: + return &rk816_buck[num + 4]; + } case RK818_ID: return &rk818_buck[num]; default: @@ -101,7 +139,7 @@ static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic,
static int _buck_set_value(struct udevice *pmic, int buck, int uvolt) { - const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck - 1); + const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck, uvolt); int mask = info->vsel_mask; int val;
@@ -114,23 +152,76 @@ static int _buck_set_value(struct udevice *pmic, int buck, int uvolt) return pmic_clrsetbits(pmic, info->vsel_reg, mask, val); }
+static int _buck_get_enable(struct udevice *pmic, int buck) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask = 0; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (buck >= 4) { + mask = 1 << (buck - 4); + ret = pmic_reg_read(pmic, RK816_REG_DCDC_EN2); + } else { + mask = 1 << buck; + ret = pmic_reg_read(pmic, RK816_REG_DCDC_EN1); + } + break; + case RK808_ID: + case RK818_ID: + mask = 1 << buck; + ret = pmic_reg_read(pmic, REG_DCDC_EN); + if (ret < 0) + return ret; + break; + } + return ret & mask ? true : false; +} + + static int _buck_set_enable(struct udevice *pmic, int buck, bool enable) { - uint mask; + uint mask, value, en_reg; int ret; + struct rk8xx_priv *priv = dev_get_priv(pmic);
- buck--; - mask = 1 << buck; - if (enable) { - ret = pmic_clrsetbits(pmic, REG_DCDC_ILMAX, 0, 3 << (buck * 2)); - if (ret) - return ret; - ret = pmic_clrsetbits(pmic, REG_DCDC_UV_ACT, 1 << buck, 0); - if (ret) - return ret; + switch (priv->variant) { + case RK816_ID: + if (buck >= 4) { + buck -= 4; + en_reg = RK816_REG_DCDC_EN2; + } else { + en_reg = RK816_REG_DCDC_EN1; + } + if (enable) + value = ((1 << buck) | (1 << (buck + 4))); + else + value = ((0 << buck) | (1 << (buck + 4))); + ret = pmic_reg_write(pmic, en_reg, value); + break; + + case RK808_ID: + case RK818_ID: + mask = 1 << buck; + if (enable) { + ret = pmic_clrsetbits(pmic, REG_DCDC_ILMAX, + 0, 3 << (buck * 2)); + if (ret) + return ret; + ret = pmic_clrsetbits(pmic, REG_DCDC_UV_ACT, + 1 << buck, 0); + if (ret) + return ret; + } + ret = pmic_clrsetbits(pmic, REG_DCDC_EN, mask, + enable ? mask : 0); + break; + default: + ret = -EINVAL; }
- return pmic_clrsetbits(pmic, REG_DCDC_EN, mask, enable ? mask : 0); + return ret; }
#ifdef ENABLE_DRIVER @@ -138,7 +229,10 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, int num) { struct rk8xx_priv *priv = dev_get_priv(pmic); + switch (priv->variant) { + case RK816_ID: + return &rk816_ldo[num]; case RK818_ID: return &rk818_ldo[num]; default: @@ -146,10 +240,70 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, } }
+static int _ldo_get_enable(struct udevice *pmic, int ldo) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask = 0; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (ldo >= 4) { + mask = 1 << (ldo - 4); + ret = pmic_reg_read(pmic, RK816_REG_LDO_EN2); + } else { + mask = 1 << ldo; + ret = pmic_reg_read(pmic, RK816_REG_LDO_EN1); + } + break; + case RK808_ID: + case RK818_ID: + mask = 1 << ldo; + ret = pmic_reg_read(pmic, REG_LDO_EN); + if (ret < 0) + return ret; + break; + } + return ret & mask ? true : false; +} + + +static int _ldo_set_enable(struct udevice *pmic, int ldo, bool enable) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask, value, en_reg; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (ldo >= 4) { + ldo -= 4; + en_reg = RK816_REG_LDO_EN2; + } else { + en_reg = RK816_REG_LDO_EN1; + } + if (enable) + value = ((1 << ldo) | (1 << (ldo + 4))); + else + value = ((0 << ldo) | (1 << (ldo + 4))); + + ret = pmic_reg_write(pmic, en_reg, value); + break; + case RK808_ID: + case RK818_ID: + mask = 1 << ldo; + ret = pmic_clrsetbits(pmic, REG_LDO_EN, mask, + enable ? mask : 0); + break; + } + + return ret; +} + static int buck_get_value(struct udevice *dev) { int buck = dev->driver_data - 1; - const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck); + const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck, 0); int mask = info->vsel_mask; int ret, val;
@@ -165,14 +319,14 @@ static int buck_get_value(struct udevice *dev)
static int buck_set_value(struct udevice *dev, int uvolt) { - int buck = dev->driver_data; + int buck = dev->driver_data - 1;
return _buck_set_value(dev->parent, buck, uvolt); }
static int buck_set_enable(struct udevice *dev, bool enable) { - int buck = dev->driver_data; + int buck = dev->driver_data - 1;
return _buck_set_enable(dev->parent, buck, enable); } @@ -180,16 +334,8 @@ static int buck_set_enable(struct udevice *dev, bool enable) static int buck_get_enable(struct udevice *dev) { int buck = dev->driver_data - 1; - int ret; - uint mask; - - mask = 1 << buck;
- ret = pmic_reg_read(dev->parent, REG_DCDC_EN); - if (ret < 0) - return ret; - - return ret & mask ? true : false; + return _buck_get_enable(dev->parent, buck); }
static int ldo_get_value(struct udevice *dev) @@ -228,27 +374,15 @@ static int ldo_set_value(struct udevice *dev, int uvolt) static int ldo_set_enable(struct udevice *dev, bool enable) { int ldo = dev->driver_data - 1; - uint mask; - - mask = 1 << ldo;
- return pmic_clrsetbits(dev->parent, REG_LDO_EN, mask, - enable ? mask : 0); + return _ldo_set_enable(dev->parent, ldo, enable); }
static int ldo_get_enable(struct udevice *dev) { int ldo = dev->driver_data - 1; - int ret; - uint mask; - - mask = 1 << ldo;
- ret = pmic_reg_read(dev->parent, REG_LDO_EN); - if (ret < 0) - return ret; - - return ret & mask ? true : false; + return _ldo_get_enable(dev->parent, ldo); }
static int switch_set_enable(struct udevice *dev, bool enable) diff --git a/include/power/rk8xx_pmic.h b/include/power/rk8xx_pmic.h index 47a6b36..8e821c3 100644 --- a/include/power/rk8xx_pmic.h +++ b/include/power/rk8xx_pmic.h @@ -171,8 +171,15 @@ enum { };
enum { - RK805_ID = 0x8050, + RK816_REG_DCDC_EN1 = 0x23, + RK816_REG_DCDC_EN2, + RK816_REG_LDO_EN1 = 0x27, + RK816_REG_LDO_EN2, +}; + +enum { RK808_ID = 0x0000, + RK816_ID = 0x8160, RK818_ID = 0x8180, };
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Could you summarise some of the key-features of the RK816 here? Just a few words, so we know how it's different from the others and what it's used for (e.g. "PMIC matching the RK3xxx").
- { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, { }
- /* buck 1 */
- { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 1800000, 200000, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 2300000, 0, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- /* buck 2 */
- { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 1800000, 200000, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 2300000, 0, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- /* buck 3 */
- { 712500, 12500, -1, RK818_BUCK_VSEL_MASK, },
- /* buck 4 */
- { 800000, 100000, REG_BUCK4_ON_VSEL, RK818_BUCK4_VSEL_MASK, },
- { 800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO3_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO4_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO5_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO6_ON_VSEL, RK818_LDO_VSEL_MASK, },
int num)
int num, int uvolt)
- switch (priv->variant) {
- case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
I am very concerned with this driver turning into a large switch statement: this really is not the way driver_data is supposed to be used.
Can we have a single path through this function and use driver_data to parameterize the cut-offs? As an alternative, we'll need to start splitting this into separate drivers.
- const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck, uvolt); int mask = info->vsel_mask; int val;
- struct rk8xx_priv *priv = dev_get_priv(pmic);
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (buck >= 4) {
} else {
mask = 1 << buck;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (ret < 0)
return ret;
break;
Again, the RK816 appears to be a significantly different device.
- uint mask;
- uint mask, value, en_reg; int ret;
- buck--;
- mask = 1 << buck;
- if (enable) {
if (ret)
return ret;
if (ret)
return ret;
- case RK816_ID:
if (buck >= 4) {
buck -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (enable) {
if (ret)
return ret;
1 << buck, 0);
if (ret)
return ret;
enable ? mask : 0);
break;
- default:
}ret = -EINVAL;
- return ret;
This define doesn't make any sense: I see that it's always been here, but still: it is just a wrapper around a "#ifndef CONFIG_SPL_BUILD". Can we use the #ifndef CONFIG_SPL_BUILD directly?
- case RK816_ID:
case RK818_ID: return &rk818_ldo[num]; default:return &rk816_ldo[num];
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
} else {
mask = 1 << ldo;
Same comment as above.
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
if (ret < 0)
return ret;
break;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
ldo -= 4;
} else {
if (enable)
else
break;
Again, it looks as if this should be a separate driver.
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
enable ? mask : 0);
break;
- return ret;
- const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck, 0); int mask = info->vsel_mask; int ret, val;
int ret;
uint mask;
mask = 1 << buck;
if (ret < 0)
return ret;
- return _buck_get_enable(dev->parent, buck);
uint mask;
mask = 1 << ldo;
enable ? mask : 0);
- return _ldo_set_enable(dev->parent, ldo, enable);
int ret;
uint mask;
mask = 1 << ldo;
if (ret < 0)
return ret;
- return _ldo_get_enable(dev->parent, ldo);
enum {
- RK816_REG_DCDC_EN1 = 0x23,
- RK816_REG_DCDC_EN2,
- RK816_REG_LDO_EN1 = 0x27,
- RK816_REG_LDO_EN2,
- RK816_ID = 0x8160, RK818_ID = 0x8180,
On 13 September 2017 at 14:22, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
/* buck 1 */
/* buck 2 */
/* buck 3 */
/* buck 4 */
int num)
int num, int uvolt)
case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
Yes it is worth considering that. I don't see a good reason to have this new device in the same driver, given all the changes.
If there is shared code it could be split out into a new file.
Hi Simon, Philipp,
Will add detail difference between these chips, they are very similar as regulator and it's reasonable to make then in one driver instead of use different drivers for them: - different DCDC/LDO numbers; - different voltage output range and current loading; - RK816 and RK805 add mask bit for enable/disable to make read/write more safe.
/* buck 1 */
/* buck 2 */
/* buck 3 */
/* buck 4 */
int num)
int num, int uvolt)
case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
The framework and the setting for all these chips are the same, except the BUCK/LDO numbers are different, and rk805/rk816 need extra mask bit for enable/disable.
Abstract the difference into array structure is a good way to share the code, I don't think split this into rk805.c rk808.c rk816.c and rk818.c will have a better shape.
BTW, these are all the PMICs we have since early 2013, so don't worry, it won't grow into large switch statement.
Thanks, - Kever
Add Rockchip pmic rk805 support.
drivers/power/pmic/rk8xx.c | 1 + drivers/power/regulator/rk8xx.c | 6 ++++++ include/power/rk8xx_pmic.h | 1 + 3 files changed, 8 insertions(+)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 0fdea95..f2a2f07 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -99,6 +99,7 @@ static struct dm_pmic_ops rk8xx_ops = { };
static const struct udevice_id rk8xx_ids[] = { + { .compatible = "rockchip,rk805" }, { .compatible = "rockchip,rk808" }, { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index cf3566e..6d4a243 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -117,6 +117,7 @@ static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic, struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: switch (num) { case 0: @@ -159,6 +160,7 @@ static int _buck_get_enable(struct udevice *pmic, int buck) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (buck >= 4) { mask = 1 << (buck - 4); @@ -187,6 +189,7 @@ static int _buck_set_enable(struct udevice *pmic, int buck, bool enable) struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (buck >= 4) { buck -= 4; @@ -231,6 +234,7 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: return &rk816_ldo[num]; case RK818_ID: @@ -247,6 +251,7 @@ static int _ldo_get_enable(struct udevice *pmic, int ldo) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (ldo >= 4) { mask = 1 << (ldo - 4); @@ -275,6 +280,7 @@ static int _ldo_set_enable(struct udevice *pmic, int ldo, bool enable) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (ldo >= 4) { ldo -= 4; diff --git a/include/power/rk8xx_pmic.h b/include/power/rk8xx_pmic.h index 8e821c3..b1482b7 100644 --- a/include/power/rk8xx_pmic.h +++ b/include/power/rk8xx_pmic.h @@ -178,6 +178,7 @@ enum { };
enum { + RK805_ID = 0x8050, RK808_ID = 0x0000, RK816_ID = 0x8160, RK818_ID = 0x8180,
Again: a bit more info would be helpful (see my review of patch 2/5 for a few hints).
- { .compatible = "rockchip,rk805" }, { .compatible = "rockchip,rk808" }, { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" },
- case RK805_ID: case RK816_ID: switch (num) { case 0:
So the RK805 is identical to the RK816 for all practical purposes?
- case RK805_ID: case RK816_ID: if (buck >= 4) { mask = 1 << (buck - 4);
- case RK805_ID: case RK816_ID: if (buck >= 4) { buck -= 4;
- case RK805_ID: case RK816_ID: return &rk816_ldo[num]; case RK818_ID:
- case RK805_ID: case RK816_ID: if (ldo >= 4) { mask = 1 << (ldo - 4);
- case RK805_ID: case RK816_ID: if (ldo >= 4) { ldo -= 4;
enum {
- RK805_ID = 0x8050, RK808_ID = 0x0000, RK816_ID = 0x8160, RK818_ID = 0x8180,
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Add defconfig for rk8xx and regulator and i2c controller.
configs/evb-rk3328_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7bec001..6d0f3af 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -22,12 +22,18 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK3328=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_DM_REGULATOR=y CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_BASE=0xFF130000
add i2c1 and rk805 nodes to support rk805 init setting.
arch/arm/dts/rk3328-evb.dts | 118 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 118 insertions(+)
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts index 8a14c65..f71690f 100644 --- a/arch/arm/dts/rk3328-evb.dts +++ b/arch/arm/dts/rk3328-evb.dts @@ -87,3 +87,121 @@ vbus-supply = <&vcc5v0_host_xhci>; status = "okay"; }; + +&i2c1 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk805: pmic@18 { + compatible = "rockchip,rk805"; + status = "okay"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + gpio-controller; + #gpio-cells = <2>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vdd_18: LDO_REG1 { + regulator-name = "vdd_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_18emmc: LDO_REG2 { + regulator-name = "vcc_18emmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; /* gpio2_a6 */ + }; + }; +}; +
Kever Yang
Philipp Tomsich
